  4. JavaScript Adapter 8.0.0
    6.6k
51 Beiträge 18 Kommentatoren 8.3k Aufrufe 16 Beobachtet
  • DiginixD Offline
    DiginixD Offline
    Diginix
    schrieb am zuletzt editiert von Diginix
    #41
    @haus-automatisierung Ich habe seit mehreren Betaversionen das Problem, dass der Adapter Upload nach dem Update nicht fehlerfrei durchläuft. Die Skripte starten alle und laufen auch, aber das UI kann nicht geöffnet werden mit Meldung
    404
    Oops! The page you're looking for can't be found. 😔
    File tab.html not found
    Das ist die Ausgabe vom Update:
    $ iobroker upgrade javascript@8.5.1 --debug
    Update javascript from @8.5.0 to @8.5.1
    NPM version: 10.7.0
    Installing iobroker.javascript@8.5.1... (System call)
    npm warn ERESOLVE overriding peer dependencynpm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
    changed 1 package in 15s
    190 packages are looking for funding run `npm fund` for details
    Update "system.adapter.javascript.0"
    upload [730] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js-_9d271.58ff8a1c.chunk.js.map custom/static/js/node_modules_iobroker_adapter-react-v5_node_modules_react_index_js-_9d271.58ff8a1c.chunk.js.map application/json
    upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/de.js google-blockly/msg/js/de.js application/javascript
    upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/173.4e774f7f.chunk.js.map static/js/173.4e774f7f.chunk.js.map application/json
    ERROR: Process exited with code null
    Und das die vom manuellen Upload, nachdem dann auch das UI fehlerfrei läuft.
    $ iobroker upload javascript --debug
    upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/310.57c4d9e8.chunk.js.map static/js/310.57c4d9e8.chunk.js.map application/json
    upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.168f947c.chunk.js.map static/js/409.168f947c.chunk.js.map application/json
    upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/456.e92b95ee.chunk.js static/js/456.e92b95ee.chunk.js application/javascript
    upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/7.647eff54.chunk.js static/js/7.647eff54.chunk.js application/javascript
    upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/823.dfc6b5cf.chunk.js.map static/js/823.dfc6b5cf.chunk.js.map application/json
    upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/899.360cdee6.chunk.js.map static/js/899.360cdee6.chunk.js.map application/json
    upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.2d8956a6.js.map static/js/main.2d8956a6.js.map application/json
    upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Ceiling Spotlights.485822441b5df3b3384a.svg static/media/Ceiling Spotlights.485822441b5df3b3384a.svg image/svg+xml
    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Living Area.1c29b81e75b75e3310db.svg static/media/Living Area.1c29b81e75b75e3310db.svg image/svg+xml
    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Outdoors.da42e64a4b6ec2dd1e1c.svg static/media/Outdoors.da42e64a4b6ec2dd1e1c.svg image/svg+xml
    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Second Floor.a2d5ed32df336591c06b.svg static/media/Second Floor.a2d5ed32df336591c06b.svg image/svg+xml
    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Stairwell.0914feea948153a8637a.svg static/media/Stairwell.0914feea948153a8637a.svg image/svg+xml
    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/coffee/coffee.js vs/basic-languages/coffee/coffee.js application/javascript
    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
    Process exited with code 0
    javascript 8.5.1
    node: v18.20.3
    js-controller: 5.0.19
    Irgend eine Idee?
    ..:: So long! Tom ::..
    • DiginixD Diginix
      404
      NPM version: 10.7.0
      javascript 8.5.1
      node: v18.20.3
      Irgend eine Idee?
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #42
      @diginix
      Wie installierst du die Betas?
      "Normal" via UI im Admin Interface?
      Oder über die Katze?
      Oder ...
      Frage storniert - hast eh einen log gepostet
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        @diginix
        Oder ...
        DiginixD Offline
        DiginixD Offline
        Diginix
        #43
        @mcm1957 Ausschließlich im Adapter Tab vom Admin.
        Edit: Updates aller anderen Adapter laufen alle inkl Upload mit Exit Code 0 durch.
        (zuletzt zB Admin, Telegram, Backitup, email)
        • DiginixD Offline
          DiginixD Offline
          Diginix
          #44
          Auch mit node 20.14.0 und js-controller 6.0.4 muss ich beim javascript Adapter den upload manuell nach jedem Update machen. Alle anderen Adapter aktualisieren sich komplett fehlerfrei.
          Ausgabe vom Update mit unvollständigem upload:
          $ iobroker upgrade javascript@8.6.0 --debug
          Update javascript from @8.5.2 to @8.6.0
          NPM version: 10.7.0
          Installing iobroker.javascript@8.6.0... (System call)
          changed 1 package in 19s190 packages are looking for funding run `npm fund` for details
          upload [754] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
          upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
          upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/vendors-node_modules_mui_system_esm_GlobalStyles_GlobalStyles_js-node_modules_mui_system_esm_-8241e1.b8c9d73a.chunk.js.map custom/static/js/vendors-node_modules_mui_system_esm_GlobalStyles_GlobalStyles_js-node_modules_mui_system_esm_-8241e1.b8c9d73a.chunk.js.map application/json
          upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_switch.js google-blockly/own/blocks_switch.js application/javascript
          upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/122.405c394f.chunk.js.map static/js/122.405c394f.chunk.js.map application/json
          upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/239.4b3a951a.chunk.js static/js/239.4b3a951a.chunk.js application/javascript
          Ausgabe vom manuellen upload:
          upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/335.9591bd2c.chunk.js.map static/js/335.9591bd2c.chunk.js.map application/json
          upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.a78d4702.chunk.js.map static/js/409.a78d4702.chunk.js.map application/json
          upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/498.660757a3.chunk.js.map static/js/498.660757a3.chunk.js.map application/json
          upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/704.7f142efd.chunk.js.map static/js/704.7f142efd.chunk.js.map application/json
          upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/837.70f35e1e.chunk.js.map static/js/837.70f35e1e.chunk.js.map application/json
          upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/928.f1f4f4bb.chunk.js static/js/928.f1f4f4bb.chunk.js application/javascript
          upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.5424e0d7.js.map static/js/main.5424e0d7.js.map application/json
          Bin für jeden Tipp dankbar.
          • DiginixD Diginix
            NPM version: 10.7.0
            #45
            @diginix
            Hast du den admin mal neuinstalliert?
              @diginix
              DiginixD Offline
              DiginixD Offline
              Diginix
              #46
              @thomas-braun Bisher nicht. Updates aller anderen Adapter funktionieren vollautomatisch. An den "/opt/iobroker/node_modules/iobroker.javascript/..." Dateien vom javascript Adapter liegt es nicht?
              Weil da bricht ja der automatische upload immer ab. Aber beim nachträglichen manuellen upload klappt es dann mit allen Dateien.
              • DiginixD Diginix
                #47
                @diginix
                Schaut für mich eher nach einem Thema beim admin aus:
                  @diginix
                  DiginixD Offline
                  DiginixD Offline
                  Diginix
                  #48
                  @thomas-braun Ok, da hast du definitiv mehr know-how. Soll ich 6.17.14 einfach nochmal im Admin selbst hierüber drüber inst?
                  • DiginixD Diginix
                    #49
                    @diginix
                    Ich würde sowas immer über die Kommandozeile machen.
                    iob update
                    iob upgrade admin@6.17.14 --omit=dev
                      @diginix
                      iob update
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #50
                      @thomas-braun Ok, hab schon vor deiner Antw. den admin nochmal über die GUI neu inst. Und danach das gleiche beim javascript. Nun lief es mit exit code 0 durch. Ob das beim nächsten "echten" Update dann auch so ist, wird sich zeigen.
                      Ausgabe der javascript Inst.:
                      Update javascript from @8.6.0 to @8.6.0
                      Uninstall npm packet "iobroker.javascript" for a clean re-installation
                      192 packages are looking for funding run `npm fund` for details
                      NPM version: 10.7.0
                      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                      added 17 packages in 14s
                      • DiginixD Diginix
                        NPM version: 10.7.0
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #51
                        Leider klappt ein echtes Versionsupdate von javascript weiterhin nicht vollautomatisch inkl. sauberem upload. Admin ist mittlerweile 7.0.2 und alle Tipps von @Thomas-Braun hatte ich auch probiert.
                        NPM version: 10.7.0
                        changed 1 package in 11s
                        Danach laufen alle Skripte, aber man kann keine Skripte bearbeiten. Wie hier https://forum.iobroker.net/topic/73946/javascript-adapter-8-0-0/41?_=1719305444921 schon geschrieben.
                        Der upload steigt immer bei diesen javascript/admin/static/js/???.chunk.js.map Dateien aus.
                        Nach manuellem upload des Adapter im Admin, passt dann alles:
                        admin: 7.0.2
                        nodejs: 20.15.0
                        js-controller: 6.0.5
                        javascript update von 8.5.2 auf 8.6.0 (aber war auch schon bei update von 8.5.x auf 8.5.y)
