  4. Homebridge Fehler Code 243
41 Beiträge 4 Kommentatoren 7.8k Aufrufe 3 Beobachtet
    @marcelinho sagte in Homebridge Fehler Code 243:
    Wüsste nicht was da falsch gehen sollte
    Dann schau in das Log:
    2024-04-24 15:56:16.028  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=1
    2024-04-24 15:56:16.031  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.032  - warn: influxdb.0 (1208) Error on writePoint("{"value":-2,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.032  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=2
    2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.037  - warn: influxdb.0 (1208) Error on writePoint("{"value":0,"time":"2024-04-24T13:55:54.255Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.037  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=1
    2024-04-24 15:56:16.132  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.133  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.088Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.134  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
    2024-04-24 15:56:16.154  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.155  - warn: influxdb.0 (1208) Error on writePoint("{"value":96,"time":"2024-04-24T13:55:59.437Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.155  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=1
    2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.165  - warn: influxdb.0 (1208) Error on writePoint("{"value":-8,"time":"2024-04-24T13:56:05.091Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.165  - info: influxdb.0 (1208) Add point that had error for 0_userdata.0.Stromverbrauch.Netzbezug_W to buffer again, error-count=3
    2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.173  - warn: influxdb.0 (1208) Error on writePoint("{"value":24.5,"time":"2024-04-24T13:55:02.852Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.174  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=1
    2024-04-24 15:56:16.180  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.181  - warn: influxdb.0 (1208) Error on writePoint("{"value":98,"time":"2024-04-24T13:50:00.207Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.181  - info: influxdb.0 (1208) Add point that had error for BatterieProzent to buffer again, error-count=2
    2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Point could not be written to database: admin
    2024-04-24 15:56:16.202  - warn: influxdb.0 (1208) Error on writePoint("{"value":24,"time":"2024-04-24T13:56:01.967Z","from":"system.adapter.tuya.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
    2024-04-24 15:56:16.203  - info: influxdb.0 (1208) Add point that had error for EsszimmerThermostat to buffer again, error-count=2
    Sieht für mich nicht gesund aus. Insbesondere nicht in der Frequenz mit der da Zeug geloggt wird. Das bläst dir alleine das Logfile in kürzester Zeit auf unnötige Größen auf.
    Homebridge über den ham-Adapter? Der ist aber gar nicht installiert bei dir.
    M
    M
    marcelinho
    @thomas-braun said in Homebridge Fehler Code 243:
    ham-Adapter
    Homebridge habe ich über die SD-Karte über ein Image installiert gehabt
    https://smartapfel.de/homebridge/installieren/
    • Marc BergM Marc Berg
      Influxdb habe ich gestern mit @Marc-Berg bereinigt
      Jain. Du hattest den Speicherzeitraum der InfluxDB auf 90 Tage gesetzt und wir haben gesagt, dass die ungewollt geloggten Daten nach 90 Tagen endgültig raus sind.
      Du könntest des Speicherzeitraum jetzt auch noch weiter verkürzen, um den Effekt zu beschleunigen.
      Weiterhin kannst du in den Datenpunkteinstellungen des InfluxDB Adapters prüfen, ob du weniger Daten wegschreibst, indem du z.B. die Blockierzeit auf 30 Sekunden setzt.
      M
      M
      marcelinho
      @marc-berg ich habe im influx.db Adapter nun auch 90 Tage geändert und die Blockzeit auf 30 gesetzt - ist dies so korrekt?Screenshot 2024-04-25 075854.png
      • M marcelinho
        ham-Adapter
        Thomas BraunT
        Thomas BraunT
        @marcelinho
        Und wo ist da jetzt die Verbindung zum ioBroker?
        Marc BergM M 2 Antworten Letzte Antwort
        • M marcelinho
          Marc BergM
          Marc BergM
          Marc Berg
          Ob du die Einstellung für die Vorhaltezeit in der Instanz des Adapters änderst oder direkt in der Datenbank-Oberfläche ist völlig egal, das funktioniert beides.
          Zur Blockzeit: Du hast jetzt lediglich die "Standardeinstellung" geändert, die angezogen wird, wenn du neue Datenpunkte mit der InfluxDB verbindest. Dies hat keine Auswirkungen auf schon bestehende Datenpunkte.
          Du solltest also Datenpunkt für Datenpunkt durchgehen und jeweils schauen, ob du nur geänderte Werte aufzeichnen willst, ob du eine Blockzeit verwendest oder nur Änderungen protokollierst, wenn sich der Wert um x ändert.
          Das kann man nicht pauschal empfehlen, es hängt einfach davon ab, welche Daten jeweils in welchen Intervallen reinfliegen. Ziel sollte jedenfalls sein, die Menge an Daten, die (vielleicht unnötigerweise) in die Datenbank geschrieben wird, auf ein sinnvolles Maß zu reduzieren.
          EDIT: Außerdem wird die Blockzeit in Millisekunden angegeben
            @marcelinho
            Marc BergM
            Marc BergM
            Marc Berg
            @thomas-braun sagte in Homebridge Fehler Code 243:
            Im Tab "DB Settings"!? :-)
              M
              M
              marcelinho
              @marc-berg jetzt sieht es wohl besser aus, habe alle Influxdb Datenpunkte mit Millisekunden angepasst:
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                        Kernel: Linux 6.1.0-rpi7-rpi-v8
                  Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               09:23:33 up 1 day, 15:37,  3 users,  load average: 0.27, 0.37, 0.33
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Thu 2024-04-25 09:23:33 CEST
                         Universal time: Thu 2024-04-25 07:23:33 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            4.0G        2.9G        827M         28K        296M        1.0G
              Swap:           104M        104M        278K
              Total:          4.1G        3.0G        827M
                       3793 M total memory
                       2796 M used memory
                       2004 M active memory
                        808 M inactive memory
                        788 M free memory
                         16 M buffer memory
                        266 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  1.6G     0  1.6G   0% /dev
              tmpfs          tmpfs     380M  1.2M  379M   1% /run
              /dev/mmcblk0p2 ext4       29G   20G  8.0G  71% /
              tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
              /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
              tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
              [Tue Apr 23 17:46:09 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=1e048ecb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
              [Tue Apr 23 17:46:12 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
              [Tue Apr 23 17:46:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              11G     /var/
              8.9G    /var/lib
              8.3G    /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
              Archived and active journals take up 739.9M in the file system.
              /opt/iobroker/backups:
              217M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              303M    /opt/iobroker/iobroker-data/
              191M    /opt/iobroker/iobroker-data/files
              57M     /opt/iobroker/iobroker-data/files/javascript.admin
              52M     /opt/iobroker/iobroker-data/backup-objects
              38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
              22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
              18M     /opt/iobroker/iobroker-data/objects.jsonl
              8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s
              8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf        33d1a5a7669f5d-if00-port0
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.20.2
              /usr/bin/node           v18.20.2
              /usr/bin/npm            10.5.0
              /usr/bin/npx            10.5.0
              /usr/bin/corepack       0.25.2
              nodejs:
                Installed: 18.20.2-1nodesource1
                Candidate: 18.20.2-1nodesource1
                Version table:
               *** 18.20.2-1nodesource1 600
                      500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                   18.20.1-1nodesource1 600
                   18.20.0-1nodesource1 600
                   18.19.1-1nodesource1 600
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                   18.19.0-1nodesource1 600
                   18.18.2-1nodesource1 600
                   18.18.1-1nodesource1 600
                   18.18.0-1nodesource1 600
                   18.17.1-1nodesource1 600
                   18.17.0-1nodesource1 600
                   18.16.1-1nodesource1 600
                   18.16.0-1nodesource1 600
                   18.15.0-1nodesource1 600
                   18.14.2-1nodesource1 600
                   18.14.1-1nodesource1 600
                   18.14.0-1nodesource1 600
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main arm64 Packages
                   18.13.0-1nodesource1 600
                   18.12.0-1nodesource1 600
                   18.11.0-1nodesource1 600
                   18.10.0-1nodesource1 600
                   18.9.1-1nodesource1 600
                   18.9.0-1nodesource1 600
                   18.8.0-1nodesource1 600
                   18.7.0-1nodesource1 600
                   18.6.0-1nodesource1 600
                   18.5.0-1nodesource1 600
                   18.4.0-1nodesource1 600
                   18.3.0-1nodesource1 600
                   18.2.0-1nodesource1 600
                   18.1.0-1nodesource1 600
                   18.0.0-1nodesource1 600
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.13.16
              javascript:     7.8.0
              Adapters from github:   3
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
              + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi        -  enabled
              + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi        -  enabled
              + system.adapter.daikin.0                 : daikin                : raspberrypi        -  enabled
              + system.adapter.daikin.1                 : daikin                : raspberrypi        -  enabled
              + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
              + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi        -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
              + system.adapter.iqontrol.0               : iqontrol              : raspberrypi        -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
              + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi        -  enabled
              + system.adapter.meross.0                 : meross                : raspberrypi        -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1885, bind: 0.0.0.0
              + system.adapter.myenergi.0               : myenergi              : raspberrypi        -  enabled
              + system.adapter.node-red.0               : node-red              : raspberrypi        -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.smart-eq.0               : smart-eq              : raspberrypi        -  enabled
              + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi        -  enabled
              + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
              + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi        -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.13.16  , installed 6.13.16
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "daikin"       : 1.4.2    , installed 1.4.2
              Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
              Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
              Adapter    "homekit-controller": 0.5.10, installed 0.5.10
              Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Controller "js-controller": 5.0.19   , installed 5.0.19
              Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
              Adapter    "meross"       : 1.17.0   , installed 1.17.0
              Adapter    "modbus"       : 6.1.0    , installed 6.1.0
              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
              Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
              Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
              Adapter    "node-red"     : 5.2.0    , installed 5.2.0
              Adapter    "openhab"      : 1.1.0    , installed 1.1.0
              Adapter    "shelly"       : 6.8.0    , installed 6.8.0
              Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
              Adapter    "socketio"     : 6.6.1    , installed 6.6.1
              Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
              Adapter    "tuya"         : 3.15.0   , installed 3.15.0
              Adapter    "web"          : 6.2.5    , installed 6.2.5
              Adapter    "ws"           : 2.5.11   , installed 2.5.11
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
              Objects and States
              Objects:        14991
              States:         13387
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
              Hit:8 https://repo.homebridge.io stable InRelease
              Reading package lists...
              Pending Updates: 3
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:38691         0.0.0.0:*               LISTEN      112        17194      1300/homebridge: @0
              tcp        0      0 127.0.0.1:38543         0.0.0.0:*               LISTEN      112        17159      1317/homebridge: ho
              tcp        0      0 127.0.0.1:40315         0.0.0.0:*               LISTEN      112        17110      1290/homebridge: ho
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26211      1952/node-red
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        16746      786/mosquitto
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19125      1561/io.shelly.0
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20031      1576/io.mqtt.0
              tcp        0      0 127.0.0.1:46551         0.0.0.0:*               LISTEN      112        21533      1634/homebridge: ho
              tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21580      1617/node
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16938      1082/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17920      1082/iobroker.js-co
              tcp        0      0 127.0.0.1:37849         0.0.0.0:*               LISTEN      112        19798      1298/homebridge: ho
              tcp        0      0 127.0.0.1:35727         0.0.0.0:*               LISTEN      112        17154      1291/homebridge: ho
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17543      792/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1585299    38874/cupsd
              tcp        0      0 127.0.0.1:45139         0.0.0.0:*               LISTEN      112        18280      1293/homebridge: ho
              tcp        0      0 127.0.0.1:39007         0.0.0.0:*               LISTEN      112        19738      1319/homebridge: ho
              tcp6       0      0 :::52403                :::*                    LISTEN      112        19754      1298/homebridge: ho
              tcp6       0      0 :::44253                :::*                    LISTEN      112        19726      1317/homebridge: ho
              tcp6       0      0 :::1883                 :::*                    LISTEN      114        16747      786/mosquitto
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19538      1140/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21629      1690/io.web.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        16913      892/influxd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1585298    38874/cupsd
              tcp6       0      0 :::37166                :::*                    LISTEN      112        18883      1291/homebridge: ho
              tcp6       0      0 :::45391                :::*                    LISTEN      112        18903      1300/homebridge: @0
              tcp6       0      0 :::8581                 :::*                    LISTEN      112        17952      1058/hb-service
              tcp6       0      0 :::53299                :::*                    LISTEN      112        19213      1634/homebridge: ho
              tcp6       0      0 :::22                   :::*                    LISTEN      0          17545      792/sshd: /usr/sbin
              tcp6       0      0 :::47961                :::*                    LISTEN      112        18841      1290/homebridge: ho
              tcp6       0      0 :::3000                 :::*                    LISTEN      113        15360      1081/grafana
              tcp6       0      0 :::52120                :::*                    LISTEN      112        17120      1319/homebridge: ho
              tcp6       0      0 :::51798                :::*                    LISTEN      112        18821      1147/homebridge
              tcp6       0      0 :::39667                :::*                    LISTEN      112        18857      1293/homebridge: ho
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        18887      1293/homebridge: ho
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        17949      1058/hb-service
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14012      549/avahi-daemon: r
              udp        0      0 0.0.0.0:38879           0.0.0.0:*                           104        14014      549/avahi-daemon: r
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20514      1467/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20515      1467/io.tuya.0
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1586228    38876/cups-browsed
              udp6       0      0 :::5353                 :::*                                104        14013      549/avahi-daemon: r
              udp6       0      0 :::49377                :::*                                104        14015      549/avahi-daemon: r
              udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          17593      652/NetworkManager
              2024-04-25 09:10:38.129  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.gas_savings.total_spent.raw_value" has to be type "number" but received type "string"
              2024-04-25 09:10:38.133  - info: tesla-motors.0 (1742) State value to set for "tesla-motors.0.XP7YGCEK0RB294491.charge_history.total_spent.raw_value" has to be type "number" but received type "string"
              2024-04-25 09:11:45.291  - info: influxdb.0 (47993) enabled logging of PV Tagesertrag, Alias=true
              2024-04-25 09:12:30.314  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTag, Alias=true
              2024-04-25 09:12:50.951  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTag, Alias=true
              2024-04-25 09:13:25.909  - warn: influxdb.0 (47993) Error in query "from(bucket: "admin")  |> range(start: 1999-12-31T23:00:00.000Z, stop: 2024-04-25T07:12:55.411Z) |> filter(fn: (r) => r["_measurement"] == "BatterieEntladung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> group() |> sort(columns:["_time"], desc: false) |> limit(n: 500)": RequestTimedOutError: Request timed out
              2024-04-25 09:14:14.696  - info: influxdb.0 (47993) enabled logging of BatterieEntladung, Alias=true
              2024-04-25 09:14:23.823  - info: influxdb.0 (47993) enabled logging of BatterieProzent, Alias=true
              2024-04-25 09:14:32.228  - info: influxdb.0 (47993) enabled logging of BatterieGeladenTotal, Alias=true
              2024-04-25 09:14:38.869  - info: influxdb.0 (47993) enabled logging of BatterieEntladenTotal, Alias=true
              2024-04-25 09:14:42.461  - info: shelly.0 (1561) [MQTT] Device with client id "shellyplus1-fcb467bf172c" connected!
              2024-04-25 09:14:57.799  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Accumulated_Energy_Yield, Alias=false
              2024-04-25 09:15:10.195  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Active_Power, Alias=false
              2024-04-25 09:15:16.964  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Daily_Energy_Yield, Alias=false
              2024-04-25 09:15:31.414  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Input_Power, Alias=false
              2024-04-25 09:15:42.478  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Huawei.Inverter.Internal_Temperature, Alias=false
              2024-04-25 09:18:36.103  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_Euro, Alias=true
              2024-04-25 09:18:42.306  - info: influxdb.0 (47993) enabled logging of Hausspeicher_gespart, Alias=true
              2024-04-25 09:18:48.544  - info: influxdb.0 (47993) enabled logging of Netzbezug_Tag_Euro, Alias=true
              2024-04-25 09:19:00.758  - info: influxdb.0 (47993) enabled logging of Netzeinspeisung_Tag_Euro, Alias=true
              2024-04-25 09:19:13.266  - info: influxdb.0 (47993) enabled logging of Eigenverbrauch_Tag_kWh, Alias=true
              2024-04-25 09:19:20.297  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, Alias=false
              2024-04-25 09:19:26.029  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Einspeisung_W, Alias=false
              2024-04-25 09:19:34.118  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_Tag_kWh, Alias=false
              2024-04-25 09:19:43.416  - info: influxdb.0 (47993) enabled logging of 0_userdata.0.Stromverbrauch.Netzbezug_W, Alias=false
                @marcelinho
                M
                M
                marcelinho
                @thomas-braun hast du zufällig noch einen Vorschlag was ich gegen den Fehler machen könnte?
                • M marcelinho
                  Thomas BraunT
                  Thomas BraunT
                  @marcelinho
                  Nein. Mit GUIs hab ich aber auch wenig am Hut. Und mit Homebridge auch nicht.
                  • M marcelinho
                    ich kann keine Plugins mehr löschen bzw. Homebridge updaten von v1.7.0 --> v1.8.0
                    Kann mir jemand bitte behilflich sein? Danke vorab.
                    Folgender Fehler:
                    USER: homebridge
                    DIR: /var/lib/homebridge
                    CMD: npm install --save homebridge@1.8.0
                    npm ERR! code EACCES
                    npm ERR! syscall mkdir
                    npm ERR! path /nonexistent
                    npm ERR! errno -13
                    npm ERR! Error: EACCES: permission denied, mkdir '/nonexistent'
                    npm ERR! [Error: EACCES: permission denied, mkdir '/nonexistent'] {
                    npm ERR! errno: -13,
                    npm ERR! code: 'EACCES',
                    npm ERR! syscall: 'mkdir',
                    npm ERR! path: '/nonexistent'
                    npm ERR! }
                    npm ERR!
                    npm ERR! The operation was rejected by your operating system.
                    npm ERR! It is likely you do not have the permissions to access this file as the current user
                    npm ERR!
                    npm ERR! If you believe this might be a permissions issue, please double-check the
                    npm ERR! permissions of the file and its containing directories, or try running
                    npm ERR! the command again as root/Administrator.
                    npm ERR! Log files were not written due to an error writing to the directory: /nonexistent/.npm/_logs
                    npm ERR! You can rerun the command with --loglevel=verbose to see the logs in your terminal
                    Operation failed with code 243.
                    You can download this log file for future reference.
                    See https://github.com/homebridge/homebridge-config-ui-x/wiki/Troubleshooting for help.
                    M
                    M
                    marcelinho
                    habe nun folgenden Fehler:
                    npm ERR! syscall rename
                    npm ERR! path /usr/local/bin/homebridge
                    npm ERR! dest /usr/local/bin/.homebridge-kaN4ImAr
                    npm ERR! errno -13
                    npm ERR! Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'
                    npm ERR! [Error: EACCES: permission denied, rename '/usr/local/bin/homebridge' -> '/usr/local/bin/.homebridge-kaN4ImAr'] {
                    npm ERR! syscall: 'rename',
                    npm ERR! path: '/usr/local/bin/homebridge',
                    npm ERR! dest: '/usr/local/bin/.homebridge-kaN4ImAr'
                    npm ERR! }
                    npm ERR!
                    npm ERR!
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-05-06T15_54_11_806Z-debug-0.log
                    jemand eine Idee?
                    • M marcelinho
                      npm ERR! errno -13
                      npm ERR! }
                      npm ERR!
                      npm ERR!
                      jemand eine Idee?
                      Thomas BraunT
                      Thomas BraunT
                      jemand eine Idee?
                      Du könntest dazu schreiben welche Aktion mit welchem User zu diesen Meldungen führt.
                      Und welche Berechtigungen für homebridge erforderlich sind.
                      ls -lah  /usr/local/bin/homebridge
                        jemand eine Idee?
                        M
                        M
                        marcelinho
                        @thomas-braun wenn ich den Befehl in der Konsole eingebe kommt folgendes:
                        pi@raspberrypi:~ $ ls -lah /usr/local/bin/homebridge
                        lrwxrwxrwx 1 root root 45 May 6 17:51 /usr/local/bin/homebridge -> ../lib/node_ modules/homebridge/bin/homebridge
                        ich bin etwas überfragt, weis nicht genau was du meinst.
                        • M marcelinho
                          Thomas BraunT
                          Thomas BraunT
                          @marcelinho
                          Und
                          ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                          sagt?
                          Konsolentext bitte immer in CodeTags setzen. Kann man besser lesen. Danke.
                          Edit: c&p Fehler
                            @marcelinho
                            Und
                            sagt?
                            Edit: c&p Fehler
                            M
                            M
                            marcelinho
                            @thomas-braun ok sorry
                            es kommt folgendes:
                            pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_ modules/homebridge/bin/homebridg                                    e
                            ls: cannot access '/usr/local/lib/node_': No such file or directory
                            ls: cannot access 'modules/homebridge/bin/homebridge': No such file or directory
                            • M marcelinho
                              es kommt folgendes:
                              DJMarc75D
                              DJMarc75D
                              DJMarc75
                              @marcelinho
                              war ein leerzeichen drin
                              Lehrling seit 1975 !!!
                              • DJMarc75D DJMarc75
                                @marcelinho
                                M
                                M
                                marcelinho
                                @djmarc75 danke anbei neu
                                pi@raspberrypi:~ $ ls -lah /usr/local/lib/node_modules/homebridge/bin/homebridge
                                -rwxr-xr-x 1 pi root 349 May  6 17:51 /usr/local/lib/node_modules/homebridge/bin               /homebridge
                                pi@raspberrypi:~ $
                                • M
                                  M
                                  marcelinho
                                  Hat jemand bezgl. des Fehler noch eine Idee ? Danke vorab:
                                  [28/05/2024, 15:45:48] [Homebridge UI] Operation failed with code 243.
