  4. Probleme plötzlich
Probleme plötzlich
4 Beiträge 4 Kommentatoren 815 Aufrufe 4 Beobachtet
  • C Offline
    cainam
    schrieb am zuletzt editiert von cainam
    Hallo zusammen
    Habe seit sehr kurzen diese Fehler im Protokoll. Kann mir da jemand helfen?
    Error on writePoint("{"value":4366954,"time":"2024-01-26T18:58:05.746Z","from":"system.adapter.shelly.0","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
    influxdb.0
    2024-01-26 19:58:35.756	warn	Point could not be written to database: iobroker
    influxdb.0
    2024-01-26 19:58:35.746	info	Add point that had error for shelly.0.SHEM-3#D8BFC01A8074#1.Emeter1.Total to buffer again, error-count=9
    influxdb.0
    2024-01-26 19:58:35.746	warn	Error on writePoint("{"value":4224319.6,"time":"2024-01-26T18:58:05.726Z","from":"system.adapter.shelly.0","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
    influxdb.0
    2024-01-26 19:58:35.745	warn	Point could not be written to database: iobroker
    influxdb.0
    2024-01-26 19:58:35.739	info	Add point that had error for shelly.0.SHEM-3#D8BFC01A8074#1.Emeter1.Power to buffer again, error-count=8
    influxdb.0
    2024-01-26 19:58:35.738	warn	Error on writePoint("{"value":241.8,"time":"2024-01-26T18:58:05.726Z","from":"system.adapter.shelly.0","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
    influxdb.0
    2024-01-26 19:58:35.738	warn	Point could not be written to database: iobroker
    influxdb.0
    2024-01-26 19:58:35.730	info	Add point that had error for shelly.0.SHEM-3#D8BFC01A8074#1.Emeter0.Total to buffer again, error-count=9
    influxdb.0
    2024-01-26 19:58:35.730	warn	Error on writePoint("{"value":6150043,"time":"2024-01-26T18:58:05.718Z","from":"system.adapter.shelly.0","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
    influxdb.0
    2024-01-26 19:58:35.729	warn	Point could not be written to database: iobroker
    influxdb.0
    2024-01-26 19:58:35.724	info	Discard point that had error for shelly.0.SHEM-3#D8BFC01A8074#1.Emeter0.Power, error-count=10
    influxdb.0
    2024-01-26 19:58:35.723	warn	Error on writePoint("{"value":429.08,"time":"2024-01-26T18:58:05.717Z","from":"system.adapter.shelly.0","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
    influxdb.0
    2024-01-26 19:58:35.722	warn	Point could not be written to database: iobroker
    influxdb.1
    2024-01-26 19:58:32.849	error	Error during ping: RequestTimedOutError: Request timed out. Attempting reconnect.
    influxdb.0
    2024-01-26 19:58:30.843	info	Add point that had error for Wattverbrauch_Brenner_Oelpumpe to buffer again, error-count=7
    influxdb.0
    2024-01-26 19:58:30.843	warn	Error on writePoint("{"value":188.51,"time":"2024-01-26T18:58:00.837Z","from":"system.adapter.shelly.0","q":0,"ack":true}): RequestTimedOutError: Request timed out / "Request timed out""
    Was ich gerade noch festgestellt habe wenn ich die VM neu starte kommt diese Warnung:
    WARN: iothread is only valid with virtio disk or virtio-scsi-single controller, ignoring
    TASK WARNINGS: 1
    und beim starten geht es ehwig:
    • GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @cainam
      Dein Thread Titel ...
      Probleme plötzlich
      gehört / passt eher hier mit rein ..
      https://forum.iobroker.net/topic/72244/iobroker-sehr-träg-und-langsam
      • arteckA Offline
        arteckA Offline
        arteck
        ja bei mir läuft auch nix mehr.. seit heute
        • crunchipC Offline
          crunchipC Offline
          @cainam sagte in Probleme plötzlich:
          TASK WARNINGS: 1
          https://forum.proxmox.com/threads/start-vm-iothread-is-only-valid-with-virtio-disk-or-virtio-scsi-single-controller-ignoring.92463/
