  4. Upgrade js-controller von 4.04.24 auf 5.0.17 geht nicht
69 Beiträge 8 Kommentatoren 11.3k Aufrufe 6 Beobachtet
  • Z Zippolighter
    @glasfaser Neuer versuch. Sorry. Hoffe ist jetzt vollständig
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker-Master
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     17:07:45 up  8:57,  1 user,  load average: 0.92, 0.64, 0.54
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2024-02-09 17:07:45 CET
               Universal time: Fri 2024-02-09 16:07:45 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.1G        1.0G        108M        1.7G        2.5G
    Swap:           99M         13M         86M
    Total:         3.9G        1.1G        1.1G
             3838 M total memory
             1105 M used memory
              445 M active memory
             2161 M inactive memory
             1011 M free memory
              149 M buffer memory
             1572 M swap cache
               99 M total swap
               13 M used swap
               86 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   30G   27G  53% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G  121M  1.8G   7% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Fri Feb  9 08:09:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:18:82:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Feb  9 08:09:58 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Feb  9 08:09:58 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Feb  9 08:10:01 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    641M    /var/
    381M    /var/cache
    375M    /var/cache/apt
    316M    /var/cache/apt/archives
    92M     /var/lib
    Archived and active journals take up 119.9M in the file system.
    /opt/iobroker/backups:
    380M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    25G     /opt/iobroker/iobroker-data/history
    465M    /opt/iobroker/iobroker-data/files
    141M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    21M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
    npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-09T16_07_56_595Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.13.15
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-Master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-Master                          -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-Master                          -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker-Master                          -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker-Master                          - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker-Master                          -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-Master                          -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker-Slave                           -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker-Slave                           - disabled
    + system.adapter.harmony.0                : harmony               : iobroker-Master                          -  enabled
    + system.adapter.history.0                : history               : iobroker-Master                          -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-Master                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Master                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Master                          -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Master                          -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : ioBroker-Slave                           -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Master                          - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Master                          - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Master                          - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Master                          - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Master                          - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Master                          - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Master                          - disabled
    + system.adapter.info.0                   : info                  : iobroker-Master                          -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker-Master                          -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-Master                          -  enabled
      system.adapter.mobile.0                 : mobile                : iobroker-Master                          - disabled
      system.adapter.modbus.0                 : modbus                : iobroker-Smartmeter                      -  enabled
      system.adapter.parser.0                 : parser                : ioBroker-Slave                           - disabled
      system.adapter.parser.1                 : parser                : ioBroker-Slave                           - disabled
      system.adapter.parser.2                 : parser                : ioBroker-Slave                           -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker-Master                          -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker-Master                          -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker-Master                          -  enabled
      system.adapter.rpi2.1                   : rpi2                  : ioBroker-Slave                           -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker-Master                          -  enabled
      system.adapter.smartmeter.0             : smartmeter            : iobroker-Smartmeter                      -  enabled
      system.adapter.smartmeter.1             : smartmeter            : iobroker-Smartmeter                      -  enabled
      system.adapter.solarwetter.0            : solarwetter           : ioBroker-Slave                           -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Master                          -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker-Master                          - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Master                          - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Master                          - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Master                          - disabled
      system.adapter.vis-history.0            : vis-history           : iobroker-Master                          - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Master                          - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Master                          - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Master                          - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-Master                          - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker-Master                          - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker-Master                          - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Master                          - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Master                          - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Master                          - disabled
      system.adapter.vis.0                    : vis                   : iobroker-Master                          -  enabled
    + system.adapter.web.0                    : web                   : iobroker-Master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : iobroker-Master                          -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.15 [Updatable]
    Adapter    "alexa2"       : 3.26.4   , installed 3.23.2 [Updatable]
    Adapter    "backitup"     : 2.9.8    , installed 2.4.12 [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
    Adapter    "daswetter"    : 3.1.13   , installed 3.1.8  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
    Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
    Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
    Adapter    "parser"       : 2.1.0    , installed 2.1.0
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.1.1
    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.5
    Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Objects and States
    Objects:        23503
    States:         18201
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.33.190:2001     0.0.0.0:*               LISTEN      1001       783037     31111/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16677      634/sshd
    tcp        0      0 192.168.33.190:2010     0.0.0.0:*               LISTEN      1001       785596     31145/io.hm-rpc.2
    tcp        0      0 192.168.33.190:8701     0.0.0.0:*               LISTEN      1001       785555     31134/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       782176     30999/iobroker.js-c
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       782169     30999/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       820316     7862/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       784669     31281/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       783209     31300/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16679      634/sshd
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       785552     31213/io.harmony.0
    udp        0      0 0.0.0.0:54818           0.0.0.0:*                           108        13149      373/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       785553     31213/io.harmony.0
    udp        0      0 0.0.0.0:51240           0.0.0.0:*                           1001       1126849    31212/io.broadlink2
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      626/dhcpcd
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       784086     31212/io.broadlink2
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13147      373/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          17473      626/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13148      373/avahi-daemon: r
    udp6       0      0 :::42225                :::*                                108        13150      373/avahi-daemon: r
    2024-02-09 17:07:23.247  - info: javascript.0 (7798) script.js.Allgemein.Lichthelligkeit(1): Diele 35
    2024-02-09 17:07:23.252  - info: javascript.0 (7798) script.js.Allgemein.Präsenzmelder: Bewegung Küche an
    2024-02-09 17:08:21.522  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: eCount 1057.48
    2024-02-09 17:08:21.523  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: Jahresverbrauch 1057.48
    2024-02-09 17:08:21.523  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: eCost 243.2204
    2024-02-09 17:08:21.523  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: Zaehlerjahresendstand 61464.6134
    2024-02-09 17:08:21.524  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: Datum 09.02.2024
    2024-02-09 17:08:21.579  - info: javascript.0 (7798) script.js.Strom.Strom_EG: eCount 531.826599
    2024-02-09 17:08:21.580  - info: javascript.0 (7798) script.js.Strom.Strom_EG: eCost 122.32011777
    2024-02-09 17:08:21.580  - info: javascript.0 (7798) script.js.Strom.Strom_EG: Zaehlerjahresendstand 38344.053299
    2024-02-09 17:08:21.581  - info: javascript.0 (7798) script.js.Strom.Strom_EG: Datum 09.02.2024
    2024-02-09 17:08:21.584  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: eCount 224.6934
    2024-02-09 17:08:21.585  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: eCost 51.679482
    2024-02-09 17:08:21.585  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: Zaehlerjahresendstand 14525.5201
    2024-02-09 17:08:21.585  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: Datum 09.02.2024
    2024-02-09 17:08:49.368  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:53.320  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:53.338  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:53.353  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:53.369  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:53.466  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:53.511  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:54.314  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:54.333  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    2024-02-09 17:08:54.347  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
    iob diag has finished.
    Press any key for a summary
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @zippolighter sagte in Upgrade js-controller von 4.04.24 auf 5.0.17 geht nicht:
    Würde später auf Bookworm gehen !
    Z 1 Antwort Letzte Antwort
    • Z Zippolighter
      @Glasfaser
      Danke, ja mache ich
      @zippolighter
      Zuvor die ganzen Adapter hochziehen.
      iob update
      iob upgrade all
      Und dann mit dem aktuellen ioBroker auf ein NEU installiertes 64bit-Lite 'Bookworm' umziehen.
      • GlasfaserG Glasfaser
        Z Offline
        Z Offline
        Zippolighter
        @glasfaser
        Jepp, aber da muss erstmal dann wieder auch der Slave laufen.
        Dann wieder zuerst den Master machen und dann die Slaves??
        Ist das problematisch wenn ein Teil des Clusters dann auf Bookwoorm läuft und der Rest für ne Woche oder so noch auf Buster?? Danke
          @zippolighter
          iob update
          iob upgrade all
          Z Offline
          Z Offline
          Zippolighter
          @thomas-braun update der Adapter läuft gerade. Dauert pro Adapter ne Stunde
          • Z Zippolighter
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            ?kann nicht sein , sollte innerhalb von ein paar Minuten fertig sein !
              Z Offline
              Z Offline
              Zippolighter
              @glasfaser Nee ist so. Ich weiß auch nicht warum. Ging früher auch super schnell.
              Dachte ist weil ich so lange nicht mehr upgedatet habe.
              Deswegen bin ich ja über eine Woche dran
              • Z Zippolighter
                Z Offline
                Z Offline
                Zippolighter
                @zippolighter
                So jetzt habe ich den 217 auch gesehen. Schaue mal was wir dazu im Forum haben
                pi@iobroker-Master:/opt/iobroker $ iob upgrade self
                Update js-controller from @4.0.24 to @5.0.17
                Stopped Objects DB
                Stopped States DB
                NPM version: 10.2.3
                Installing iobroker.js-controller@5.0.17... (System call)
                host.iobroker-Master Cannot install iobroker.js-controller@5.0.17: 217
                • Z Zippolighter
                  @zippolighter
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.2.3
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  iob fix
                  • Z Offline
                    Z Offline
                    Zippolighter
                    schrieb am zuletzt editiert von Zippolighter
                    @Glasfaser
                    Erstes Packet 17 min, zweites 23 min, rpc 19 min
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.2.3
                    added 11 packages, removed 5 packages, and changed 847 packages in 17m
                    62 packages are looking for funding
                      run `npm fund` for details
                    This upgrade of "icons-mfd-png" will introduce the following changes:
                    -> 1.2.1:
                    update mfd icons (many new icons)
                    Would you like to upgrade icons-mfd-png from @1.1.0 to @1.2.1 now? [(y)es, (n)o]: y
                    Update icons-mfd-png from @1.1.0 to @1.2.1
                    NPM version: 10.2.3
                    Installing iobroker.icons-mfd-png@1.2.1... (System call)
                    removed 1 package, and changed 853 packages in 23m
                    upload [940] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_audio.png audio_audio.png image/png
                    upload [900] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_arrow_down.png control_arrow_down.png image/png
                    upload [850] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_flat_s_okg_og.png control_building_flat_s_okg_og.png image/png
                    upload [800] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_s_int_all.png control_building_s_int_all.png image/png
                    upload [750] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/edit_collapse.png edit_collapse.png image/png
                    upload [700] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_blade_s_10.png fts_blade_s_10.png image/png
                    upload [650] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_garage_door_50.png fts_garage_door_50.png image/png
                    upload [600] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_shutter_vert_blade_90.png fts_shutter_vert_blade_90.png image/png
                    upload [550] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/info_ack.png info_ack.png image/png
                    upload [500] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/light_disco_ball.png light_disco_ball.png image/png
                    upload [450] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/light_table_lamp.png light_table_lamp.png image/png
                    upload [400] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/measure_power_meter.png measure_power_meter.png image/png
                    upload [350] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/message_tendency_steady.png message_tendency_steady.png image/png
                    upload [300] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/sani_towel_rad.png sani_towel_rad.png image/png
                    upload [250] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/scene_fitness_2.png scene_fitness_2.png image/png
                    upload [200] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/scene_robo_vac_cleaner_charging.png scene_robo_vac_cleaner_charging.png image/png
                    upload [150] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/status_child_girl.png status_child_girl.png image/png
                    upload [100] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/user_available.png user_available.png image/png
                    upload [90] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/veh_car_01_charging_battery_75.png veh_car_01_charging_battery_75.png image/png
                    upload [80] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/vent_low_pressure_protection_unit.png vent_low_pressure_protection_unit.png image/png
                    upload [70] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/vent_ventilation_level_3.png vent_ventilation_level_3.png image/png
                    upload [60] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_directions_nw.png weather_directions_nw.png image/png
                    upload [50] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_humidity_abs.png weather_humidity_abs.png image/png
                    upload [40] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_moon_phases_7_half.png weather_moon_phases_7_half.png image/png
                    upload [30] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_rain_heavy.png weather_rain_heavy.png image/png
                    upload [20] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_station_quadra.png weather_station_quadra.png image/png
                    upload [19] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_storm.png weather_storm.png image/png
                    upload [18] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_summer.png weather_summer.png image/png
                    upload [17] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_sun.png weather_sun.png image/png
                    upload [16] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_sunrise.png weather_sunrise.png image/png
                    upload [15] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_sunset.png weather_sunset.png image/png
                    upload [14] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_thunderstorm.png weather_thunderstorm.png image/png
                    upload [13] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind.png weather_wind.png image/png
                    upload [12] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_e.png weather_wind_directions_e.png image/png
                    upload [11] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_n.png weather_wind_directions_n.png image/png
                    upload [10] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_ne.png weather_wind_directions_ne.png image/png
                    upload [9] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_nw.png weather_wind_directions_nw.png image/png
                    upload [8] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_s.png weather_wind_directions_s.png image/png
                    upload [7] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_se.png weather_wind_directions_se.png image/png
                    upload [6] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_sw.png weather_wind_directions_sw.png image/png
                    upload [5] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_w.png weather_wind_directions_w.png image/png
                    upload [4] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_no_wind.png weather_wind_no_wind.png image/png
                    upload [3] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_speed.png weather_wind_speed.png image/png
                    upload [2] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_speed_bft.png weather_wind_speed_bft.png image/png
                    upload [1] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_speed_ms.png weather_wind_speed_ms.png image/png
                    upload [0] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_winter.png weather_winter.png image/png
                    Update "system.adapter.icons-mfd-png.0"
                    upload [1] icons-mfd-png.admin /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin/icons-mfd-png.png icons-mfd-png.png image/png
                    upload [0] icons-mfd-png.admin /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin/index.html index.html text/html
                    This upgrade of "hm-rpc" will introduce the following changes:
                    -> 1.16.0:
                    Added support for the device manager
                    Added JSON config
                    port to adapters internal `setTimeout/setInterval` methods
                    -> 1.15.19:
                    Updated packages
                    -> 1.15.18:
                    no longer support EOL versions, please upgrade to node 16
                    -> 1.15.17:
                    added new images (closes #778, closes #873, closes #882)
                    fix wrong paramsets (closes #617, closes #584, closes #539, closes #764, closes #460, closes #748, closes #756)
                    fix wrong events (closes #872)
                    Would you like to upgrade hm-rpc from @1.15.16 to @1.16.0 now? [(y)es, (n)o]:
                    -> 1.16.0:
                    Added JSON config
                    -> 1.15.19:
                    Updated packages
                    -> 1.15.18:
                    -> 1.15.17:
                    Would you like to upgrade hm-rpc from @1.15.16 to @1.16.0 now? [(y)es, (n)o]: y
                    Update hm-rpc from @1.15.16 to @1.16.0
                    NPM version: 10.2.3
                    Installing iobroker.hm-rpc@1.16.0... (System call)
                    added 2 packages, removed 1 package, and changed 852 packages in 19m
                    Update "system.adapter.hm-rpc.0"
                    Update "system.adapter.hm-rpc.1"
                    Update "system.adapter.hm-rpc.2"
                    upload [281] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                    upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                    upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                    upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/204_hmip-drdi3_thumb.png icons/204_hmip-drdi3_thumb.png image/png
                    upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/43_hm-cc-vd_thumb.png icons/43_hm-cc-vd_thumb.png image/png
                    upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/52_hm-sec-sd-team_thumb.png icons/52_hm-sec-sd-team_thumb.png image/png
                    upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/5_hm-lc-sw2-fm_thumb.png icons/5_hm-lc-sw2-fm_thumb.png image/png
                    upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/6_hm-lc-bl1-sm_thumb.png icons/6_hm-lc-bl1-sm_thumb.png image/png
                    upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/80_hm-sen-mdir-o_thumb.png icons/80_hm-sen-mdir-o_thumb.png image/png
                    upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/88_hm-lc-sw4-ba-pcb_thumb.png icons/88_hm-lc-sw4-ba-pcb_thumb.png image/png
                    upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/9_hm-ws550-us_thumb.png icons/9_hm-ws550-us_thumb.png image/png
                    upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/OM55_DimmerSwitch_thumb.png icons/OM55_DimmerSwitch_thumb.png image/png
                    upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                    upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                    upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                    upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                    upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                    upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                    upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                    upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                    upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                    upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                    upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                    upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                    upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                    upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                    upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                    upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                    upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                    upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
                    upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
                    upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                    upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                    • Z Offline
                      Z Offline
                      Zippolighter
                      So Master ist erstmal fertig
                      Habe aber noch Problem mit den beiden Slave
                      ioBroker-Slave und iobroker-Smartmeter
                      iobroker-Smartmeter war komplett im eimer. Habe ich neuinstalliert. Allerdings bekomme ich ihn nicht mehr ins Cluster.
                      Beide Varianten versucht.
                      Bei der neuen erscheint immer
                      pi@iobroker-Smartmeter:~ $ sudo iobroker multihost browse
                      No connection to databases possible ...
                      Beide sind im selben Subnet
                      Auf dem Master habe ich es enabled. Trotzdem bleibt es im Admin unter Hosts der Smartmeter rot.
                      Danke für Eure Hilfe
                      LG Zippolighter
                      Z GlasfaserG 2 Antworten Letzte Antwort
                      • Z Zippolighter
                        LG Zippolighter
                        Z Offline
                        Z Offline
                        Zippolighter
                        @zippolighter
                        Problem gefunden falsch IP im Slave
                        • Z Zippolighter
                          @zippolighter
                          @zippolighter
                          Und
                          sudo iobroker
                          ist auch immer falsch...
                          Wo werden die Dinger eigentlich immer ausgegraben?
                          • Z Zippolighter
                            LG Zippolighter
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            Kein sudo vor iobroker Befehle !
                            Dann schmeiß mal ein
                            iob fix
                            mal rein !
                              @zippolighter
                              Und
                              sudo iobroker
                              Z Offline
                              Z Offline
                              Zippolighter
                              Hi Thomas Doku iobroker.net
                              https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                              Ab der Version des js-controller v1.1.3 wird die Einrichtung eines Multihost-Systems noch weiter vereinfacht.
                              Man gibt beim Master nur noch ein: sudo iobroker multihost enable
                              Anschließend auf dem slave: sudo iobroker multihost browse
                              Jetzt müssten vorhandene Master angezeigt werden.
                              Daraufhin wird mit sudo iobroker multihost connect der entsprechenden Master ausgewählt
                              Damit ist die Multihost-Verbindung fertig.
                              Sollte es auf diesem Wege nicht klappen, bitte weiterhin die manuelle Methode (s.o.) durchführen.
                              GlasfaserG HomoranH 3 Antworten Letzte Antwort
                              • Z Zippolighter
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                @zippolighter
                                Das ist eine nicht mehr gültige Doku ..
                                Google vergißt nicht !
                                Aktuell :
                                • Z Zippolighter
                                  HomoranH Offline
                                  HomoranH Offline
                                  @zippolighter
                                  etwas älter ;-)
                                  aber anscheinend auch noch zusammengewürfelt.
                                  im ersten Teil steht es noch richtig ohne sudo
                                  • Z Zippolighter
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    Wenn du darüber gehst ... ist Sie aber aktuell .
                                      Z Offline
                                      Z Offline
                                      Zippolighter
                                      Danke an Euch
                                      • Z Offline
                                        Z Offline
                                        Zippolighter
                                        Hallo, wollte jetzt eurer Empfehlung folgen und das OS updaten.
                                        Hier auch zuerst mit dem Master anfangen oder ist das egal??
                                        Ich bin ja noch auf jessie. Im Netz wird beschrieben von jessie auf stretch auf buster usw.
                                        Allerdings finde ich für stretch schon keine funktionierende sources.list.
                                        Habt Ihr da noch einen Tipp für mich.
                                        Vielen Dank
                                        LG Zippolighter
                                        • Z Zippolighter
                                          Vielen Dank
                                          LG Zippolighter
                                          HomoranH Offline
                                          HomoranH Offline
                                          komplett neu installieren und Backup einspielen
                                          genau!
                                          die verschwinden nach einiger Zeit. Deswegen ist zeitnahes updaten wichtig
