Sonoff Zigbee 3.0 Dongle E
Do I need to flash Sonoff Zigbee 3.0 Dongle E with any specific firmware to work with iobroker? I tried non-flashed dongle and it seems to be working after I set proper communication port and type to Silicon Labs.
The stick usually comes with the correct firmware. If everything works, then it's good.
The P is more common here in the forum, you can also find some instructions for flashing here.
@david-g Thanks. I've noticed that on Silabs Firmware Flasher sire https://darkxst.github.io/silabs-firmware-builder/ there are few versions of firmware for -E adapter in addition to latest Sonoff version, Is there any advantage using one of these?
