  3. Off Topic
  4. InfluxDB
  5. mit backitup kein Influxdb und Grafana backup möglich
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
119 Beiträge 10 Kommentatoren 19.8k Aufrufe 8 Beobachtet
  • W Willi-Wunder
    pi@iobroker:~ $ sudo influx auth list -t 74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A== --json
    /usr/local/bin/influx: 1: Syntax error: ")" unexpected
    #81
    @willi-wunder
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    W 1 Antwort Letzte Antwort
      @willi-wunder
      sudo apt update
      sudo reboot
      W Offline
      W Offline
      Willi-Wunder
      schrieb am zuletzt editiert von Willi-Wunder
      #82
      pi@iobroker:~ $ sudo apt update
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists... Done
      Building dependency tree... Done
      3 packages can be upgraded. Run 'apt list --upgradable' to see them.
      pi@iobroker:~ $ sudo apt full-upgrade
      Calculating upgrade... Done
      The following packages will be upgraded:
        curl libcurl3-gnutls libcurl4
      3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 1034 kB of archives.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 http://deb.debian.org/debian-security bookworm-security/main arm64 curl arm64 7.88.1-10+deb12u5 [308 kB]
      Get:2 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl4 arm64 7.88.1-10+deb12u5 [366 kB]
      Get:3 http://deb.debian.org/debian-security bookworm-security/main arm64 libcurl3-gnutls arm64 7.88.1-10+deb12u5 [360 kB]
      Fetched 1034 kB in 0s (3344 kB/s)
      apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
      Changelogs werden gelesen... Fertig
      perl: warning: Setting locale failed.
      perl: warning: Please check that your locale settings:
              LANGUAGE = "de_DE",
              LC_ALL = "de_DE",
              LANG = (unset)
          are supported and installed on your system.
      perl: warning: Falling back to the standard locale ("C").
      locale: Cannot set LC_CTYPE to default locale: No such file or directory
      locale: Cannot set LC_MESSAGES to default locale: No such file or directory
      locale: Cannot set LC_ALL to default locale: No such file or directory
      (Reading database ... 146179 files and directories currently installed.)
      Preparing to unpack .../curl_7.88.1-10+deb12u5_arm64.deb ...
      Unpacking curl (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
      Preparing to unpack .../libcurl4_7.88.1-10+deb12u5_arm64.deb ...
      Unpacking libcurl4:arm64 (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
      Preparing to unpack .../libcurl3-gnutls_7.88.1-10+deb12u5_arm64.deb ...
      Unpacking libcurl3-gnutls:arm64 (7.88.1-10+deb12u5) over (7.88.1-10+deb12u4) ...
      Setting up libcurl3-gnutls:arm64 (7.88.1-10+deb12u5) ...
      Setting up libcurl4:arm64 (7.88.1-10+deb12u5) ...
      Setting up curl (7.88.1-10+deb12u5) ...
      Processing triggers for man-db (2.11.2-2) ...
      Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
      Nach Reboot:
      Bleibt es leider so......
      • W Willi-Wunder
                LANGUAGE = "de_DE",
                LC_ALL = "de_DE",
                LANG = (unset)
        Nach Reboot:
        #83
        @willi-wunder
        ls -lAh /usr/local/bin/influx
          @willi-wunder
          W Offline
          W Offline
          Willi-Wunder
          #84
          pi@iobroker:~ $ ls -lAh /usr/local/bin/influx
          -rwxr-xr-x 1 root root 25M Dec 26 22:38 /usr/local/bin/influx
          • W Willi-Wunder
            #85
            @willi-wunder
            sudo rm /usr/local/bin/influx
            Das ist ein Überbleibsel aus dem manuellen Hantier mit influx. Eine ordentliche Installation landet nicht in /usr/local/bin
              @willi-wunder
              W Offline
              W Offline
              Willi-Wunder
              #86
              Bingo Banane........ jetzt kommt etwas. Brauch ich die anderen zwei Einträge? (Iobroker (cloned at 2023-12-26 20:56:55) + Backitup in den API Token in InfluxDB? Diese dann löschen und nur den iobroker behalten?
                              "id": "0c54cd2ed3814000",
                              "description": "Iobroker",
                              "token": "74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A==",
                              "status": "active",
                              "userName": "Markus",
                              "userID": "0c52172c23814000",
                              "permissions": [
                                      "read:orgs/5585922b87b26ff0/annotations",
                                      "write:orgs/5585922b87b26ff0/annotations",
                                      "read:orgs/5585922b87b26ff0/authorizations",
                                      "write:orgs/5585922b87b26ff0/authorizations",
                                      "read:orgs/5585922b87b26ff0/buckets",
                                      "write:orgs/5585922b87b26ff0/buckets",
                                      "read:orgs/5585922b87b26ff0/checks",
                                      "write:orgs/5585922b87b26ff0/checks",
                                      "read:orgs/5585922b87b26ff0/dashboards",
                                      "write:orgs/5585922b87b26ff0/dashboards",
                                      "read:orgs/5585922b87b26ff0/dbrp",
                                      "write:orgs/5585922b87b26ff0/dbrp",
                                      "read:orgs/5585922b87b26ff0/documents",
                                      "write:orgs/5585922b87b26ff0/documents",
                                      "read:orgs/5585922b87b26ff0/labels",
                                      "write:orgs/5585922b87b26ff0/labels",
                                      "read:orgs/5585922b87b26ff0/notebooks",
                                      "write:orgs/5585922b87b26ff0/notebooks",
                                      "read:orgs/5585922b87b26ff0/notificationEndpoints",
                                      "write:orgs/5585922b87b26ff0/notificationEndpoints",
                                      "read:orgs/5585922b87b26ff0/notificationRules",
                                      "write:orgs/5585922b87b26ff0/notificationRules",
                                      "read:/orgs/5585922b87b26ff0",
                                      "read:orgs/5585922b87b26ff0/remotes",
                                      "write:orgs/5585922b87b26ff0/remotes",
                                      "read:orgs/5585922b87b26ff0/replications",
                                      "write:orgs/5585922b87b26ff0/replications",
                                      "read:orgs/5585922b87b26ff0/scrapers",
                                      "write:orgs/5585922b87b26ff0/scrapers",
                                      "read:orgs/5585922b87b26ff0/secrets",
                                      "write:orgs/5585922b87b26ff0/secrets",
                                      "read:orgs/5585922b87b26ff0/sources",
                                      "write:orgs/5585922b87b26ff0/sources",
                                      "read:orgs/5585922b87b26ff0/tasks",
                                      "write:orgs/5585922b87b26ff0/tasks",
                                      "read:orgs/5585922b87b26ff0/telegrafs",
                                      "write:orgs/5585922b87b26ff0/telegrafs",
                                      "read:/users/0c52172c23814000",
                                      "write:/users/0c52172c23814000",
                                      "read:orgs/5585922b87b26ff0/variables",
                                      "write:orgs/5585922b87b26ff0/variables",
                                      "read:orgs/5585922b87b26ff0/views",
                                      "write:orgs/5585922b87b26ff0/views"
                              "id": "0c55f9fbfc67e000",
                              "description": "Iobroker (cloned at 2023-12-26 20:56:55)",
                              "token": "2HXiLlQiU_mc3wKWMMkPSlnH66opy68vpkXBxIkWlDfzwpOFf3JjRfk8HUdEUxLegV3Vy0qHSY7dIR78jUB8bA==",
                              "status": "active",
                              "permissions": [
                              "id": "0c55fb5aac495000",
                              "description": "Backitup",
                              "token": "qa1TtBLVxvesQrUawIgN98VLv4__pSLmstVX6L-uW28IlUQk8EvcKNeCbUH82BH3t3JV6RWUB-ssdFdxg4xyqg==",
                              "status": "active",
                              "permissions": [
                                      "write:/orgs/5585922b87b26ff0",
                                      "write:orgs/5585922b87b26ff0/views",
              W simatecS 2 Antworten Letzte Antwort
              • W Willi-Wunder
                                "status": "active",
                                "permissions": [
                                "status": "active",
                                "permissions": [
                                "status": "active",
                                "permissions": [
                W Offline
                W Offline
                Willi-Wunder
                #87
                Backitup klappt aber trotzdem noch nicht
                [DEBUG] [influxDB] - InfluxDB-Backup started ...
                [DEBUG] [influxDB] - Start InfluxDB Backup ...
                [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_12_27-00_04_27_backupiobroker"
                [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_12_27-00_04_27_backupiobroker" successfully deleted
                [ERROR] [influxDB] - Error: Command failed: influx backup --bucket Iobroker -t 74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A== "/opt/iobroker/backups/influxDB_2023_12_27-00_04_27_backupiobroker"
                2023/12/27 00:04:27 INFO: Downloading metadata snapshot
                Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                • W Willi-Wunder
                                  "status": "active",
                                  "permissions": [
                                  "status": "active",
                                  "permissions": [
                                  "status": "active",
                                  "permissions": [
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #88
                  @willi-wunder Bingo ... du hast deinen Operator-Token gelöscht
                  https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#operator-token-für-influxdb-2x-wiederherstellen
                  • Besuche meine Github Seite
                  • HowTo Restore ioBroker
                  • simatecS simatec
                    W Offline
                    W Offline
                    Willi-Wunder
                    #89
                    @simatec
                    pi@iobroker:~ $ sudo influxd recovery auth create-operator --org my-org --userna        me Markus --bolt-path /var/lib/influxdb2/influxd.bolt
                    2023-12-26T23:12:55.164195Z     info    Resources opened        {"log_id": "0mM6        HmUW000", "system": "bolt-kvstore", "path": "/var/lib/influxdb2/influxd.bolt"}
                    Error: bucket "authorizationsv1": bucket not found
                    See 'influxd -h' for help
                    • W Willi-Wunder
                      @simatec
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #90
                      @willi-wunder da fehlt die Hälfte
                      • W Willi-Wunder
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #91
                        @willi-wunder sagte in mit backitup kein Influxdb und Grafana backup möglich:
                        Es steht doch im der Anleitung, was du machen musst, wenn dieser Fehler kommt ...
                        Du hast mit großer Wahrscheinlichkeit von einer influxdb 1.x migriert und deshalb passt der Pfad nicht
                        • simatecS simatec
                          W Offline
                          W Offline
                          Willi-Wunder
                          #92
                          @simatec
                          sudo influxd recovery auth create-operator --org my-org --username Markus --bolt-path /var/lib/influxdb2/influxd.bolt
                          Die Zeichen "<>" werden ja weggelassen. Was habe ich noch falsch gemacht?
                          • W Willi-Wunder
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #93
                            @willi-wunder
                            find / -name influxd.bolt
                            • simatecS simatec
                              W Offline
                              W Offline
                              Willi-Wunder
                              #94
                              Vermutlich dann eher aus dem einspielen vom Backup. Hatte auf dem neuen System alles neu installiert gehabt, aber dann wird das vermutlich so sein.
                              • W Offline
                                W Offline
                                Willi-Wunder
                                #95
                                pi@iobroker:~ $ sudo find / -name influxd.bolt
                                find: '/run/user/1000/doc': Permission denied
                                find: '/run/user/1000/gvfs': Permission denied
                                /var/lib/influxdb/influxd.bolt
                                • W Willi-Wunder
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  #96
                                  pi@iobroker:~ $ sudo influxd recovery auth create-operator --org my-org --username Markus --bolt-path /var/lib/influxdb/influxd.bolt
                                  2023-12-26T23:27:27.171331Z     info    Resources opened        {"log_id": "0mM76~lW000", "system": "bolt-kvstore", "path": "/var/lib/influxdb/influxd.bolt"}
                                  ID                      User Name       User ID                 Description                                     Token                                      Permissions
                                  0c54cd2ed3814000        Markus          0c52172c23814000        Iobroker                                        74VTRbf_Qc6sAG_goAo4AMkdEdPKkPdWFyxVzrPhY5hNuxX43QdnYAiIWp9rmexTYHJbxa1I0dQ_wNkqkexV7A==    [read:orgs/5585922b87b26ff0/annotations write:orgs/5585922b87b26ff0/annotations read:orgs/5585922b87b26ff0/authorizations write:orgs/5585922b87b26ff0/authorizations read:orgs/5585922b87b26ff0/buckets write:orgs/5585922b87b26ff0/buckets read:orgs/5585922b87b26ff0/checks write:orgs/5585922b87b26ff0/checks read:orgs/5585922b87b26ff0/dashboards write:orgs/5585922b87b26ff0/dashboards read:orgs/5585922b87b26ff0/dbrp write:orgs/5585922b87b26ff0/dbrp read:orgs/5585922b87b26ff0/documents write:orgs/5585922b87b26ff0/documents read:orgs/5585922b87b26ff0/labels write:orgs/5585922b87b26ff0/labels read:orgs/5585922b87b26ff0/notebooks write:orgs/5585922b87b26ff0/notebooks read:orgs/5585922b87b26ff0/notificationEndpoints write:orgs/5585922b87b26ff0/notificationEndpoints read:orgs/5585922b87b26ff0/notificationRules write:orgs/5585922b87b26ff0/notificationRules read:orgs/5585922b87b26ff0 read:orgs/5585922b87b26ff0/remotes write:orgs/5585922b87b26ff0/remotes read:orgs/5585922b87b26ff0/replications write:orgs/5585922b87b26ff0/replications read:orgs/5585922b87b26ff0/scrapers write:orgs/5585922b87b26ff0/scrapers read:orgs/5585922b87b26ff0/secrets write:orgs/5585922b87b26ff0/secrets read:orgs/5585922b87b26ff0/sources write:orgs/5585922b87b26ff0/sources read:orgs/5585922b87b26ff0/tasks write:orgs/5585922b87b26ff0/tasks read:orgs/5585922b87b26ff0/telegrafs write:orgs/5585922b87b26ff0/telegrafs read:users/0c52172c23814000 write:users/0c52172c23814000 read:orgs/5585922b87b26ff0/variables write:orgs/5585922b87b26ff0/variables read:orgs/5585922b87b26ff0/views write:orgs/5585922b87b26ff0/views]
                                  0c55f9fbfc67e000        Markus          0c52172c23814000        Iobroker (cloned at 2023-12-26 20:56:55)        2HXiLlQiU_mc3wKWMMkPSlnH66opy68vpkXBxIkWlDfzwpOFf3JjRfk8HUdEUxLegV3Vy0qHSY7dIR78jUB8bA==    [read:orgs/5585922b87b26ff0/annotations write:orgs/5585922b87b26ff0/annotations read:orgs/5585922b87b26ff0/authorizations write:orgs/5585922b87b26ff0/authorizations read:orgs/5585922b87b26ff0/buckets write:orgs/5585922b87b26ff0/buckets read:orgs/5585922b87b26ff0/checks write:orgs/5585922b87b26ff0/checks read:orgs/5585922b87b26ff0/dashboards write:orgs/5585922b87b26ff0/dashboards read:orgs/5585922b87b26ff0/dbrp write:orgs/5585922b87b26ff0/dbrp read:orgs/5585922b87b26ff0/documents write:orgs/5585922b87b26ff0/documents read:orgs/5585922b87b26ff0/labels write:orgs/5585922b87b26ff0/labels read:orgs/5585922b87b26ff0/notebooks write:orgs/5585922b87b26ff0/notebooks read:orgs/5585922b87b26ff0/notificationEndpoints write:orgs/5585922b87b26ff0/notificationEndpoints read:orgs/5585922b87b26ff0/notificationRules write:orgs/5585922b87b26ff0/notificationRules read:orgs/5585922b87b26ff0 read:orgs/5585922b87b26ff0/remotes write:orgs/5585922b87b26ff0/remotes read:orgs/5585922b87b26ff0/replications write:orgs/5585922b87b26ff0/replications read:orgs/5585922b87b26ff0/scrapers write:orgs/5585922b87b26ff0/scrapers read:orgs/5585922b87b26ff0/secrets write:orgs/5585922b87b26ff0/secrets read:orgs/5585922b87b26ff0/sources write:orgs/5585922b87b26ff0/sources read:orgs/5585922b87b26ff0/tasks write:orgs/5585922b87b26ff0/tasks read:orgs/5585922b87b26ff0/telegrafs write:orgs/5585922b87b26ff0/telegrafs read:users/0c52172c23814000 write:users/0c52172c23814000 read:orgs/5585922b87b26ff0/variables write:orgs/5585922b87b26ff0/variables read:orgs/5585922b87b26ff0/views write:orgs/5585922b87b26ff0/views]
                                  0c55fb5aac495000        Markus          0c52172c23814000        Backitup                                        qa1TtBLVxvesQrUawIgN98VLv4__pSLmstVX6L-uW28IlUQk8EvcKNeCbUH82BH3t3JV6RWUB-ssdFdxg4xyqg==    [read:orgs/5585922b87b26ff0/authorizations write:orgs/5585922b87b26ff0/authorizations read:orgs/5585922b87b26ff0/buckets write:orgs/5585922b87b26ff0/buckets read:orgs/5585922b87b26ff0/dashboards write:orgs/5585922b87b26ff0/dashboards read:orgs/5585922b87b26ff0 write:orgs/5585922b87b26ff0 read:orgs/5585922b87b26ff0/sources write:orgs/5585922b87b26ff0/sources read:orgs/5585922b87b26ff0/tasks write:orgs/5585922b87b26ff0/tasks read:orgs/5585922b87b26ff0/telegrafs write:orgs/5585922b87b26ff0/telegrafs read:users/0c52172c23814000 write:users/0c52172c23814000 read:orgs/5585922b87b26ff0/variables write:orgs/5585922b87b26ff0/variables read:orgs/5585922b87b26ff0/scrapers write:orgs/5585922b87b26ff0/scrapers read:orgs/5585922b87b26ff0/secrets write:orgs/5585922b87b26ff0/secrets read:orgs/5585922b87b26ff0/labels write:orgs/5585922b87b26ff0/labels read:orgs/5585922b87b26ff0/views write:orgs/5585922b87b26ff0/views read:orgs/5585922b87b26ff0/documents write:orgs/5585922b87b26ff0/documents read:orgs/5585922b87b26ff0/notificationRules write:orgs/5585922b87b26ff0/notificationRules read:orgs/5585922b87b26ff0/notificationEndpoints write:orgs/5585922b87b26ff0/notificationEndpoints read:orgs/5585922b87b26ff0/checks write:orgs/5585922b87b26ff0/checks read:orgs/5585922b87b26ff0/dbrp write:orgs/5585922b87b26ff0/dbrp read:orgs/5585922b87b26ff0/notebooks write:orgs/5585922b87b26ff0/notebooks read:orgs/5585922b87b26ff0/annotations write:orgs/5585922b87b26ff0/annotations read:orgs/5585922b87b26ff0/remotes write:orgs/5585922b87b26ff0/remotes read:orgs/5585922b87b26ff0/replications write:orgs/5585922b87b26ff0/replications]
                                  0c561c6ff19d0000        Markus          0c52172c23814000        Markus's Recovery Token                         yaNHdwh6KjzO0euGPkiyhVon1uZKN4tuqaDAUL4tvVKIz14-4A-_0ZIsP9ScW_XkjVYrdwpm5iUahPDBCbuhIw==    [read:authorizations write:authorizations read:buckets write:buckets read:dashboards write:dashboards read:orgs write:orgs read:sources write:sources read:tasks write:tasks read:telegrafs write:telegrafs read:users write:users read:variables write:variables read:scrapers write:scrapers read:secrets write:secrets read:labels write:labels read:views write:views read:documents write:documents read:notificationRules write:notificationRules read:notificationEndpoints write:notificationEndpoints read:checks write:checks read:dbrp write:dbrp read:notebooks write:notebooks read:annotations write:annotations read:remotes write:remotes read:replications write:replications]
                                  • W Willi-Wunder
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #97
                                    @willi-wunder
                                    sudo ls -lah /var/lib/influxdb2
                                    sudo ls -lah /var/lib/influxdb/influxd.bolt
                                    • W Willi-Wunder
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #98
                                      Hier ist dein neuer Operatortoken... Den fügst du in Backitup ein und bitte nie wieder löschen
                                      W 2 Antworten Letzte Antwort
                                      • simatecS simatec
                                        W Offline
                                        W Offline
                                        Willi-Wunder
                                        #99
                                        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_12_27-00_30_36_backupiobroker"
                                        [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_12_27-00_30_36_backupiobroker" successfully deleted
                                        [ERROR] [influxDB] - Error: Command failed: influx backup --bucket Iobroker -t yaNHdwh6KjzO0euGPkiyhVon1uZKN4tuqaDAUL4tvVKIz14-4A-_0ZIsP9ScW_XkjVYrdwpm5iUahPDBCbuhIw== "/opt/iobroker/backups/influxDB_2023_12_27-00_30_36_backupiobroker"
                                        Error: API compatibility check failed: Get "http://localhost:8086/health": dial tcp [::1]:8086: connect: connection refused
                                        [DEBUG] [influxDB] - InfluxDB-Backup for is finish
                                        [DEBUG] [influxDB] - done
                                        Warte, doof, influxDb war nicht gestartet, glaube jetzt läuft es......
                                        [DEBUG] [influxDB] - Packed 71MB so far...
                                        [DEBUG] [influxDB] - Packed 144MB so far...
                                        [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2023_12_27-00_34_14_backupiobroker.tar.gz
                                        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_12_27-00_34_14_backupiobroker"
                                        [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_12_27-00_34_14_backupiobroker" successfully deleted
                                        • W Willi-Wunder
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #100
                                          @willi-wunder jup jetzt passt alles
