  4. YAKAH startet nicht nach js-controller upgrade auf 5.x.x
22 Beiträge 5 Kommentatoren 4.6k Aufrufe 5 Beobachtet
  • lehmann-makerL lehmann-maker
    @thomas-braun Gesagt getan in einem neuen Docker. Fehler bleibt der gleiche. Node.js Installation scheint nun iO zu sein. Anbei die Diag.:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
    Hardware Vendor :
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.1.1
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     18:46:26 up 1 day,  9:15,  0 user,  load average: 1.97, 2.32, 2.65
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Jan 28 17:46:26 UTC 2024
    Sun Jan 28 18:46:26 CET 2024
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             16G        6.3G        835M        492M         10G         10G
    Swap:            32G         81M         32G
    Total:           49G        6.4G         33G
            15856 M total memory
             6020 M used memory
             1731 M active memory
            11515 M inactive memory
              796 M free memory
              591 M buffer memory
             9499 M swap cache
            31016 M total swap
               77 M used swap
            30938 M free swap
    *** FILESYSTEM ***
    Filesystem            Type     Size  Used Avail Use% Mounted on
    overlay               overlay  374G   39G  335G  11% /
    tmpfs                 tmpfs     64M     0   64M   0% /dev
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
    shm                   tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev1 ext4     374G   39G  335G  11% /opt/iobroker
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/cachedev1[/Public/Docker/iobroker-test2]        ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/resolv.conf /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/resolv.conf] ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/hostname    /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/hostname]    ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/hosts       /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/hosts]       ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /var:
    34M     /var/
    32M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    87M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    197M    /opt/iobroker/iobroker-data/
    172M    /opt/iobroker/iobroker-data/files
    55M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    42M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
     *** 18.19.0-1nodesource1 1001
           1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.9
    javascript:     7.5.1
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : NAS                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      system.adapter.alexa2.0                 : alexa2                : NAS                                      - disabled
    + system.adapter.backitup.0               : backitup              : NAS                                      -  enabled
      system.adapter.boschindego.0            : boschindego           : NAS                                      - disabled
      system.adapter.cloud.0                  : cloud                 : NAS                                      - disabled
      system.adapter.discovery.0              : discovery             : NAS                                      - disabled
      system.adapter.doorbird.0               : doorbird              : NAS                                      - disabled
      system.adapter.homeconnect.0            : homeconnect           : NAS                                      - disabled
      system.adapter.iot.0                    : iot                   : NAS                                      - disabled
      system.adapter.javascript.0             : javascript            : NAS                                      - disabled
      system.adapter.mihome-cloud.1           : mihome-cloud          : NAS                                      - disabled
      system.adapter.onkyo.0                  : onkyo                 : NAS                                      - disabled
      system.adapter.openknx.0                : openknx               : NAS                                      - disabled
      system.adapter.sma-em.0                 : sma-em                : NAS                                      - disabled
      system.adapter.telegram.0               : telegram              : NAS                                      - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : NAS                                      - disabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : NAS                                      - disabled
      system.adapter.vaillant.0               : vaillant              : NAS                                      - disabled
      system.adapter.vis.0                    : vis                   : NAS                                      - disabled
      system.adapter.vw-connect.0             : vw-connect            : NAS                                      - disabled
      system.adapter.web.0                    : web                   : NAS                                      - disabled, port: 8090, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : NAS                                      -  enabled
      system.adapter.yahka.1                  : yahka                 : NAS                                      - disabled
      system.adapter.yahka.2                  : yahka                 : NAS                                      - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.13.15  , installed 6.13.9 [Updatable]
    Adapter    "alexa2"       : 3.26.4   , installed 3.25.2 [Updatable]
    Adapter    "backitup"     : 2.10.6   , installed 2.9.8  [Updatable]
    Adapter    "boschindego"  : 1.1.0    , installed 1.1.0
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.7.0    , installed 7.5.1  [Updatable]
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openknx"      : 0.7.2    , installed 0.7.0  [Updatable]
    Adapter    "sma-em"       : 1.0.1    , installed 1.0.0  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vaillant"     : 0.3.1    , installed 0.2.1  [Updatable]
    Adapter    "vis"          : 1.5.4    , installed 1.4.15 [Updatable]
    Adapter    "vw-connect"   : 0.5.1    , installed 0.0.67 [Updatable]
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.10   , installed 2.5.10
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects:        4382
    States:         3399
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.11:45543        0.0.0.0:*               LISTEN      0          27210132   -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       27227538   -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       27225086   -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       27229016   -
    udp        0      0 127.0.0.11:45160        0.0.0.0:*                           0          27210131   -
    2024-01-28 18:44:27.631  - info: yahka.0 (1770) cleaning up ...
    2024-01-28 18:44:27.631  - info: yahka.0 (1770) cleaned up ...
    2024-01-28 18:44:27.632  - info: yahka.0 (1770) terminating
    2024-01-28 18:44:27.633  - warn: yahka.0 (1770) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-01-28 18:44:28.135  - info: yahka.0 (1770) terminating
    2024-01-28 18:44:28.204  - error: host.NAS Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
    2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[1]: [Yahka-0 DAC7@Küche Temperatur@Temperatur@Target Temperature] characteristic was supplied illegal value: number 7 exceeded minimum of 10
    2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[2]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
    2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[3]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
    2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[4]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[6]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[8]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[10]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[12]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[14]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[16]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
    2024-01-28 18:44:28.207  - error: host.NAS instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-01-28 18:44:28.208  - info: host.NAS Restart adapter system.adapter.yahka.0 because enabled
    2024-01-28 18:44:28.208  - warn: host.NAS Do not restart adapter system.adapter.yahka.0 because restart loop detected
    @lehmann-maker sagte in YAKAH startet nicht nach js-controller upgrade auf 5.x.x:
    Aber deine Basis ist stabil.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor :
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
      CET +0100
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            32G         81M         32G
      Total:           49G        6.4G         33G
               6020 M used memory
                796 M free memory
                591 M buffer memory
               9499 M swap cache
              31016 M total swap
                 77 M used swap
              30938 M free swap
      *** FILESYSTEM ***
      /var:
      34M     /var/
      32M     /var/lib
      19M     /var/lib/apt
      13M     /var/lib/dpkg
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.9
      javascript:     7.5.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        4382
      States:         3399
      Pending Updates: 0
      @lehmann-maker
      Und jetzt bringst du den ganzen ioBroker auf Stand...
      lehmann-makerL 1 Antwort Letzte Antwort
        @lehmann-maker
        lehmann-makerL Offline
        lehmann-maker
        @thomas-braun Damit meinst du Adapter updaten? YAKAH ist allerdings bereits neuste Version.
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          Schätze dann wird da wohl der Maintainer des Adapters was dazu sagen müssen.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
            @lehmann-maker
            Die ganzen Adapter-Updates die da in der Pipeline hängen. Und/oder schalt das beta-Repo aus.
            • ? Offline
              @lehmann-maker
              Warum hast du 3 Yahka Instanzen, wusste garnicht, dass das geht..?
              Wie hast du avahi konfiguriert?
                @lehmann-maker
                lehmann-maker
                Getan. Leider ohne Änderung. Es betrifft wie gesagt nur die Instanz 0. Die beiden anderen Instanzen laufen. Auf meiner Hauptinstallation mit folgendem Setup laufen alle 3 Instanzen:
                YAHKA 1.0.3
                Node.js 18.16.0
                NPM 9.5.1
                js-controller 4.0.24
                Hier nochmals das Log der Diagnose nach dem Adapterupdate:
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                Hardware Vendor :
                Kernel          : x86_64
                Userland        : amd64
                Docker          : v9.1.1
                Kernel          : x86_64
                Userland        : amd64
                 09:21:30 up 1 day, 23:50,  0 user,  load average: 1.60, 2.08, 2.08
                CPU threads: 4
                Mon Jan 29 08:21:30 UTC 2024
                Mon Jan 29 09:21:30 CET 2024
                CET +0100
                Etc/UTC
                root
                /root
                root
                X-Server:       false
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:             16G        7.5G        317M        488M        9.9G        9.1G
                Swap:            32G         98M         32G
                Total:           49G        7.6G         32G
                         7133 M used memory
                         2215 M active memory
                        11436 M inactive memory
                          302 M free memory
                         1216 M buffer memory
                         8253 M swap cache
                        31016 M total swap
                           93 M used swap
                        30922 M free swap
                *** FILESYSTEM ***
                /var:
                34M     /var/
                32M     /var/lib
                19M     /var/lib/apt
                13M     /var/lib/dpkg
                215M    /opt/iobroker/iobroker-data/
                42M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.13.15
                javascript:     7.5.1
                Adapter State
                + system.adapter.yahka.1                  : yahka                 : NAS                                      -  enabled
                + system.adapter.yahka.2                  : yahka                 : NAS                                      -  enabled
                + instance is alive
                Active repo(s): stable
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.13.15
                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                Adapter    "backitup"     : 2.9.8    , installed 2.10.6
                Adapter    "javascript"   : 7.1.6    , installed 7.5.1
                Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.1
                Adapter    "openknx"      : 0.6.3    , installed 0.7.0
                Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
                Adapter    "vaillant"     : 0.1.2    , installed 0.2.1
                Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
                Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                Adapter    "web"          : 6.1.10   , installed 6.2.3
                Adapter    "ws"           : 2.5.8    , installed 2.5.10
                Objects and States
                Objects:        4382
                States:         3403
                Pending Updates: 0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       38475089   -
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       38477790   -
                tcp        0      0 127.0.0.11:40349        0.0.0.0:*               LISTEN      0          38446094   -
                tcp6       0      0 :::42505                :::*                    LISTEN      1000       38899787   -
                tcp6       0      0 :::35019                :::*                    LISTEN      1000       38899839   -
                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       38813362   -
                udp        0      0 127.0.0.11:45393        0.0.0.0:*                           0          38446093   -
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       38899840   -
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       38899788   -
                2024-01-29 09:20:48.490  - info: yahka.0 (1911) cleaning up ...
                2024-01-29 09:20:48.490  - info: yahka.0 (1911) cleaned up ...
                2024-01-29 09:20:48.491  - info: yahka.0 (1911) terminating
                2024-01-29 09:20:48.492  - warn: yahka.0 (1911) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2024-01-29 09:20:48.993  - info: yahka.0 (1911) terminating
                2024-01-29 09:20:49.067  - error: host.NAS Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
                2024-01-29 09:20:49.068  - error: host.NAS Caught by controller[1]: [Yahka-0 DAC7@Küche Temperatur@Temperatur@Target Temperature] characteristic was supplied illegal value: number 7 exceeded minimum of 10
                2024-01-29 09:20:49.068  - error: host.NAS Caught by controller[2]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[3]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[4]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[6]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[8]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[10]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[12]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[14]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.071  - error: host.NAS Caught by controller[16]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                2024-01-29 09:20:49.071  - error: host.NAS instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2024-01-29 09:20:49.071  - info: host.NAS Restart adapter system.adapter.yahka.0 because enabled
                2024-01-29 09:20:49.071  - warn: host.NAS Do not restart adapter system.adapter.yahka.0 because restart loop detected
                  @lehmann-maker
                  lehmann-maker
                  @ilovegym
                  Wenn du in der Adapteransicht im ioBroker im Adapter auf + drückst, kannst du weitere Instanzen hinzufügen. Da ich mit YAHKA meine knx Geräte integriere habe ich mehr als 150 Geräte und muss diese daher aufteilen.
                    YAHKA 1.0.3
                    Node.js 18.16.0
                    NPM 9.5.1
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                    Hardware Vendor :
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v9.1.1
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 4
                    CET +0100
                    Etc/UTC
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:            32G         98M         32G
                    Total:           49G        7.6G         32G
                             7133 M used memory
                              302 M free memory
                             8253 M swap cache
                            31016 M total swap
                               93 M used swap
                            30922 M free swap
                    *** FILESYSTEM ***
                    /var:
                    34M     /var/
                    32M     /var/lib
                    19M     /var/lib/apt
                    13M     /var/lib/dpkg
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.13.15
                    javascript:     7.5.1
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        4382
                    States:         3403
                    Pending Updates: 0
                    lehmann-maker
                    @Thomas-Braun Noch eine Idee? Danke im Voraus.
                    • wendy2702W Online
                      wendy2702W Online
                      Wie sieht denn das log vom Adapter jetzt aus?
                      • wendy2702W wendy2702
                        lehmann-maker
                        @wendy2702
                        Nach wie vor:
                        yahka.0
                        2024-02-03 17:28:15.978 error Error The pattern "[object Object]" is not a valid ID pattern
                        yahka.0
                        2024-02-03 17:28:15.977 error ReplyError: Error The pattern "[object Object]" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                        yahka.0
                        2024-02-03 17:28:15.976 error unhandled promise rejection: Error The pattern "[object Object]" is not a valid ID pattern
                        yahka.0
                        2024-02-03 17:28:15.975 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          @wendy2702
                          Nach wie vor:
                          yahka.0
                          yahka.0
                          yahka.0
                          yahka.0
                          wendy2702W Online
                          wendy2702W Online
                          @lehmann-maker laut log sieht es für mich so aus als wenn du in Instanz 0 etwas konfiguriert hast was der JS Controller jetzt als falsch interpretiert.
                          Weiß nicht wieviel Geräte da drin sind sonst würde ich mal eins nach dem anderen löschen und schauen ob der Adapter startet.
