  4. YAKAH startet nicht nach js-controller upgrade auf 5.x.x
22 Beiträge 5 Kommentatoren 4.6k Aufrufe 5 Beobachtet
  • lehmann-makerL Offline
    lehmann-maker
    nach einem notwendigen upgrade des js-controllers von 4.x.x zu beliebiger Version 5.x.x funktioniert eine meiner YAKAH Instanzen nicht mehr bzw. fährt nicht mehr hoch. Ich benötige das upgrade um mit vis-2 zu arbeiten. Anbei ein Fehlerauszug aus dem Log. Habt ihr Ideen zur Lösung? Vielen Dank.
    host.NAS
    2024-01-27 10:41:31.525	warn	Do not restart adapter system.adapter.yahka.0 because restart loop detected
    host.NAS
    2024-01-27 10:41:31.525	info	Restart adapter system.adapter.yahka.0 because enabled
    host.NAS
    2024-01-27 10:41:31.524	error	instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.NAS
    2024-01-27 10:41:31.524	error	Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.524	error	Caught by controller[14]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.524	error	Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.524	error	Caught by controller[12]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.523	error	Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.523	error	Caught by controller[10]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.523	error	Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.523	error	Caught by controller[8]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.523	error	Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.522	error	Caught by controller[6]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.522	error	Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.522	error	Caught by controller[4]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
    host.NAS
    2024-01-27 10:41:31.522	error	Caught by controller[3]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
    host.NAS
    2024-01-27 10:41:31.522	error	Caught by controller[2]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
    host.NAS
    2024-01-27 10:41:31.521	error	Caught by controller[1]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
    host.NAS
    2024-01-27 10:41:31.521	error	Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
    yahka.0
    2024-01-27 10:41:30.949	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    yahka.0
    2024-01-27 10:41:30.948	info	terminating
    yahka.0
    2024-01-27 10:41:30.947	info	cleaned up ...
    yahka.0
    2024-01-27 10:41:30.947	info	cleaning up ...
    yahka.0
    2024-01-27 10:41:30.896	error	Error The pattern "[object Object]" is not a valid ID pattern
    yahka.0
    2024-01-27 10:41:30.895	error	ReplyError: Error The pattern "[object Object]" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    yahka.0
    2024-01-27 10:41:30.893	error	unhandled promise rejection: Error The pattern "[object Object]" is not a valid ID pattern
    yahka.0
    2024-01-27 10:41:30.893	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
    • lehmann-makerL lehmann-maker
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      host.NAS
      yahka.0
      yahka.0
      yahka.0
      yahka.0
      yahka.0
      yahka.0
      yahka.0
      yahka.0
      @lehmann-maker
      Zeig mal wie und wo du da nun unterwegs bist.
      iob diag
      lehmann-makerL 1 Antwort Letzte Antwort
        @lehmann-maker
        iob diag
        lehmann-maker
        @thomas-braun Danke für deine Antwort. Bin gerade unterwegs, daher hier nur Screenshots vom iPhone aus.IMG_2370.png IMG_2369.png
          @lehmann-maker
          Dan poste es später richtig. Mit Screenshots kann keiner was anfangen.
            @lehmann-maker
            lehmann-maker
            @thomas-braun Guten Morgen, anbei das copy/paste. Befürchte aber, dass das weniger übersichtlich ist :(
            Skript v.2023-10-10
            107*** BASE SYSTEM
            cat:
            /sys/devices/virtual/dmi/id/sys_vendor:
            No such file or directory
            Hardware Vendor :
            Kernel	: x86 64
            Userland	: ama64
            Docker	: 18.0.1
            Virtualization	: Docker
            Kernel	: x86 64
            Userland	: amd64
            Systemuptime and Load:
            15:18:47 up
            5:47,
            o users,
            average: 1.52,
            1.61, 1.52
            CPU
            threads: 4
            load
            107*** Time and Time Zones
            Sat Jan 27 14:18:47 UTC 2024
            Sat Jan 27 15:18:47 CET
            2024
            CET
            +0100
            Etc /UTC
            107*** User and
            Groups
            iobroker
            /opt/iobroker
            iobroker tty dialout audio video
            107*** X-Server-Setup
            *火*
            X-Server:
            false
            Desktop:
            Terminal:
            107*** MEMORY ***
            total available
            Mem:
            15G
            10G
            Swap:
            24M
            Total:
            46G
            used
            5.1G
            9.7G
            30G
            5. 1G
            free
            309M
            shared
            buff/cache
            497M
            31G
            31G
            15856	M total memory
            5074	M used memory
            1491	M active memory
            12379	M inactive memory
            107***FILESYSTEM ***
            Filesystem
            Size
            Used
            Type
            • Avail Use: Mounted
            overlay
            overlay
            36G
            338G
            10% 1
            tmpfs
            64M
            64M
            0%
            tmpfs
            /dev
            tmpfs
            tmpfs
            7.8G
            7.8G
            0%
            /sys/fs/cgroup
            shm
            tmpfs
            64M
            64M
            0% / dev/shm
            / dev/mapper/cachedev] ext
            36G
            338G
            10% / opt/iobroker
            tmpfs
            tmpfs
            7. 8G
            7. 8G
            /proc/asound tmpfs
            tmpfs
            7. 8G
            7.8G
            0%
            /proc/acpi tmpfs
            tmpfs
            7.8G
            7.8G
            0%
            /proc/scsi tmpfs
            tmpfs
            7.8G
            7.8G
            0%
            /sys/firmware
            374G
            374G
            Messages concerning ext filesystem in dmesg:
              Skript v.2023-10-10
              107*** BASE SYSTEM
              cat:
              Hardware Vendor :
              Kernel	: x86 64
              Userland	: ama64
              Docker	: 18.0.1
              Kernel	: x86 64
              Userland	: amd64
              15:18:47 up
              5:47,
              o users,
              average: 1.52,
              1.61, 1.52
              CPU
              threads: 4
              load
              2024
              CET
              +0100
              Etc /UTC
              107*** User and
              Groups
              iobroker
              /opt/iobroker
              *火*
              X-Server:
              false
              Desktop:
              Terminal:
              107*** MEMORY ***
              total available
              Mem:
              15G
              10G
              Swap:
              24M
              Total:
              46G
              used
              5.1G
              9.7G
              30G
              5. 1G
              free
              309M
              shared
              buff/cache
              497M
              31G
              31G
              5074	M used memory
              Filesystem
              Size
              Used
              Type
              overlay
              overlay
              36G
              338G
              10% 1
              tmpfs
              64M
              64M
              0%
              tmpfs
              /dev
              tmpfs
              tmpfs
              7.8G
              7.8G
              0%
              /sys/fs/cgroup
              shm
              tmpfs
              64M
              64M
              0% / dev/shm
              36G
              338G
              10% / opt/iobroker
              tmpfs
              tmpfs
              7. 8G
              7. 8G
              /proc/asound tmpfs
              tmpfs
              7. 8G
              7.8G
              0%
              /proc/acpi tmpfs
              tmpfs
              7.8G
              7.8G
              0%
              /proc/scsi tmpfs
              tmpfs
              7.8G
              7.8G
              0%
              /sys/firmware
              374G
              374G
              @lehmann-maker
              Vor allem Dingen ist es nicht vollständig.
              Nochmal...
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                host.NAS
                yahka.0
                yahka.0
                yahka.0
                yahka.0
                yahka.0
                yahka.0
                yahka.0
                yahka.0
                mcm1957M Online
                mcm1957M Online
                mcm1957
                @lehmann-maker
                Und bitte noch zwei Dinge:
                Bitte gib bei Problemmeldungen IMMER die betroffenen versionen von Adapter, js-controller, admin und node an.
                Und wenn du ein passendes Issue findest oder eh selbst eines erstellst, verlink es bitte hier:
                https://github.com/jensweigele/ioBroker.yahka/issues/461
                Auch in deinem Issue fehlen die wichtigen Versionsngaben. Keiner weiß ob du nicht ev. nur mit einer älteren Adapterversion die nicht js-controller 5 fähig ist unterwegs bist.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • mcm1957M mcm1957
                  @lehmann-maker
                  lehmann-maker
                  @mcm57 @Thomas-Braun Nächster Versuch, danke für eure Geduld mit mir. In der Diagnose erscheint, dass node.js nicht korrekt installiert sei... Details unten in summary und Komplettdiagnose. Danke nochmals für eure Hilfe. Zu den Versionen:
                  ioBroker Dockerfile buanet
                  YAKAH v. 1.0.3
                  admin v. 6.13.3
                  npm v. 10.4.0
                  Nde.js v. 18.17.1
                  js-controller v. 5.0.17
                  Summary:
                  ====================== SUMMARY =======================
                                          v.2023-10-10
                  model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                  Kernel          : x86_64
                  Userland        : amd64
                  Docker          : v8.0.1
                  Installation:           Docker
                  Kernel:                 x86_64
                  Userland:               amd64
                  Timezone:               Etc/UTC
                  User-ID:                0
                  X-Server:               false
                  Pending OS-Updates:     47
                  Pending iob updates:    10
                  /home/iobroker/.diag.sh: line 486: nodejs: command not found
                  Nodejs-Installation:
                                          /usr/bin/node           v18.17.1
                                          /usr/bin/npm            10.4.0
                                          /usr/bin/npx            10.4.0
                                          /usr/bin/corepack       0.24.1
                  Recommended versions are nodejs 18.19.0 and npm 10.2.3
                  *** nodejs is NOT correctly installed ***
                  Wrong installation path detected. This needs to be fixed.
                  Please check
                  for more information on how to fix these errors.
                  MEMORY:
                  Mem:             15G        6.1G        525M        489M        9.3G        8.7G
                  Swap:            31G         47M         30G
                  Total:           46G        6.1G         31G
                  Active iob-Instances:   5
                  Active repo(s): beta
                  ioBroker Core:          js-controller           5.0.17
                                          admin                   6.13.3
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : NAS                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.web.0                    : web                   : NAS                                      -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
                  Objects:                4412
                  States:                 3279
                  Size of iob-Database:
                  21M     /opt/iobroker/iobroker-data/objects.jsonl
                  3.0M    /opt/iobroker/iobroker-data/states.jsonl
                  Diagnose
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                  cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
                  Hardware Vendor :
                  Kernel          : x86_64
                  Userland        : amd64
                  Docker          : v8.0.1
                  Kernel          : x86_64
                  Userland        : amd64
                   17:48:35 up 1 day,  8:17,  0 users,  load average: 5.18, 3.47, 2.54
                  CPU threads: 4
                  *** Time and Time Zones ***
                  Sun Jan 28 16:48:35 UTC 2024
                  Sun Jan 28 17:48:35 CET 2024
                  CET +0100
                  Etc/UTC
                  *** User and Groups ***
                  root
                  /root
                  root
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:             15G        6.0G        319M        487M        9.5G        8.7G
                  Swap:            31G         49M         30G
                  Total:           46G        6.1G         31G
                           6040 M used memory
                           2327 M active memory
                          11419 M inactive memory
                            318 M free memory
                           1409 M buffer memory
                           8088 M swap cache
                          31016 M total swap
                             49 M used swap
                          30967 M free swap
                  *** FILESYSTEM ***
                  Filesystem            Type     Size  Used Avail Use% Mounted on
                  overlay               overlay  374G   36G  338G  10% /
                  tmpfs                 tmpfs     64M     0   64M   0% /dev
                  tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
                  shm                   tmpfs     64M     0   64M   0% /dev/shm
                  /dev/mapper/cachedev1 ext4     374G   36G  338G  10% /opt/iobroker
                  tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
                  tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
                  tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
                  tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
                  dmesg: read kernel buffer failed: Operation not permitted
                  Show mounted filesystems \(real ones only\):
                  TARGET           SOURCE        FSTYPE OPTIONS
                  /opt/iobroker    /dev/mapper/cachedev1[/Public/Docker/iobroker-test]        ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                  /etc/resolv.conf /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/3306d90610d61ab1525e3fc80e70ec7520a08b9e51a3e15d97c56c97af4e6a3d/resolv.conf] ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                  /etc/hostname    /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/3306d90610d61ab1525e3fc80e70ec7520a08b9e51a3e15d97c56c97af4e6a3d/hostname]    ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                  /etc/hosts       /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/3306d90610d61ab1525e3fc80e70ec7520a08b9e51a3e15d97c56c97af4e6a3d/hosts]       ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                  /var:
                  33M     /var/
                  31M     /var/lib
                  18M     /var/lib/apt/lists
                  18M     /var/lib/apt
                  13M     /var/lib/dpkg
                  /opt/iobroker/backups:
                  85M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  390M    /opt/iobroker/iobroker-data/
                  298M    /opt/iobroker/iobroker-data/files
                  125M    /opt/iobroker/iobroker-data/files/vis-2
                  76M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                  33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                  22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                  19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.55ce10c1.js.map
                  17M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.a5a94c49.js.map
                  USB-Devices by-id:
                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                  find: '/dev/serial/by-id/': No such file or directory
                  *** NodeJS-Installation ***
                  /home/iobroker/.diag.sh: line 277: nodejs: command not found
                  /usr/bin/npm            10.4.0
                  /usr/bin/npx            10.4.0
                  /home/iobroker/.diag.sh: line 288: nodejs: command not found
                  nodejs:
                    Installed: 18.17.1-deb-1nodesource1
                    Candidate: 18.17.1-deb-1nodesource1
                    Version table:
                   *** 18.17.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                          100 /var/lib/dpkg/status
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main amd64 Packages
                          500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  5.0.17
                  admin:          6.13.3
                  javascript:     7.5.1
                  Adapters from github:   0
                  Adapter State
                    system.adapter.alexa2.0                 : alexa2                : NAS                                      - disabled
                  + system.adapter.backitup.0               : backitup              : NAS                                      -  enabled
                    system.adapter.boschindego.0            : boschindego           : NAS                                      - disabled
                    system.adapter.cloud.0                  : cloud                 : NAS                                      - disabled
                    system.adapter.discovery.0              : discovery             : NAS                                      - disabled
                    system.adapter.doorbird.0               : doorbird              : NAS                                      - disabled
                    system.adapter.homeconnect.0            : homeconnect           : NAS                                      - disabled
                    system.adapter.iot.0                    : iot                   : NAS                                      - disabled
                    system.adapter.javascript.0             : javascript            : NAS                                      - disabled
                    system.adapter.mihome-cloud.1           : mihome-cloud          : NAS                                      - disabled
                    system.adapter.onkyo.0                  : onkyo                 : NAS                                      - disabled
                    system.adapter.openknx.0                : openknx               : NAS                                      - disabled
                    system.adapter.sma-em.0                 : sma-em                : NAS                                      - disabled
                    system.adapter.telegram.0               : telegram              : NAS                                      - disabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.terminal.0               : terminal              : NAS                                      -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                    system.adapter.tr-064.0                 : tr-064                : NAS                                      - disabled
                    system.adapter.vaillant.0               : vaillant              : NAS                                      - disabled
                    system.adapter.vis-2.0                  : vis-2                 : NAS                                      - disabled
                    system.adapter.vis.0                    : vis                   : NAS                                      -  enabled
                    system.adapter.vw-connect.0             : vw-connect            : NAS                                      - disabled
                    system.adapter.yahka.0                  : yahka                 : NAS                                      -  enabled
                    system.adapter.yahka.1                  : yahka                 : NAS                                      - disabled
                    system.adapter.yahka.2                  : yahka                 : NAS                                      - disabled
                  + instance is alive
                  ioBroker-Repositories
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "admin"        : 6.13.15  , installed 6.13.3 [Updatable]
                  Adapter    "alexa2"       : 3.26.4   , installed 3.25.2 [Updatable]
                  Adapter    "backitup"     : 2.10.6   , installed 2.9.8  [Updatable]
                  Adapter    "boschindego"  : 1.1.0    , installed 1.1.0
                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                  Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
                  Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                  Adapter    "javascript"   : 7.7.0    , installed 7.5.1  [Updatable]
                  Controller "js-controller": 5.0.17   , installed 5.0.17
                  Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
                  Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                  Adapter    "openknx"      : 0.7.2    , installed 0.7.0  [Updatable]
                  Adapter    "sma-em"       : 1.0.1    , installed 1.0.0  [Updatable]
                  Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                  Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                  Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
                  Adapter    "vaillant"     : 0.3.1    , installed 0.2.1  [Updatable]
                  Adapter    "vis"          : 1.5.4    , installed 1.4.15 [Updatable]
                  Adapter    "vis-2"        : 2.9.24   , installed 2.9.8  [Updatable]
                  Adapter    "vw-connect"   : 0.5.1    , installed 0.0.67 [Updatable]
                  Adapter    "web"          : 6.2.3    , installed 6.2.3
                  Adapter    "ws"           : 2.5.10   , installed 2.5.10
                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                  Objects and States
                  Objects:        4412
                  States:         3279
                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                  Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                  Reading package lists...
                  Pending Updates: 47
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       758353     -
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       757749     -
                  tcp        0      0 127.0.0.11:34037        0.0.0.0:*               LISTEN      0          739055     -
                  tcp6       0      0 :::8090                 :::*                    LISTEN      1000       769060     -
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       765486     -
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1000       763823     -
                  udp        0      0 127.0.0.11:51827        0.0.0.0:*                           0          739054     -
                  2024-01-28 09:03:18.848  - info: admin.0 (168) Request actual repository...
                  2024-01-28 09:03:19.534  - info: host.NAS Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                  2024-01-28 09:03:23.321  - info: admin.0 (168) Repository received successfully.
                  2024-01-28 10:40:09.785  - info: admin.0 (168) Adapter rating updated
                  2024-01-28 17:05:40.753  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:06:30.752  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:07:17.557  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:08:02.568  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:09:31.104  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:09:31.115  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:09:32.278  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:10:12.283  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:10:52.765  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:11:12.765  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:20:02.869  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:20:03.061  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:20:03.160  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:20:23.166  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:20:26.858  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:20:46.860  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:26:00.615  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:26:00.710  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:26:01.756  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                  2024-01-28 17:26:31.757  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                  2024-01-28 17:35:27.928  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    YAKAH v. 1.0.3
                    admin v. 6.13.3
                    npm v. 10.4.0
                    Nde.js v. 18.17.1
                    Summary:
                                            v.2023-10-10
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v8.0.1
                    Kernel:                 x86_64
                    Userland:               amd64
                    Timezone:               Etc/UTC
                    User-ID:                0
                    X-Server:               false
                                            /usr/bin/npm            10.4.0
                                            /usr/bin/npx            10.4.0
                    Please check
                    MEMORY:
                    Swap:            31G         47M         30G
                    Total:           46G        6.1G         31G
                                            admin                   6.13.3
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                4412
                    States:                 3279
                    Diagnose
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                    Hardware Vendor :
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v8.0.1
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 4
                    CET +0100
                    Etc/UTC
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:            31G         49M         30G
                    Total:           46G        6.1G         31G
                             6040 M used memory
                              318 M free memory
                             8088 M swap cache
                            31016 M total swap
                               49 M used swap
                            30967 M free swap
                    *** FILESYSTEM ***
                    /var:
                    33M     /var/
                    31M     /var/lib
                    18M     /var/lib/apt
                    13M     /var/lib/dpkg
                    USB-Devices by-id:
                    /usr/bin/npm            10.4.0
                    /usr/bin/npx            10.4.0
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.3
                    javascript:     7.5.1
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        4412
                    States:         3279
                    Pending Updates: 47
                    @lehmann-maker sagte in YAKAH startet nicht nach js-controller upgrade auf 5.x.x:
                    Das war mir so klar...
                    Neuen Docker ausrollen. Und beim Docker die Finger von individuellen Installationen non npm oder nodejs lassen. Das wird da immer in die Konservendose eingedockert.
                      lehmann-maker
                      @thomas-braun Gesagt getan in einem neuen Docker. Fehler bleibt der gleiche. Node.js Installation scheint nun iO zu sein. Anbei die Diag.:
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                      Hardware Vendor :
                      Kernel          : x86_64
                      Userland        : amd64
                      Docker          : v9.1.1
                      Kernel          : x86_64
                      Userland        : amd64
                       18:46:26 up 1 day,  9:15,  0 user,  load average: 1.97, 2.32, 2.65
                      CPU threads: 4
                      Sun Jan 28 17:46:26 UTC 2024
                      Sun Jan 28 18:46:26 CET 2024
                      CET +0100
                      Etc/UTC
                      root
                      /root
                      root
                      X-Server:       false
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:             16G        6.3G        835M        492M         10G         10G
                      Swap:            32G         81M         32G
                      Total:           49G        6.4G         33G
                               6020 M used memory
                               1731 M active memory
                              11515 M inactive memory
                                796 M free memory
                                591 M buffer memory
                               9499 M swap cache
                              31016 M total swap
                                 77 M used swap
                              30938 M free swap
                      *** FILESYSTEM ***
                      overlay               overlay  374G   39G  335G  11% /
                      /dev/mapper/cachedev1 ext4     374G   39G  335G  11% /opt/iobroker
                      /opt/iobroker    /dev/mapper/cachedev1[/Public/Docker/iobroker-test2]        ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                      /etc/resolv.conf /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/resolv.conf] ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                      /etc/hostname    /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/hostname]    ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                      /etc/hosts       /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/hosts]       ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                      /var:
                      34M     /var/
                      32M     /var/lib
                      19M     /var/lib/apt/lists
                      19M     /var/lib/apt
                      13M     /var/lib/dpkg
                      87M     /opt/iobroker/backups/
                      197M    /opt/iobroker/iobroker-data/
                      172M    /opt/iobroker/iobroker-data/files
                      55M     /opt/iobroker/iobroker-data/files/javascript.admin
                      43M     /opt/iobroker/iobroker-data/files/iot.admin
                      42M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                      25M     /opt/iobroker/iobroker-data/objects.jsonl
                      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                      USB-Devices by-id:
                      /usr/bin/nodejs         v18.19.0
                      /usr/bin/node           v18.19.0
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      /usr/bin/corepack       0.22.0
                      nodejs:
                        Installed: 18.19.0-1nodesource1
                        Candidate: 18.19.0-1nodesource1
                        Version table:
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                       *** 18.19.0-1nodesource1 1001
                             1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.9
                      javascript:     7.5.1
                      Adapter State
                        system.adapter.terminal.0               : terminal              : NAS                                      - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                        system.adapter.vis.0                    : vis                   : NAS                                      - disabled
                        system.adapter.web.0                    : web                   : NAS                                      - disabled, port: 8090, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Adapter    "admin"        : 6.13.15  , installed 6.13.9 [Updatable]
                      Objects and States
                      Objects:        4382
                      States:         3399
                      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.11:45543        0.0.0.0:*               LISTEN      0          27210132   -
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       27227538   -
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       27225086   -
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       27229016   -
                      udp        0      0 127.0.0.11:45160        0.0.0.0:*                           0          27210131   -
                      2024-01-28 18:44:27.631  - info: yahka.0 (1770) cleaning up ...
                      2024-01-28 18:44:27.631  - info: yahka.0 (1770) cleaned up ...
                      2024-01-28 18:44:27.632  - info: yahka.0 (1770) terminating
                      2024-01-28 18:44:27.633  - warn: yahka.0 (1770) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2024-01-28 18:44:28.135  - info: yahka.0 (1770) terminating
                      2024-01-28 18:44:28.204  - error: host.NAS Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
                      2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[1]: [Yahka-0 DAC7@Küche Temperatur@Temperatur@Target Temperature] characteristic was supplied illegal value: number 7 exceeded minimum of 10
                      2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[2]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
                      2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[3]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                      2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[4]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[6]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[8]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[10]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[12]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[14]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[16]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                      2024-01-28 18:44:28.207  - error: host.NAS instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2024-01-28 18:44:28.208  - info: host.NAS Restart adapter system.adapter.yahka.0 because enabled
                      2024-01-28 18:44:28.208  - warn: host.NAS Do not restart adapter system.adapter.yahka.0 because restart loop detected
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                        Hardware Vendor :
                        Kernel          : x86_64
                        Userland        : amd64
                        Docker          : v9.1.1
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 4
                        CET +0100
                        Etc/UTC
                        root
                        /root
                        root
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:            32G         81M         32G
                        Total:           49G        6.4G         33G
                                 6020 M used memory
                                  796 M free memory
                                  591 M buffer memory
                                 9499 M swap cache
                                31016 M total swap
                                   77 M used swap
                                30938 M free swap
                        *** FILESYSTEM ***
                        /var:
                        34M     /var/
                        32M     /var/lib
                        19M     /var/lib/apt
                        13M     /var/lib/dpkg
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.9
                        javascript:     7.5.1
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        4382
                        States:         3399
                        Pending Updates: 0
                        Aber deine Basis ist stabil.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                          Hardware Vendor :
                          Kernel          : x86_64
                          Userland        : amd64
                          Docker          : v9.1.1
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                          CET +0100
                          Etc/UTC
                          root
                          /root
                          root
                          X-Server:       false
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Swap:            32G         81M         32G
                          Total:           49G        6.4G         33G
                                   6020 M used memory
                                    796 M free memory
                                    591 M buffer memory
                                   9499 M swap cache
                                  31016 M total swap
                                     77 M used swap
                                  30938 M free swap
                          *** FILESYSTEM ***
                          /var:
                          34M     /var/
                          32M     /var/lib
                          19M     /var/lib/apt
                          13M     /var/lib/dpkg
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                               18.13.0+dfsg1-1 500
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.13.9
                          javascript:     7.5.1
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        4382
                          States:         3399
                          Pending Updates: 0
                          @lehmann-maker
                          Und jetzt bringst du den ganzen ioBroker auf Stand...
                            @lehmann-maker
                            lehmann-maker
                            @thomas-braun Damit meinst du Adapter updaten? YAKAH ist allerdings bereits neuste Version.
                            • mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              Schätze dann wird da wohl der Maintainer des Adapters was dazu sagen müssen.
                                @lehmann-maker
                                Die ganzen Adapter-Updates die da in der Pipeline hängen. Und/oder schalt das beta-Repo aus.
                                • ? Offline
                                  @lehmann-maker
                                  Warum hast du 3 Yahka Instanzen, wusste garnicht, dass das geht..?
                                  Wie hast du avahi konfiguriert?
                                    @lehmann-maker
                                    lehmann-maker
                                    Getan. Leider ohne Änderung. Es betrifft wie gesagt nur die Instanz 0. Die beiden anderen Instanzen laufen. Auf meiner Hauptinstallation mit folgendem Setup laufen alle 3 Instanzen:
                                    YAHKA 1.0.3
                                    Node.js 18.16.0
                                    NPM 9.5.1
                                    js-controller 4.0.24
                                    Hier nochmals das Log der Diagnose nach dem Adapterupdate:
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                    Hardware Vendor :
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    Docker          : v9.1.1
                                    Kernel          : x86_64
                                    Userland        : amd64
                                     09:21:30 up 1 day, 23:50,  0 user,  load average: 1.60, 2.08, 2.08
                                    CPU threads: 4
                                    Mon Jan 29 08:21:30 UTC 2024
                                    Mon Jan 29 09:21:30 CET 2024
                                    CET +0100
                                    Etc/UTC
                                    root
                                    /root
                                    root
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:             16G        7.5G        317M        488M        9.9G        9.1G
                                    Swap:            32G         98M         32G
                                    Total:           49G        7.6G         32G
                                             7133 M used memory
                                             2215 M active memory
                                            11436 M inactive memory
                                              302 M free memory
                                             1216 M buffer memory
                                             8253 M swap cache
                                            31016 M total swap
                                               93 M used swap
                                            30922 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    34M     /var/
                                    32M     /var/lib
                                    19M     /var/lib/apt
                                    13M     /var/lib/dpkg
                                    215M    /opt/iobroker/iobroker-data/
                                    42M     /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.13.15
                                    javascript:     7.5.1
                                    Adapter State
                                    + system.adapter.yahka.1                  : yahka                 : NAS                                      -  enabled
                                    + system.adapter.yahka.2                  : yahka                 : NAS                                      -  enabled
                                    + instance is alive
                                    Active repo(s): stable
                                    Used repository: stable
                                    Adapter    "admin"        : 6.12.0   , installed 6.13.15
                                    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                    Adapter    "backitup"     : 2.9.8    , installed 2.10.6
                                    Adapter    "javascript"   : 7.1.6    , installed 7.5.1
                                    Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.1
                                    Adapter    "openknx"      : 0.6.3    , installed 0.7.0
                                    Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
                                    Adapter    "vaillant"     : 0.1.2    , installed 0.2.1
                                    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
                                    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                                    Adapter    "web"          : 6.1.10   , installed 6.2.3
                                    Adapter    "ws"           : 2.5.8    , installed 2.5.10
                                    Objects and States
                                    Objects:        4382
                                    States:         3403
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       38475089   -
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       38477790   -
                                    tcp        0      0 127.0.0.11:40349        0.0.0.0:*               LISTEN      0          38446094   -
                                    tcp6       0      0 :::42505                :::*                    LISTEN      1000       38899787   -
                                    tcp6       0      0 :::35019                :::*                    LISTEN      1000       38899839   -
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       38813362   -
                                    udp        0      0 127.0.0.11:45393        0.0.0.0:*                           0          38446093   -
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       38899840   -
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       38899788   -
                                    2024-01-29 09:20:48.490  - info: yahka.0 (1911) cleaning up ...
                                    2024-01-29 09:20:48.490  - info: yahka.0 (1911) cleaned up ...
                                    2024-01-29 09:20:48.491  - info: yahka.0 (1911) terminating
                                    2024-01-29 09:20:48.492  - warn: yahka.0 (1911) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2024-01-29 09:20:48.993  - info: yahka.0 (1911) terminating
                                    2024-01-29 09:20:49.067  - error: host.NAS Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
                                    2024-01-29 09:20:49.068  - error: host.NAS Caught by controller[1]: [Yahka-0 DAC7@Küche Temperatur@Temperatur@Target Temperature] characteristic was supplied illegal value: number 7 exceeded minimum of 10
                                    2024-01-29 09:20:49.068  - error: host.NAS Caught by controller[2]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[3]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[4]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[6]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[8]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[10]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[12]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[14]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.071  - error: host.NAS Caught by controller[16]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                                    2024-01-29 09:20:49.071  - error: host.NAS instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2024-01-29 09:20:49.071  - info: host.NAS Restart adapter system.adapter.yahka.0 because enabled
                                    2024-01-29 09:20:49.071  - warn: host.NAS Do not restart adapter system.adapter.yahka.0 because restart loop detected
                                      @lehmann-maker
                                      lehmann-maker
                                      @ilovegym
                                      Wenn du in der Adapteransicht im ioBroker im Adapter auf + drückst, kannst du weitere Instanzen hinzufügen. Da ich mit YAHKA meine knx Geräte integriere habe ich mehr als 150 Geräte und muss diese daher aufteilen.
                                        YAHKA 1.0.3
                                        Node.js 18.16.0
                                        NPM 9.5.1
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                        Hardware Vendor :
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        Docker          : v9.1.1
                                        Kernel          : x86_64
                                        Userland        : amd64
                                        CPU threads: 4
                                        CET +0100
                                        Etc/UTC
                                        root
                                        /root
                                        root
                                        X-Server:       false
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Swap:            32G         98M         32G
                                        Total:           49G        7.6G         32G
                                                 7133 M used memory
                                                  302 M free memory
                                                 8253 M swap cache
                                                31016 M total swap
                                                   93 M used swap
                                                30922 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        34M     /var/
                                        32M     /var/lib
                                        19M     /var/lib/apt
                                        13M     /var/lib/dpkg
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.13.15
                                        javascript:     7.5.1
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        4382
                                        States:         3403
                                        Pending Updates: 0
                                        lehmann-maker
                                        @Thomas-Braun Noch eine Idee? Danke im Voraus.
                                        • wendy2702W Online
                                          wendy2702W Online
                                          wendy2702
                                          Wie sieht denn das log vom Adapter jetzt aus?
