  4. Sonoff Presence Sensor SNZB-06P problem
    2.8k
    4.9k
    4.1k
80 Beiträge 14 Kommentatoren 17.6k Aufrufe 13 Beobachtet
  • arteckA arteck
    @arteck schaumal bitte noch
    editiere
    /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js
    ganz unten zeile 144
    // do nothing ignore it
    ersetze diese durch
    return true;
    adapter neu starten
    FredFF Online
    FredFF Online
    FredF
    Most Active Forum Testing
    #41
    @arteck zu früh gefreut, die Fehlermeldungen kommen weiter
    2024-01-03 12:24:39.133	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:24:39.005	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:24:36.189	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:24:36.026	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:24:33.198	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:24:33.053	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:24:30.203	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:24:30.059	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:24:27.237	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:24:27.086	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:14:30.861	info	Device '0xec1bbdfffea30275' announced itself
    2024-01-03 12:14:25.910	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:14:25.690	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:14:22.929	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:14:22.716	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:14:19.951	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:14:19.730	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:14:16.960	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:14:16.789	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 12:14:14.125	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
    2024-01-03 12:14:13.812	info	Configuring 0x3410f4fffee39865 SNZB-06P
    • FredFF FredF
      arteckA Offline
      arteckA Offline
      arteck
      #42
      @fredf installier nochmal von GIT
      FredFF 1 Antwort Letzte Antwort
      • arteckA arteck
        FredFF Online
        FredFF Online
        FredF
        schrieb am zuletzt editiert von FredF
        #43
        @arteck Beim Start des Adapters immer noch:
        2024-01-03 12:34:52.689	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:34:52.388	info	Configuring 0x3410f4fffee39865 SNZB-06P
        2024-01-03 12:34:49.691	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:34:49.405	info	Configuring 0x3410f4fffee39865 SNZB-06P
        2024-01-03 12:34:46.724	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:34:46.424	info	Configuring 0x3410f4fffee39865 SNZB-06P
        2024-01-03 12:34:43.751	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:34:43.445	info	Configuring 0x3410f4fffee39865 SNZB-06P
        2024-01-03 12:34:40.782	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:34:40.471	info	Configuring 0x3410f4fffee39865 SNZB-06P
        Ansonsten scheint jetzt ruhe zu sein (seit 10 Minuten)
        Edit gerade geschrieben und schon kommen die Fehlermeldung wieder
        • FredFF FredF
          arteckA Offline
          arteckA Offline
          arteck
          #44
          @fredf nochmal von GIT
          da sollte jetzt wieder ein error arteck : kommen
          den brauch ich
          • arteckA arteck
            den brauch ich
            FredFF Online
            FredFF Online
            FredF
            #45
            @arteck Es kommt keine solche Meldung...
            host.Tower
            2024-01-03 12:50:06.301	info	iobroker exit 0
            host.Tower
            2024-01-03 12:50:05.205	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
            host.Tower
            2024-01-03 12:50:05.198	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
            host.Tower
            2024-01-03 12:50:05.191	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
            host.Tower
            2024-01-03 12:50:05.179	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
            host.Tower
            2024-01-03 12:50:05.171	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
            host.Tower
            2024-01-03 12:50:05.164	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
            host.Tower
            2024-01-03 12:50:05.157	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
            host.Tower
            2024-01-03 12:50:05.151	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
            host.Tower
            2024-01-03 12:50:05.139	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
            host.Tower
            2024-01-03 12:50:05.133	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
            host.Tower
            2024-01-03 12:50:05.126	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
            host.Tower
            2024-01-03 12:50:05.118	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
            host.Tower
            2024-01-03 12:50:05.110	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
            host.Tower
            2024-01-03 12:50:05.096	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
            host.Tower
            2024-01-03 12:50:05.077	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
            host.Tower
            2024-01-03 12:50:05.070	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
            host.Tower
            2024-01-03 12:50:05.062	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
            host.Tower
            2024-01-03 12:50:05.054	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
            host.Tower
            2024-01-03 12:50:05.047	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
            host.Tower
            2024-01-03 12:50:05.040	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
            host.Tower
            2024-01-03 12:50:05.033	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
            host.Tower
            2024-01-03 12:50:04.954	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
            host.Tower
            2024-01-03 12:50:04.885	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
            host.Tower
            2024-01-03 12:50:04.818	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
            host.Tower
            2024-01-03 12:50:04.749	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
            host.Tower
            2024-01-03 12:50:04.638	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
            host.Tower
            2024-01-03 12:50:04.559	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
            host.Tower
            2024-01-03 12:50:04.498	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
            host.Tower
            2024-01-03 12:50:04.432	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
            host.Tower
            2024-01-03 12:50:04.079	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
            host.Tower
            2024-01-03 12:50:03.727	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
            host.Tower
            2024-01-03 12:50:03.415	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
            host.Tower
            2024-01-03 12:50:03.040	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
            host.Tower
            2024-01-03 12:50:02.874	info	iobroker upload [323] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
            host.Tower
            2024-01-03 12:50:00.143	info	iobroker 313 packages are looking for funding run `npm fund` for details
            host.Tower
            2024-01-03 12:50:00.142	info	iobroker changed 1 package in 17s
            host.Tower
            host.Tower
            2024-01-03 12:49:42.351	info	iobroker Installing ioBroker/ioBroker.zigbee... (System call)
            host.Tower
            2024-01-03 12:49:42.351	info	iobroker NPM version: 10.2.3
            host.Tower
            2024-01-03 12:49:41.984	info	iobroker install ioBroker/ioBroker.zigbee
            host.Tower
            2024-01-03 12:49:38.412	info	iobroker url ioBroker/ioBroker.zigbee --host Tower --debug
            Edit: Ah... Nach Neustart des Adpaters
            arteck : 'Error: Expected one of: 0, 1, got: 'undefined''
            • FredFF FredF
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              host.Tower
              arteckA Offline
              arteckA Offline
              arteck
              #46
              @fredf so jetzt nochmal von GIT... und neustart nicht vergessen :-)
              • arteckA arteck
                FredFF Online
                FredFF Online
                FredF
                #47
                @arteck
                zigbee.0
                2024-01-03 13:05:32.503	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:05:32.290	info	Configuring 0x3410f4fffee39865 SNZB-06P
                zigbee.0
                2024-01-03 13:05:29.543	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:05:29.301	info	Configuring 0x3410f4fffee39865 SNZB-06P
                zigbee.0
                2024-01-03 13:05:26.527	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:05:26.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
                zigbee.0
                2024-01-03 13:05:23.479	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:05:23.334	info	Configuring 0x3410f4fffee39865 SNZB-06P
                zigbee.0
                2024-01-03 13:05:20.531	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:05:20.351	info	Configuring 0x3410f4fffee39865 SNZB-06P
                zigbee.0
                2024-01-03 13:03:37.149	warn	DeviceAvailability:Failed to ping 0x385cfbfffe8ce7c8 TRADFRIbulbGU10WS345lm
                zigbee.0
                2024-01-03 13:03:37.065	warn	DeviceAvailability:Failed to ping 0x04cd15fffe0ae3fc TS0505B
                zigbee.0
                2024-01-03 13:03:15.048	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:03:14.894	info	Configuring 0x3410f4fffee39865 SNZB-06P
                zigbee.0
                2024-01-03 13:03:13.379	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                zigbee.0
                2024-01-03 13:03:12.900	info	debug devices set to []
                • arteckA Offline
                  arteckA Offline
                  arteck
                  #48
                  @fredf
                  ich werd bescheuert mit dem Gerät....
                  so installier nochmal von GIT.. sollte es immer onch kommen.. dann muss ich Morgen weiter schauen..
                  FredFF T 3 Antworten Letzte Antwort
                  • arteckA arteck
                    @fredf
                    FredFF Online
                    FredFF Online
                    FredF
                    #49
                    @arteck Bis auf das, gibt es keine Fehlermeldung
                    2024-01-03 13:21:18.883	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:18:29.357	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:15:45.585	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:15:42.615	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:15:39.680	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:15:36.650	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:15:33.660	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:13:13.261	info	Configuring 0x3410f4fffee39865 SNZB-06P
                    2024-01-03 13:13:11.233	info	debug devices set to []
                    • arteckA arteck
                      @fredf
                      tobrog
                      #50
                      @arteck Sieht bei mir ähnlich aus. Nach der anfänglichen Fehlermeldung kommt auch nur alle paar Minuten diese info Meldung.
                      zigbee.0
                      2024-01-03 15:31:30.015	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:28:52.569	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:21:22.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:21:19.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:21:16.321	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:21:13.306	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:21:10.297	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:14:13.742	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x3410f4fffee99489 SNZB-06P (Error: Read 0x3410f4fffee99489/1 64529([8193], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (18)) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:666:23) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:81:20) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:460:28) at setupAttributes (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:62:9) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:72:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21))
                      zigbee.0
                      2024-01-03 15:14:02.862	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-03 15:14:00.650	info	debug devices set to []
                      zigbee.0
                      2024-01-03 15:14:00.169	info	Zigbee started
                      • arteckA arteck
                        @fredf
                        FredFF Online
                        FredFF Online
                        FredF
                        #51
                        @arteck
                        Bonus: Der Sensor funktionierte nicht mehr... musste ihn neu anlernen
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #52
                          so weiter gehts. :-)
                          von GIT bitte
                          • arteckA arteck
                            von GIT bitte
                            FredFF Online
                            FredFF Online
                            FredF
                            #53
                            @arteck
                            2024-01-04 09:50:52.709	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-04 09:50:49.761	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-04 09:50:46.738	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-04 09:50:43.764	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-04 09:50:40.772	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            Edit: kommt alle 10 Minuten
                            arteckA 2 Antworten Letzte Antwort
                            • FredFF FredF
                              @arteck
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #54
                              kein Plan.. . da ich das Gerät nicht habe, ich weiss nicht was bei dem falsch läuft..
                              hat das Teil vielleicht jemand doppelt gekauft und kann mir ein Verkaufen ?
                              • FredFF FredF
                                @arteck
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #55
                                @fredf installier nochmal von GIT... bitte
                                die Meldung sollte jetzt nur einmal kommen
                                • arteckA arteck
                                  FredFF Online
                                  FredFF Online
                                  FredF
                                  #56
                                  @arteck sagte in Sonoff Presence Sensor SNZB-06P problem:
                                  Jep, die kam tatsächlich nun nur einmal beim neustart
                                  2024-01-04 17:54:38.407	info	-> Configuring 0x3410f4fffee39865 SNZB-06P
                                  und seitdem nicht mehr 👍
                                  • FredFF FredF
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #57
                                    @fredf dann schau ob der sensor daten liefert
                                    • arteckA arteck
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      #58
                                      @arteck Tut er
                                      Besten dank für deine unermüdlich Arbeit, Top.
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #59
                                        dann mach ich ne neue version
                                        • arteckA arteck
                                          tobrog
                                          #60
                                          @arteck Bei mir läuft die letzte GIT version auch problemlos ohne weitere Meldungen im log.
                                          Vielen Dank!
