  4. Homebridge Fehler Code 243
    5.1k
41 Beiträge 4 Kommentatoren 5.7k Aufrufe 3 Watching
    marcelinho
    ich kann keine Plugins mehr löschen bzw. Homebridge updaten von v1.7.0 --> v1.8.0
    Kann mir jemand bitte behilflich sein? Danke vorab.
    Folgender Fehler:
    USER: homebridge
    DIR: /var/lib/homebridge
    CMD: npm install --save homebridge@1.8.0
    npm ERR! code EACCES
    npm ERR! syscall mkdir
    npm ERR! path /nonexistent
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, mkdir '/nonexistent'
    npm ERR! [Error: EACCES: permission denied, mkdir '/nonexistent'] {
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'mkdir',
    npm ERR! path: '/nonexistent'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR! Log files were not written due to an error writing to the directory: /nonexistent/.npm/_logs
    npm ERR! You can rerun the command with --loglevel=verbose to see the logs in your terminal
    Operation failed with code 243.
    You can download this log file for future reference.
    See https://github.com/homebridge/homebridge-config-ui-x/wiki/Troubleshooting for help.
    Thomas BraunT M 2 Antworten Letzte Antwort
    • M marcelinho
      Folgender Fehler:
      USER: homebridge
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      @marcelinho
      Und wer ruft da mit welchem Befehl was genau auf?
        @marcelinho
        marcelinho
        @thomas-braun was meinst du genau ? mein Username = homebridge
        wollte jediglich udaten aber dann kam die Fehlermeldung. Danke Dir
          @marcelinho
          marcelinho
          @thomas-braun wenn ich ein Plugin löschen will kommt folgendes:
          USER: homebridge
          CMD: npm uninstall --save homebridge-lay-z-spa
          npm ERR! errno -13
          npm ERR! path: '/nonexistent',
          npm ERR! requiredBy: 'node_modules/homebridge-deebotecovacs/node_modules/node-xmpp-core'
          npm ERR! }
          npm ERR!
          npm ERR!
          • M marcelinho
            @marcelinho sagte in Homebridge Fehler Code 243:
            Wie? In der GUI? Über die Kommandozeile?
              marcelinho
              @thomas-braun beides in der GUI - habe schon via putty versucht aber bekomme es irgendwie nicht hin.
              • M marcelinho
                @marcelinho
                Gib mal die Ausgabe von
                iob diag
                bekannt. Bevorzugt die Langfassung.
                  @marcelinho
                  iob diag
                  marcelinho
                  @thomas-braun said in Homebridge Fehler Code 243:
                  iob diag
                  ======== Start marking the full check here =========
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.1.0-rpi7-rpi-v8
                      Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.5
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : arm64
                  Systemuptime and Load:
                   11:24:00 up 69 days, 16:18,  4 users,  load average: 0.34, 0.23, 0.36
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Tue 2024-04-23 11:24:01 CEST
                             Universal time: Tue 2024-04-23 09:24:01 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** User and Groups ***
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        3.3G        232M         14M        502M        640M
                  Swap:           104M        104M        270K
                  Total:          4.1G        3.4G        232M
                           3793 M total memory
                           3182 M used memory
                           1041 M active memory
                           2284 M inactive memory
                            221 M free memory
                             56 M buffer memory
                            423 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  lifetime oom required: 0 Mbytes
                  total time in oom handler: 0 ms
                  max time spent in oom handler: 0 ms
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.3M  379M   1% /run
                  /dev/mmcblk0p2 ext4       29G   26G  2.1G  93% /
                  tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
                  tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                  /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                  tmpfs          tmpfs     380M   36K  380M   1% /run/user/1000
                  [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc        m2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_me        m.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=1e048ecb-02 rootfstyp        e=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                  [Tue Feb 13 18:05:11 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Feb 13 18:05:14 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  Show mounted filesystems \(real ones only\):
                  TARGET               SOURCE         FSTYPE      OPTIONS
                  /                    /dev/mmcblk0p2 ext4        rw,noatime
                  |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortnam        e=mixed,errors=remount-ro
                  /var:
                  17G     /var/
                  16G     /var/lib
                  15G     /var/lib/influxdb/engine/data/86690b2dbdd230c8/autogen
                  Archived and active journals take up 699.9M in the file system.
                  /opt/iobroker/backups:
                  213M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  302M    /opt/iobroker/iobroker-data/
                  191M    /opt/iobroker/iobroker-data/files
                  57M     /opt/iobroker/iobroker-data/files/javascript.admin
                  52M     /opt/iobroker/iobroker-data/backup-objects
                  38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                  20M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                  8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c4452914ae9ded11bf33d1a5a7669f5d-if00-port0
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.11.0
                  /usr/local/bin/node             v21.1.0
                  /usr/local/bin/npm              10.2.0
                  /usr/local/bin/npx              10.2.0
                  /usr/local/bin/corepack         0.22.0
                  *** nodejs is NOT correctly installed ***
                  nodejs:
                    Installed: 20.11.0-1nodesource1
                    Candidate: 20.12.2-1nodesource1
                    Version table:
                       20.12.2-1nodesource1 600
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                       20.12.1-1nodesource1 600
                       20.12.0-1nodesource1 600
                       20.11.1-1nodesource1 600
                   *** 20.11.0-1nodesource1 600
                          100 /var/lib/dpkg/status
                       20.10.0-1nodesource1 600
                       20.9.0-1nodesource1 600
                       20.8.1-1nodesource1 600
                       20.8.0-1nodesource1 600
                       20.7.0-1nodesource1 600
                       20.6.1-1nodesource1 600
                       20.6.0-1nodesource1 600
                       20.5.1-1nodesource1 600
                       20.5.0-1nodesource1 600
                       20.4.0-1nodesource1 600
                       20.3.1-1nodesource1 600
                       20.3.0-1nodesource1 600
                       20.2.0-1nodesource1 600
                       20.1.0-1nodesource1 600
                       20.0.0-1nodesource1 600
                       18.19.0+dfsg-6~deb12u1 500
                       18.13.0+dfsg1-1 500
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.19
                  admin:          6.13.16
                  javascript:     7.8.0
                  Adapters from github:   3
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                  + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
                  + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
                  + system.adapter.daikin.1                 : daikin                : raspberrypi                              -  enabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
                  + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                  + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.myenergi.0               : myenergi              : raspberrypi                              -  enabled
                  + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.smart-eq.0               : smart-eq              : raspberrypi                              -  enabled
                  + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
                  + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                  + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Instances
                  Used repository: stable
                  Adapter    "admin"        : 6.13.16  , installed 6.13.16
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                  Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                  Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                  Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                  Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                  Adapter    "homekit-controller": 0.5.10, installed 0.5.10
                  Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                  Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                  Controller "js-controller": 5.0.19   , installed 5.0.19
                  Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                  Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                  Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
                  Adapter    "node-red"     : 5.2.0    , installed 5.2.0
                  Adapter    "openhab"      : 1.1.0    , installed 1.1.0
                  Adapter    "shelly"       : 6.8.0    , installed 6.8.0
                  Adapter    "smart-eq"     : 0.0.4    , installed 0.0.6
                  Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                  Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                  Adapter    "ws"           : 2.5.11   , installed 2.5.11
                  Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                  Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                  Objects and States
                  Objects:        14990
                  States:         13387
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://repos.influxdata.com/debian stable InRelease
                  Hit:6 https://apt.grafana.com stable InRelease
                  Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:8 https://repo.homebridge.io stable InRelease
                  Reading package lists...
                  Pending Updates: 180
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:39715         0.0.0.0:*               LISTEN      112        46457213   2097759/homebridge:
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5021298    228976/iobroker.js-
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5021312    228976/iobroker.js-
                  tcp        0      0 127.0.0.1:39639         0.0.0.0:*               LISTEN      112        46457242   2097771/homebridge:
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          46142328   2081606/cupsd
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17032      803/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:43327         0.0.0.0:*               LISTEN      112        46458116   2097772/homebridge:
                  tcp        0      0 127.0.0.1:45013         0.0.0.0:*               LISTEN      112        46455694   2097765/homebridge:
                  tcp        0      0 127.0.0.1:34425         0.0.0.0:*               LISTEN      112        46480613   2097757/homebridge:
                  tcp        0      0 127.0.0.1:34275         0.0.0.0:*               LISTEN      112        46457194   2097778/homebridge:
                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       684423     32124/node
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       33174888   1491043/node-red
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       28392686   1277149/io.shelly.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      114        17024      779/mosquitto
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       5023995    229264/io.mqtt.0
                  tcp        0      0 127.0.0.1:44081         0.0.0.0:*               LISTEN      112        46456352   2097758/homebridge:
                  tcp        0      0 127.0.0.1:33795         0.0.0.0:*               LISTEN      112        46457227   2097785/homebridge:
                  tcp6       0      0 :::8581                 :::*                    LISTEN      112        46418999   2094723/hb-service
                  tcp6       0      0 :::45391                :::*                    LISTEN      112        46458125   2097771/homebridge:
                  tcp6       0      0 :::37166                :::*                    LISTEN      112        46456334   2097758/homebridge:
                  tcp6       0      0 :::53299                :::*                    LISTEN      112        46456339   2097772/homebridge:
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17034      803/sshd: /usr/sbin
                  tcp6       0      0 :::3000                 :::*                    LISTEN      113        19873      1596/grafana
                  tcp6       0      0 :::52120                :::*                    LISTEN      112        46455673   2097785/homebridge:
                  tcp6       0      0 :::47961                :::*                    LISTEN      112        46455615   2097757/homebridge:
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          46142327   2081606/cupsd
                  tcp6       0      0 :::39667                :::*                    LISTEN      112        46456297   2097759/homebridge:
                  tcp6       0      0 :::51798                :::*                    LISTEN      112        46457171   2097719/homebridge
                  tcp6       0      0 :::44253                :::*                    LISTEN      112        46455623   2097778/homebridge:
                  tcp6       0      0 :::52403                :::*                    LISTEN      112        46456301   2097765/homebridge:
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5021363    229001/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38441274   1730388/io.web.0
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        19857      1400/influxd
                  tcp6       0      0 :::1883                 :::*                    LISTEN      114        17025      779/mosquitto
                  udp        0      0 0.0.0.0:47202           0.0.0.0:*                           104        13649      516/avahi-daemon: r
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5021645    229175/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5021646    229175/io.tuya.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          46142333   2081608/cups-browse
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46458119   2097759/homebridge:
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        46418996   2094723/hb-service
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      516/avahi-daemon: r
                  udp6       0      0 :::39317                :::*                                104        13650      516/avahi-daemon: r
                  udp6       0      0 fe80::81a3:20c2:583:546 :::*                                0          20485      651/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        13648      516/avahi-daemon: r
                  2024-04-23 11:25:31.610  - warn: influxdb.0 (229070) Error on writePoint("{"value":4294,"time":"2024-04-23T09:25:19.093Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 11:25:31.610  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=4
                  2024-04-23 11:25:31.619  - warn: influxdb.0 (229070) Point could not be written to database: admin
                  2024-04-23 11:25:31.619  - warn: influxdb.0 (229070) Error on writePoint("{"value":5.3333,"time":"2024-04-23T09:25:20.001Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 11:25:31.620  - info: influxdb.0 (229070) Discard point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_Tag_kWh, error-count=10
                  2024-04-23 11:25:31.624  - warn: influxdb.0 (229070) Point could not be written to database: admin
                  2024-04-23 11:25:31.624  - warn: influxdb.0 (229070) Error on writePoint("{"value":0.3733310000000001,"time":"2024-04-23T09:25:20.007Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 11:25:31.625  - info: influxdb.0 (229070) Add point that had error for Netzeinspeisung_Tag_Euro to buffer again, error-count=6
                  2024-04-23 11:25:34.932  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 closed: null
                  2024-04-23 11:25:39.931  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 reconnected
                  2024-04-23 11:25:40.155  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 connected
                  2024-04-23 11:25:56.900  - warn: influxdb.0 (229070) Point could not be written to database: admin
                  2024-04-23 11:25:56.901  - warn: influxdb.0 (229070) Error on writePoint("{"value":2360,"time":"2024-04-23T09:25:46.607Z","from":"system.adapter.javascript.0","q":0,"ack":false}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 11:25:56.902  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeisung_W to buffer again, error-count=5
                  2024-04-23 11:25:56.908  - warn: influxdb.0 (229070) Point could not be written to database: admin
                  2024-04-23 11:25:56.913  - warn: influxdb.0 (229070) Error on writePoint("{"value":7474,"time":"2024-04-23T09:25:40.968Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 11:25:56.914  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_Power to buffer again, error-count=7
                  2024-04-23 11:25:56.923  - warn: influxdb.0 (229070) Point could not be written to database: admin
                  2024-04-23 11:25:56.934  - warn: influxdb.0 (229070) Error on writePoint("{"value":2360,"time":"2024-04-23T09:25:46.603Z","from":"system.adapter.node-red.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                  2024-04-23 11:25:56.934  - info: influxdb.0 (229070) Add point that had error for 0_userdata.0.Huawei.Meter.Active_Power to buffer again, error-count=2
                  2024-04-23 11:26:00.245  - info: meross.0 (229216) Can not get Data for Device 2103163856729736101148e1e9629220: Error: Timeout
                  2024-04-23 11:26:00.246  - warn: meross.0 (229216) Can not get Data for Device 2103163856729736101148e1e9629220: undefined
                  2024-04-23 11:26:04.933  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 closed: null
                  2024-04-23 11:26:09.934  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 reconnected
                  2024-04-23 11:26:10.115  - info: meross.0 (229216) Device: 2103163856729736101148e1e9629220 connected
                  iob diag has finished.
                    @marcelinho
                    iob diag
                    marcelinho
                    Copy text starting here:
                                            v.2023-10-10
                           Icon name: computer
                        Architecture: arm64
                    Installation:           native
                    Kernel:                 aarch64
                    Userland:               arm64
                    Timezone:               Europe/Berlin (CEST, +0200)
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     180
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v20.11.0
                    Recommended versions are nodejs 18.20.2 and npm 10.5.0
                    Wrong installation path detected. This needs to be fixed.
                    Please check
                    for more information on how to fix these errors.
                    MEMORY:
                    Mem:            4.0G        3.4G        101M         14M        601M        608M
                    Swap:           104M        104M        221K
                    Total:          4.1G        3.5G        101M
                    Active iob-Instances:   24
                    ioBroker Core:          js-controller           5.0.19
                                            admin                   6.13.16
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                14990
                    States:                 13387
                    Size of iob-Database:
                    4.0M    /opt/iobroker/iobroker-data/states.jsonl
                    === Mark text until here for copying ===
                    • M marcelinho
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                               3793 M total memory
                               3182 M used memory
                                221 M free memory
                                 56 M buffer memory
                                423 M swap cache
                                 99 M total swap
                                 99 M used swap
                                  0 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      17G     /var/
                      16G     /var/lib
                      USB-Devices by-id:
                      nodejs:
                        Version table:
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.16
                      javascript:     7.8.0
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        14990
                      States:         13387
                      Boot Target: graphical.target
                      Stell da um auf multi-user.
                      sudo systemctl set-default multi-user.target
                      Dein root-Verzeichnis läuft voll.
                      Räum da auf.
                      nodejs ist hinten und vorne falsch installiert.
                      iob nodejs-update
                      und nodejs18 darüber sauber installieren lassen.
                      System regelmäßig (bzw. überhaupt) pflegen.
                      Mit der influxdb gibt es wohl auch Trouble.
                        Räum da auf.
                        iob nodejs-update
                        marcelinho
                        iob nodejs-update
                        Danke Dir, wie kann ich root-Verzeichnis aufräumen?
                        Influxdb läuft bisher problemlos - was kann ich da tun?
                        Thomas BraunT Marc BergM 3 Antworten Letzte Antwort
                        • M marcelinho
                          iob nodejs-update
                          Erstmal schauen, was da so dickes drin liegt und wo man ansetzen muss.
                          Ich mach das immer per
                          sudo ncdu /
                          ncdu muss u. U. noch nachinstalliert werden.
                          • M marcelinho
                            iob nodejs-update
                            Wenn es problemlos liefe hättest du nicht die ganzen Meldungen im LogFile.
                            Ich setze influxdb aber nicht ein, muss dir vielleicht wer anders helfen.
                            @Marc-Berg ist hier der DB-Spezialist.
                            • M marcelinho
                              iob nodejs-update
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              Ich würde sagen, unter normalen Bedingungen bekommt man eine InfluxDB kaum in solche Größenordnungen wie bei dir. Der Klassiker ist, dass man versehentlich das Logging von Performancedaten aktiviert hat. Du kannst mal diesen Thread anschauen, ob das bei dir der Fall ist:
                              https://forum.iobroker.net/topic/73784/speicherplatzbelegung-influxdb2-nach-containerisierung
                                marcelinho
                                @thomas-braun also nodejs habe ich hinbekommen laut iob diag. Aber in Homebridge funktioniert es noch nicht...
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 12:51:12 up 69 days, 17:46,  4 users,  load average: 0.92, 0.67, 1.32
                                CPU threads: 4
                                Current issues:
                                               Local time: Tue 2024-04-23 12:51:12 CEST
                                           Universal time: Tue 2024-04-23 10:51:12 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                Boot Target:    multi-user.target
                                *** MEMORY ***
                                Mem:            4.0G        2.9G        321M         17M        878M        1.1G
                                Swap:           104M        104M        389K
                                Total:          4.1G        3.0G        322M
                                         3793 M total memory
                                         2740 M used memory
                                         1102 M active memory
                                         2016 M inactive memory
                                          306 M free memory
                                           36 M buffer memory
                                          801 M swap cache
                                           99 M total swap
                                           99 M used swap
                                            0 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/mmcblk0p2 ext4       29G   27G  1.2G  96% /
                                tmpfs          tmpfs     1.9G  140K  1.9G   1% /dev/shm
                                [Tue Feb 13 18:05:08 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bc_hdmi=0  smsc95xx.macaddr=D8:3A:DD:1A:71:9B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200s rootwait quiet splash plymouth.ignore-serial-consoles
                                /var:
                                18G     /var/
                                16G     /var/lib
                                308M    /opt/iobroker/iobroker-data/
                                21M     /opt/iobroker/iobroker-data/objects.jsonl
                                8.7M    /opt/iobroker/iobroker-data/states.jsonl
                                USB-Devices by-id:
                                /usr/bin/nodejs         v18.20.2
                                /usr/bin/node           v18.20.2
                                /usr/bin/npm            10.5.0
                                /usr/bin/npx            10.5.0
                                /usr/bin/corepack       0.25.2
                                nodejs:
                                  Installed: 18.20.2-1nodesource1
                                  Candidate: 18.20.2-1nodesource1
                                  Version table:
                                 *** 18.20.2-1nodesource1 600
                                        500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                     18.20.1-1nodesource1 600
                                     18.20.0-1nodesource1 600
                                     18.19.1-1nodesource1 600
                                     18.19.0-1nodesource1 600
                                     18.18.2-1nodesource1 600
                                     18.18.1-1nodesource1 600
                                     18.18.0-1nodesource1 600
                                     18.17.1-1nodesource1 600
                                     18.17.0-1nodesource1 600
                                     18.16.1-1nodesource1 600
                                     18.16.0-1nodesource1 600
                                     18.15.0-1nodesource1 600
                                     18.14.2-1nodesource1 600
                                     18.14.1-1nodesource1 600
                                     18.14.0-1nodesource1 600
                                     18.13.0+dfsg1-1 500
                                     18.13.0-1nodesource1 600
                                     18.12.0-1nodesource1 600
                                     18.11.0-1nodesource1 600
                                     18.10.0-1nodesource1 600
                                     18.9.1-1nodesource1 600
                                     18.9.0-1nodesource1 600
                                     18.8.0-1nodesource1 600
                                     18.7.0-1nodesource1 600
                                     18.6.0-1nodesource1 600
                                     18.5.0-1nodesource1 600
                                     18.4.0-1nodesource1 600
                                     18.3.0-1nodesource1 600
                                     18.2.0-1nodesource1 600
                                     18.1.0-1nodesource1 600
                                     18.0.0-1nodesource1 600
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.13.16
                                javascript:     7.8.0
                                Adapter State
                                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled
                                + instance is alive
                                Objects and States
                                Objects:        14990
                                States:         13387
                                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       46540273   2123199/iobroker.
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       46539313   2123199/iobroker.
                                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       46540528   2123279/node-red
                                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       46541106   2123467/io.shelly
                                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       46541132   2123482/io.mqtt.0
                                tcp6       0      0 :::3000                 :::*                    LISTEN      113        46530636   2107469/grafana
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46538428   2123223/io.admin.
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46541385   2123559/io.web.0
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       46543999   2123507/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       46544000   2123507/io.tuya.0
                                2024-04-23 12:51:34.173  - error: zigbee2mqtt.0 (2123452) Publish 'get' 'color' to 'Nachtlicht Schlafzimmer' failed: 'E
                                2024-04-23 12:52:46.833  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:52:46.836  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:35.89unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:52:46.836  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                                2024-04-23 12:52:46.849  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:52:46.850  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7357,"time":"2024-04-23T10:52:36.51unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:52:46.850  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Input_P
                                2024-04-23 12:53:05.267  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:53:05.270  - warn: influxdb.0 (2123264) Error on writePoint("{"value":3495,"time":"2024-04-23T10:52:53.02r: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:53:05.270  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                                2024-04-23 12:53:09.343  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:53:09.349  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7381,"time":"2024-04-23T10:52:53.11unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:53:09.350  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Huawei.Inverter.Active_
                                2024-04-23 12:53:11.700  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:53:11.701  - warn: influxdb.0 (2123264) Error on writePoint("{"value":7,"time":"2024-04-23T10:52:55.155Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:53:11.701  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                                2024-04-23 12:53:13.275  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:53:13.276  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8,"time":"2024-04-23T10:52:59.725Z"xpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:53:13.276  - info: influxdb.0 (2123264) Add point that had error for BatterieEntladung to buffer again, e
                                2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:53:13.286  - warn: influxdb.0 (2123264) Error on writePoint("{"value":0.6175750000000001,"time":"2024-04-se}): HttpError: unexpected error writing points to database: timeout / "unexpected error writing points to database: t
                                2024-04-23 12:53:13.287  - info: influxdb.0 (2123264) Add point that had error for Netzeinspeisung_Tag_Euro to buffer a
                                2024-04-23 12:53:13.290  - warn: influxdb.0 (2123264) Point could not be written to database: admin
                                2024-04-23 12:53:13.291  - warn: influxdb.0 (2123264) Error on writePoint("{"value":8.8225,"time":"2024-04-23T10:53:00.ror: unexpected error writing points to database: timeout / "unexpected error writing points to database: timeout""
                                2024-04-23 12:53:13.291  - info: influxdb.0 (2123264) Add point that had error for 0_userdata.0.Stromverbrauch.Einspeis
                                • M marcelinho
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                           3793 M total memory
                                           2740 M used memory
                                            306 M free memory
                                             36 M buffer memory
                                            801 M swap cache
                                             99 M total swap
                                             99 M used swap
                                              0 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  18G     /var/
                                  16G     /var/lib
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.5.0
                                  /usr/bin/npx            10.5.0
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.16
                                  javascript:     7.8.0
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        14990
                                  States:         13387
                                  Pending Updates: 0
                                  @marcelinho
                                  Bei den Updates war ein Kernel-Update dabei:
                                  Neustart der Kiste erforderlich!
                                  iob stop
                                  sudo reboot
                                  • Marc BergM Marc Berg
                                    marcelinho
                                    @marc-berg ja das ist bei mir in der Tat so, ich schreibe viele Datenpunkte in die influxdb (siehe screenshot) die Scrapers habe ich nun gelöscht - wie kann ich nun die Daten bereinigen ? Danke auch Dir für deine Mühe/Hilfe. Screenshot 2024-04-23 130336.png
                                      @marcelinho
                                      iob stop
                                      sudo reboot
                                      marcelinho
                                      @thomas-braun danke habe ich gemacht - Fehler bleibt bestehen :(
                                      • M marcelinho
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        Ja da hast du jetzt ein kleines Problem. Dadurch, dass die zu löschenden Daten mit in deinem ioBroker Bucket gelandet sind (so habe ich es verstanden), musst du diese einzeln auf der Kommandozeile löschen (Bucketname, Organisation und Measurement anpassen)
                                        influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home
                                        bzw.:
                                        influx delete --bucket "iobroker" --predicate '_measurement="storage_cache_inuse_bytes"' --start '1970-01-01T00:00:00Z' --stop '2030-12-31T23:59:00Z' -o home -t <token>
                                        Ich würde aber dringend empfehlen, die Daten dort rauszulöschen, da man ja in deinen Logs schon sieht, dass die Datenbank Probleme und Timeouts hat.
                                        EDIT: hier ein kleines Script zum Löschen der Daten:
                                        delete_scraper_data.sh
                                          bzw.:
                                          marcelinho
                                          @marc-berg Danke nochmal, Nodered funktioniert jetzt auch - hat nur etwas Zeit gebraucht.
                                          Bist der beste - Schönen Abend noch Marc :)
                                          32.7k
                                          82.5k
