  4. Upgrade js-controller von 4.04.24 auf 5.0.17 geht nicht
69 Beiträge 8 Kommentatoren 11.3k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @zippolighter
    Backup machen !
    dann
    iobroker stop
    iobroker update
    iobroker upgrade self
    iobroker start
    Z Offline
    Z Offline
    Zippolighter
    @Glasfaser
    Danke, ja mache ich
    • Z Zippolighter
      @glasfaser Neuer versuch. Sorry. Hoffe ist jetzt vollständig
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker-Master
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       17:07:45 up  8:57,  1 user,  load average: 0.92, 0.64, 0.54
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-02-09 17:07:45 CET
                 Universal time: Fri 2024-02-09 16:07:45 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        1.1G        1.0G        108M        1.7G        2.5G
      Swap:           99M         13M         86M
      Total:         3.9G        1.1G        1.1G
               3838 M total memory
               1105 M used memory
                445 M active memory
               2161 M inactive memory
               1011 M free memory
                149 M buffer memory
               1572 M swap cache
                 99 M total swap
                 13 M used swap
                 86 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   30G   27G  53% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G  121M  1.8G   7% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Fri Feb  9 08:09:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:18:82:88 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=52e4cf4c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Fri Feb  9 08:09:58 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Feb  9 08:09:58 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Feb  9 08:10:01 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      641M    /var/
      381M    /var/cache
      375M    /var/cache/apt
      316M    /var/cache/apt/archives
      92M     /var/lib
      Archived and active journals take up 119.9M in the file system.
      /opt/iobroker/backups:
      380M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      25G     /opt/iobroker/iobroker-data/history
      465M    /opt/iobroker/iobroker-data/files
      141M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      21M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: xmlbuilder@0.4.2 /opt/iobroker/node_modules/xmlbuilder
      npm ERR! invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-09T16_07_56_595Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.13.15
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-Master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker-Master                          -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-Master                          -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker-Master                          -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker-Master                          - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker-Master                          -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-Master                          -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker-Slave                           -  enabled
        system.adapter.flot.0                   : flot                  : ioBroker-Slave                           - disabled
      + system.adapter.harmony.0                : harmony               : iobroker-Master                          -  enabled
      + system.adapter.history.0                : history               : iobroker-Master                          -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-Master                          -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Master                          -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Master                          -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Master                          -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : ioBroker-Slave                           -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Master                          - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Master                          - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Master                          - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Master                          - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Master                          - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Master                          - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Master                          - disabled
      + system.adapter.info.0                   : info                  : iobroker-Master                          -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker-Master                          -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-Master                          -  enabled
        system.adapter.mobile.0                 : mobile                : iobroker-Master                          - disabled
        system.adapter.modbus.0                 : modbus                : iobroker-Smartmeter                      -  enabled
        system.adapter.parser.0                 : parser                : ioBroker-Slave                           - disabled
        system.adapter.parser.1                 : parser                : ioBroker-Slave                           - disabled
        system.adapter.parser.2                 : parser                : ioBroker-Slave                           -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-Master                          -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker-Master                          -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker-Master                          -  enabled
        system.adapter.rpi2.1                   : rpi2                  : ioBroker-Slave                           -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker-Master                          -  enabled
        system.adapter.smartmeter.0             : smartmeter            : iobroker-Smartmeter                      -  enabled
        system.adapter.smartmeter.1             : smartmeter            : iobroker-Smartmeter                      -  enabled
        system.adapter.solarwetter.0            : solarwetter           : ioBroker-Slave                           -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Master                          -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker-Master                          - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Master                          - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Master                          - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Master                          - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker-Master                          - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Master                          - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Master                          - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Master                          - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-Master                          - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker-Master                          - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker-Master                          - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Master                          - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Master                          - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Master                          - disabled
        system.adapter.vis.0                    : vis                   : iobroker-Master                          -  enabled
      + system.adapter.web.0                    : web                   : iobroker-Master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.ws.0                     : ws                    : iobroker-Master                          -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      sources       : conf/sources-dist.json
      online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.15 [Updatable]
      Adapter    "alexa2"       : 3.26.4   , installed 3.23.2 [Updatable]
      Adapter    "backitup"     : 2.9.8    , installed 2.4.12 [Updatable]
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.8  [Updatable]
      Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
      Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
      Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.16 [Updatable]
      Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
      Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "parser"       : 2.1.0    , installed 2.1.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.6.0    , installed 6.6.0
      Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
      Adapter    "vis"          : 1.5.4    , installed 1.5.4
      Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.5
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        23503
      States:         18201
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.33.190:2001     0.0.0.0:*               LISTEN      1001       783037     31111/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16677      634/sshd
      tcp        0      0 192.168.33.190:2010     0.0.0.0:*               LISTEN      1001       785596     31145/io.hm-rpc.2
      tcp        0      0 192.168.33.190:8701     0.0.0.0:*               LISTEN      1001       785555     31134/io.hm-rpc.1
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       782176     30999/iobroker.js-c
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       782169     30999/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       820316     7862/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       784669     31281/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       783209     31300/io.ws.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16679      634/sshd
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       785552     31213/io.harmony.0
      udp        0      0 0.0.0.0:54818           0.0.0.0:*                           108        13149      373/avahi-daemon: r
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       785553     31213/io.harmony.0
      udp        0      0 0.0.0.0:51240           0.0.0.0:*                           1001       1126849    31212/io.broadlink2
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      626/dhcpcd
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       784086     31212/io.broadlink2
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13147      373/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          17473      626/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13148      373/avahi-daemon: r
      udp6       0      0 :::42225                :::*                                108        13150      373/avahi-daemon: r
      2024-02-09 17:07:23.247  - info: javascript.0 (7798) script.js.Allgemein.Lichthelligkeit(1): Diele 35
      2024-02-09 17:07:23.252  - info: javascript.0 (7798) script.js.Allgemein.Präsenzmelder: Bewegung Küche an
      2024-02-09 17:08:21.522  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: eCount 1057.48
      2024-02-09 17:08:21.523  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: Jahresverbrauch 1057.48
      2024-02-09 17:08:21.523  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: eCost 243.2204
      2024-02-09 17:08:21.523  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: Zaehlerjahresendstand 61464.6134
      2024-02-09 17:08:21.524  - info: javascript.0 (7798) script.js.Strom.Strom_1OG: Datum 09.02.2024
      2024-02-09 17:08:21.579  - info: javascript.0 (7798) script.js.Strom.Strom_EG: eCount 531.826599
      2024-02-09 17:08:21.580  - info: javascript.0 (7798) script.js.Strom.Strom_EG: eCost 122.32011777
      2024-02-09 17:08:21.580  - info: javascript.0 (7798) script.js.Strom.Strom_EG: Zaehlerjahresendstand 38344.053299
      2024-02-09 17:08:21.581  - info: javascript.0 (7798) script.js.Strom.Strom_EG: Datum 09.02.2024
      2024-02-09 17:08:21.584  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: eCount 224.6934
      2024-02-09 17:08:21.585  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: eCost 51.679482
      2024-02-09 17:08:21.585  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: Zaehlerjahresendstand 14525.5201
      2024-02-09 17:08:21.585  - info: javascript.0 (7798) script.js.Strom.Strom_2OG: Datum 09.02.2024
      2024-02-09 17:08:49.368  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:53.320  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:53.338  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:53.353  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:53.369  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:53.466  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:53.511  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:54.314  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:54.333  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      2024-02-09 17:08:54.347  - info: ws.0 (31300) ==> Connected system.user.admin from ::ffff:192.168.33.220
      iob diag has finished.
      Press any key for a summary
      GlasfaserG Offline
      GlasfaserG Offline
      @zippolighter sagte in Upgrade js-controller von 4.04.24 auf 5.0.17 geht nicht:
      Würde später auf Bookworm gehen !
      Z 1 Antwort Letzte Antwort
      • Z Zippolighter
        @Glasfaser
        Danke, ja mache ich
        @zippolighter
        Zuvor die ganzen Adapter hochziehen.
        iob update
        iob upgrade all
        Und dann mit dem aktuellen ioBroker auf ein NEU installiertes 64bit-Lite 'Bookworm' umziehen.
          Z Offline
          Z Offline
          Zippolighter
          @glasfaser
          Jepp, aber da muss erstmal dann wieder auch der Slave laufen.
          Dann wieder zuerst den Master machen und dann die Slaves??
          Ist das problematisch wenn ein Teil des Clusters dann auf Bookwoorm läuft und der Rest für ne Woche oder so noch auf Buster?? Danke
            @zippolighter
            iob update
            iob upgrade all
            Z Offline
            Z Offline
            Zippolighter
            @thomas-braun update der Adapter läuft gerade. Dauert pro Adapter ne Stunde
            • Z Zippolighter
              GlasfaserG Offline
              GlasfaserG Offline
              ?kann nicht sein , sollte innerhalb von ein paar Minuten fertig sein !
                Z Offline
                Z Offline
                Zippolighter
                @glasfaser Nee ist so. Ich weiß auch nicht warum. Ging früher auch super schnell.
                Dachte ist weil ich so lange nicht mehr upgedatet habe.
                Deswegen bin ich ja über eine Woche dran
                • Z Zippolighter
                  Z Offline
                  Z Offline
                  Zippolighter
                  @zippolighter
                  So jetzt habe ich den 217 auch gesehen. Schaue mal was wir dazu im Forum haben
                  pi@iobroker-Master:/opt/iobroker $ iob upgrade self
                  Update js-controller from @4.0.24 to @5.0.17
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 10.2.3
                  Installing iobroker.js-controller@5.0.17... (System call)
                  host.iobroker-Master Cannot install iobroker.js-controller@5.0.17: 217
                  • Z Zippolighter
                    @zippolighter
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 10.2.3
                    GlasfaserG Offline
                    GlasfaserG Offline
                    iob fix
                    • Z Offline
                      Z Offline
                      Zippolighter
                      schrieb am zuletzt editiert von Zippolighter
                      @Glasfaser
                      Erstes Packet 17 min, zweites 23 min, rpc 19 min
                      Stopped Objects DB
                      Stopped States DB
                      NPM version: 10.2.3
                      added 11 packages, removed 5 packages, and changed 847 packages in 17m
                      62 packages are looking for funding
                        run `npm fund` for details
                      This upgrade of "icons-mfd-png" will introduce the following changes:
                      -> 1.2.1:
                      update mfd icons (many new icons)
                      Would you like to upgrade icons-mfd-png from @1.1.0 to @1.2.1 now? [(y)es, (n)o]: y
                      Update icons-mfd-png from @1.1.0 to @1.2.1
                      NPM version: 10.2.3
                      Installing iobroker.icons-mfd-png@1.2.1... (System call)
                      removed 1 package, and changed 853 packages in 23m
                      upload [940] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/audio_audio.png audio_audio.png image/png
                      upload [900] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_arrow_down.png control_arrow_down.png image/png
                      upload [850] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_flat_s_okg_og.png control_building_flat_s_okg_og.png image/png
                      upload [800] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/control_building_s_int_all.png control_building_s_int_all.png image/png
                      upload [750] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/edit_collapse.png edit_collapse.png image/png
                      upload [700] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_blade_s_10.png fts_blade_s_10.png image/png
                      upload [650] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_garage_door_50.png fts_garage_door_50.png image/png
                      upload [600] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/fts_shutter_vert_blade_90.png fts_shutter_vert_blade_90.png image/png
                      upload [550] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/info_ack.png info_ack.png image/png
                      upload [500] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/light_disco_ball.png light_disco_ball.png image/png
                      upload [450] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/light_table_lamp.png light_table_lamp.png image/png
                      upload [400] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/measure_power_meter.png measure_power_meter.png image/png
                      upload [350] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/message_tendency_steady.png message_tendency_steady.png image/png
                      upload [300] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/sani_towel_rad.png sani_towel_rad.png image/png
                      upload [250] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/scene_fitness_2.png scene_fitness_2.png image/png
                      upload [200] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/scene_robo_vac_cleaner_charging.png scene_robo_vac_cleaner_charging.png image/png
                      upload [150] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/status_child_girl.png status_child_girl.png image/png
                      upload [100] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/user_available.png user_available.png image/png
                      upload [90] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/veh_car_01_charging_battery_75.png veh_car_01_charging_battery_75.png image/png
                      upload [80] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/vent_low_pressure_protection_unit.png vent_low_pressure_protection_unit.png image/png
                      upload [70] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/vent_ventilation_level_3.png vent_ventilation_level_3.png image/png
                      upload [60] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_directions_nw.png weather_directions_nw.png image/png
                      upload [50] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_humidity_abs.png weather_humidity_abs.png image/png
                      upload [40] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_moon_phases_7_half.png weather_moon_phases_7_half.png image/png
                      upload [30] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_rain_heavy.png weather_rain_heavy.png image/png
                      upload [20] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_station_quadra.png weather_station_quadra.png image/png
                      upload [19] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_storm.png weather_storm.png image/png
                      upload [18] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_summer.png weather_summer.png image/png
                      upload [17] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_sun.png weather_sun.png image/png
                      upload [16] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_sunrise.png weather_sunrise.png image/png
                      upload [15] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_sunset.png weather_sunset.png image/png
                      upload [14] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_thunderstorm.png weather_thunderstorm.png image/png
                      upload [13] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind.png weather_wind.png image/png
                      upload [12] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_e.png weather_wind_directions_e.png image/png
                      upload [11] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_n.png weather_wind_directions_n.png image/png
                      upload [10] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_ne.png weather_wind_directions_ne.png image/png
                      upload [9] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_nw.png weather_wind_directions_nw.png image/png
                      upload [8] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_s.png weather_wind_directions_s.png image/png
                      upload [7] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_se.png weather_wind_directions_se.png image/png
                      upload [6] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_sw.png weather_wind_directions_sw.png image/png
                      upload [5] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_directions_w.png weather_wind_directions_w.png image/png
                      upload [4] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_no_wind.png weather_wind_no_wind.png image/png
                      upload [3] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_speed.png weather_wind_speed.png image/png
                      upload [2] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_speed_bft.png weather_wind_speed_bft.png image/png
                      upload [1] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_wind_speed_ms.png weather_wind_speed_ms.png image/png
                      upload [0] icons-mfd-png /opt/iobroker/node_modules/iobroker.icons-mfd-png/www/weather_winter.png weather_winter.png image/png
                      Update "system.adapter.icons-mfd-png.0"
                      upload [1] icons-mfd-png.admin /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin/icons-mfd-png.png icons-mfd-png.png image/png
                      upload [0] icons-mfd-png.admin /opt/iobroker/node_modules/iobroker.icons-mfd-png/admin/index.html index.html text/html
                      This upgrade of "hm-rpc" will introduce the following changes:
                      -> 1.16.0:
                      Added support for the device manager
                      Added JSON config
                      port to adapters internal `setTimeout/setInterval` methods
                      -> 1.15.19:
                      Updated packages
                      -> 1.15.18:
                      no longer support EOL versions, please upgrade to node 16
                      -> 1.15.17:
                      added new images (closes #778, closes #873, closes #882)
                      fix wrong paramsets (closes #617, closes #584, closes #539, closes #764, closes #460, closes #748, closes #756)
                      fix wrong events (closes #872)
                      Would you like to upgrade hm-rpc from @1.15.16 to @1.16.0 now? [(y)es, (n)o]:
                      -> 1.16.0:
                      Added JSON config
                      -> 1.15.19:
                      Updated packages
                      -> 1.15.18:
                      -> 1.15.17:
                      Would you like to upgrade hm-rpc from @1.15.16 to @1.16.0 now? [(y)es, (n)o]: y
                      Update hm-rpc from @1.15.16 to @1.16.0
                      NPM version: 10.2.3
                      Installing iobroker.hm-rpc@1.16.0... (System call)
                      added 2 packages, removed 1 package, and changed 852 packages in 19m
                      Update "system.adapter.hm-rpc.0"
                      Update "system.adapter.hm-rpc.1"
                      Update "system.adapter.hm-rpc.2"
                      upload [281] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
                      upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/113_hmip-psm_thumb.png icons/113_hmip-psm_thumb.png image/png
                      upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/159_hmip-mod-rc8_thumb.png icons/159_hmip-mod-rc8_thumb.png image/png
                      upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/204_hmip-drdi3_thumb.png icons/204_hmip-drdi3_thumb.png image/png
                      upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/43_hm-cc-vd_thumb.png icons/43_hm-cc-vd_thumb.png image/png
                      upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/52_hm-sec-sd-team_thumb.png icons/52_hm-sec-sd-team_thumb.png image/png
                      upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/5_hm-lc-sw2-fm_thumb.png icons/5_hm-lc-sw2-fm_thumb.png image/png
                      upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/6_hm-lc-bl1-sm_thumb.png icons/6_hm-lc-bl1-sm_thumb.png image/png
                      upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/80_hm-sen-mdir-o_thumb.png icons/80_hm-sen-mdir-o_thumb.png image/png
                      upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/88_hm-lc-sw4-ba-pcb_thumb.png icons/88_hm-lc-sw4-ba-pcb_thumb.png image/png
                      upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/9_hm-ws550-us_thumb.png icons/9_hm-ws550-us_thumb.png image/png
                      upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/OM55_DimmerSwitch_thumb.png icons/OM55_DimmerSwitch_thumb.png image/png
                      upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
                      upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
                      upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
                      upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
                      upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
                      upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
                      upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
                      upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
                      upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
                      upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
                      upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
                      upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
                      upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
                      upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
                      upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
                      upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
                      upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
                      upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
                      upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
                      upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/jsonConfig.json jsonConfig.json application/json
                      upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
                      • Z Offline
                        Z Offline
                        Zippolighter
                        So Master ist erstmal fertig
                        Habe aber noch Problem mit den beiden Slave
                        ioBroker-Slave und iobroker-Smartmeter
                        iobroker-Smartmeter war komplett im eimer. Habe ich neuinstalliert. Allerdings bekomme ich ihn nicht mehr ins Cluster.
                        Beide Varianten versucht.
                        Bei der neuen erscheint immer
                        pi@iobroker-Smartmeter:~ $ sudo iobroker multihost browse
                        No connection to databases possible ...
                        Beide sind im selben Subnet
                        Auf dem Master habe ich es enabled. Trotzdem bleibt es im Admin unter Hosts der Smartmeter rot.
                        Danke für Eure Hilfe
                        LG Zippolighter
                        Z GlasfaserG 2 Antworten Letzte Antwort
                        • Z Zippolighter
                          LG Zippolighter
                          Z Offline
                          Z Offline
                          Zippolighter
                          @zippolighter
                          Problem gefunden falsch IP im Slave
                          • Z Zippolighter
                            @zippolighter
                            @zippolighter
                            Und
                            sudo iobroker
                            ist auch immer falsch...
                            Wo werden die Dinger eigentlich immer ausgegraben?
                            • Z Zippolighter
                              LG Zippolighter
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Kein sudo vor iobroker Befehle !
                              Dann schmeiß mal ein
                              iob fix
                              mal rein !
                                @zippolighter
                                Und
                                sudo iobroker
                                Z Offline
                                Z Offline
                                Zippolighter
                                Hi Thomas Doku iobroker.net
                                https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                                Ab der Version des js-controller v1.1.3 wird die Einrichtung eines Multihost-Systems noch weiter vereinfacht.
                                Man gibt beim Master nur noch ein: sudo iobroker multihost enable
                                Anschließend auf dem slave: sudo iobroker multihost browse
                                Jetzt müssten vorhandene Master angezeigt werden.
                                Daraufhin wird mit sudo iobroker multihost connect der entsprechenden Master ausgewählt
                                Damit ist die Multihost-Verbindung fertig.
                                Sollte es auf diesem Wege nicht klappen, bitte weiterhin die manuelle Methode (s.o.) durchführen.
                                GlasfaserG HomoranH 3 Antworten Letzte Antwort
                                • Z Zippolighter
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @zippolighter
                                  Das ist eine nicht mehr gültige Doku ..
                                  Google vergißt nicht !
                                  Aktuell :
                                  • Z Zippolighter
                                    HomoranH Offline
                                    HomoranH Offline
                                    @zippolighter
                                    etwas älter ;-)
                                    aber anscheinend auch noch zusammengewürfelt.
                                    im ersten Teil steht es noch richtig ohne sudo
                                    • Z Zippolighter
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Wenn du darüber gehst ... ist Sie aber aktuell .
                                        Z Offline
                                        Z Offline
                                        Zippolighter
                                        Danke an Euch
                                        • Z Offline
                                          Z Offline
                                          Zippolighter
                                          Hallo, wollte jetzt eurer Empfehlung folgen und das OS updaten.
                                          Hier auch zuerst mit dem Master anfangen oder ist das egal??
                                          Ich bin ja noch auf jessie. Im Netz wird beschrieben von jessie auf stretch auf buster usw.
                                          Allerdings finde ich für stretch schon keine funktionierende sources.list.
                                          Habt Ihr da noch einen Tipp für mich.
                                          Vielen Dank
                                          LG Zippolighter
