  4. Sonoff Presence Sensor SNZB-06P problem
    2.8k
    4.9k
    4.1k
80 Beiträge 14 Kommentatoren 17.6k Aufrufe 13 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    super ihr beiden
    @mrjeschke
    @fredf
    aber
    !!!!!!!!!!!!!!!!!!!!!!!!!!!! ich brauch mal ein LOG
    adapter stoppen
    und jetzt
    starten warten bis zum abbruch und LOG posten
    F T D 3 Antworten Letzte Antwort
    • arteckA arteck
      super ihr beiden
      @mrjeschke
      @fredf
      aber
      adapter stoppen
      und jetzt
      Förster
      @arteck
      zigbee.0
      	2024-01-02 13:21:52.012	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198089639,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"}
      zigbee.0
      	2024-01-02 13:21:51.993	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 1030 [{"attribute":{"ID":32,"type":33},"min":-1,"max":-1,"change":-1}]
      zigbee.0
      	2024-01-02 13:21:51.985	info	Configuring 0x3410f4fffee9c7fe SNZB-06P
      zigbee.0
      	2024-01-02 13:21:51.979	info	0x00124b0022146607 (addr 20276): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
      zigbee.0
      	2024-01-02 13:21:51.977	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00124b0022146607","_networkAddress":20276,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":12,"inputClusters":[0],"outputClusters":[1,1024,1026,1027,1029,1032],"deviceNetworkAddress":20276,"deviceIeeeAddress":"0x00124b0022146607","clusters":{"genBasic":{"attributes":{"modelId":"DIYRuZ_Flower","manufacturerName":"modkam.ru","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":4,"hwVersion":1,"dateCode":"18/01/2021 10:59","swBuildId":"18/01/2021 10:59"}},"genPowerCfg":{"attributes":{"512":6245,"batteryVoltage":28,"batteryPercentageRemaining":44}},"msPressureMeasurement":{"attributes":{"scale":-1,"scaledValue":0,"measuredValue":0}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":545}},"msSoilMoisture":{"attributes":{"512":4985,"513":6245,"measuredValue":274}},"msTemperatureMeasurement":{"attributes":{"measuredValue":0}},"msRelativeHumidity":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1027,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1032,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1029,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1027,"attrId":16,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1024,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1032,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00124b0022146607"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":260,"deviceID":12,"inputClusters":[],"outputClusters":[1026],"deviceNetworkAddress":20276,"deviceIeeeAddress":"0x00124b0022146607","clusters":{"msTemperatureMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":2,"deviceIeeeAddress":"0x00124b0022146607"}}],"_manufacturerName":"modkam.ru","_powerSource":"Battery","_modelID":"DIYRuZ_Flower","_applicationVersion":3,"_stackVersion":4,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"18/01/2021 10:59","_softwareBuildID":"18/01/2021 10:59","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1661031806167,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["DIYRuZ_Flower"],"model":"DIYRuZ_Flower","vendor":"DIYRuZ","description":"[Flower sensor](http://modkam.ru/?p=1700)","fromZigbee":[{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"temperature_precision","label":"Temperature precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","label":"Temperature calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","label":"Humidity precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","label":"Humidity calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"illuminance_calibration","label":"Illuminance calibration","property":"illuminance_calibration","access":2,"description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"illuminance_lux_calibration","label":"Illuminance lux calibration","property":"illuminance_lux_calibration","access":2,"description":"Calibrates the illuminance_lux value (percentual offset), takes into effect on next report of device."}]},{"cluster":"msSoilMoisture","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"soil_moisture_precision","label":"Soil moisture precision","property":"soil_moisture_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for soil_moisture, takes into effect on next report of device."},{"type":"numeric","name":"soil_moisture_calibration","label":"Soil moisture calibration","property":"soil_moisture_calibration","access":2,"description":"Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","label":"Pressure precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","label":"Pressure calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"meta":{"multiEndpoint":true,"multiEndpointSkip":["humidity"]},"exposes":[{"type":"numeric","name":"soil_moisture","label":"Soil moisture","property":"soil_moisture","access":1,"unit":"%","description":"Measured soil moisture value"},{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"illuminance","label":"Illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance"},{"type":"numeric","name":"humidity","label":"Humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","label":"Pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_ds","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"ds"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_bme","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"bme"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00124b0022146607"}
      zigbee.0
      	2024-01-02 13:21:51.970	debug	DeviceConfigure:DeviceConfigure 0x3410f4fffee9c7fe SNZB-06P needed
      zigbee.0
      	2024-01-02 13:21:51.969	debug	DeviceConfigure:DeviceConfigure 0x00124b0022146607 DIYRuZ_Flower not needed
      zigbee.0
      	2024-01-02 13:21:51.963	debug	DeviceAvailability:Publish LQ for 0x54ef4410003e507f = 10
      zigbee.0
      	2024-01-02 13:21:51.957	debug	DeviceAvailability:Publish available for 0x54ef4410003e507f = true
      zigbee.0
      	2024-01-02 13:21:51.938	debug	DeviceAvailability:Publish LQ for 0x00158d0007ec86e0 = 10
      zigbee.0
      	2024-01-02 13:21:51.934	debug	DeviceAvailability:Publish available for 0x00158d0007ec86e0 = true
      zigbee.0
      	2024-01-02 13:21:51.930	debug	DeviceAvailability:Publish LQ for 0x00158d00041fdb24 = 10
      zigbee.0
      	2024-01-02 13:21:51.926	debug	DeviceAvailability:Publish available for 0x00158d00041fdb24 = true
      zigbee.0
      	2024-01-02 13:21:51.921	debug	DeviceAvailability:Publish LQ for 0x00124b002214642f = 10
      zigbee.0
      	2024-01-02 13:21:51.917	debug	DeviceAvailability:Publish available for 0x00124b002214642f = true
      zigbee.0
      	2024-01-02 13:21:51.910	debug	DeviceAvailability:Publish LQ for 0x00158d000543212d = 10
      zigbee.0
      	2024-01-02 13:21:51.903	debug	DeviceAvailability:Publish available for 0x00158d000543212d = true
      zigbee.0
      	2024-01-02 13:21:51.895	debug	DeviceAvailability:Publish LQ for 0x00124b0022146607 = 10
      zigbee.0
      	2024-01-02 13:21:51.885	debug	DeviceAvailability:Publish available for 0x00124b0022146607 = true
      zigbee.0
      	2024-01-02 13:21:51.884	info	Currently 8 devices are joined:
      zigbee.0
      	2024-01-02 13:21:51.868	info	--> transmitPower : normal
      zigbee.0
      	2024-01-02 13:21:51.835	info	Unable to disable LED, unsupported function.
      zigbee.0
      	2024-01-02 13:21:51.833	debug	Zigbee network parameters: panID=6755 channel=11 extendedPanID=83c4a403004b1200
      zigbee.0
      	2024-01-02 13:21:51.828	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
      zigbee.0
      	2024-01-02 13:21:51.826	debug	zigbee-herdsman started
      zigbee.0
      	2024-01-02 13:21:51.523	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_02-13_21_50.tar.gz success
      zigbee.0
      	2024-01-02 13:21:51.018	info	Installed Version: ioBroker/ioBroker.zigbee#a5fe3e3048be77e32210ce2181b769653d0f22c1
      zigbee.0
      	2024-01-02 13:21:50.696	debug	Starting zigbee-herdsman...
      zigbee.0
      	2024-01-02 13:21:50.633	info	Starting Zigbee npm ...
      zigbee.0
      	2024-01-02 13:21:50.630	info	delete old Backup files. keep only last 10
      zigbee.0
      	2024-01-02 13:21:50.530	debug	Using zigbee-herdsman with settings: {"network":{"panID":6755,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      zigbee.0
      	2024-01-02 13:21:50.457	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee#a5fe3e3048be77e32210ce2181b769653d0f22c1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      • F Offline
        Förster
        zigbee.0
        	2024-01-02 13:21:52.808	error	Error while processing converters DEVICE_ID: '3410f4fffee9c7fe'
        zigbee.0
        	2024-01-02 13:21:52.747	debug	DeviceAvailability:Successfully pinged 0x3410f4fffee9c7fe SNZB-06P
        zigbee.0
        	2024-01-02 13:21:52.741	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 1030 [{"attribute":{"ID":32,"type":33},"min":-1,"max":-1,"change":-1}]
        zigbee.0
        	2024-01-02 13:21:52.739	info	Configuring 0x3410f4fffee9c7fe SNZB-06P
        zigbee.0
        	2024-01-02 13:21:52.735	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112725,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":5},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112725,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":5},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":34,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":5,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.730	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
        zigbee.0
        	2024-01-02 13:21:52.726	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112725,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":4},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":34,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":5,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.716	debug	DeviceConfigure:Reading for 0x3410f4fffee3428b/1 1030 [{"attribute":{"ID":32,"type":33},"min":-1,"max":-1,"change":-1}]
        zigbee.0
        	2024-01-02 13:21:52.714	info	Configuring 0x3410f4fffee3428b SNZB-06P
        zigbee.0
        	2024-01-02 13:21:52.714	debug	DeviceConfigure:DeviceConfigure 0x3410f4fffee3428b SNZB-06P needed
        zigbee.0
        	2024-01-02 13:21:52.713	debug	DeviceConfigure:DeviceConfigure 0x00124b002214642f DIYRuZ_Flower not needed
        zigbee.0
        	2024-01-02 13:21:52.713	debug	DeviceConfigure:DeviceConfigure 0x00158d000543212d lumi.vibration.aq1 not needed
        zigbee.0
        	2024-01-02 13:21:52.609	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112605,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":4},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112605,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":4},"endpoint":"[Circular]","data":{},"linkquality":34,"groupID":0,"cluster":"64529","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.608	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster '64529', data '{}' from endpoint 1 with groupID 0
        zigbee.0
        	2024-01-02 13:21:52.606	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112605,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":3},"endpoint":"[Circular]","data":{},"linkquality":34,"groupID":0,"cluster":"64529","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.222	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 64529 [{"attribute":{"ID":8193,"type":32},"min":-1,"max":-1,"change":-1}]
        zigbee.0
        	2024-01-02 13:21:52.214	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112208,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":26,"_lastDefaultResponseSequenceNumber":3},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112208,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":26,"_lastDefaultResponseSequenceNumber":3},"endpoint":"[Circular]","data":{"ultrasonicUToOThreshold":2},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":3,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.212	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster 'msOccupancySensing', data '{"ultrasonicUToOThreshold":2}' from endpoint 1 with groupID 0
        zigbee.0
        	2024-01-02 13:21:52.210	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112208,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":26,"_lastDefaultResponseSequenceNumber":2},"endpoint":"[Circular]","data":{"ultrasonicUToOThreshold":2},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":3,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.190	debug	getGroups result: {}
        zigbee.0
        	2024-01-02 13:21:52.164	debug	DeviceAvailability:register device Ping for "0x54ef4410003e507f"
        zigbee.0
        	2024-01-02 13:21:52.164	debug	DeviceAvailability:register device Ping for "0x00158d0007ec86e0"
        zigbee.0
        	2024-01-02 13:21:52.163	debug	DeviceAvailability:register device Ping for "0x00158d00041fdb24"
        zigbee.0
        	2024-01-02 13:21:52.161	debug	DeviceAvailability:register device Ping for "0x3410f4fffee3428b"
        zigbee.0
        	2024-01-02 13:21:52.160	debug	DeviceAvailability:register device Ping for "0x00124b002214642f"
        zigbee.0
        	2024-01-02 13:21:52.159	debug	DeviceAvailability:register device Ping for "0x00158d000543212d"
        zigbee.0
        	2024-01-02 13:21:52.157	debug	DeviceAvailability:register device Ping for "0x3410f4fffee9c7fe"
        zigbee.0
        	2024-01-02 13:21:52.156	info	debug devices set to []
        zigbee.0
        	2024-01-02 13:21:52.139	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 1030 [{"attribute":{"ID":34,"type":32},"min":-1,"max":-1,"change":-1}]
        zigbee.0
        	2024-01-02 13:21:52.131	debug	DeviceAvailability:Publish LQ for 0x3410f4fffee9c7fe = 10
        zigbee.0
        	2024-01-02 13:21:52.128	debug	DeviceAvailability:Publish available for 0x3410f4fffee9c7fe = true
        zigbee.0
        	2024-01-02 13:21:52.125	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112113,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":2},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112113,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":2},"endpoint":"[Circular]","data":{"ultrasonicOToUDelay":60},"linkquality":34,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.121	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster 'msOccupancySensing', data '{"ultrasonicOToUDelay":60}' from endpoint 1 with groupID 0
        zigbee.0
        	2024-01-02 13:21:52.117	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112113,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34},"endpoint":"[Circular]","data":{"ultrasonicOToUDelay":60},"linkquality":34,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
        zigbee.0
        	2024-01-02 13:21:52.103	debug	DeviceAvailability:register device Ping for "0x00124b0022146607"
        zigbee.0
        	2024-01-02 13:21:52.042	info	Zigbee started
        zigbee.0
        	2024-01-02 13:21:52.040	info	0x54ef4410003e507f (addr 57427): ZNJLBL01LM - Xiaomi Aqara roller shade companion E1 (EndDevice)
        zigbee.0
        	2024-01-02 13:21:52.038	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_type":"EndDevice","_ieeeAddr":"0x54ef4410003e507f","_networkAddress":57427,"_manufacturerID":4447,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":256,"inputClusters":[0,2,3,4,5,6,9,13,19,258],"outputClusters":[10,25],"deviceNetworkAddress":57427,"deviceIeeeAddress":"0x54ef4410003e507f","clusters":{"genBasic":{"attributes":{"modelId":"lumi.curtain.acn002","manufacturerName":"LUMI","powerSource":0,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"11-24-2021"}},"aqaraOpple":{"attributes":{"1033":1,"1034":39}},"genAnalogOutput":{"attributes":{"presentValue":0}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x54ef4410003e507f"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":57427,"deviceIeeeAddress":"0x54ef4410003e507f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x54ef4410003e507f"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.curtain.acn002","_applicationVersion":27,"_stackVersion":2,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"11-24-2021","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":60219893},"_lastSeen":1656281459439,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.curtain.acn002"],"model":"ZNJLBL01LM","description":"Aqara roller shade companion E1","vendor":"Xiaomi","whiteLabel":[{"vendor":"Xiaomi","model":"RSD-M01"}],"fromZigbee":[{"cluster":"genAnalogOutput","type":["attributeReport","readResponse"],"options":[{"type":"binary","name":"invert_cover","label":"Invert cover","property":"invert_cover","access":2,"value_on":true,"value_off":false,"description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false)."}]},{"cluster":"genMultistateOutput","type":["attributeReport"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"aqaraOpple","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","position"],"options":[{"type":"binary","name":"invert_cover","label":"Invert cover","property":"invert_cover","access":2,"value_on":true,"value_off":false,"description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false)."}]},{"key":["battery"]},{"key":["charging_status"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"cover","features":[{"type":"enum","name":"state","label":"State","property":"state","access":7,"values":["OPEN","CLOSE","STOP"]},{"type":"numeric","name":"position","label":"Position","property":"position","access":7,"value_min":0,"value_max":100,"description":"Position of this cover","unit":"%"}]},{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":5,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"binary","name":"charging_status","label":"Charging status","property":"charging_status","access":5,"value_on":true,"value_off":false,"description":"The current charging status."},{"type":"enum","name":"motor_state","label":"Motor state","property":"motor_state","access":1,"values":["declining","rising","pause","blocked"],"description":"The current state of the motor."},{"type":"binary","name":"running","label":"Running","property":"running","access":1,"value_on":true,"value_off":false,"description":"Whether the motor is moving or not"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"options":["[Circular]",{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."}]},"name":"0x54ef4410003e507f"}
        zigbee.0
        	2024-01-02 13:21:52.036	info	0x00158d0007ec86e0 (addr 49157): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
        zigbee.0
        	2024-01-02 13:21:52.034	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d0007ec86e0","_networkAddress":49157,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,3,25,257],"outputClusters":[0,4,3,5,25,257],"deviceNetworkAddress":49157,"deviceIeeeAddress":"0x00158d0007ec86e0","clusters":{"genBasic":{"attributes":{"65281":{"1":2925,"3":35,"4":424,"5":78,"6":[0,1],"8":776,"10":0,"152":40,"153":0,"154":[65535,68485341]},"modelId":"lumi.vibration.aq1","appVersion":8}},"closuresDoorLock":{"attributes":{"85":2,"1283":110,"1285":262144,"1288":[64911,131103]}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d0007ec86e0"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":49157,"deviceIeeeAddress":"0x00158d0007ec86e0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":2,"deviceIeeeAddress":"0x00158d0007ec86e0"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.vibration.aq1","_applicationVersion":8,"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1703095818501,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.vibration.aq1"],"model":"DJT11LM","vendor":"Xiaomi","description":"Aqara vibration sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"vibration_timeout","label":"Vibration timeout","property":"vibration_timeout","access":2,"value_min":0,"description":"Time in seconds after which vibration is cleared after detecting it (default 90 seconds)."},{"type":"numeric","name":"x_calibration","label":"X calibration","property":"x_calibration","access":2,"description":"Calibrates the x value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"y_calibration","label":"Y calibration","property":"y_calibration","access":2,"description":"Calibrates the y value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"z_calibration","label":"Z calibration","property":"z_calibration","access":2,"description":"Calibrates the z value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["sensitivity"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"binary","name":"vibration","label":"Vibration","property":"vibration","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected vibration"},{"type":"enum","name":"action","label":"Action","property":"action","access":1,"values":["vibration","tilt","drop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"strength","label":"Strength","property":"strength","access":1},{"type":"enum","name":"sensitivity","label":"Sensitivity","property":"sensitivity","access":3,"values":["low","medium","high"]},{"type":"numeric","name":"angle_x","label":"Angle x","property":"angle_x","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_y","label":"Angle y","property":"angle_y","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_z","label":"Angle z","property":"angle_z","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"x_axis","label":"X axis","property":"x_axis","access":1,"description":"Accelerometer X value"},{"type":"numeric","name":"y_axis","label":"Y axis","property":"y_axis","access":1,"description":"Accelerometer Y value"},{"type":"numeric","name":"z_axis","label":"Z axis","property":"z_axis","access":1,"description":"Accelerometer Z value"},{"type":"numeric","name":"voltage","label":"Voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"power_outage_count","label":"Power outage count","property":"power_outage_count","access":1,"description":"Number of power outages"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."},"[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00158d0007ec86e0"}
        zigbee.0
        	2024-01-02 13:21:52.033	info	0x00158d00041fdb24 (addr 16249): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
        zigbee.0
        	2024-01-02 13:21:52.031	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d00041fdb24","_networkAddress":16249,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,6],"outputClusters":[0,4,65535],"deviceNetworkAddress":16249,"deviceIeeeAddress":"0x00158d00041fdb24","clusters":{"genBasic":{"attributes":{"65281":{"1":2965,"3":12,"4":17320,"5":243,"6":[0,1],"10":0,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20161128","swBuildId":"3000-0001"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d00041fdb24"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20161128","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":-1496948516},"_lastSeen":1704197691025,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"binary","name":"contact","label":"Contact","property":"contact","access":1,"value_on":false,"value_off":true,"description":"Indicates if the contact is closed (= true) or open (= false)"},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"numeric","name":"voltage","label":"Voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"power_outage_count","label":"Power outage count","property":"power_outage_count","access":1,"description":"Number of power outages"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."}]},"name":"0x00158d00041fdb24"}
        zigbee.0
        	2024-01-02 13:21:52.029	info	0x3410f4fffee3428b (addr 28201): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
        zigbee.0
        	2024-01-02 13:21:52.028	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":7,"_type":"Router","_ieeeAddr":"0x3410f4fffee3428b","_networkAddress":28201,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":28201,"deviceIeeeAddress":"0x3410f4fffee3428b","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"occupancy":0,"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee3428b"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198012562,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee3428b"}
        zigbee.0
        	2024-01-02 13:21:52.026	info	0x00124b002214642f (addr 38327): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
        zigbee.0
        	2024-01-02 13:21:52.024	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00124b002214642f","_networkAddress":38327,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":12,"inputClusters":[0],"outputClusters":[1,1024,1026,1027,1029,1032],"deviceNetworkAddress":38327,"deviceIeeeAddress":"0x00124b002214642f","clusters":{"genBasic":{"attributes":{"modelId":"DIYRuZ_Flower","manufacturerName":"modkam.ru","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":4,"hwVersion":1,"dateCode":"18/01/2021 10:59","swBuildId":"18/01/2021 10:59"}},"genPowerCfg":{"attributes":{"512":6317,"batteryVoltage":28,"batteryPercentageRemaining":54}},"msPressureMeasurement":{"attributes":{"scale":-1,"scaledValue":0,"measuredValue":0}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":556}},"msSoilMoisture":{"attributes":{"512":4970,"513":6317,"measuredValue":406}},"msTemperatureMeasurement":{"attributes":{"measuredValue":0}},"msRelativeHumidity":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1027,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1032,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1029,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1027,"attrId":16,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1024,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1032,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00124b002214642f"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":260,"deviceID":12,"inputClusters":[],"outputClusters":[1026],"deviceNetworkAddress":38327,"deviceIeeeAddress":"0x00124b002214642f","clusters":{"msTemperatureMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":2,"deviceIeeeAddress":"0x00124b002214642f"}}],"_manufacturerName":"modkam.ru","_powerSource":"Battery","_modelID":"DIYRuZ_Flower","_applicationVersion":3,"_stackVersion":4,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"18/01/2021 10:59","_softwareBuildID":"18/01/2021 10:59","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1673866955578,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["DIYRuZ_Flower"],"model":"DIYRuZ_Flower","vendor":"DIYRuZ","description":"[Flower sensor](http://modkam.ru/?p=1700)","fromZigbee":[{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"temperature_precision","label":"Temperature precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","label":"Temperature calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","label":"Humidity precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","label":"Humidity calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"illuminance_calibration","label":"Illuminance calibration","property":"illuminance_calibration","access":2,"description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"illuminance_lux_calibration","label":"Illuminance lux calibration","property":"illuminance_lux_calibration","access":2,"description":"Calibrates the illuminance_lux value (percentual offset), takes into effect on next report of device."}]},{"cluster":"msSoilMoisture","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"soil_moisture_precision","label":"Soil moisture precision","property":"soil_moisture_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for soil_moisture, takes into effect on next report of device."},{"type":"numeric","name":"soil_moisture_calibration","label":"Soil moisture calibration","property":"soil_moisture_calibration","access":2,"description":"Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","label":"Pressure precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","label":"Pressure calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"meta":{"multiEndpoint":true,"multiEndpointSkip":["humidity"]},"exposes":[{"type":"numeric","name":"soil_moisture","label":"Soil moisture","property":"soil_moisture","access":1,"unit":"%","description":"Measured soil moisture value"},{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"illuminance","label":"Illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance"},{"type":"numeric","name":"humidity","label":"Humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","label":"Pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_ds","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"ds"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_bme","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"bme"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00124b002214642f"}
        zigbee.0
        	2024-01-02 13:21:52.020	info	0x00158d000543212d (addr 25713): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
        zigbee.0
        	2024-01-02 13:21:52.018	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d000543212d","_networkAddress":25713,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":25713,"deviceIeeeAddress":"0x00158d000543212d","clusters":{"genBasic":{"attributes":{"65281":{"1":3015,"3":23,"4":17320,"5":122,"6":[0,6],"8":776,"10":0,"152":25,"153":316,"154":[209,969]},"modelId":"lumi.vibration.aq1","appVersion":8}},"closuresDoorLock":{"attributes":{"85":1,"1283":5,"1285":393216,"1288":[242,4294509540]}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d000543212d"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.vibration.aq1","_applicationVersion":8,"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704197984100,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.vibration.aq1"],"model":"DJT11LM","vendor":"Xiaomi","description":"Aqara vibration sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"vibration_timeout","label":"Vibration timeout","property":"vibration_timeout","access":2,"value_min":0,"description":"Time in seconds after which vibration is cleared after detecting it (default 90 seconds)."},{"type":"numeric","name":"x_calibration","label":"X calibration","property":"x_calibration","access":2,"description":"Calibrates the x value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"y_calibration","label":"Y calibration","property":"y_calibration","access":2,"description":"Calibrates the y value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"z_calibration","label":"Z calibration","property":"z_calibration","access":2,"description":"Calibrates the z value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["sensitivity"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"binary","name":"vibration","label":"Vibration","property":"vibration","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected vibration"},{"type":"enum","name":"action","label":"Action","property":"action","access":1,"values":["vibration","tilt","drop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"strength","label":"Strength","property":"strength","access":1},{"type":"enum","name":"sensitivity","label":"Sensitivity","property":"sensitivity","access":3,"values":["low","medium","high"]},{"type":"numeric","name":"angle_x","label":"Angle x","property":"angle_x","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_y","label":"Angle y","property":"angle_y","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_z","label":"Angle z","property":"angle_z","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"x_axis","label":"X axis","property":"x_axis","access":1,"description":"Accelerometer X value"},{"type":"numeric","name":"y_axis","label":"Y axis","property":"y_axis","access":1,"description":"Accelerometer Y value"},{"type":"numeric","name":"z_axis","label":"Z axis","property":"z_axis","access":1,"description":"Accelerometer Z value"},{"type":"numeric","name":"voltage","label":"Voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"power_outage_count","label":"Power outage count","property":"power_outage_count","access":1,"description":"Number of power outages"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."},"[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00158d000543212d"}
        zigbee.0
        	2024-01-02 13:21:52.014	info	0x3410f4fffee9c7fe (addr 4766): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
        • arteckA arteck
          super ihr beiden
          @mrjeschke
          @fredf
          aber
          !!!!!!!!!!!!!!!!!!!!!!!!!!!! ich brauch mal ein LOG
          adapter stoppen
          und jetzt
          starten warten bis zum abbruch und LOG posten
          tobrog
          schrieb am zuletzt editiert von tobrog
          @arteck hier auch nochmal ein log von mir mit der aktuelle Git version.
          Der zweite Präsenzsensor (0x048727fffeb18c96) ist momentan nicht an.
          zigbee.0
          2024-01-02 17:33:04.823	warn	DeviceAvailability:Failed to ping 0x048727fffeb18c96 SNZB-06P
          zigbee.0
          2024-01-02 17:33:02.396	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
          zigbee.0
          2024-01-02 17:32:54.254	info	Configuring 0x3410f4fffee99489 SNZB-06P
          zigbee.0
          2024-01-02 17:32:53.366	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
          zigbee.0
          2024-01-02 17:32:52.778	info	Configuring 0x048727fffeb18c96 SNZB-06P
          zigbee.0
          2024-01-02 17:32:52.246	info	debug devices set to []
          zigbee.0
          2024-01-02 17:32:52.107	warn	download icon from https://www.zigbee2mqtt.io/images/devices/SNZB-06P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SNZB-06P.png
          zigbee.0
          2024-01-02 17:32:52.098	warn	download icon from https://www.zigbee2mqtt.io/images/devices/SNZB-06P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SNZB-06P.png
          zigbee.0
          2024-01-02 17:32:52.046	info	Zigbee started
          zigbee.0
          2024-01-02 17:32:52.045	info	0x048727fffeb18c96 (addr 42562): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
          zigbee.0
          2024-01-02 17:32:52.044	info	0x3410f4fffee99489 (addr 54779): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
          zigbee.0
          2024-01-02 17:32:52.044	info	0x847127fffe33d461 (addr 63785): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          zigbee.0
          2024-01-02 17:32:52.043	info	0x847127fffe4270a6 (addr 1307): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
          zigbee.0
          2024-01-02 17:32:52.042	info	0x00158d0006b245e7 (addr 29823): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.042	info	0x847127fffec731ec (addr 9835): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.041	info	0x5c0272fffed12f83 (addr 13606): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
          zigbee.0
          2024-01-02 17:32:52.041	info	0x5c0272fffef5d514 (addr 50002): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
          zigbee.0
          2024-01-02 17:32:52.039	info	0x7cb03eaa0a0beebe (addr 24279): AB3257001NJ - OSRAM Smart+ plug (Router)
          zigbee.0
          2024-01-02 17:32:52.024	info	0x7cb03eaa0a0bfbdf (addr 25609): AB3257001NJ - OSRAM Smart+ plug (Router)
          zigbee.0
          2024-01-02 17:32:52.021	info	0x7cb03eaa0a0bfb47 (addr 16039): AB3257001NJ - OSRAM Smart+ plug (Router)
          zigbee.0
          2024-01-02 17:32:52.019	info	0x7cb03eaa0a0bf6b6 (addr 13030): AB3257001NJ - OSRAM Smart+ plug (Router)
          zigbee.0
          2024-01-02 17:32:52.017	info	0x00158d0006c57f78 (addr 21990): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.015	info	0x00158d0006c521ec (addr 23215): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.014	info	0x00158d000700186c (addr 4751): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.014	info	0x00158d000805a976 (addr 58423): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.013	info	0x00158d0007e5fe63 (addr 17147): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:52.005	info	Configuring 0x3410f4fffee99489 SNZB-06P
          zigbee.0
          2024-01-02 17:32:52.004	info	0x00158d0007e4c53c (addr 11255): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0
          2024-01-02 17:32:51.957	info	Currently 18 devices are joined:
          zigbee.0
          2024-01-02 17:32:51.953	info	Unable to set transmit power, unsupported function.
          zigbee.0
          2024-01-02 17:32:51.886	info	--> transmitPower : high+
          zigbee.0
          2024-01-02 17:32:51.875	info	Unable to disable LED, unsupported function.
          zigbee.0
          2024-01-02 17:32:51.850	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
          zigbee.0
          2024-01-02 17:32:50.646	info	Installed Version: ioBroker/ioBroker.zigbee
          zigbee.0
          2024-01-02 17:32:50.218	info	Starting Zigbee npm ...
          zigbee.0
          2024-01-02 17:32:50.200	info	delete old Backup files. keep only last 10
          zigbee.0
          2024-01-02 17:32:50.015	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
          host.iobroker
          2024-01-02 17:32:44.194	info	instance system.adapter.zigbee.0 started with pid 44215
          • arteckA arteck
            super ihr beiden
            @mrjeschke
            @fredf
            aber
            adapter stoppen
            und jetzt
            denjo
            @arteck moin, habe mit der aktuellen github version auch das gleiche problem mit den sonoff
            zigbee.0
            2024-01-02 18:45:53.962	error	Error while processing converters DEVICE_ID: '84ba20fffed21f14'
            • arteckA Offline
              arteckA Offline
              arteck
              und die Meldung kommt nur bei Start richtig ?
              FredFF T 2 Antworten Letzte Antwort
              • arteckA arteck
                FredFF Offline
                FredFF Offline
                FredF
                Most Active Forum Testing
                @arteck Nö, öfters:
                2024-01-03 09:51:21.508	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:51:19.228	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:51:18.519	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:51:16.491	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:51:16.246	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:51:13.528	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:51:13.263	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:51:10.754	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:51:10.331	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:51:07.763	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:51:07.392	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:44:14.569	info	Device '0xec1bbdfffea30275' announced itself
                2024-01-03 09:41:06.129	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:41:05.914	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:41:03.152	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:41:02.931	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:41:00.250	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:40:59.938	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:40:57.237	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:40:56.958	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:40:54.209	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:40:54.012	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:35:32.062	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:35:31.643	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:30:52.784	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:30:52.577	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:30:49.788	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:30:49.597	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:30:46.861	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:30:46.620	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:30:43.855	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:30:43.630	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:30:40.842	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:30:40.650	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:29:14.763	info	Device '0xec1bbdfffea30275' announced itself
                2024-01-03 09:25:22.683	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:25:22.482	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:24:17.353	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:24:17.139	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:20:39.455	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:20:39.249	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:20:36.491	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:20:36.271	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:20:33.538	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:20:33.298	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:20:30.493	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:20:30.305	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:20:27.624	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:20:27.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:10:26.112	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:10:25.927	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:10:23.168	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:10:22.952	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:10:20.151	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:10:19.961	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:10:17.264	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:10:16.990	info	Configuring 0x3410f4fffee39865 SNZB-06P
                2024-01-03 09:10:14.185	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                2024-01-03 09:10:13.996	info	Configuring 0x3410f4fffee39865 SNZB-06P
                • arteckA arteck
                  tobrog
                  @arteck Bei mir auch. Wiederholt sich alle paar Minuten:
                  zigbee.0
                  2024-01-03 09:50:51.375	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:50:51.137	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:50:48.600	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:50:48.111	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:50:45.433	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:50:45.113	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:50:42.256	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:50:42.089	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:50:39.235	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:50:39.072	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:48:02.275	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:48:01.723	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:40:31.648	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:40:31.377	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:40:29.204	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:40:28.360	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:40:25.563	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:40:25.345	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:40:22.483	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:40:22.328	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:40:19.521	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:40:19.331	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:37:42.089	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:37:41.892	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:30:12.372	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:30:11.620	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:30:08.826	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:30:08.603	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:30:05.897	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:30:05.588	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:30:03.318	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:30:02.579	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:29:59.768	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:29:59.566	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  zigbee.0
                  2024-01-03 09:27:22.335	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                  zigbee.0
                  2024-01-03 09:27:22.113	info	Configuring 0x3410f4fffee99489 SNZB-06P
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    na dann weiter gehts
                    bitte die
                    /opt/iobroker/node_modules/iobroker.zigbee/main.js
                    editieren und diese Zeile suchen (ca. Zeile 559 )
                    this.log.error(`Error while processing converters DEVICE_ID: '${devId}' `);
                    direkt danach das einfügen..(copy paste nutzen nicht abtippen)
                    this.log.error(`arteck: '${cluster}' -> '${type}'`);
                    es sollte dann erst die Fehlermeldung kommen und dann noch eine mit
                    arteck:
                    diese brauch ich
                    FredFF 1 Antwort Letzte Antwort
                    • arteckA arteck
                      bitte die
                      arteck:
                      diese brauch ich
                      FredFF Offline
                      FredFF Offline
                      FredF
                      @arteck Adapter vorher stoppen?
                      • FredFF FredF
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @fredf ne musst du nicht.. danach aber nue starten
                        oder stoppen editieren und starten
                        • arteckA arteck
                          FredFF Offline
                          FredFF Offline
                          FredF
                          @arteck
                          2024-01-03 11:15:18.918	error	arteck: '64529' -> 'readResponse'
                          2024-01-03 11:15:18.918	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                          2024-01-03 11:15:18.913	error	arteck: '64529' -> 'readResponse'
                          2024-01-03 11:15:18.913	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                          2024-01-03 11:15:16.712	info	Configuring 0x3410f4fffee39865 SNZB-06P
                          2024-01-03 11:15:15.279	error	arteck: '64529' -> 'readResponse'
                          2024-01-03 11:15:15.279	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                          2024-01-03 11:15:15.275	error	arteck: '64529' -> 'readResponse'
                          2024-01-03 11:15:15.275	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                          2024-01-03 11:15:14.867	info	debug devices set to []
                          • FredFF FredF
                            @arteck
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @fredf sagte in Sonoff Presence Sensor SNZB-06P problem:
                            readResponse
                            du bist ja schnell ..
                            paar zeilen dadrüber sollte
                            meta.state = { state: '' };   // for tuya
                            da sein ..lösche mal die zeile... und starte adapter neu...
                            kommt dann die error meldung ?? für den SNZB-06P
                            • arteckA arteck
                              readResponse
                              FredFF Offline
                              FredFF Offline
                              FredF
                              @arteck Immer noch
                              2024-01-03 11:20:37.439	error	arteck: '64529' -> 'readResponse'
                              2024-01-03 11:20:37.439	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                              2024-01-03 11:20:37.276	info	Configuring 0x3410f4fffee39865 SNZB-06P
                              2024-01-03 11:20:35.704	error	arteck: '64529' -> 'readResponse'
                              2024-01-03 11:20:35.703	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                              2024-01-03 11:20:35.299	info	debug devices set to []
                              • FredFF FredF
                                @arteck Immer noch
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @fredf bist sicher dass du den adapter neu gestertet hast ??
                                • arteckA arteck
                                  FredFF Offline
                                  FredFF Offline
                                  FredF
                                  schrieb am zuletzt editiert von FredF
                                  @arteck Na klar:
                                  2024-01-03 11:20:32.794	info	Starting Zigbee npm ...
                                  2024-01-03 11:20:32.792	info	delete old Backup files. keep only last 10
                                  2024-01-03 11:20:32.666	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                                  2024-01-03 11:20:27.249	info	instance system.adapter.zigbee.0 started with pid 1280
                                  2024-01-03 11:20:24.971	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-01-03 11:20:24.355	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2024-01-03 11:20:24.354	info	terminating
                                  2024-01-03 11:20:24.113	info	stopInstance system.adapter.zigbee.0 send kill signal
                                  2024-01-03 11:20:24.010	info	Zigbee: disabling joining new devices.
                                  2024-01-03 11:20:23.854	info	cleaned everything up...
                                  2024-01-03 11:20:23.853	info	Got terminate signal TERMINATE_YOURSELF
                                  2024-01-03 11:20:23.849	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  Aber zur Sicherheit nchmal gestartet:
                                  2024-01-03 11:26:19.969	error	arteck: '64529' -> 'readResponse'
                                  2024-01-03 11:26:19.969	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                  2024-01-03 11:26:19.587	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                  2024-01-03 11:26:18.333	error	arteck: '64529' -> 'readResponse'
                                  2024-01-03 11:26:18.332	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                  2024-01-03 11:26:17.644	info	debug devices set to []
                                  • FredFF FredF
                                    @arteck Na klar:
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @fredf ok warte gleich kommt ne GIT version
                                    @fredf installier mal von git
                                    • arteckA arteck
                                      FredFF Offline
                                      FredFF Offline
                                      FredF
                                      @arteck Nur beim Adapter Start kommt das, dann nix mehr.
                                      2024-01-03 12:05:48.223	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                      2024-01-03 12:05:48.041	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 12:05:46.604	error	Error while processing converters DEVICE_ID: '3410f4fffee39865' cluster '64529' type 'readResponse'
                                      2024-01-03 12:05:46.120	info	debug devices set to []
                                      • FredFF FredF
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @fredf sehr gut..
                                        • arteckA arteck
                                          @fredf sehr gut..
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @arteck schaumal bitte noch
                                          editiere
                                          /opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js
                                          ganz unten zeile 144
                                          // do nothing ignore it
                                          ersetze diese durch
                                          return true;
                                          adapter neu starten
