  4. ioBroker oder Admin Adapter startet immer neu
47 Beiträge 4 Kommentatoren 4.8k Aufrufe 3 Beobachtet
    @iced112
    sudo apt full-upgrade
    Und ein
    iob diag
    sagt nun?
    I Offline
    I Offline
    IceD112
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     21:25:09 up 10 min,  2 users,  load average: 2.23, 1.83, 1.21
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Tue 2023-11-21 21:25:09 CET
               Universal time: Tue 2023-11-21 20:25:09 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        1.5G        123M        0.0K        182M        241M
    Swap:            99M         99M        0.0K
    Total:          1.9G        1.6G        124M
             1849 M total memory
             1543 M used memory
             1350 M active memory
              244 M inactive memory
              123 M free memory
                8 M buffer memory
              174 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G  7.6G   21G  28% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  828K  370M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Tue Nov 21 21:14:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CF:73:10 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f85227ed-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Nov 21 21:14:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Nov 21 21:14:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Nov 21 21:14:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    3.5G    /var/
    2.9G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
    2.9G    /var/log
    387M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    74M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    745M    /opt/iobroker/iobroker-data/
    381M    /opt/iobroker/iobroker-data/files
    274M    /opt/iobroker/iobroker-data/backup-objects
    74M     /opt/iobroker/iobroker-data/files/vis.0
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    52M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.blink4home.0             : blink4home            : ioBroker                                 - disabled
    + system.adapter.bring.0                  : bring                 : ioBroker                                 -  enabled
      system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker                                 -  enabled
    + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : ioBroker                                 -  enabled
    + system.adapter.heos.0                   : heos                  : ioBroker                                 -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
    + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : ioBroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
    Adapter    "admin"        : 6.12.4   , installed 6.12.0 [Updatable]
    Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
    Adapter    "backitup"     : 2.9.4    , installed 2.8.7  [Updatable]
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "bydhvs"       : 1.5.0    , installed 1.4.0  [Updatable]
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.10 [Updatable]
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "followthesun" : 0.4.2    , installed 0.4.2
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.3.0    , installed 1.2.2  [Updatable]
    Adapter    "heos"         : 2.1.0    , installed 2.1.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "javascript"   : 7.1.6    , installed 7.1.4  [Updatable]
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.1  [Updatable]
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "modbus"       : 6.0.1    , installed 5.0.11 [Updatable]
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.5.5  [Updatable]
    Adapter    "spotify-premium": 1.3.1  , installed 1.2.2  [Updatable]
    Adapter    "telegram"     : 3.0.0    , installed 1.16.0 [Updatable]
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.3.0    , installed 2.2.0  [Updatable]
    Adapter    "vis"          : 1.5.1    , installed 1.4.16 [Updatable]
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.97.3   , installed 0.96.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "web"          : 6.1.10   , installed 6.1.2  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 2.5.5  [Updatable]
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        36301
    States:         29693
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13260      492/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12171      492/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14204      522/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21660      1583/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13308      804/io.admin.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       21010      1362/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14206      522/sshd: /usr/sbin
    udp        0      0 0.0.0.0:52690           0.0.0.0:*                           108        12954      353/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21011      1362/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17764      971/io.shelly.0
    udp        0      0 0.0.0.0:50951           0.0.0.0:*                           1001       21091      1408/io.heos.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14500      723/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12952      353/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14558      723/dhcpcd
    udp6       0      0 :::57204                :::*                                108        12955      353/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12953      353/avahi-daemon: r
    2023-11-21 21:21:01.596  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:21:01.597  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:21:01.597  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    2023-11-21 21:22:02.604  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:22:02.605  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:22:02.606  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    2023-11-21 21:23:03.611  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:23:03.612  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:23:03.613  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    2023-11-21 21:24:04.620  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:24:04.621  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:24:04.622  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    2023-11-21 21:25:00.070  - info: host.ioBroker instance system.adapter.dwd.0 started with pid 2301
    2023-11-21 21:25:03.908  - info: dwd.0 (2301) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.16
    2023-11-21 21:25:05.246  - info: dwd.0 (2301) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-11-21 21:25:05.627  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:25:05.628  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:25:05.629  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    2023-11-21 21:25:05.781  - info: host.ioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-11-21 21:26:06.635  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:26:06.636  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:26:06.636  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    2023-11-21 21:27:07.643  - error: modbus.0 (1049) Socket Error
    2023-11-21 21:27:07.644  - error: modbus.0 (1049) Client in error state.
    2023-11-21 21:27:07.645  - warn: modbus.0 (1049) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.152","port":502}
    iob diag has finished.
    Press any key for a summary
    • I IceD112
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         99M        0.0K
               1849 M total memory
               1543 M used memory
                123 M free memory
                  8 M buffer memory
                174 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      3.5G    /var/
      2.9G    /var/log
      387M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        36301
      States:         29693
      Pending Updates: 0
      @iced112
      Zu wenig RAM.
      • I IceD112
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 1849 M total memory
                 1543 M used memory
                  123 M free memory
                    8 M buffer memory
                  174 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.5G    /var/
        2.9G    /var/log
        387M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.12.0
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        36301
        States:         29693
        Pending Updates: 0
        @iced112
        Zu viel Beta-Zeugs aktiv.
        I 1 Antwort Letzte Antwort
          @iced112
          Zu wenig RAM.
          HomoranH Offline
          HomoranH Offline
          @thomas-braun sagte in ioBroker oder Admin Adapter startet immer neu:
          @iced112
          Zu wenig RAM.
          bei 32 aktiven Instanzen +scheduled kein Wunder mit einem Pi2GB
          und Beta Versionen on top
            @iced112
            I Offline
            I Offline
            IceD112
            schrieb am zuletzt editiert von IceD112
            heißt, ich sollte da mal bisschen aufräumen und das system abspecken?
            CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
            • I IceD112
              CodierknechtC Offline
              Codierknecht
              @iced112 sagte in ioBroker oder Admin Adapter startet immer neu:
              Naja. Aufräumen und abspecken wird da wohl kaum reichen.
              Ein Pi2 mit 2 GB reicht bestenfalls für 'ne handvoll Instanzen oder als Testkiste.
              Da solltest Du eher ein paar € in die Hand nehmen und aufrüsten.
              Statt 'nem Pi kriegt man generalüberholte Hardware auch schon für kleines Geld.
              Lenovo ThinkCentre oder ein NUC. Mit 8 GB und 'ner ordenlichen CPU.
              Langfristig hat man daran mehr Freude.
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              • I IceD112
                @iced112
                Oder den Arbeitsspeicher aufspecken...
                2GB ist die untere Grenze, wenn man etwas mit dem ioBroker anfangen will.
                  @iced112
                  I Offline
                  I Offline
                  IceD112
                  wusste garnicht, dass man den PI mit RAM aufrüsten kann?
                  @Codierknecht
                  Wäre auch ne Überlegung wert
                  • I IceD112
                    @Codierknecht
                    @iced112
                    Kann man auch nicht. Halt ein dickeres System beschaffen.
                      @iced112
                      I Offline
                      I Offline
                      IceD112
                      ok, was wäre denn an der Stelle derzeit ratsam?
                      • I IceD112
                        @iced112
                        Ich gebe ungern Hardware-Empfehlungen.
                        Irgendwas mit 4, besser 8 GB RAM.
                          @iced112
                          I Offline
                          I Offline
                          IceD112
                          Klar, nach extern Empfehlungen auszusprechen, wo man nicht weis, was derjenige für Anforderungen hat, ist schwierig
                          Ging mir nur drum ne grobe Richtung zu haben. Eher schon einen Pi5 oder reicht Pi4 aus? Wenn ich da die aktuellen Preise sehe, ist ein Lenovo ThinkCenter ja tatsächlich nicht weit weg.
                          Die Instalation des ioB auf einem Windows PC ist mir gänzlich unbekannt
                          Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                          • I IceD112
                            @iced112
                            Ich habe einen Pi4 / 8GB im Einsatz. Und der wird es mir auch noch eine geraume Zeit tun.
                            I 2 Antworten Letzte Antwort
                              @iced112
                              I Offline
                              I Offline
                              IceD112
                              Gut, ich denke mir ja dann, dass ich bei einem neuen Pi, nach der Instalation mit einem Backup, das aktuelle System gut umziehen kann?
                              Aber hat der andauernde Neustart dann damit zu tun, dass das System mit 2GB zu schwach ist?
                              • I IceD112
                                Codierknecht
                                Auf dem NUC oder dem Lenovo installiert man dann konsequenterweise natürlich ein aktuelles Linux.
                                Nur so als Hausnummer: https://www.amazon.de/dp/B0B2MLV1LB
                                • I IceD112
                                  Das hat damit zu tun, dass der Kernel in höchster Not anfängt 'unwichtige' Dinge abzuwerfen. Und der ioBroker ist aus Sicht des Kernels halt unwichtiges Zeug.
                                    I Offline
                                    I Offline
                                    IceD112
                                    Unwichtig 😲
                                    Wie kann der denn behaupten dass der unwichtig ist 😊
                                    Ok, gut, dann werde ich das Hardware Upgrade mal gedanklich angehen...
                                    • CodierknechtC Codierknecht
                                      I Offline
                                      I Offline
                                      IceD112
                                      @codierknecht said in [ioBroker oder Admin Adapter startet immer neu](/post
                                      den hatte ich grad unter der Lupe...
                                      Ich werd mich mal mit beiden Möglichkeiten auseinandersetzen.
                                      Ich denke schonmal für eure Hilfe und Ratschläge
                                      • I IceD112
                                        Codierknecht
                                        @iced112
                                        Du solltest zunächst mal damit beginnen, nicht lebenswichtige Instanzen zu stoppen.
                                        Discovery kannst Du komplett rauswerfen. Das wird nach der Installtion eigentlich nicht mehr benötigt.
                                        Für das Backup brauchst Du genügend freien Speicher. Sonst wird dass nix.
                                        • I IceD112
                                          Codierknecht
                                          Sowas werde ich mir noch als Spielkiste besorgen und auf einen Regalboden in den 10" Schrank stellen.
