  4. Probleme mit npm bei Iobroker installation
8 Beiträge 3 Kommentatoren 614 Aufrufe 3 Beobachtet
  • N Offline
    N Offline
    NFTVirus
    Hallo
    ich versuche gerade mein iobroker neu auf zu setzen. Allerdings gibt es irgendwie immer Probleme mit der npm Installation hier mal mein iob diag File:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.20+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     16:33:53 up  1:59,  2 users,  load average: 0.18, 3.94, 12.29
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** Time and Time Zones ***
                   Local time: Tue 2024-03-26 16:33:53 CET
               Universal time: Tue 2024-03-26 15:33:53 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            951M        276M        486M        229K        255M        675M
    Swap:           104M         20M         84M
    Total:          1.1G        296M        570M
              907 M total memory
              263 M used memory
              226 M active memory
              119 M inactive memory
              464 M free memory
               23 M buffer memory
              220 M swap cache
               99 M total swap
               19 M used swap
               80 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  318M     0  318M   0% /dev
    tmpfs          tmpfs      91M  1.1M   90M   2% /run
    /dev/mmcblk0p2 ext4       29G  2.5G   25G  10% /
    tmpfs          tmpfs     454M     0  454M   0% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    [Tue Mar 26 14:34:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=192d7b3d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Mar 26 14:34:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
    [Tue Mar 26 14:34:44 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    513M    /var/
    203M    /var/cache
    197M    /var/cache/apt
    161M    /var/lib
    133M    /var/lib/apt/lists
    Archived and active journals take up 48.0M in the file system.
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    14M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466692-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.1
    /usr/bin/node           v18.19.1
    /usr/bin/npm            10.2.4
    /usr/bin/npx            10.2.4
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.1-1nodesource1
      Candidate: 18.19.1-1nodesource1
      Version table:
     *** 18.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.19.0+dfsg-6~deb12u1 500
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    find: '/opt/iobroker/node_modules': No such file or directory
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-26T15_34_03_649Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.19.1
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v18.19.1
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.19.1
    admin:
      throw err;
      requireStack: []
    Node.js v18.19.1
    javascript:
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-26T15_34_07_732Z-debug-0.log
    Adapters from github:   0
    Adapter State
      throw err;
      requireStack: []
    Node.js v18.19.1
      throw err;
      requireStack: []
    Node.js v18.19.1
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v18.19.1
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v18.19.1
    Objects and States
    Objects:        0
    States:         0
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5486       603/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       47117      11617/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47110      11617/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44593      11654/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5488       603/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3049       436/avahi-daemon: r
    udp        0      0 0.0.0.0:36870           0.0.0.0:*                           104        3051       436/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        3050       436/avahi-daemon: r
    udp6       0      0 fe80::7aa9:1a5c:f94:546 :::*                                0          5044       505/NetworkManager
    udp6       0      0 :::59041                :::*                                104        3052       436/avahi-daemon: r
    2024-03-26 15:03:56.349  - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
    2024-03-26 15:03:56.369  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
    2024-03-26 15:03:56.372  - info: host.raspberrypi hostname: raspberrypi, node: v18.19.1
    2024-03-26 15:03:56.374  - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:afb1:6500:795a:2fed:21ad:69ae fd00::c4bf:562:3ef2:5b6f fe80::7aa9:1a5c:f94a:62f6
    2024-03-26 15:03:57.213  - info: host.raspberrypi connected to Objects and States
    2024-03-26 15:03:57.280  - info: host.raspberrypi Node.js version has changed from unknown to 18.19.1
    2024-03-26 15:03:57.404  - info: host.raspberrypi added notifications configuration of host
    2024-03-26 15:03:57.434  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2024-03-26 15:03:58.508  - info: host.raspberrypi 2 instances found
    2024-03-26 15:03:58.524  - info: host.raspberrypi starting 2 instances
    2024-03-26 15:03:58.647  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 11654
    2024-03-26 15:04:02.595  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 11734
    2024-03-26 15:04:16.785  - info: discovery.0 (11734) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
    2024-03-26 15:04:17.239  - info: admin.0 (11654) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
    2024-03-26 15:04:17.400  - info: admin.0 (11654) requesting all objects
    2024-03-26 15:04:18.282  - info: admin.0 (11654) received all objects
    2024-03-26 15:04:52.087  - warn: admin.0 (11654) Cannot update news: timeout of 13000ms exceeded
    2024-03-26 15:05:01.808  - info: admin.0 (11654) socket.io server listening on port 8081
    2024-03-26 15:05:04.181  - info: admin.0 (11654) http server listening on port 8081
    2024-03-26 15:05:04.639  - info: admin.0 (11654) Use link "http://127.0.0.1:8081" to configure.
    2024-03-26 15:11:39.162  - warn: admin.0 (11654) Repository cannot be read: Active repo - stable
    2024-03-26 15:11:39.187  - warn: admin.0 (11654) Active repository "stable" cannot be read
    2024-03-26 16:25:13.982  - warn: admin.0 (11654) Cannot check node.js/npm version
    Hat jemand eine Idee was ich falsch mache?
    Schönen Gruß!
    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
    • N NFTVirus
      Hallo
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M         20M         84M
                907 M total memory
                263 M used memory
                226 M active memory
                464 M free memory
                 23 M buffer memory
                220 M swap cache
                 99 M total swap
                 19 M used swap
                 80 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      513M    /var/
      203M    /var/cache
      197M    /var/cache/apt
      161M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.1
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.1
      javascript:
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 0
      Schönen Gruß!
      crunchipC Offline
      crunchipC Offline
      @nftvirus sagte in Probleme mit npm bei Iobroker installation:
      Fehlt da nicht eine?
      Netzwerk Probleme?
      Kenn ich so auch nicht
      Mem: 951M
      Damit lässt sich auch nur noch bedingt arbeiten, je nach Einsatzzweck
      N 1 Antwort Letzte Antwort
        Netzwerk Probleme?
        Mem: 951M
        N Offline
        N Offline
        NFTVirus
        @crunchip
        Ja wegen Arbeitsspeicher ist eng aber bisher hatte das immer alles gepasst der Iobroker soll garnicht so viel machen ein paar Zigbee Geräte steuern und per Modbus die PV Anlage überwachen. Das hat alles mti dem Pi 3B+ in der Vergangenheit gut funktioniert aber jetzt ist gerade etwas der Wurm drin.
        Wegen Verbindungsprobleme muss ich mal im Fritz Box Log schauen der PI hängt direkt am LAN.
        Danke schonmal!
        • N NFTVirus
          @crunchip
          Danke schonmal!
          N Offline
          N Offline
          NFTVirus
          @nftvirus Hat niemand mehr eine Idee woran es liegen könnte?
          • N NFTVirus
            Hallo
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           104M         20M         84M
                      907 M total memory
                      263 M used memory
                      226 M active memory
                      464 M free memory
                       23 M buffer memory
                      220 M swap cache
                       99 M total swap
                       19 M used swap
                       80 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            513M    /var/
            203M    /var/cache
            197M    /var/cache/apt
            161M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            nodejs:
              Version table:
                 18.13.0+dfsg1-1 500
            Errors in npm tree:
            ioBroker Status
              throw err;
              requireStack: []
            Node.js v18.19.1
              throw err;
              requireStack: []
            Node.js v18.19.1
            js-controller:
              throw err;
              requireStack: []
            Node.js v18.19.1
            admin:
              throw err;
              requireStack: []
            Node.js v18.19.1
            javascript:
            Adapter State
              throw err;
              requireStack: []
            Node.js v18.19.1
              throw err;
              requireStack: []
            Node.js v18.19.1
              throw err;
              requireStack: []
            Node.js v18.19.1
              throw err;
              requireStack: []
            Node.js v18.19.1
            Objects and States
            Objects:        0
            States:         0
            Pending Updates: 0
            Schönen Gruß!
            /usr/bin/npm            10.2.4
            /usr/bin/npx            10.2.4
            Alles in Ordnung mit nodejs&Co.
            Deine Installation des ioBroker hängt schief. Wie genau machst du das?
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              N Offline
              N Offline
              NFTVirus
              @thomas-braun habe ganz normal erst Bookworm per RPI Imager aufgespielt. Dann über
              curl -sLf https://iobroker.net/install.sh | bash -
              versucht den Iobroker zu installieren. Bei Punkt 3/4 iobroker installieren dauert es aber sehr lange. habe es jetzt schon mehrfach versucht immer mit den oben gezeigten Fehlermeldungen am Schluss.
              • N NFTVirus
                Laufen lassen... Mit mageren 1GB dauert es eben sehr lange.
                  N Offline
                  N Offline
                  NFTVirus
                  @thomas-braun danke. ich werde die Karte nochmal formatieren und schauen ob es dann funktioniert.
