  4. Sonoff Presence Sensor SNZB-06P problem
    6.5k
80 Beiträge 14 Kommentatoren 18.4k Aufrufe 13 Beobachtet
  • arteckA arteck
    @fredf bist sicher dass du den adapter neu gestertet hast ??
    FredFF Online
    FredFF Online
    FredF
    Most Active Forum Testing
    schrieb am zuletzt editiert von FredF
    @arteck Na klar:
    2024-01-03 11:20:32.794	info	Starting Zigbee npm ...
    2024-01-03 11:20:32.792	info	delete old Backup files. keep only last 10
    2024-01-03 11:20:32.666	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
    2024-01-03 11:20:27.249	info	instance system.adapter.zigbee.0 started with pid 1280
    2024-01-03 11:20:24.971	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-01-03 11:20:24.355	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-01-03 11:20:24.354	info	terminating
    2024-01-03 11:20:24.113	info	stopInstance system.adapter.zigbee.0 send kill signal
    2024-01-03 11:20:24.010	info	Zigbee: disabling joining new devices.
    2024-01-03 11:20:23.854	info	cleaned everything up...
    2024-01-03 11:20:23.853	info	Got terminate signal TERMINATE_YOURSELF
    2024-01-03 11:20:23.849	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    Aber zur Sicherheit nchmal gestartet:
    2024-01-03 11:26:19.969	error	arteck: '64529' -> 'readResponse'
    2024-01-03 11:26:19.969	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
    2024-01-03 11:26:19.587	info	Configuring 0x3410f4fffee39865 SNZB-06P
    2024-01-03 11:26:18.333	error	arteck: '64529' -> 'readResponse'
    2024-01-03 11:26:18.332	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
    2024-01-03 11:26:17.644	info	debug devices set to []
    • FredFF FredF
      @arteck Na klar:
      arteckA Offline
      arteckA Offline
      arteck
      @fredf ok warte gleich kommt ne GIT version
      @fredf installier mal von git
      • arteckA arteck
        FredFF Online
        FredFF Online
        FredF
        @arteck Nur beim Adapter Start kommt das, dann nix mehr.
        2024-01-03 12:05:48.223	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:05:48.041	info	Configuring 0x3410f4fffee39865 SNZB-06P
        2024-01-03 12:05:46.604	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
        2024-01-03 12:05:46.120	info	debug devices set to []
        • FredFF FredF
          arteckA Offline
          arteckA Offline
          arteck
          @fredf sehr gut..
          • arteckA arteck
            @fredf sehr gut..
            arteckA Offline
            arteckA Offline
            arteck
            @arteck schaumal bitte noch
            editiere
            /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js
            ganz unten zeile 144
            // do nothing ignore it
            ersetze diese durch
            return true;
            adapter neu starten
            • arteckA arteck
              editiere
              ersetze diese durch
              return true;
              adapter neu starten
              FredFF Online
              FredFF Online
              FredF
              @arteck zu früh gefreut, die Fehlermeldungen kommen weiter
              2024-01-03 12:24:39.133	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:24:39.005	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:24:36.189	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:24:36.026	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:24:33.198	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:24:33.053	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:24:30.203	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:24:30.059	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:24:27.237	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:24:27.086	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:14:30.861	info	Device '0xec1bbdfffea30275' announced itself
              2024-01-03 12:14:25.910	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:14:25.690	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:14:22.929	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:14:22.716	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:14:19.951	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:14:19.730	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:14:16.960	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:14:16.789	info	Configuring 0x3410f4fffee39865 SNZB-06P
              2024-01-03 12:14:14.125	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
              2024-01-03 12:14:13.812	info	Configuring 0x3410f4fffee39865 SNZB-06P
              • FredFF FredF
                arteckA Offline
                arteckA Offline
                arteck
                @fredf installier nochmal von GIT
                • arteckA arteck
                  FredFF Online
                  FredFF Online
                  FredF
                  @arteck Beim Start des Adapters immer noch:
                  2024-01-03 12:34:52.689	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                  2024-01-03 12:34:52.388	info	Configuring 0x3410f4fffee39865 SNZB-06P
                  2024-01-03 12:34:49.691	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                  2024-01-03 12:34:49.405	info	Configuring 0x3410f4fffee39865 SNZB-06P
                  2024-01-03 12:34:46.724	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                  2024-01-03 12:34:46.424	info	Configuring 0x3410f4fffee39865 SNZB-06P
                  2024-01-03 12:34:43.751	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                  2024-01-03 12:34:43.445	info	Configuring 0x3410f4fffee39865 SNZB-06P
                  2024-01-03 12:34:40.782	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                  2024-01-03 12:34:40.471	info	Configuring 0x3410f4fffee39865 SNZB-06P
                  Ansonsten scheint jetzt ruhe zu sein (seit 10 Minuten)
                  Edit gerade geschrieben und schon kommen die Fehlermeldung wieder
                  • FredFF FredF
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @fredf nochmal von GIT
                    da sollte jetzt wieder ein error arteck : kommen
                    den brauch ich
                    • arteckA arteck
                      den brauch ich
                      FredFF Online
                      FredFF Online
                      FredF
                      @arteck Es kommt keine solche Meldung...
                      host.Tower
                      2024-01-03 12:50:06.301	info	iobroker exit 0
                      host.Tower
                      2024-01-03 12:50:05.205	info	iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                      host.Tower
                      2024-01-03 12:50:05.198	info	iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                      host.Tower
                      2024-01-03 12:50:05.191	info	iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                      host.Tower
                      2024-01-03 12:50:05.179	info	iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                      host.Tower
                      2024-01-03 12:50:05.171	info	iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                      host.Tower
                      2024-01-03 12:50:05.164	info	iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                      host.Tower
                      2024-01-03 12:50:05.157	info	iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                      host.Tower
                      2024-01-03 12:50:05.151	info	iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                      host.Tower
                      2024-01-03 12:50:05.139	info	iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                      host.Tower
                      2024-01-03 12:50:05.133	info	iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                      host.Tower
                      2024-01-03 12:50:05.126	info	iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                      host.Tower
                      2024-01-03 12:50:05.118	info	iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                      host.Tower
                      2024-01-03 12:50:05.110	info	iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                      host.Tower
                      2024-01-03 12:50:05.096	info	iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                      host.Tower
                      2024-01-03 12:50:05.077	info	iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                      host.Tower
                      2024-01-03 12:50:05.070	info	iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                      host.Tower
                      2024-01-03 12:50:05.062	info	iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                      host.Tower
                      2024-01-03 12:50:05.054	info	iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                      host.Tower
                      2024-01-03 12:50:05.047	info	iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                      host.Tower
                      2024-01-03 12:50:05.040	info	iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                      host.Tower
                      2024-01-03 12:50:05.033	info	iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                      host.Tower
                      2024-01-03 12:50:04.954	info	iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                      host.Tower
                      2024-01-03 12:50:04.885	info	iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                      host.Tower
                      2024-01-03 12:50:04.818	info	iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                      host.Tower
                      2024-01-03 12:50:04.749	info	iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/plug.png img/plug.png image/png
                      host.Tower
                      2024-01-03 12:50:04.638	info	iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ltc021.png img/philips_hue_ltc021.png image/png
                      host.Tower
                      2024-01-03 12:50:04.559	info	iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_e27_ambiance.png img/philips_hue_e27_ambiance.png image/png
                      host.Tower
                      2024-01-03 12:50:04.498	info	iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_ambiance.png img/philips_hue_ambiance.png image/png
                      host.Tower
                      2024-01-03 12:50:04.432	info	iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_amaze.png img/philips_amaze.png image/png
                      host.Tower
                      2024-01-03 12:50:04.079	info	iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lh_32Zb.png img/lh_32Zb.png image/png
                      host.Tower
                      2024-01-03 12:50:03.727	info	iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
                      host.Tower
                      2024-01-03 12:50:03.415	info	iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion.png img/bitron_motion.png image/png
                      host.Tower
                      2024-01-03 12:50:03.040	info	iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                      host.Tower
                      2024-01-03 12:50:02.874	info	iobroker upload [323] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                      host.Tower
                      2024-01-03 12:50:00.143	info	iobroker 313 packages are looking for funding run `npm fund` for details
                      host.Tower
                      2024-01-03 12:50:00.142	info	iobroker changed 1 package in 17s
                      host.Tower
                      host.Tower
                      2024-01-03 12:49:42.351	info	iobroker Installing ioBroker/ioBroker.zigbee... (System call)
                      host.Tower
                      2024-01-03 12:49:42.351	info	iobroker NPM version: 10.2.3
                      host.Tower
                      2024-01-03 12:49:41.984	info	iobroker install ioBroker/ioBroker.zigbee
                      host.Tower
                      2024-01-03 12:49:38.412	info	iobroker url ioBroker/ioBroker.zigbee --host Tower --debug
                      Edit: Ah... Nach Neustart des Adpaters
                      arteck : 'Error: Expected one of: 0, 1, got: 'undefined''
                      • FredFF FredF
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        host.Tower
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @fredf so jetzt nochmal von GIT... und neustart nicht vergessen :-)
                        • arteckA arteck
                          FredFF Online
                          FredFF Online
                          FredF
                          @arteck
                          zigbee.0
                          2024-01-03 13:05:32.503	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:05:32.290	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          zigbee.0
                          2024-01-03 13:05:29.543	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:05:29.301	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          zigbee.0
                          2024-01-03 13:05:26.527	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:05:26.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          zigbee.0
                          2024-01-03 13:05:23.479	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:05:23.334	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          zigbee.0
                          2024-01-03 13:05:20.531	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:05:20.351	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          zigbee.0
                          2024-01-03 13:03:37.149	warn	DeviceAvailability:Failed to ping 0x385cfbfffe8ce7c8 TRADFRIbulbGU10WS345lm
                          zigbee.0
                          2024-01-03 13:03:37.065	warn	DeviceAvailability:Failed to ping 0x04cd15fffe0ae3fc TS0505B
                          zigbee.0
                          2024-01-03 13:03:15.048	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:03:14.894	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          zigbee.0
                          2024-01-03 13:03:13.379	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                          zigbee.0
                          2024-01-03 13:03:12.900	info	debug devices set to []
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            @fredf
                            ich werd bescheuert mit dem Gerät....
                            so installier nochmal von GIT.. sollte es immer onch kommen.. dann muss ich Morgen weiter schauen..
                            FredFF T 3 Antworten Letzte Antwort
                            • arteckA arteck
                              @fredf
                              FredFF Online
                              FredFF Online
                              FredF
                              @arteck Bis auf das, gibt es keine Fehlermeldung
                              2024-01-03 13:21:18.883	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:18:29.357	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:15:45.585	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:15:42.615	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:15:39.680	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:15:36.650	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:15:33.660	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:13:13.261	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 13:13:11.233	info	debug devices set to []
                              • arteckA arteck
                                @fredf
                                tobrog
                                @arteck Sieht bei mir ähnlich aus. Nach der anfänglichen Fehlermeldung kommt auch nur alle paar Minuten diese info Meldung.
                                zigbee.0
                                2024-01-03 15:31:30.015	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:28:52.569	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:21:22.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:21:19.341	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:21:16.321	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:21:13.306	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:21:10.297	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:14:13.742	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x3410f4fffee99489 SNZB-06P (Error: Read 0x3410f4fffee99489/1 64529([8193], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (18)) at DeconzAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:666:23) at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:81:20) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:460:28) at setupAttributes (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:62:9) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:72:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21))
                                zigbee.0
                                2024-01-03 15:14:02.862	info	Configuring 0x3410f4fffee99489 SNZB-06P
                                zigbee.0
                                2024-01-03 15:14:00.650	info	debug devices set to []
                                zigbee.0
                                2024-01-03 15:14:00.169	info	Zigbee started
                                • arteckA arteck
                                  @fredf
                                  FredFF Online
                                  FredFF Online
                                  FredF
                                  @arteck
                                  Bonus: Der Sensor funktionierte nicht mehr... musste ihn neu anlernen
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    so weiter gehts. :-)
                                    von GIT bitte
                                    • arteckA arteck
                                      von GIT bitte
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      @arteck
                                      2024-01-04 09:50:52.709	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-04 09:50:49.761	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-04 09:50:46.738	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-04 09:50:43.764	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-04 09:50:40.772	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      Edit: kommt alle 10 Minuten
                                      arteckA 2 Antworten Letzte Antwort
                                      • FredFF FredF
                                        @arteck
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        kein Plan.. . da ich das Gerät nicht habe, ich weiss nicht was bei dem falsch läuft..
                                        hat das Teil vielleicht jemand doppelt gekauft und kann mir ein Verkaufen ?
                                        • FredFF FredF
                                          @arteck
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @fredf installier nochmal von GIT... bitte
                                          die Meldung sollte jetzt nur einmal kommen
