  4. Cannot start Samsung_Tizen Adapter
3 Beiträge 3 Kommentatoren 153 Aufrufe 3 Beobachtet
  • rnc11R Offline
    rnc11R Offline
    rnc11
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry Pi 4 Model B Rev 1.2
    Arbeitsspeicher: 4GB
    Festplattenart: Samsung SSD
    Betriebssystem: Raspbian 10 (Buster)
    Node-Version: 16.20.2
    Nodejs-Version: 16.20.2
    NPM-Version: 8.19.4
    Installationsart: PivCCU Image
    Image genutzt: Ja
    The adapter has been installed from the following GitHub path:
    https://github.com/dahuby/iobroker.samsung_tizen/tarball/master
    The adapter version is: 0.0.12
    The Adapter creates the following log entries when trying to start:
    2023-11-13 11:06:28.604 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1031
    2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: throw err;
    2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: ^
    2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
    2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.samsung_tizen/main.js
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:873:27)
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1100:19)
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
    2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js:46:25)
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1198:14)
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1076:32)
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:911:12)
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1100:19) {
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: requireStack: [
    2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js',
    2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.samsung_tizen/main.js'
    2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: ]
    2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: }
    2023-11-13 11:06:28.608 - error: host.raspberrypi instance system.adapter.samsung_tizen.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
    • rnc11R rnc11
      NPM-Version: 8.19.4
      Image genutzt: Ja
      @rnc11 sagte in Cannot start Samsung_Tizen Adapter:
      Buster
      Is busted. Install a living release.
      nodejs 16.20.2
      Too aged, install the recommended v18.
      • rnc11R rnc11
        NPM-Version: 8.19.4
        Image genutzt: Ja
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @rnc11
        Warum hier auch ein Issue?
        Ich habe dir schon im aAdapter Issue geantwortet dass
        • Installationen von Github nur dann erfolgen sollen wenn man vom Maintainer dazu aufgefordert wird
        • Dass man bei Github Installation aus veralteten Repositories wohl Probleme haben kann. Nur weil irgendwo auf Github ein Repository mit dem Namen ioBroker.irgendwas existiert, heißt das nicht, dass das ein funktionierender und supporteter Adapter ist. Gute und vor allem gewartete Adapter sind immer in den Repositories gelistet.
        Also installier den Adapter sauber über die in den ioBroker Repositories angebotene version (1.0.0 im Latest) und er wird starten.
        Und node 16 ist veraltet, mach ein Update sobald wie möglich.
        https://github.com/iobroker-community-adapters/ioBroker.samsung_tizen/issues/41
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
