  4. [gelöst] - Fritzbox-Adapter startet nicht
30 Beiträge 6 Kommentatoren 3.7k Aufrufe 5 Beobachtet
  • P Papi 0
    @codierknecht
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : Insyde
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     22:34:22 up 7 days,  4:34,  0 users,  load average: 3.25, 3.02, 2.95
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Nov 22 21:34:22 UTC 2023
    Wed Nov 22 22:34:22 CET 2023
    CET +0100
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             16G        4.6G        163M         46M         11G         11G
    Swap:           2.0G        1.4G        663M
    Total:           18G        5.9G        827M
            16041 M total memory
             4547 M used memory
             4971 M active memory
             5567 M inactive memory
              166 M free memory
               48 M buffer memory
            11278 M swap cache
             2047 M total swap
             1384 M used swap
              663 M free swap
    *** FILESYSTEM ***
    Filesystem        Type   Size  Used Avail Use% Mounted on
    /dev/vg2/volume_1 btrfs   48T   27T   21T  58% /
    tmpfs             tmpfs   64M     0   64M   0% /dev
    tmpfs             tmpfs  7.9G     0  7.9G   0% /sys/fs/cgroup
    shm               tmpfs   64M     0   64M   0% /dev/shm
    /dev/vg2/volume_1 btrfs   48T   27T   21T  58% /opt/iobroker
    /dev/vg2/volume_1 btrfs   48T   27T   21T  58% /etc/hosts
    tmpfs             tmpfs  7.9G     0  7.9G   0% /proc/asound
    tmpfs             tmpfs  7.9G     0  7.9G   0% /proc/acpi
    tmpfs             tmpfs  7.9G     0  7.9G   0% /proc/scsi
    tmpfs             tmpfs  7.9G     0  7.9G   0% /sys/firmware
    [Wed Nov 15 18:00:05 2023] EXT4-fs (md0): barriers disabled
    [Wed Nov 15 18:00:05 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
    [Wed Nov 15 18:00:07 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Wed Nov 15 18:00:08 2023] EXT4-fs (md0): re-mounted. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/vg2/volume_1[/@docker/btrfs/subvolumes/9ab1c3faaeadf83f6f62dd1db43a34333cd29699762986eb66ad4c0a09a102a4]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
    |-/opt/iobroker    /dev/vg2/volume_1[/docker/iobroker1_data]        btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
    |-/etc/resolv.conf /dev/vg2/volume_1[/@docker/containers/1a7f7c299ee380d7f600c1de144d6c14a8d7d32d35a0d83dcef115c7819c7e29/resolv.conf] btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
    |-/etc/hostname    /dev/vg2/volume_1[/@docker/containers/1a7f7c299ee380d7f600c1de144d6c14a8d7d32d35a0d83dcef115c7819c7e29/hostname]    btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
    `-/etc/hosts       /dev/vg2/volume_1[/@docker/containers/1a7f7c299ee380d7f600c1de144d6c14a8d7d32d35a0d83dcef115c7819c7e29/hosts]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
    /var:
    33M     /var/
    30M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    48M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    311M    /opt/iobroker/iobroker-data/
    201M    /opt/iobroker/iobroker-data/files
    77M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    13M     /opt/iobroker/iobroker-data/states.jsonl
    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    *** NodeJS-Installation ***
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker1                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker1                                -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker1                                -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker1                                -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker1                                -  enabled
    + system.adapter.divera247.0              : divera247             : iobroker1                                -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker1                                -  enabled
    + system.adapter.email.0                  : email                 : iobroker1                                -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker1                                -  enabled
      system.adapter.fritzbox.0               : fritzbox              : iobroker1                                -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker1                                -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker1                                -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker1                                -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker1                                -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker1                                -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker1                                -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker1                                -  enabled, port: 0
    + system.adapter.info.0                   : info                  : iobroker1                                -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker1                                -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker1                                -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker1                                - disabled, port: 54321
    + system.adapter.net-tools.0              : net-tools             : iobroker1                                -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker1                                -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker1                                -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker1                                -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker1                                -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker1                                -  enabled
    + system.adapter.vesync.0                 : vesync                : iobroker1                                -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker1                                - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker1                                - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker1                                - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker1                                -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker1                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker1                                - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker1                                - disabled
      system.adapter.vis.0                    : vis                   : iobroker1                                -  enabled
    + system.adapter.web.0                    : web                   : iobroker1                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : iobroker1                                -  enabled
    + system.adapter.ws.0                     : ws                    : iobroker1                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : iobroker1                                -  enabled
    + instance is alive
    ioBroker-Repositories
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "divera247"    : 0.2.0    , installed 0.2.0
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "socketio"     : 6.5.5    , installed 6.6.0
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vesync"       : 0.0.3    , installed 0.0.3
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.97.1   , installed 0.97.1
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "worx"         : 2.3.4    , installed 2.3.4
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        23727
    States:         20029
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 35
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       130242998  -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       130236565  -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       130234447  -
    tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      1000       130243065  -
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       130243663  -
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       130243202  -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       130238696  -
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       130264322  -
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       130259813  -
    udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          130214941  -
    2023-11-22 22:30:08.403  - info: host.iobroker1 instance system.adapter.yr.0 started with pid 5343
    2023-11-22 22:30:11.070  - info: yr.0 (5343) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-11-22 22:30:11.243  - info: yr.0 (5343) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v18.17.1, js-controller: 5.0.16
    2023-11-22 22:30:11.290  - info: yr.0 (5343) longitude/longitude not set, get data from system
    2023-11-22 22:30:11.326  - info: yr.0 (5343) system latitude: 51.28058000 longitude: 6.45123000
    2023-11-22 22:30:12.483  - info: host.iobroker1 instance system.adapter.daswetter.0 started with pid 5362
    2023-11-22 22:30:15.224  - info: daswetter.0 (5362) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-11-22 22:30:15.421  - info: daswetter.0 (5362) starting. Version 3.1.10 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.17.1, js-controller: 5.0.16
    2023-11-22 22:30:31.553  - info: openweathermap.0 (5321) Terminated (NO_ERROR): Without reason
    2023-11-22 22:30:32.093  - info: host.iobroker1 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2023-11-22 22:30:42.180  - info: yr.0 (5343) Data updated.
    2023-11-22 22:30:42.183  - info: yr.0 (5343) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-22 22:30:42.735  - info: host.iobroker1 instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-22 22:30:46.955  - info: daswetter.0 (5362) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-11-22 22:30:47.471  - info: daswetter.0 (5362) cleaned everything up...
    2023-11-22 22:30:47.502  - info: host.iobroker1 instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-22 22:31:10.559  - info: hm-rega.0 (291) pollingTrigger
    2023-11-22 22:33:11.546  - info: hm-rega.0 (291) pollingTrigger
    2023-11-22 22:34:17.747  - info: hm-rega.0 (291) pollingTrigger
    2023-11-22 22:35:00.072  - info: host.iobroker1 instance system.adapter.dwd.0 started with pid 6375
    2023-11-22 22:35:03.088  - info: dwd.0 (6375) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-11-22 22:35:03.524  - info: dwd.0 (6375) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.16
    2023-11-22 22:35:06.569  - info: dwd.0 (6375) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-22 22:35:07.109  - info: host.iobroker1 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-22 22:35:16.459  - info: hm-rega.0 (291) pollingTrigger
    Copy text starting here:
                            v.2023-10-10
    model name      : Intel(R) Atom(TM) CPU  C2538  @ 2.40GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     35
    Pending iob updates:    1
    /home/iobroker/.diag.sh: line 486: nodejs: command not found
    Nodejs-Installation:
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    Wrong installation path detected. This needs to be fixed.
    Please check
    for more information on how to fix these errors.
    MEMORY:
    Mem:             16G        4.5G        306M         46M         11G         11G
    Swap:           2.0G        1.4G        666M
    Total:           18G        5.9G        972M
    Active iob-Instances:   28
    ioBroker Core:          js-controller           5.0.16
                            admin                   6.12.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                23727
    States:                 20029
    Size of iob-Database:
    15M     /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    Ich sehe schon - *** nodejs is NOT correctly installed ***
    Hier ist aber mein Latein eingeschränkt, denn mit Linux habe ich es nicht so und ich weiß auch nicht, wo nodejs ansonsten hin muss und wie ich das bewerkstelligen muss.
    CodierknechtC Offline
    Codierknecht
    @papi-0 sagte in Fritzbox-Adapter startet nicht:
    Du hast das Verzeichnis mit den Daten vom NAS in den Container gemappt?
    • Container stoppen (und löschen)
    • Neuen Container mit identischen EInstellungen erzeugen und starten
      Dazu am besten das aktuelle Image von buanet verwenden
    • warten, warten, warten ... voilá
    Container sind Wegwerfartikel. Dazu sind sie gedacht.
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    P 1 Antwort Letzte Antwort
    • CodierknechtC Codierknecht
      Papi 0
      schrieb am zuletzt editiert von Papi 0
      @codierknecht
      Ja, ich habe das Verzeichnis mit den Daten vom NAS in den Container gemappt.
      Also mit Portainer einfach ein Recreate unter neuem Image ausführen?
      • P Papi 0
        @codierknecht
        Codierknecht
        @papi-0
        Ich habe das immer ohne Portainer gemacht.
        Ist ja mit ein paar Klicks gemacht.
        Mit Portainer müssen andere weiterhelfen.
        Läuft auf dem NAS eigentlich noch etwas anderes, außer dass es als Datengrab dient?
        Wenn Portkollisionen ausgeschlossen sind, könntest Du den neuen Container auch im Host-Modus betreiben. Spart das Durchreichen der einzelnen Ports.
        P 2 Antworten Letzte Antwort
          @papi-0
          Papi 0
          @codierknecht
          Ja, da läuft noch etwas viel Anderes, der Host-Mode wäre mir darum echt zu heikel.
          Das Ding ist so ausgelastet, dass ich schon ein paar Container auf Raspi auslagern musste.
          Bisher habe ich meine Ports aber noch genauestens im Griff, da sollte sich nichts überschneiden.
          Ok, dann erstmal vielen Dank für die professionelle Hilfe!
          Ich werde das wohl besser am Wochenende direkt zu Hause machen, da ich momentan auf Dienstreise bin, solche Sachen nicht gerne fernab der Basis per VPN mache, langsam in die Kiste muss und vorher alles wegsichern möchte, was erfahrungsgemäß eine Weile dauert, genauso, wie dann die Wiederherstellung des ioBrokers.
          1000 Dank, ich werde wieder Rückmeldung erstatten.
          Gruß Michael
          • P Papi 0
            @codierknecht
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v8.1.0
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
            CET +0100
            Etc/UTC
            root
            /root
            root
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
                     4547 M used memory
                      166 M free memory
                       48 M buffer memory
                    11278 M swap cache
                     2047 M total swap
                     1384 M used swap
                      663 M free swap
            *** FILESYSTEM ***
            /var:
            33M     /var/
            30M     /var/lib
            18M     /var/lib/apt
            13M     /var/lib/dpkg
            USB-Devices by-id:
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        23727
            States:         20029
            Pending Updates: 35
                                    v.2023-10-10
            Kernel          : x86_64
            Userland        : amd64
            Docker          : v8.1.0
            Kernel:                 x86_64
            Userland:               amd64
            Timezone:               Etc/UTC
            User-ID:                0
            X-Server:               false
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            Please check
            MEMORY:
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                23727
            States:                 20029
            Quark geschrieben...
              Papi 0
              Was soll denn dieser Beitrag?
              • P Papi 0
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @papi-0
                wenn man selbst "Unsinn" geschrieben hat dann löscht man die eigenen Beiträge und schreibt dann eben so was wie "Quark geschrieben" !
                Lehrling seit 1975 !!!
                  @papi-0
                  Papi 0
                  @codierknecht
                  So, wie angekündigt, habe ich Deinen Rat gerade befolgt. Der ioBroker läuft mit aktuellem Image (buanet/iobroker:latest (22.11.2023)) wieder, aber das eingangs aufgeführte Problem hat sich leider nicht verflüchtigt, obwohl Nodejs wohl nun korrekt installiert ist, wie die Diagnose mitteilt:
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                  Kernel          : x86_64
                  Userland        : amd64
                  Docker          : v9.0.1
                  Kernel          : x86_64
                  Userland        : amd64
                   08:37:26 up 10 days, 14:37,  0 user,  load average: 3.07, 3.85, 4.39
                  CPU threads: 4
                  Sun Nov 26 07:37:26 UTC 2023
                  Sun Nov 26 08:37:26 CET 2023
                  CET +0100
                  Etc/UTC
                  root
                  /root
                  root
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:             16G         15G        1.6G        243M         10G        1.6G
                  Swap:           2.1G        1.7G        461M
                  Total:           18G         16G        2.0G
                          14550 M used memory
                           4948 M active memory
                           6405 M inactive memory
                           1490 M free memory
                             23 M buffer memory
                           9796 M swap cache
                           2047 M total swap
                           1607 M used swap
                            440 M free swap
                  *** FILESYSTEM ***
                  /                  /dev/vg2/volume_1[/@docker/btrfs/subvolumes/09dffbd202054221355666351eaac6b319b400c00c732f58fe9fa106a6f6ddc9]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                  |-/etc/resolv.conf /dev/vg2/volume_1[/@docker/containers/028486a4b205d410539f43bd68ba301c328c01af9ee9251a6c3716fce2cc196e/resolv.conf] btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                  |-/etc/hostname    /dev/vg2/volume_1[/@docker/containers/028486a4b205d410539f43bd68ba301c328c01af9ee9251a6c3716fce2cc196e/hostname]    btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                  `-/etc/hosts       /dev/vg2/volume_1[/@docker/containers/028486a4b205d410539f43bd68ba301c328c01af9ee9251a6c3716fce2cc196e/hosts]       btrfs  rw,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50
                  /var:
                  15M     /var/
                  13M     /var/lib/dpkg
                  13M     /var/lib
                  12M     /var/lib/dpkg/info
                  1.9M    /var/cache
                  363M    /opt/iobroker/iobroker-data/
                  215M    /opt/iobroker/iobroker-data/files
                  78M     /opt/iobroker/iobroker-data/backup-objects
                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                  48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                  38M     /opt/iobroker/iobroker-data/states.jsonl
                  33M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  /usr/bin/nodejs         v18.18.2
                  /usr/bin/node           v18.18.2
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  /usr/bin/corepack       0.19.0
                  nodejs:
                    Installed: 18.18.2-1nodesource1
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                   *** 18.18.2-1nodesource1 100
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker1                                -  enabled, port: 54321
                  + instance is alive
                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                  Adapter    "socketio"     : 6.6.0    , installed 6.6.0
                  Objects and States
                  Objects:        23731
                  States:         20046
                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       192287449  -
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       192278619  -
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       192277686  -
                  tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      1000       192289429  -
                  tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       192285535  -
                  tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       192289513  -
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       192283699  -
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1000       192302715  -
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1000       192303709  -
                  udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          192256079  -
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       192475277  -
                  2023-11-26 08:36:52.394  - error: host.iobroker1 Caught by controller[4]:  4: 0x7f6e5c7c247c Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                  2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[5]:  5: 0x7f6e5c7b43d3  [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                  2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[6]:  6: 0xdc4e00  [io.mihome-vacuum.0]
                  2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[7]:  7: 0xdc633f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
                  2023-11-26 08:36:52.395  - error: host.iobroker1 Caught by controller[8]:  8: 0x1705c39  [io.mihome-vacuum.0]
                  2023-11-26 08:36:52.396  - warn: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                  2023-11-26 08:36:52.396  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated with code null ()
                  2023-11-26 08:36:52.396  - info: host.iobroker1 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                  2023-11-26 08:37:22.690  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 started with pid 3593
                  2023-11-26 08:37:36.323  - error: mihome-vacuum.0 (3593) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                  2023-11-26 08:37:37.416  - info: hm-rega.0 (635) pollingTrigger
                  2023-11-26 08:38:03.653  - error: host.iobroker1 Caught by controller[0]: FATAL ERROR: v8::ToLocalChecked Empty MaybeLocal.
                  2023-11-26 08:38:03.654  - error: host.iobroker1 Caught by controller[1]:  1: 0xb85bc0 node::Abort() [io.mihome-vacuum.0]
                  2023-11-26 08:38:03.654  - error: host.iobroker1 Caught by controller[2]:  2: 0xa94749 node::OOMErrorHandler(char const*, bool) [io.mihome-vacuum.0]
                  2023-11-26 08:38:03.654  - error: host.iobroker1 Caught by controller[3]:  3: 0xd66a2a v8::Utils::ReportApiFailure(char const*, char const*) [io.mihome-vacuum.0]
                  2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[3]:  4: 0x7f0b7846847c Context2d::GetImageData(Nan::FunctionCallbackInfo<v8::Value> const&) [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                  2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[3]:  5: 0x7f0b7845a3d3  [/opt/iobroker/node_modules/canvas/build/Release/canvas.node]
                  2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[4]:  6: 0xdc4e00  [io.mihome-vacuum.0]
                  2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[5]:  7: 0xdc633f v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.mihome-vacuum.0]
                  2023-11-26 08:38:03.655  - error: host.iobroker1 Caught by controller[6]:  8: 0x1705c39  [io.mihome-vacuum.0]
                  2023-11-26 08:38:03.656  - warn: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                  2023-11-26 08:38:03.656  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 terminated with code null ()
                  2023-11-26 08:38:03.656  - info: host.iobroker1 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                  2023-11-26 08:38:17.891  - info: hm-rega.0 (635) pollingTrigger
                  2023-11-26 08:38:33.911  - info: host.iobroker1 instance system.adapter.mihome-vacuum.0 started with pid 4224
                  (Den Fully-Adapter habe ich übrigens extra noch auf 2.2.0, weil ichMQTT mit der 3.0.6 ad hoc auf den Displays nicht ans Laufen bekomme. Das Alte Display kann das eh nicht mehr)
                                          v.2023-10-10
                  Kernel          : x86_64
                  Userland        : amd64
                  Docker          : v9.0.1
                  Kernel:                 x86_64
                  Userland:               amd64
                  Timezone:               Etc/UTC
                  User-ID:                0
                  X-Server:               false
                  Pending OS-Updates:     0
                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                  MEMORY:
                  Mem:             16G         15G        1.3G        243M         10G        1.3G
                  Total:           18G         17G        1.8G
                  Active iob-Instances:   29
                                          admin                   6.12.0
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                23731
                  States:                 20046
                  40M     /opt/iobroker/iobroker-data/states.jsonl
                  Ich habe schonmal einen Vergleich zwischen den beiden Diags gemacht, mit dem Ergebnis, dass alles Negative wohl dankenswerterweise nun beseitigt ist.
                  Beim Starten des ioBrokers werde ich aber schon darauf hingewiesen, dass fritzbox.0 Ärger macht und ich mir das Log vor einem weiteren Restart ansehen soll.
                  Nachfolgend das Log, gefiltert auf den fritzbox.0-Adapter, ich meine, es steht dasselbe drin, wie zuvor:
                  fritzbox.0
                  2023-11-26 08:58:07.848	info	terminating
                  fritzbox.0
                  2023-11-26 08:58:07.346	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  fritzbox.0
                  2023-11-26 08:58:07.335	info	terminating
                  fritzbox.0
                  2023-11-26 08:58:07.280	error	Cannot read properties of undefined (reading 'startsWith')
                  fritzbox.0
                  2023-11-26 08:58:07.279	error	TypeError: Cannot read properties of undefined (reading 'startsWith') at /opt/iobroker/node_modules/iobroker.fritzbox/main.js:1440:73 at Parser.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (node:events:517:28) at SAXParser.onclosetag (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:625:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:630:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:890:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1437:13) at exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:323:31) at Parser.parseString (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/xml2js/lib/parser.js:5:59)
                  fritzbox.0
                  2023-11-26 08:58:07.276	error	uncaught exception: Cannot read properties of undefined (reading 'startsWith')
                  fritzbox.0
                  2023-11-26 08:58:03.057	warn	TR-064: Error reading files from dir /tam: Error: ENOENT: no such file or directory, scandir 'tam'
                  fritzbox.0
                  2023-11-26 08:58:02.890	info	Successfully connected to TR-064
                  fritzbox.0
                  2023-11-26 08:57:57.551	info	adapter connected to fritzbox: 192.168.1.100
                  fritzbox.0
                  2023-11-26 08:57:57.494	info	Trying to connect to TR-064: 192.168.1.100:49000
                  fritzbox.0
                  2023-11-26 08:57:57.491	info	try to connect: 192.168.1.100
                  fritzbox.0
                  2023-11-26 08:57:57.426	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.fritzbox, node: v18.18.2, js-controller: 5.0.16
                  fritzbox.0
                  2023-11-26 08:57:55.343	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  Der Host meint übrigens wieder, dass er von 5.0.16 auf 5.0.16 geupdated werden könnte.
                  Auch ein Restart des ioBrokers überzeugt ihn nicht von seinem Glück, dass er bereits aktuell ist.
                  (Beim letzten Mal - vorige Tage - war es am nachfolgenden Tag nicht mehr zu sehen.)
                  Der Staubsauger macht übrigens auch wieder das gleiche Theater. :-/
                  Ich hänge ihn (mihome-vacuum.0) hier der Vollständigkeit halber noch debug-mäßig mit an:
                  mihome-vacuum.0
                  2023-11-26 09:26:14.727	debug	Message= {"id":16,"method":"get_consumable"}
                  mihome-vacuum.0
                  2023-11-26 09:26:14.727	debug	Startup: setGetCleanSummary Answer: false
                  mihome-vacuum.0
                  2023-11-26 09:26:14.726	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:26:14.418	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:26:14.418	debug	Receive <<< Helo <<< 21310020000000000707a91265631695ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:26:12.725	debug	Message= {"id":15,"method":"get_clean_summary"}
                  mihome-vacuum.0
                  2023-11-26 09:26:12.724	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:26:10.723	debug	Message= {"id":14,"method":"get_sound_volume"}
                  mihome-vacuum.0
                  2023-11-26 09:26:10.722	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:26:08.721	debug	Message= {"id":13,"method":"get_network_info"}
                  mihome-vacuum.0
                  2023-11-26 09:26:08.719	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:26:06.718	debug	Message= {"id":12,"method":"get_status"}
                  mihome-vacuum.0
                  2023-11-26 09:26:06.717	debug	get params for stock Vacuum
                  mihome-vacuum.0
                  2023-11-26 09:26:04.415	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:26:04.414	debug	Receive <<< Helo <<< 21310020000000000707a9126563168bffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:25:54.411	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:25:54.409	debug	Receive <<< Helo <<< 21310020000000000707a91265631681ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:25:46.716	debug	Startup: setGetConsumable Answer: false
                  mihome-vacuum.0
                  2023-11-26 09:25:46.714	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:44.712	debug	Message= {"id":11,"method":"get_consumable"}
                  mihome-vacuum.0
                  2023-11-26 09:25:44.711	debug	Startup: setGetCleanSummary Answer: false
                  mihome-vacuum.0
                  2023-11-26 09:25:44.710	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:44.391	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:25:44.390	debug	Receive <<< Helo <<< 21310020000000000707a91265631677ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:25:42.708	debug	Message= {"id":10,"method":"get_clean_summary"}
                  mihome-vacuum.0
                  2023-11-26 09:25:42.708	debug	Startup: Delete getMultiMapsList
                  mihome-vacuum.0
                  2023-11-26 09:25:42.707	debug	Startup: getMultiMapsList Answer: true
                  mihome-vacuum.0
                  2023-11-26 09:25:42.707	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:40.703	debug	Message= {"id":9,"method":"get_multi_maps_list"}
                  mihome-vacuum.0
                  2023-11-26 09:25:40.701	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:38.699	debug	Message= {"id":8,"method":"get_sound_volume"}
                  mihome-vacuum.0
                  2023-11-26 09:25:38.698	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:36.696	debug	Message= {"id":7,"method":"get_network_info"}
                  mihome-vacuum.0
                  2023-11-26 09:25:36.692	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:35.215	info	settest next timer: not available
                  mihome-vacuum.0
                  2023-11-26 09:25:34.683	debug	Message= {"id":6,"method":"get_status"}
                  mihome-vacuum.0
                  2023-11-26 09:25:34.682	debug	get params for stock Vacuum
                  mihome-vacuum.0
                  2023-11-26 09:25:34.681	debug	Create State done!
                  mihome-vacuum.0
                  2023-11-26 09:25:34.680	debug	Create State for map: loadMap
                  mihome-vacuum.0
                  2023-11-26 09:25:34.679	debug	Create State for map: mapURL
                  mihome-vacuum.0
                  2023-11-26 09:25:34.679	debug	Create State for map: mapStatus
                  mihome-vacuum.0
                  2023-11-26 09:25:34.679	debug	Create State for map: actualMap
                  mihome-vacuum.0
                  2023-11-26 09:25:34.678	debug	Create State for map: map64
                  mihome-vacuum.0
                  2023-11-26 09:25:34.640	debug	Create State for map:
                  mihome-vacuum.0
                  2023-11-26 09:25:34.634	debug	Create State for Queue: queue
                  mihome-vacuum.0
                  2023-11-26 09:25:34.514	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                  mihome-vacuum.0
                  2023-11-26 09:25:34.494	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2023-11-26 09:25:34.493	debug	DeviceModel selected to: roborock.vacuum.s5
                  mihome-vacuum.0
                  2023-11-26 09:25:34.492	warn	No Answer for DeviceModel use old one
                  mihome-vacuum.0
                  2023-11-26 09:25:34.492	error	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                  mihome-vacuum.0
                  2023-11-26 09:25:34.491	debug	Get Device data..4
                  mihome-vacuum.0
                  2023-11-26 09:25:34.491	debug	GETMODELFROMAPI:Data: {}
                  mihome-vacuum.0
                  2023-11-26 09:25:34.490	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:34.382	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:25:34.382	debug	Receive <<< Helo <<< 21310020000000000707a9126563166dffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:25:32.485	debug	Message= {"id":5,"method":"miIO.info"}
                  mihome-vacuum.0
                  2023-11-26 09:25:32.485	debug	Get Device data..3
                  mihome-vacuum.0
                  2023-11-26 09:25:32.484	debug	GETMODELFROMAPI:Data: {}
                  mihome-vacuum.0
                  2023-11-26 09:25:32.483	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:30.481	debug	Message= {"id":4,"method":"miIO.info"}
                  mihome-vacuum.0
                  2023-11-26 09:25:30.480	debug	Get Device data..2
                  mihome-vacuum.0
                  2023-11-26 09:25:30.480	debug	GETMODELFROMAPI:Data: {}
                  mihome-vacuum.0
                  2023-11-26 09:25:30.479	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:28.475	debug	Message= {"id":3,"method":"miIO.info"}
                  mihome-vacuum.0
                  2023-11-26 09:25:28.474	debug	Get Device data..1
                  mihome-vacuum.0
                  2023-11-26 09:25:28.474	debug	GETMODELFROMAPI:Data: {}
                  mihome-vacuum.0
                  2023-11-26 09:25:28.473	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:26.471	debug	Message= {"id":2,"method":"miIO.info"}
                  mihome-vacuum.0
                  2023-11-26 09:25:26.471	debug	Get Device data..0
                  mihome-vacuum.0
                  2023-11-26 09:25:26.470	debug	GETMODELFROMAPI:Data: {}
                  mihome-vacuum.0
                  2023-11-26 09:25:26.469	debug	your device is connected, but didn't answer yet - sometime connection is broken and can take up to 10 Minutes
                  mihome-vacuum.0
                  2023-11-26 09:25:24.462	debug	Message= {"id":1,"method":"miIO.info"}
                  mihome-vacuum.0
                  2023-11-26 09:25:24.453	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5","ack":true,"ts":1700987084613,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1669663806090}
                  mihome-vacuum.0
                  2023-11-26 09:25:24.378	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:25:24.375	debug	MAIN: Connected to device, try to get model..
                  mihome-vacuum.0
                  2023-11-26 09:25:24.374	debug	Receive <<< Helo <<< 21310020000000000707a91265631663ffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:25:24.362	debug	server started on 0.0.0.0:53421
                  mihome-vacuum.0
                  2023-11-26 09:25:24.357	info	IOT enabled, create state
                  mihome-vacuum.0
                  2023-11-26 09:25:24.348	debug	MIIO: Config: ip:192.168.1.41 token: 436559496bXXXXXXXXX
                  mihome-vacuum.0
                  2023-11-26 09:25:24.346	debug	Create State for deviceInfounsupported
                  mihome-vacuum.0
                  2023-11-26 09:25:24.345	debug	Create State for deviceInfowifi_signal
                  mihome-vacuum.0
                  2023-11-26 09:25:24.343	debug	Create State for deviceInfofw_ver
                  mihome-vacuum.0
                  2023-11-26 09:25:24.342	debug	Create State for deviceInfomodel
                  mihome-vacuum.0
                  2023-11-26 09:25:24.341	debug	Create State for deviceInfomac
                  mihome-vacuum.0
                  2023-11-26 09:25:24.340	debug	Create State for deviceInfo
                  mihome-vacuum.0
                  2023-11-26 09:25:24.288	debug	load Map creator... true
                  mihome-vacuum.0
                  2023-11-26 09:25:24.184	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.18.2, js-controller: 5.0.16
                  mihome-vacuum.0
                  2023-11-26 09:25:23.615	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  mihome-vacuum.0
                  2023-11-26 09:25:23.599	debug	Plugin sentry Initialize Plugin (enabled=true)
                  mihome-vacuum.0
                  2023-11-26 09:25:23.470	debug	States connected to redis: 127.0.0.1:9000
                  mihome-vacuum.0
                  2023-11-26 09:25:23.292	debug	States create User PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:25:23.291	debug	States create System PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:25:23.223	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                  mihome-vacuum.0
                  2023-11-26 09:25:23.070	debug	Objects connected to redis: 127.0.0.1:9001
                  mihome-vacuum.0
                  2023-11-26 09:25:23.059	debug	Objects client initialize lua scripts
                  mihome-vacuum.0
                  2023-11-26 09:25:22.831	debug	Objects create User PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:25:22.829	debug	Objects create System PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:25:22.719	debug	Objects client ready ... initialize now
                  mihome-vacuum.0
                  2023-11-26 09:25:21.705	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                  mihome-vacuum.0
                  2023-11-26 09:24:45.858	debug	Message= {"id":21,"method":"get_clean_record","params":[1700314076]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.857	debug	MIIO RECIVE: {"result":[[1700317501,1700318356,769,13972500,0,0,3,1]],"id":20}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.856	debug	MIIO MESSAGE TESTING: {"result":[[1700317501,1700318356,769,13972500,0,0,3,1]],"id":20}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.835	debug	Message= {"id":20,"method":"get_clean_record","params":[1700317501]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.833	debug	MIIO RECIVE: {"result":[[1700403901,1700405572,1671,31715000,0,1,3,1]],"id":19}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.831	debug	MIIO MESSAGE TESTING: {"result":[[1700403901,1700405572,1671,31715000,0,1,3,1]],"id":19}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.813	debug	Message= {"id":19,"method":"get_clean_record","params":[1700403901]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.812	debug	MIIO RECIVE: {"result":[[1700486701,1700488361,1660,31490000,0,1,3,1]],"id":18}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.811	debug	MIIO MESSAGE TESTING: {"result":[[1700486701,1700488361,1660,31490000,0,1,3,1]],"id":18}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.801	debug	Message= {"id":18,"method":"get_clean_record","params":[1700486701]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.800	debug	MIIO RECIVE: {"result":[[1700573101,1700574894,1793,31385000,0,1,3,1]],"id":17}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.799	debug	MIIO MESSAGE TESTING: {"result":[[1700573101,1700574894,1793,31385000,0,1,3,1]],"id":17}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.797	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":16}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.796	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":16}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.795	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":16}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.773	debug	Message= {"id":17,"method":"get_clean_record","params":[1700573101]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.772	debug	MIIO MESSAGE TESTING: {"result":[[1700659501,1700661175,1674,31800000,0,1,3,1]],"id":15}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.771	debug	MIIO RECIVE: {"result":[[1700659501,1700661175,1674,31800000,0,1,3,1]],"id":15}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.770	debug	MIIO MESSAGE TESTING: {"result":[[1700659501,1700661175,1674,31800000,0,1,3,1]],"id":15}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.767	debug	Message= {"id":16,"method":"get_carpet_mode"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.766	info	create state for carpet_mode
                  mihome-vacuum.0
                  2023-11-26 09:24:45.765	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":14}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.764	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":14}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.763	debug	MIIO MESSAGE TESTING: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":14}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.761	debug	Message= {"id":15,"method":"get_clean_record","params":[1700659501]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.760	debug	MIIO MESSAGE TESTING: {"result":[[1700745900,1700747612,1712,31885000,0,1,3,1]],"id":13}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.760	debug	MIIO RECIVE: {"result":[[1700745900,1700747612,1712,31885000,0,1,3,1]],"id":13}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.759	debug	MIIO MESSAGE TESTING: {"result":[[1700745900,1700747612,1712,31885000,0,1,3,1]],"id":13}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.757	debug	Message= {"id":14,"method":"get_carpet_mode"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.755	debug	Startup: Delete setGetConsumable
                  mihome-vacuum.0
                  2023-11-26 09:24:45.755	debug	Startup: setGetConsumable Answer: true
                  mihome-vacuum.0
                  2023-11-26 09:24:45.753	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":12}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.752	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":12}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.751	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":12}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.749	debug	Message= {"id":13,"method":"get_clean_record","params":[1700745900]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.748	debug	MIIO MESSAGE TESTING: {"result":[[1700832301,1700834121,1820,31445000,0,1,3,1]],"id":11}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.748	debug	MIIO RECIVE: {"result":[[1700832301,1700834121,1820,31445000,0,1,3,1]],"id":11}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.747	debug	MIIO MESSAGE TESTING: {"result":[[1700832301,1700834121,1820,31445000,0,1,3,1]],"id":11}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.745	debug	Message= {"id":12,"method":"get_consumable"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.744	debug	Startup: Delete setGetCleanSummary
                  mihome-vacuum.0
                  2023-11-26 09:24:45.744	debug	Startup: setGetCleanSummary Answer: true
                  mihome-vacuum.0
                  2023-11-26 09:24:45.742	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":10}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.740	debug	MIIO RECIVE: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":10}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.739	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":10}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.724	debug	Message= {"id":11,"method":"get_clean_record","params":[1700832301]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.722	debug	MIIO MESSAGE TESTING: {"result":[[1700918701,1700920380,1679,31117500,0,1,3,1]],"id":9}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.721	debug	MIIO RECIVE: {"result":[[1700918701,1700920380,1679,31117500,0,1,3,1]],"id":9}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.720	debug	MIIO MESSAGE TESTING: {"result":[[1700918701,1700920380,1679,31117500,0,1,3,1]],"id":9}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.711	debug	Message= {"id":10,"method":"get_clean_summary"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.710	debug	Startup: Delete getMultiMapsList
                  mihome-vacuum.0
                  2023-11-26 09:24:45.710	debug	Startup: getMultiMapsList Answer: true
                  mihome-vacuum.0
                  2023-11-26 09:24:45.709	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":8}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.708	debug	MIIO RECIVE: {"result":"unknown_method","id":8}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.707	debug	MIIO MESSAGE TESTING: {"result":"unknown_method","id":8}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.705	debug	Message= {"id":9,"method":"get_clean_record","params":[1700918701]}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.702	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":7}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.701	debug	MIIO RECIVE: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":7}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.700	debug	MIIO MESSAGE TESTING: {"result":[2925029,52405125000,1837,[1700918701,1700832301,1700745900,1700659501,1700573101,1700486701,1700403901,1700317501,1700314076,1700227501,1700141101,1700054701,1699968301,1699881901,1699799101,1699712701,1699622701,1699536301,1699449901,1699363501]],"id":7}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.696	debug	Message= {"id":8,"method":"get_multi_maps_list"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.695	debug	MIIO MESSAGE TESTING: {"result":[73],"id":6}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.693	debug	MIIO RECIVE: {"result":[73],"id":6}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.692	debug	MIIO MESSAGE TESTING: {"result":[73],"id":6}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.689	debug	Message= {"id":7,"method":"get_clean_summary"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.684	debug	Message= {"id":6,"method":"get_sound_volume"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.622	debug	MIIO RECIVE: {"result":{"ssid":"Papi1","ip":"192.168.1.41","mac":"40:31:3c:aa:51:97","bssid":"e8:df:70:b8:a1:44","rssi":-57},"id":5}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.619	debug	MIIO MESSAGE TESTING: {"result":{"ssid":"Papi1","ip":"192.168.1.41","mac":"40:31:3c:aa:51:97","bssid":"e8:df:70:b8:a1:44","rssi":-57},"id":5}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.607	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":4}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.605	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":4}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.604	debug	MIIO MESSAGE TESTING: {"result":[{"main_brush_work_time":1294324,"side_brush_work_time":420918,"filter_work_time":806724,"filter_element_work_time":0,"sensor_dirty_time":420768}],"id":4}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.591	debug	Message= {"id":5,"method":"get_network_info"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.589	debug	Message= {"id":4,"method":"get_consumable"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.588	debug	MIIO RECIVE: {"result":[],"id":3}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.586	debug	MIIO MESSAGE TESTING: {"result":[],"id":3}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.570	debug	Message= {"id":3,"method":"get_room_mapping"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.545	info	settest next timer: not available
                  mihome-vacuum.0
                  2023-11-26 09:24:45.142	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                  mihome-vacuum.0
                  2023-11-26 09:24:45.134	info	create states for water box
                  mihome-vacuum.0
                  2023-11-26 09:24:45.132	info	change states from State control.fan_power
                  mihome-vacuum.0
                  2023-11-26 09:24:45.131	debug	setGetStatus {"msg_ver":3,"msg_seq":502,"state":8,"battery":100,"clean_time":1679,"clean_area":31117500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.129	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":502,"state":8,"battery":100,"clean_time":1679,"clean_area":31117500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.128	debug	MIIO MESSAGE TESTING: {"result":[{"msg_ver":3,"msg_seq":502,"state":8,"battery":100,"clean_time":1679,"clean_area":31117500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.119	debug	Message= {"id":2,"method":"get_status"}
                  mihome-vacuum.0
                  2023-11-26 09:24:45.118	debug	get params for stock Vacuum
                  mihome-vacuum.0
                  2023-11-26 09:24:45.117	debug	Create State done!
                  mihome-vacuum.0
                  2023-11-26 09:24:45.115	debug	Create State for map: loadMap
                  mihome-vacuum.0
                  2023-11-26 09:24:45.114	debug	Create State for map: mapURL
                  mihome-vacuum.0
                  2023-11-26 09:24:45.113	debug	Create State for map: mapStatus
                  mihome-vacuum.0
                  2023-11-26 09:24:45.113	debug	Create State for map: actualMap
                  mihome-vacuum.0
                  2023-11-26 09:24:45.112	debug	Create State for map: map64
                  mihome-vacuum.0
                  2023-11-26 09:24:45.074	debug	Create State for map:
                  mihome-vacuum.0
                  2023-11-26 09:24:45.067	debug	Create State for Queue: queue
                  mihome-vacuum.0
                  2023-11-26 09:24:44.730	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                  mihome-vacuum.0
                  2023-11-26 09:24:44.690	info	select standard vacuum protocol....
                  mihome-vacuum.0
                  2023-11-26 09:24:44.682	debug	DeviceModel selected to: roborock.vacuum.s5
                  mihome-vacuum.0
                  2023-11-26 09:24:44.565	debug	Get Device data from robot.. {"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496bXXXXXX":27167}
                  mihome-vacuum.0
                  2023-11-26 09:24:44.564	debug	Get Device data..0
                  mihome-vacuum.0
                  2023-11-26 09:24:44.562	debug	GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496bXXXXXX":27167}}
                  mihome-vacuum.0
                  2023-11-26 09:24:44.560	debug	MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496b50444c32686a316a6d3737","life":27167}}
                  mihome-vacuum.0
                  2023-11-26 09:24:44.558	debug	MIIO MESSAGE TESTING: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.7_002008","ap":{"ssid":"Papi1","bssid":"E8:DF:70:B8:A1:44","rssi":-57},"netif":{"localIp":"192.168.1.41","mask":"255.255.255.0","gw":"192.168.1.100"},"model":"roborock.vacuum.s5","mac":"40:31:3C:AA:51:97","token":"436559496b50444c32686a316a6d3737","life":27167}}
                  mihome-vacuum.0
                  2023-11-26 09:24:44.542	debug	Message= {"id":1,"method":"miIO.info"}
                  mihome-vacuum.0
                  2023-11-26 09:24:44.540	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5","ack":true,"ts":1700986820893,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1669663806090}
                  mihome-vacuum.0
                  2023-11-26 09:24:44.456	debug	Time difference between Mihome Vacuum and ioBroker: 5487 sec
                  mihome-vacuum.0
                  2023-11-26 09:24:44.452	debug	MAIN: Connected to device, try to get model..
                  mihome-vacuum.0
                  2023-11-26 09:24:44.450	debug	Receive <<< Helo <<< 21310020000000000707a9126563163bffffffffffffffffffffffffffffffff
                  mihome-vacuum.0
                  2023-11-26 09:24:44.429	debug	server started on 0.0.0.0:53421
                  mihome-vacuum.0
                  2023-11-26 09:24:44.423	info	IOT enabled, create state
                  mihome-vacuum.0
                  2023-11-26 09:24:44.417	debug	MIIO: Config: ip:192.168.1.41 token: 436559496bXXXXXXXXX
                  mihome-vacuum.0
                  2023-11-26 09:24:44.415	debug	Create State for deviceInfounsupported
                  mihome-vacuum.0
                  2023-11-26 09:24:44.415	debug	Create State for deviceInfowifi_signal
                  mihome-vacuum.0
                  2023-11-26 09:24:44.414	debug	Create State for deviceInfofw_ver
                  mihome-vacuum.0
                  2023-11-26 09:24:44.413	debug	Create State for deviceInfomodel
                  mihome-vacuum.0
                  2023-11-26 09:24:44.413	debug	Create State for deviceInfomac
                  mihome-vacuum.0
                  2023-11-26 09:24:44.412	debug	Create State for deviceInfo
                  mihome-vacuum.0
                  2023-11-26 09:24:44.367	debug	load Map creator... true
                  mihome-vacuum.0
                  2023-11-26 09:24:44.285	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v18.18.2, js-controller: 5.0.16
                  mihome-vacuum.0
                  2023-11-26 09:24:44.049	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  mihome-vacuum.0
                  2023-11-26 09:24:44.041	debug	Plugin sentry Initialize Plugin (enabled=true)
                  mihome-vacuum.0
                  2023-11-26 09:24:43.940	debug	States connected to redis: 127.0.0.1:9000
                  mihome-vacuum.0
                  2023-11-26 09:24:43.763	debug	States create User PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:24:43.761	debug	States create System PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:24:43.681	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                  mihome-vacuum.0
                  2023-11-26 09:24:43.534	debug	Objects connected to redis: 127.0.0.1:9001
                  mihome-vacuum.0
                  2023-11-26 09:24:43.517	debug	Objects client initialize lua scripts
                  mihome-vacuum.0
                  2023-11-26 09:24:43.274	debug	Objects create User PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:24:43.272	debug	Objects create System PubSub Client
                  mihome-vacuum.0
                  2023-11-26 09:24:43.269	debug	Objects client ready ... initialize now
                  mihome-vacuum.0
                  2023-11-26 09:24:43.165	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                  Die Ports sind natürlich auch alle wieder durchgereicht (1012, 1880,1883, 2001, 8081, 8088, 8282, 8284, 49000, 49443 (alle TCP)).
                  So, ich muss nun wieder los, ich kann wohl erst morgen Abend wieder reinsehen, ob sich hier etwas getan hat. Also keinen Stress und auch jetzt schon wieder 1000 Dank!
                  • P Papi 0
                    @codierknecht
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v9.0.1
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 4
                    CET +0100
                    Etc/UTC
                    root
                    /root
                    root
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Total:           18G         16G        2.0G
                            14550 M used memory
                             1490 M free memory
                               23 M buffer memory
                             9796 M swap cache
                             2047 M total swap
                             1607 M used swap
                              440 M free swap
                    *** FILESYSTEM ***
                    /var:
                    15M     /var/
                    13M     /var/lib/dpkg
                    13M     /var/lib
                    1.9M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        23731
                    States:         20046
                    Pending Updates: 0
                                            v.2023-10-10
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v9.0.1
                    Kernel:                 x86_64
                    Userland:               amd64
                    Timezone:               Etc/UTC
                    User-ID:                0
                    X-Server:               false
                                            /usr/bin/npm            9.8.1
                                            /usr/bin/npx            9.8.1
                    MEMORY:
                    Total:           18G         17G        1.8G
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                23731
                    States:                 20046
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    fritzbox.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    Papi 0
                    @Codierknecht
                    Jetzt habe ich es:
                    Zwar hatte ich den Adapter schon mehrfach erfolglos gelöscht, gedowngraded, und geupdated, aber jetzt, nachdem ich den ioBroker mit Deiner freundlichen Hilfe repariert habe, habe ich aus lauter Langeweile den Adapter nochmal gelöscht und wieder angelegt, jetzt funktioniert er plötzlich! Ihm haben wohl ständig irgendwelche Grundvoraussetzungen gefehlt, die er nun verfügbar hat.
                    Dasselbe hat ich dann auch gleich mit dem Staubsauger ausprobiert, mit selbem Ergebnis, alles läuft jetzt einwandfrei!
                    Vielen Dank für alles!
                    • P Papi 0
                      @Codierknecht
                      Jetzt habe ich es:
                      Codierknecht
                      Prima!
                      Dann sei bitte so nett und markiere Deinen Beitrag als "gelöst".
                      Dazu den Eingangspost bearbeiten und ein "[gelöst] - " vor den Titel setzen.
