  4. Iobroker lässt sich nicht mehr starten.
80 Beiträge 7 Kommentatoren 8.8k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @borkenkäfer
    Es kommt erst die lange Ausgabe ....
    von
    iob diag
    dann auf abbrechen . diese brauche ich
    sonst kommt die Summary
    Borkenkäfer
    #41
    @glasfaser
    das sollte es sein
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     19:00:44 up 58 min,  3 users,  load average: 0.00, 0.00, 0.00
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-22 19:00:44 CET
               Universal time: Mon 2024-01-22 18:00:44 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    ulli
    /home/ulli
    ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        298M        2.7G         35M        803M        3.4G
    Swap:            99M          0B         99M
    Total:          3.9G        298M        2.8G
             3794 M total memory
              298 M used memory
              594 M active memory
              343 M inactive memory
             2692 M free memory
               49 M buffer memory
              753 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   11G   46G  20% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    [Mon Jan 22 18:02:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Jan 22 18:02:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jan 22 18:02:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Jan 22 18:02:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.3G    /var/
    3.4G    /var/log
    2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
    641M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    687M    /opt/iobroker/backups/
    343M    /opt/iobroker/backups/history
    268M    /opt/iobroker/backups/files
    88M     /opt/iobroker/backups/files/echarts.admin
    57M     /opt/iobroker/backups/files/echarts
    /opt/iobroker/iobroker-data:
    683M    /opt/iobroker/iobroker-data/
    347M    /opt/iobroker/iobroker-data/history
    294M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    57M     /opt/iobroker/iobroker-data/files/echarts
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    find: '/opt/iobroker/node_modules': No such file or directory
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: iobroker.admin@6.12.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.backitup@2.9.8, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.cloud@4.4.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.discovery@4.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.echarts@1.7.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.evcc@0.1.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.fritzdect@2.5.9, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.growatt@3.2.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.history@3.0.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.homeconnect@1.3.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.jarvis@3.1.8, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.javascript@7.1.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.js-controller@5.0.17, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.meross@1.17.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.parser@2.0.7, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.ping@1.6.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.pvforecast@2.9.1, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.smartmeter@3.4.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.socketio@6.6.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.tibberlink@2.0.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.tuya@3.15.0, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.vis@1.5.4, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.web@6.1.10, required by iobroker.inst@3.0.0
    npm ERR! missing: iobroker.ws@2.5.8, required by iobroker.inst@3.0.0
    npm ERR! missing: node-forge@^1.3.1, required by iobroker.inst@3.0.0
    npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_50_882Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    node:internal/modules/cjs/loader:1137
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
        at Module._load (node:internal/modules/cjs/loader:975:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.19.0
    Core adapters versions
      throw err;
      requireStack: []
    Node.js v18.19.0
    js-controller:
      throw err;
      requireStack: []
    Node.js v18.19.0
    admin:
      throw err;
      requireStack: []
    Node.js v18.19.0
    javascript:
    npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_53_223Z-debug-0.log
    Adapters from github:   0
    Adapter State
      throw err;
      requireStack: []
    Node.js v18.19.0
      throw err;
      requireStack: []
    Node.js v18.19.0
    ioBroker-Repositories
      throw err;
      requireStack: []
    Node.js v18.19.0
    Installed ioBroker-Instances
      throw err;
      requireStack: []
    Node.js v18.19.0
    Objects and States
    Objects:        0
    States:         0
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
    Hit:6 https://dl.yarnpkg.com/debian stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Fetched 5127 B in 2s (2925 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14598      600/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12272      561/cupsd
    tcp6       0      0 :::4712                 :::*                    LISTEN      116        15382      566/evcc
    tcp6       0      0 :::7070                 :::*                    LISTEN      116        17751      566/evcc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12271      561/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14600      600/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1972       506/dhcpcd
    udp        0      0 0.0.0.0:39128           0.0.0.0:*                           108        1869       431/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14632      635/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        16667      566/evcc
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1867       431/avahi-daemon: r
    udp6       0      0 :::47247                :::*                                108        1870       431/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          1984       506/dhcpcd
    udp6       0      0 :::5353                 :::*                                116        16668      566/evcc
    udp6       0      0 :::5353                 :::*                                108        1868       431/avahi-daemon: r
    2024-01-13 12:30:55.092  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:55.093  - info: host.raspberrypi stopInstance system.adapter.ping.0 killing pid 1094779
    2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 killing pid 1094912
    2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.web.0 killing pid 1094943
    2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.echarts.0 killing pid 1187136
    2024-01-13 12:30:55.096  - info: host.raspberrypi stopInstance system.adapter.parser.0 killing pid 1095017
    2024-01-13 12:30:55.136  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:55.137  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:55.139  - info: host.raspberrypi instance system.adapter.terminal.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:55.228  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:55.230  - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:55.293  - warn: host.raspberrypi instance system.adapter.parser.0 terminated due to SIGTERM
    2024-01-13 12:30:55.293  - info: host.raspberrypi instance system.adapter.parser.0 terminated with code null ()
    2024-01-13 12:30:55.294  - warn: host.raspberrypi instance system.adapter.ping.0 terminated due to SIGTERM
    2024-01-13 12:30:55.294  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
    2024-01-13 12:30:55.365  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
    2024-01-13 12:30:55.365  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
    2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
    2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
    2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
    2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
    2024-01-13 12:30:57.358  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
    2024-01-13 12:30:58.585  - info: host.raspberrypi instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-13 12:30:58.586  - info: host.raspberrypi All instances are stopped.
    2024-01-13 12:30:58.850  - info: host.raspberrypi terminated
    • B Borkenkäfer
      @glasfaser
      das sollte es sein
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ulli
      /home/ulli
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
                298 M used memory
                594 M active memory
               2692 M free memory
                 49 M buffer memory
                753 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.3G    /var/
      3.4G    /var/log
      641M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.0
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.0
      javascript:
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
      Objects and States
      Objects:        0
      States:         0
      Pending Updates: 0
      #42
      @borkenkäfer jepp, dann jag jetzt
      @glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
      @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
      leider nicht hin
      wie schon erwähnt die Full Ausgabe wäre besser :
      sonst
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      Edit :
      den Befehl über deine Installation
      B HomoranH 2 Antworten Letzte Antwort
        leider nicht hin
        sonst
        cd /opt/iobroker
        Edit :
        Borkenkäfer
        #43
        schon mehrfach ausgeführt
        kommt leider
        ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm ERR! Invalid Version:
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
        • B Borkenkäfer
          kommt leider
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #44
          zeige mal den Inhalt davon
          B 1 Antwort Letzte Antwort
            leider nicht hin
            sonst
            cd /opt/iobroker
            Edit :
            #45
            @homoran sagte in Iobroker lässt sich nicht mehr starten.:
            sudo -H -u iobroker npm install iobroker.js-controller --debug
            nach das mal mit debug option. was da die falsche version haben soll
              Borkenkäfer
              #46
              @glasfaser
              ist es das hier??
              ulli@raspberrypi:/home/iobroker $ cat /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
              0 verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@10.2.3
              2 info using node@v18.19.0
              3 timing npm:load:whichnode Completed in 3ms
              4 timing config:load:defaults Completed in 7ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 12ms
              6 timing config:load:builtin Completed in 13ms
              7 timing config:load:cli Completed in 15ms
              8 timing config:load:env Completed in 1ms
              9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
              10 timing config:load:project Completed in 8ms
              11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
              12 timing config:load:user Completed in 1ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
              14 timing config:load:global Completed in 1ms
              15 timing config:load:setEnvs Completed in 4ms
              16 timing config:load Completed in 51ms
              17 timing npm:load:configload Completed in 51ms
              18 timing config:load:flatten Completed in 9ms
              19 timing npm:load:mkdirpcache Completed in 2ms
              20 timing npm:load:mkdirplogs Completed in 1ms
              21 verbose title npm install iobroker.js-controller
              22 verbose argv "install" "iobroker.js-controller"
              23 timing npm:load:setTitle Completed in 4ms
              24 timing npm:load:display Completed in 2ms
              25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-
              26 verbose logfile /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
              27 timing npm:load:logFile Completed in 29ms
              28 timing npm:load:timers Completed in 0ms
              29 timing npm:load:configScope Completed in 1ms
              30 timing npm:load Completed in 147ms
              31 timing arborist:ctor Completed in 3ms
              32 silly logfile start cleaning logs, removing 1 files
              33 silly logfile done cleaning log files
              34 timing idealTree:init Completed in 1707ms
              35 timing idealTree:userRequests Completed in 5ms
              36 silly idealTree buildDeps
              37 silly fetch manifest iobroker.js-controller@5.0.17
              38 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 647ms (cache revalidated)
              39 silly placeDep ROOT iobroker.js-controller@5.0.17 REPLACE for: iobroker.inst@3.0.0 want: 5.0.17
              40 timing idealTree:#root Completed in 749ms
              41 silly fetch manifest esbuild@^0.11.5
              42 http fetch GET 200 https://registry.npmjs.org/esbuild 80ms (cache revalidated)
              43 silly fetch manifest jsonc-parser@^3.0.0
              44 http fetch GET 200 https://registry.npmjs.org/jsonc-parser 70ms (cache revalidated)
              45 silly placeDep ROOT esbuild@0.11.23 OK for: @alcalzone/esbuild-register@2.5.1-1 want: ^0.11.5
              46 timing idealTree Completed in 2675ms
              47 timing command:install Completed in 2708ms
              48 verbose stack TypeError: Invalid Version:
              48 verbose stack     at new SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:38:13)
              48 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:3:32)
              48 verbose stack     at Object.gte (/usr/lib/node_modules/npm/node_modules/semver/functions/gte.js:2:30)
              48 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1079:32)
              48 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:426:14)
              48 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:278:14)
              48 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:933:18)
              48 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
              48 verbose stack     at async Promise.all (index 1)
              48 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
              49 verbose cwd /opt/iobroker
              50 verbose Linux 6.1.21-v8+
              51 verbose node v18.19.0
              52 verbose npm  v10.2.3
              53 error Invalid Version:
              54 verbose exit 1
              55 timing npm Completed in 3498ms
              56 verbose unfinished npm timer reify 1705946805688
              57 verbose unfinished npm timer reify:loadTrees 1705946805706
              58 verbose unfinished npm timer idealTree:buildDeps 1705946807423
              59 verbose unfinished npm timer idealTree:node_modules/@alcalzone/esbuild-register 1705946808178
              60 verbose code 1
              61 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
              GlasfaserG B 2 Antworten Letzte Antwort
              • B Borkenkäfer
                @glasfaser
                ist es das hier??
                54 verbose exit 1
                60 verbose code 1
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                #47
                @borkenkäfer
                Sehr komisch ..
                Teste :
                iob stop
                rm /opt/iobroker/package*
                sudo reboot
                danach
                cd /opt/iobroker
                • B Borkenkäfer
                  @glasfaser
                  ist es das hier??
                  54 verbose exit 1
                  60 verbose code 1
                  Borkenkäfer
                  #48
                  @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                  @glasfaser
                  ist es das hier??
                  54 verbose exit 1
                  60 verbose code 1
                  Muß für Heute leider schluß machen
                  Melde mich morgen wieder
                  danke für Eure Hilfe
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    #49
                    http fetch GET 200
                    Da stimmt auch etwas nicht !
                    https://forum.iobroker.net/post/441199
                      @borkenkäfer
                      Sehr komisch ..
                      Teste :
                      iob stop
                      sudo reboot
                      danach
                      cd /opt/iobroker
                      Borkenkäfer
                      #50
                      @glasfaser
                      es kommt das
                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      added 299 packages in 1m
                      14 packages are looking for funding
                        run `npm fund` for details
                      • B Borkenkäfer
                        @glasfaser
                        es kommt das
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #51
                        @borkenkäfer
                        sieht gut aus !
                        ... und Funktioniert es wieder !?
                          @borkenkäfer
                          sieht gut aus !
                          Borkenkäfer
                          #52
                          @glasfaser
                          nach iob start komme ich über port 8081 noch nicht drauf
                          • B Borkenkäfer
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #53
                            @borkenkäfer
                            Full
                            iob diag
                            zeigen !
                            • B Borkenkäfer
                              @glasfaser
                              Borkenkäfer
                              #54
                              @glasfaser
                              und bei iob Update kommt
                              iob update
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                                @borkenkäfer
                                Full
                                iob diag
                                zeigen !
                                Borkenkäfer
                                #55
                                @glasfaser
                                einmal full
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 19:36:21 up 12 min,  3 users,  load average: 0.03, 0.24, 0.27
                                CPU threads: 4
                                Current issues:
                                               Local time: Mon 2024-01-22 19:36:21 CET
                                           Universal time: Mon 2024-01-22 18:36:21 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                ulli
                                /home/ulli
                                X-Server:       true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        284M        2.7G         38M        855M        3.4G
                                Swap:            99M          0B         99M
                                Total:          3.9G        284M        2.8G
                                         3794 M total memory
                                          284 M used memory
                                          583 M active memory
                                          396 M inactive memory
                                         2654 M free memory
                                           54 M buffer memory
                                          800 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                4.3G    /var/
                                3.4G    /var/log
                                641M    /var/cache
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                js-controller:
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                admin:
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                javascript:
                                Adapter State
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                Objects and States
                                Objects:        0
                                States:         0
                                Hit:1 http://deb.debian.org/debian bullseye InRelease
                                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                Fetched 5127 B in 2s (2790 B/s)
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12977      557/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
                                tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12976      557/cupsd
                                tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12989      622/cups-browsed
                                udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
                                udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
                                udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
                                2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
                                2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.meross.0 (force=false, process=false)
                                2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
                                2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=false)
                                2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
                                2024-01-22 19:29:28.264  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
                                2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 (force=false, process=false)
                                2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
                                2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
                                2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=false)
                                2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
                                2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.echarts.0 (force=false, process=false)
                                2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.parser.0 (force=false, process=false)
                                2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
                                2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=false)
                                2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.growatt.0 (force=false, process=false)
                                2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.terminal.0 (force=false, process=false)
                                2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
                                2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.pvforecast.0 (force=false, process=false)
                                2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.evcc.0 (force=false, process=false)
                                2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.homeconnect.0 (force=false, process=false)
                                2024-01-22 19:29:28.270  - info: host.raspberrypi stopInstance system.adapter.tibberlink.0 (force=false, process=false)
                                2024-01-22 19:29:28.752  - info: host.raspberrypi terminated
                                2024-01-22 19:29:29.215  - warn: host.raspberrypi startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
                                2024-01-22 19:29:29.216  - info: host.raspberrypi iobroker install history@3.0.1 using installedFrom
                                GlasfaserG 2 Antworten Letzte Antwort
                                • B Borkenkäfer
                                  @glasfaser
                                  einmal full
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Current issues:
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  ulli
                                  /home/ulli
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           3794 M total memory
                                            284 M used memory
                                            583 M active memory
                                           2654 M free memory
                                             54 M buffer memory
                                            800 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  4.3G    /var/
                                  3.4G    /var/log
                                  641M    /var/cache
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  js-controller:
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  admin:
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  javascript:
                                  Adapter State
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  Objects and States
                                  Objects:        0
                                  States:         0
                                  Pending Updates: 0
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  #56
                                  @borkenkäfer
                                  nochmal
                                  cd /opt/iobroker
                                  npm cache clean --force
                                  • B Borkenkäfer
                                    @glasfaser
                                    einmal full
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    ulli
                                    /home/ulli
                                    X-Server:       true
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             3794 M total memory
                                              284 M used memory
                                              583 M active memory
                                             2654 M free memory
                                               54 M buffer memory
                                              800 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    4.3G    /var/
                                    3.4G    /var/log
                                    641M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    js-controller:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    admin:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    javascript:
                                    Adapter State
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Pending Updates: 0
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    #57
                                    Hast du das Steckernetzteil gezogen !?
                                    EDIT :
                                    bzw. ein root Mount
                                      @borkenkäfer
                                      nochmal
                                      cd /opt/iobroker
                                      Borkenkäfer
                                      #58
                                      @glasfaser
                                      Guten Abend
                                      Meldung nach cache clean
                                      ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
                                      npm WARN using --force Recommended protections disabled.
                                      ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
                                      • B Borkenkäfer
                                        @glasfaser
                                        Guten Abend
                                        #59
                                        @borkenkäfer
                                        Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
                                        cd /opt/iobroker
                                        sagt nun?
                                          @borkenkäfer
                                          cd /opt/iobroker
                                          sagt nun?
                                          Borkenkäfer
                                          #60
                                          sorry
                                          meldung
                                          added 289 packages in 1m
                                          15 packages are looking for funding
                                          ulli@raspberrypi:/opt/iobroker $ npm fund
                                          iobroker.core@1.0.0
                                          ├── https://github.com/sponsors/jaredhanson
                                          │   └── passport@0.6.0
                                          ├── https://github.com/sponsors/RubenVerborgh
                                          │   └── follow-redirects@1.15.5
                                          ├── https://opencollective.com/ioredis
                                          │   └── ioredis@4.28.5
                                          ├── https://github.com/sponsors/ljharb
                                          │   └── function-bind@1.1.2
                                          ├─┬ https://github.com/sindresorhus/execa?sponsor=1
                                          │ │ └── execa@5.1.1
                                          │ └── https://github.com/sponsors/sindresorhus
                                          │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
                                          ├─┬ https://paulmillr.com/funding/
                                          │ │ └── chokidar@3.5.3
                                          │ └── https://github.com/sponsors/jonschlinkert
                                          │     └── picomatch@2.3.1
                                          ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                          │ │ └── wrap-ansi@7.0.0
                                          │ └── https://github.com/chalk/ansi-styles?sponsor=1
                                          │     └── ansi-styles@4.3.0
                                          ├── https://github.com/sponsors/sibiraj-s
                                          │   └── ci-info@3.9.0
                                          ├── https://github.com/sponsors/feross
                                          │   └── safe-buffer@5.2.1
                                          └── https://github.com/sponsors/epoberezkin
                                              └── ajv@6.12.6
                                          ulli@raspberrypi:/opt/iobroker $ ^C
