  4. Admin Seite nach Update auf 6.13.15 nicht erreichbar
32 Beiträge 4 Kommentatoren 3.2k Aufrufe 2 Beobachtet
  • Marc_el_KM Marc_el_K
    @thomas-braun Den nutze ich glaube ich gar nicht mehr...
    @marc_el_k
    Dann schmeiß den Krempel raus, macht der auch keine Zicken mehr.
    iob del iobroker.ham
    Marc_el_KM 1 Antwort Letzte Antwort
      @marc_el_k
      Marc_el_KM Offline
      Marc_el_KM Offline
      Marc_el_K
      iob start admin.0
      hat nun geholfen
        iob start admin.0
        hat nun geholfen
        @marc_el_k
        Dan zeig jetzt noch mal
        iob diag
          @marc_el_k
          iob diag
          Marc_el_KM Offline
          Marc_el_KM Offline
          Marc_el_K
          ======== Start marking the full check here =========
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : armhf
          Systemuptime and Load:
           22:01:32 up 12 min,  1 user,  load average: 1.75, 2.35, 1.75
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Fri 2024-02-02 22:01:32 CET
                     Universal time: Fri 2024-02-02 21:01:32 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        1.9G        5.1G        0.0K        762M        5.8G
          Swap:            99M          0B         99M
          Total:          7.9G        1.9G        5.2G
                   7812 M total memory
                   1923 M used memory
                   1967 M active memory
                    492 M inactive memory
                   5126 M free memory
                    159 M buffer memory
                    603 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          lifetime oom required: 0 Mbytes
          total time in oom handler: 0 ms
          max time spent in oom handler: 0 ms
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      117G   19G   94G  17% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  880K  1.6G   1% /run
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          /dev/sda1      vfat      233G   30G  204G  13% /media/usb
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Fri Feb  2 21:48:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  #console=ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Fri Feb  2 21:49:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Feb  2 21:49:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri Feb  2 21:49:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems \(real ones only\):
          TARGET       SOURCE         FSTYPE OPTIONS
          /            /dev/mmcblk0p2 ext4   rw,noatime
          |-/boot      /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          `-/media/usb /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,sync,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          5.2G    /var/
          2.7G    /var/cache/apt
          2.7G    /var/cache
          2.6G    /var/cache/apt/archives
          2.4G    /var/log
          Archived and active journals take up 2.2G in the file system.
          /opt/iobroker/backups:
          1.6G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          804M    /opt/iobroker/iobroker-data/
          493M    /opt/iobroker/iobroker-data/files
          234M    /opt/iobroker/iobroker-data/backup-objects
          89M     /opt/iobroker/iobroker-data/files/echarts.admin
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          28M     /opt/iobroker/iobroker-data/objects.jsonl
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          USB-Devices by-id:
          USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
          npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
          npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
          npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
          npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
          npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
          npm ERR! extraneous: undici-types@5.26.5 /opt/iobroker/node_modules/undici-types
          npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
          npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
          npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
          npm ERR! missing: homebridge-camera-ffmpeg@^3.1.4, required by iobroker.ham@5.3.1
          npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
          npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
          npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T21_01_41_174Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.15
          javascript:     7.1.6
          Adapters from github:   6
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.ble.1                    : ble                   : raspberrypi                              -  enabled
          + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
          + system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
          + system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
            system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.76
          + system.adapter.nut.0                    : nut                   : raspberrypi                              -  enabled
            system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
          + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
            system.adapter.paw.0                    : paw                   : raspberrypi                              - disabled, port: 8898
            system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
          + system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi                              -  enabled
            system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
          + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
          + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
          + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Installed ioBroker-Instances
          Adapter    "admin"        : 6.13.15  , installed 6.13.15
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "deconz"       : 1.3.23   , installed 1.3.23
          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "firetv"       : 2.0.2    , installed 2.0.2
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
          Adapter    "ical"         : 1.13.3   , installed 1.13.3
          Adapter    "info"         : 2.0.0    , installed 2.0.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "parser"       : 2.1.0    , installed 2.1.0
          Adapter    "paw"          : 0.3.2    , installed 0.3.2
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
          Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "tado"         : 0.5.1    , installed 0.5.1
          Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
          Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
          Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
          Adapter    "vis"          : 1.5.4    , installed 1.5.4
          Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "yahoo-stock-market": 0.0.5, installed 0.0.5
          Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
          Objects and States
          Objects:        28595
          States:         23209
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       17356      1570/io.sonoff.0
          tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16890      1228/upsd
          tcp        0      0 192.168.178.76:1883     0.0.0.0:*               LISTEN      1001       19791      1481/io.mqtt.0
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16545      532/iobroker.js-con
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       12052      532/iobroker.js-con
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       30133      3868/io.jarvis.0
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11903      410/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11882      582/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14984      410/deCONZ
          tcp        0      0 192.168.178.76:3493     0.0.0.0:*               LISTEN      0          16889      1228/upsd
          tcp6       0      0 :::1984                 :::*                    LISTEN      1000       14955      413/go2rtc_linux_ar
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11884      582/sshd: /usr/sbin
          tcp6       0      0 :::8555                 :::*                    LISTEN      1000       15626      413/go2rtc_linux_ar
          tcp6       0      0 :::8554                 :::*                    LISTEN      1000       15623      413/go2rtc_linux_ar
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23642      2151/io.simple-api.
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20110      1796/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       52561      9084/io.admin.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23029      2890/io.wled.0
          udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       16344      1090/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2008       404/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16333      1198/io.shelly.0
          udp        0      0 0.0.0.0:46853           0.0.0.0:*                           108        2010       404/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22369      2126/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16505      410/deCONZ
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18978      1280/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18979      1280/io.tuya.0
          udp        0      0 0.0.0.0:36575           0.0.0.0:*                           1001       21943      2126/io.upnp.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16508      820/dhcpcd
          udp6       0      0 :::546                  :::*                                0          65344      820/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        2009       404/avahi-daemon: r
          udp6       0      0 :::42682                :::*                                108        2011       404/avahi-daemon: r
          2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
          2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
          2024-02-02 22:03:00.023  - warn: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
          2024-02-02 22:03:00.025  - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring')
          2024-02-02 22:03:00.026  - error: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50)
          2024-02-02 22:03:00.026  - error: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
          2024-02-02 22:03:00.026  - error: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
          2024-02-02 22:03:00.027  - error: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2024-02-02 22:03:00.039  - error: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
          2024-02-02 22:03:00.040  - error: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
          2024-02-02 22:03:00.465  - warn: javascript.0 (985) getState "alexa2.0.Echo-Devices.G0911M09951329SR.Info.macAddress" not found (3)
          2024-02-02 22:03:00.466  - warn: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:24)
          2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
          2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
          2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
          2024-02-02 22:03:00.468  - warn: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
          2024-02-02 22:03:00.469  - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring')
          2024-02-02 22:03:00.470  - error: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50)
          2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
          2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
          2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
          2024-02-02 22:03:00.471  - error: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7812 M total memory
                     1923 M used memory
                     5126 M free memory
                      159 M buffer memory
                      603 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            5.2G    /var/
            2.7G    /var/cache/apt
            2.7G    /var/cache
            2.4G    /var/log
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.13.15
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        28595
            States:         23209
            Pending Updates: 0
            da sind noch
            @marc_el_k sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
            ELSPROBLEMS
            und Probleme mit der fremden Frau im Haus
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : armhf
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7812 M total memory
                       1923 M used memory
                       5126 M free memory
                        159 M buffer memory
                        603 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              5.2G    /var/
              2.7G    /var/cache/apt
              2.7G    /var/cache
              2.4G    /var/log
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.13.15
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        28595
              States:         23209
              Pending Updates: 0
              Kernel : aarch64
              Userland : armhf
              Stell das in den nächsten Monaten auf eine reines 64Bit-System um. Geht aber nur per Neuinstallation (Dann halt direkt Raspberry OS 12 installieren).
              Boot Target: graphical.target
              Setz das auf
              sudo systemctl set-default multi-user.target
              Hattest du den ham-Adapter nicht rausgeworfen?
              Der zickt aber noch herum.
                da sind noch
                ELSPROBLEMS
                Marc_el_KM Offline
                Marc_el_KM Offline
                Marc_el_K
                @homoran sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
                da sind noch
                ELSPROBLEMS
                Was heißt das?
                  da sind noch
                  ELSPROBLEMS
                  Was heißt das?
                  da sind noch
                  ELSPROBLEMS
                  Was heißt das?
                  deine Alexa gat wohl die IP gewechselt
                    da sind noch
                    ELSPROBLEMS
                    Was heißt das?
                    @marc_el_k
                    Im Skript Netzwerk_Geräte.JSON_mit_Links sind Fehler enthalten.
                    • Marc_el_KM Offline
                      Marc_el_KM Offline
                      Marc_el_K
                      @thomas-braun sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
                      Setz das auf
                      Hab ich gesetzt.
                      Den HAM Adapter habe ich nicht entfernt, da ich ihn noch nutze.
                        Setz das auf
                        Hab ich gesetzt.
                        Dann schau dir die angemeckerten Module an. Irgendwas klemmt da.
                          Kernel : aarch64
                          Userland : armhf
                          Setz das auf
                          Marc_el_KM Offline
                          Marc_el_KM Offline
                          Marc_el_K
                          Das ist mir gar nicht bewusst gewesen. Danke für den Hinweis. Zu blöd, dass ich dafür ne Neuinstallation brauche. Ich habe auf meinem Raspberry weitere Dinge eingerichtet, wo ich nicht mal mehr weiß ob ich die Anleitungen noch finde 🫣
                          PS: den ham Adapter habe jetzt deinstalliert.
