  2. English
  3. ioBroker general
  4. Sonoff Zigbee 3.0 Dongle E
Geplant Angeheftet Gesperrt Verschoben ioBroker general
sonoff zigbee dongle
5 Beiträge 3 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • A
    A
    ap2017
    schrieb am zuletzt editiert von ap2017
    Do I need to flash Sonoff Zigbee 3.0 Dongle E with any specific firmware to work with iobroker? I tried non-flashed dongle and it seems to be working after I set proper communication port and type to Silicon Labs.
    • A ap2017
      David G.D
      David G.D
      David G.
      @ap2017
      The stick usually comes with the correct firmware. If everything works, then it's good.
      The P is more common here in the forum, you can also find some instructions for flashing here.
      • David G.D David G.
        @ap2017
        A
        A
        ap2017
        @david-g Thanks. I've noticed that on Silabs Firmware Flasher sire https://darkxst.github.io/silabs-firmware-builder/ there are few versions of firmware for -E adapter in addition to latest Sonoff version, Is there any advantage using one of these?
        David G.D arteckA 2 Antworten Letzte Antwort
        • A ap2017
          David G.D
          David G.D
          David G.
          @ap2017
          Ezsp is the normal firmware. This is required for zigbee. I don't know if it works with Multipan, Thread is not yet supported by iobroker. If it comes soon, I don't know if zigbee and Thread can run on one stick.
          • A ap2017
            arteckA
            arteckA
            arteck
            @ap2017 you can follow the project zigbee2mqtt..
            if it works there..then we look here if is it possible
            FYI : the dongle E does not support nvbackup function..
            83.8k
