  4. Sonoff Presence Sensor SNZB-06P problem
    6.5k
80 Beiträge 14 Kommentatoren 18.4k Aufrufe 13 Beobachtet
  • F Offline
    Förster
    habe den Sensor Sonoff SNZB-06P auch am Laufen. Nach dem Update des Zigbee-Adapters auf 1.9.5 funktioniert er zwar noch, bekomme aber ständig diese Meldung:
    zigbee.0
    	2024-01-01 19:52:21.610	error	Error while processing converters DEVICE_ID: '3410f4fffee3428b'
    zigbee.0
    	2024-01-01 19:52:21.571	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x3410f4fffee3428b SNZB-06P (Error: Read 0x3410f4fffee3428b/1 64529([8193], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE') at Endpoint.checkStatus (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:321:28) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:463:22) at setupAttributes (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:62:9) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:72:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21))
    zigbee.0
    	2024-01-01 19:52:21.426	info	Configuring 0x3410f4fffee3428b SNZB-06P
    zigbee.0
    	2024-01-01 19:49:39.042	error	Error while processing converters DEVICE_ID: '3410f4fffee3428b'
    zigbee.0
    	2024-01-01 19:49:39.025	error	DeviceConfigure:Failed to DeviceConfigure.configure 0x3410f4fffee3428b SNZB-06P (Error: Read 0x3410f4fffee3428b/1 64529([8193], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Status 'UNSUPPORTED_ATTRIBUTE') at Endpoint.checkStatus (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:321:28) at Endpoint.read (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:463:22) at setupAttributes (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:62:9) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:72:9) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21) at DeviceConfigure.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:54:21) at async Promise.all (index 1))
    zigbee.0
    	2024-01-01 19:49:38.443	info	debug devices set to []
    zigbee.0
    	2024-01-01 19:49:38.242	warn	download icon from https://www.zigbee2mqtt.io/images/devices/ZNJLBL01LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZNJLBL01LM.png
    zigbee.0
    	2024-01-01 19:49:38.223	warn	download icon from https://www.zigbee2mqtt.io/images/devices/SNZB-06P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SNZB-06P.png
    zigbee.0
    	2024-01-01 19:49:38.211	info	Zigbee started
    Node.js: v18.19.0
    NPM: 10.2.3
    @arteck Hast du eine Idee, woran das liegt bzw. was ich da machen kann ?
    Christian
    • F Förster
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Node.js: v18.19.0
      NPM: 10.2.3
      Christian
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      @förster Gibt dazu bereits ein issue: https://github.com/ioBroker/ioBroker.zigbee/issues/2018
      Wurde zwar mit Version 1.9.6 als gelöst geschlossen, die Fehlermeldung kommt aber weiterhin.
      • arteckA Offline
        arteckA Offline
        arteck
        @förster sagte in Sonoff Presence Sensor SNZB-06P problem:
        SNZB-06P
        ich brauch mal ein LOG
        adapter stoppen
        und jetzt
        starten warten bis zum abbruch und LOG posten
        • arteckA Offline
          arteckA Offline
          arteck
          installiert mal die GIT version...
          ich hab die Fehlermeldung nur abgeklemmt.. wenn es so ist das die Geräte nochrmal funktionieren .. dann ist diese überflüssig..
          checkt das mal
          FredFF M 2 Antworten Letzte Antwort
          • arteckA arteck
            checkt das mal
            FredFF Online
            FredFF Online
            FredF
            @arteck Damit kommt nur noch diese Fehlermeldung:
            2024-01-02 11:57:06.205	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
            • arteckA arteck
              checkt das mal
              mrjeschke
              @arteck
              Ein Error kommt bei mir beim SNZB-06P noch. (Github-Version des Adapters)
              2024-01-02 11:48:15.520 - error: zigbee.0 (768634) Error while processing converters DEVICE_ID: '3410f4fffee99189'
              • arteckA Offline
                arteckA Offline
                arteck
                super ihr beiden
                @mrjeschke
                @fredf
                aber
                !!!!!!!!!!!!!!!!!!!!!!!!!!!! ich brauch mal ein LOG
                adapter stoppen
                und jetzt
                F T D 3 Antworten Letzte Antwort
                • arteckA arteck
                  super ihr beiden
                  @mrjeschke
                  @fredf
                  aber
                  adapter stoppen
                  und jetzt
                  Förster
                  @arteck
                  zigbee.0
                  	2024-01-02 13:21:52.012	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198089639,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"}
                  zigbee.0
                  	2024-01-02 13:21:51.993	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 1030 [{"attribute":{"ID":32,"type":33},"min":-1,"max":-1,"change":-1}]
                  zigbee.0
                  	2024-01-02 13:21:51.985	info	Configuring 0x3410f4fffee9c7fe SNZB-06P
                  zigbee.0
                  	2024-01-02 13:21:51.979	info	0x00124b0022146607 (addr 20276): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
                  zigbee.0
                  	2024-01-02 13:21:51.977	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"EndDevice","_ieeeAddr":"0x00124b0022146607","_networkAddress":20276,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":12,"inputClusters":[0],"outputClusters":[1,1024,1026,1027,1029,1032],"deviceNetworkAddress":20276,"deviceIeeeAddress":"0x00124b0022146607","clusters":{"genBasic":{"attributes":{"modelId":"DIYRuZ_Flower","manufacturerName":"modkam.ru","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":4,"hwVersion":1,"dateCode":"18/01/2021 10:59","swBuildId":"18/01/2021 10:59"}},"genPowerCfg":{"attributes":{"512":6245,"batteryVoltage":28,"batteryPercentageRemaining":44}},"msPressureMeasurement":{"attributes":{"scale":-1,"scaledValue":0,"measuredValue":0}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":545}},"msSoilMoisture":{"attributes":{"512":4985,"513":6245,"measuredValue":274}},"msTemperatureMeasurement":{"attributes":{"measuredValue":0}},"msRelativeHumidity":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1027,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1032,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1029,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1027,"attrId":16,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1024,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1032,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00124b0022146607"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":260,"deviceID":12,"inputClusters":[],"outputClusters":[1026],"deviceNetworkAddress":20276,"deviceIeeeAddress":"0x00124b0022146607","clusters":{"msTemperatureMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":2,"deviceIeeeAddress":"0x00124b0022146607"}}],"_manufacturerName":"modkam.ru","_powerSource":"Battery","_modelID":"DIYRuZ_Flower","_applicationVersion":3,"_stackVersion":4,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"18/01/2021 10:59","_softwareBuildID":"18/01/2021 10:59","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1661031806167,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["DIYRuZ_Flower"],"model":"DIYRuZ_Flower","vendor":"DIYRuZ","description":"[Flower sensor](http://modkam.ru/?p=1700)","fromZigbee":[{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"temperature_precision","label":"Temperature precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","label":"Temperature calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","label":"Humidity precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","label":"Humidity calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"illuminance_calibration","label":"Illuminance calibration","property":"illuminance_calibration","access":2,"description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"illuminance_lux_calibration","label":"Illuminance lux calibration","property":"illuminance_lux_calibration","access":2,"description":"Calibrates the illuminance_lux value (percentual offset), takes into effect on next report of device."}]},{"cluster":"msSoilMoisture","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"soil_moisture_precision","label":"Soil moisture precision","property":"soil_moisture_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for soil_moisture, takes into effect on next report of device."},{"type":"numeric","name":"soil_moisture_calibration","label":"Soil moisture calibration","property":"soil_moisture_calibration","access":2,"description":"Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","label":"Pressure precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","label":"Pressure calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"meta":{"multiEndpoint":true,"multiEndpointSkip":["humidity"]},"exposes":[{"type":"numeric","name":"soil_moisture","label":"Soil moisture","property":"soil_moisture","access":1,"unit":"%","description":"Measured soil moisture value"},{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"illuminance","label":"Illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance"},{"type":"numeric","name":"humidity","label":"Humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","label":"Pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_ds","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"ds"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_bme","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"bme"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00124b0022146607"}
                  zigbee.0
                  	2024-01-02 13:21:51.970	debug	DeviceConfigure:DeviceConfigure 0x3410f4fffee9c7fe SNZB-06P needed
                  zigbee.0
                  	2024-01-02 13:21:51.969	debug	DeviceConfigure:DeviceConfigure 0x00124b0022146607 DIYRuZ_Flower not needed
                  zigbee.0
                  	2024-01-02 13:21:51.963	debug	DeviceAvailability:Publish LQ for 0x54ef4410003e507f = 10
                  zigbee.0
                  	2024-01-02 13:21:51.957	debug	DeviceAvailability:Publish available for 0x54ef4410003e507f = true
                  zigbee.0
                  	2024-01-02 13:21:51.938	debug	DeviceAvailability:Publish LQ for 0x00158d0007ec86e0 = 10
                  zigbee.0
                  	2024-01-02 13:21:51.934	debug	DeviceAvailability:Publish available for 0x00158d0007ec86e0 = true
                  zigbee.0
                  	2024-01-02 13:21:51.930	debug	DeviceAvailability:Publish LQ for 0x00158d00041fdb24 = 10
                  zigbee.0
                  	2024-01-02 13:21:51.926	debug	DeviceAvailability:Publish available for 0x00158d00041fdb24 = true
                  zigbee.0
                  	2024-01-02 13:21:51.921	debug	DeviceAvailability:Publish LQ for 0x00124b002214642f = 10
                  zigbee.0
                  	2024-01-02 13:21:51.917	debug	DeviceAvailability:Publish available for 0x00124b002214642f = true
                  zigbee.0
                  	2024-01-02 13:21:51.910	debug	DeviceAvailability:Publish LQ for 0x00158d000543212d = 10
                  zigbee.0
                  	2024-01-02 13:21:51.903	debug	DeviceAvailability:Publish available for 0x00158d000543212d = true
                  zigbee.0
                  	2024-01-02 13:21:51.895	debug	DeviceAvailability:Publish LQ for 0x00124b0022146607 = 10
                  zigbee.0
                  	2024-01-02 13:21:51.885	debug	DeviceAvailability:Publish available for 0x00124b0022146607 = true
                  zigbee.0
                  	2024-01-02 13:21:51.884	info	Currently 8 devices are joined:
                  zigbee.0
                  	2024-01-02 13:21:51.868	info	--> transmitPower : normal
                  zigbee.0
                  	2024-01-02 13:21:51.835	info	Unable to disable LED, unsupported function.
                  zigbee.0
                  	2024-01-02 13:21:51.833	debug	Zigbee network parameters: panID=6755 channel=11 extendedPanID=83c4a403004b1200
                  zigbee.0
                  	2024-01-02 13:21:51.828	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                  zigbee.0
                  	2024-01-02 13:21:51.826	debug	zigbee-herdsman started
                  zigbee.0
                  	2024-01-02 13:21:51.523	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_02-13_21_50.tar.gz success
                  zigbee.0
                  	2024-01-02 13:21:51.018	info	Installed Version: ioBroker/ioBroker.zigbee#a5fe3e3048be77e32210ce2181b769653d0f22c1
                  zigbee.0
                  	2024-01-02 13:21:50.696	debug	Starting zigbee-herdsman...
                  zigbee.0
                  	2024-01-02 13:21:50.633	info	Starting Zigbee npm ...
                  zigbee.0
                  	2024-01-02 13:21:50.630	info	delete old Backup files. keep only last 10
                  zigbee.0
                  	2024-01-02 13:21:50.530	debug	Using zigbee-herdsman with settings: {"network":{"panID":6755,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                  zigbee.0
                  	2024-01-02 13:21:50.457	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee#a5fe3e3048be77e32210ce2181b769653d0f22c1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                  • F Offline
                    Förster
                    zigbee.0
                    	2024-01-02 13:21:52.808	error	Error while processing converters DEVICE_ID: '3410f4fffee9c7fe'
                    zigbee.0
                    	2024-01-02 13:21:52.747	debug	DeviceAvailability:Successfully pinged 0x3410f4fffee9c7fe SNZB-06P
                    zigbee.0
                    	2024-01-02 13:21:52.741	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 1030 [{"attribute":{"ID":32,"type":33},"min":-1,"max":-1,"change":-1}]
                    zigbee.0
                    	2024-01-02 13:21:52.739	info	Configuring 0x3410f4fffee9c7fe SNZB-06P
                    zigbee.0
                    	2024-01-02 13:21:52.735	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112725,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":5},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112725,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":5},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":34,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":5,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.730	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 1 with groupID 0
                    zigbee.0
                    	2024-01-02 13:21:52.726	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112725,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":4},"endpoint":"[Circular]","data":{"zclVersion":3},"linkquality":34,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":5,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.716	debug	DeviceConfigure:Reading for 0x3410f4fffee3428b/1 1030 [{"attribute":{"ID":32,"type":33},"min":-1,"max":-1,"change":-1}]
                    zigbee.0
                    	2024-01-02 13:21:52.714	info	Configuring 0x3410f4fffee3428b SNZB-06P
                    zigbee.0
                    	2024-01-02 13:21:52.714	debug	DeviceConfigure:DeviceConfigure 0x3410f4fffee3428b SNZB-06P needed
                    zigbee.0
                    	2024-01-02 13:21:52.713	debug	DeviceConfigure:DeviceConfigure 0x00124b002214642f DIYRuZ_Flower not needed
                    zigbee.0
                    	2024-01-02 13:21:52.713	debug	DeviceConfigure:DeviceConfigure 0x00158d000543212d lumi.vibration.aq1 not needed
                    zigbee.0
                    	2024-01-02 13:21:52.609	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112605,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":4},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112605,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":4},"endpoint":"[Circular]","data":{},"linkquality":34,"groupID":0,"cluster":"64529","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.608	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster '64529', data '{}' from endpoint 1 with groupID 0
                    zigbee.0
                    	2024-01-02 13:21:52.606	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112605,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":3},"endpoint":"[Circular]","data":{},"linkquality":34,"groupID":0,"cluster":"64529","meta":{"zclTransactionSequenceNumber":4,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.222	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 64529 [{"attribute":{"ID":8193,"type":32},"min":-1,"max":-1,"change":-1}]
                    zigbee.0
                    	2024-01-02 13:21:52.214	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112208,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":26,"_lastDefaultResponseSequenceNumber":3},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112208,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":26,"_lastDefaultResponseSequenceNumber":3},"endpoint":"[Circular]","data":{"ultrasonicUToOThreshold":2},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":3,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.212	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster 'msOccupancySensing', data '{"ultrasonicUToOThreshold":2}' from endpoint 1 with groupID 0
                    zigbee.0
                    	2024-01-02 13:21:52.210	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112208,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":26,"_lastDefaultResponseSequenceNumber":2},"endpoint":"[Circular]","data":{"ultrasonicUToOThreshold":2},"linkquality":26,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":3,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.190	debug	getGroups result: {}
                    zigbee.0
                    	2024-01-02 13:21:52.164	debug	DeviceAvailability:register device Ping for "0x54ef4410003e507f"
                    zigbee.0
                    	2024-01-02 13:21:52.164	debug	DeviceAvailability:register device Ping for "0x00158d0007ec86e0"
                    zigbee.0
                    	2024-01-02 13:21:52.163	debug	DeviceAvailability:register device Ping for "0x00158d00041fdb24"
                    zigbee.0
                    	2024-01-02 13:21:52.161	debug	DeviceAvailability:register device Ping for "0x3410f4fffee3428b"
                    zigbee.0
                    	2024-01-02 13:21:52.160	debug	DeviceAvailability:register device Ping for "0x00124b002214642f"
                    zigbee.0
                    	2024-01-02 13:21:52.159	debug	DeviceAvailability:register device Ping for "0x00158d000543212d"
                    zigbee.0
                    	2024-01-02 13:21:52.157	debug	DeviceAvailability:register device Ping for "0x3410f4fffee9c7fe"
                    zigbee.0
                    	2024-01-02 13:21:52.156	info	debug devices set to []
                    zigbee.0
                    	2024-01-02 13:21:52.139	debug	DeviceConfigure:Reading for 0x3410f4fffee9c7fe/1 1030 [{"attribute":{"ID":34,"type":32},"min":-1,"max":-1,"change":-1}]
                    zigbee.0
                    	2024-01-02 13:21:52.131	debug	DeviceAvailability:Publish LQ for 0x3410f4fffee9c7fe = 10
                    zigbee.0
                    	2024-01-02 13:21:52.128	debug	DeviceAvailability:Publish available for 0x3410f4fffee9c7fe = true
                    zigbee.0
                    	2024-01-02 13:21:52.125	debug	Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112113,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":2},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee9c7fe"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112113,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34,"_lastDefaultResponseSequenceNumber":2},"endpoint":"[Circular]","data":{"ultrasonicOToUDelay":60},"linkquality":34,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.121	debug	Received Zigbee message from '0x3410f4fffee9c7fe', type 'readResponse', cluster 'msOccupancySensing', data '{"ultrasonicOToUDelay":60}' from endpoint 1 with groupID 0
                    zigbee.0
                    	2024-01-02 13:21:52.117	debug	handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"Router","_ieeeAddr":"0x3410f4fffee9c7fe","_networkAddress":4766,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":4766,"deviceIeeeAddress":"0x3410f4fffee9c7fe","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2,"occupancy":1}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee9c7fe"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198112113,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0,"_linkquality":34},"endpoint":"[Circular]","data":{"ultrasonicOToUDelay":60},"linkquality":34,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                    zigbee.0
                    	2024-01-02 13:21:52.103	debug	DeviceAvailability:register device Ping for "0x00124b0022146607"
                    zigbee.0
                    	2024-01-02 13:21:52.042	info	Zigbee started
                    zigbee.0
                    	2024-01-02 13:21:52.040	info	0x54ef4410003e507f (addr 57427): ZNJLBL01LM - Xiaomi Aqara roller shade companion E1 (EndDevice)
                    zigbee.0
                    	2024-01-02 13:21:52.038	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_type":"EndDevice","_ieeeAddr":"0x54ef4410003e507f","_networkAddress":57427,"_manufacturerID":4447,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":256,"inputClusters":[0,2,3,4,5,6,9,13,19,258],"outputClusters":[10,25],"deviceNetworkAddress":57427,"deviceIeeeAddress":"0x54ef4410003e507f","clusters":{"genBasic":{"attributes":{"modelId":"lumi.curtain.acn002","manufacturerName":"LUMI","powerSource":0,"zclVersion":3,"appVersion":27,"stackVersion":2,"hwVersion":1,"dateCode":"11-24-2021"}},"aqaraOpple":{"attributes":{"1033":1,"1034":39}},"genAnalogOutput":{"attributes":{"presentValue":0}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x54ef4410003e507f"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":57427,"deviceIeeeAddress":"0x54ef4410003e507f","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x54ef4410003e507f"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.curtain.acn002","_applicationVersion":27,"_stackVersion":2,"_zclVersion":3,"_hardwareVersion":1,"_dateCode":"11-24-2021","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":60219893},"_lastSeen":1656281459439,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.curtain.acn002"],"model":"ZNJLBL01LM","description":"Aqara roller shade companion E1","vendor":"Xiaomi","whiteLabel":[{"vendor":"Xiaomi","model":"RSD-M01"}],"fromZigbee":[{"cluster":"genAnalogOutput","type":["attributeReport","readResponse"],"options":[{"type":"binary","name":"invert_cover","label":"Invert cover","property":"invert_cover","access":2,"value_on":true,"value_off":false,"description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false)."}]},{"cluster":"genMultistateOutput","type":["attributeReport"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"aqaraOpple","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","position"],"options":[{"type":"binary","name":"invert_cover","label":"Invert cover","property":"invert_cover","access":2,"value_on":true,"value_off":false,"description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false)."}]},{"key":["battery"]},{"key":["charging_status"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"cover","features":[{"type":"enum","name":"state","label":"State","property":"state","access":7,"values":["OPEN","CLOSE","STOP"]},{"type":"numeric","name":"position","label":"Position","property":"position","access":7,"value_min":0,"value_max":100,"description":"Position of this cover","unit":"%"}]},{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":5,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"binary","name":"charging_status","label":"Charging status","property":"charging_status","access":5,"value_on":true,"value_off":false,"description":"The current charging status."},{"type":"enum","name":"motor_state","label":"Motor state","property":"motor_state","access":1,"values":["declining","rising","pause","blocked"],"description":"The current state of the motor."},{"type":"binary","name":"running","label":"Running","property":"running","access":1,"value_on":true,"value_off":false,"description":"Whether the motor is moving or not"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"options":["[Circular]",{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."}]},"name":"0x54ef4410003e507f"}
                    zigbee.0
                    	2024-01-02 13:21:52.036	info	0x00158d0007ec86e0 (addr 49157): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                    zigbee.0
                    	2024-01-02 13:21:52.034	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":9,"_type":"EndDevice","_ieeeAddr":"0x00158d0007ec86e0","_networkAddress":49157,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":10,"inputClusters":[0,3,25,257],"outputClusters":[0,4,3,5,25,257],"deviceNetworkAddress":49157,"deviceIeeeAddress":"0x00158d0007ec86e0","clusters":{"genBasic":{"attributes":{"65281":{"1":2925,"3":35,"4":424,"5":78,"6":[0,1],"8":776,"10":0,"152":40,"153":0,"154":[65535,68485341]},"modelId":"lumi.vibration.aq1","appVersion":8}},"closuresDoorLock":{"attributes":{"85":2,"1283":110,"1285":262144,"1288":[64911,131103]}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d0007ec86e0"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":49157,"deviceIeeeAddress":"0x00158d0007ec86e0","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":2,"deviceIeeeAddress":"0x00158d0007ec86e0"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.vibration.aq1","_applicationVersion":8,"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1703095818501,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.vibration.aq1"],"model":"DJT11LM","vendor":"Xiaomi","description":"Aqara vibration sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"vibration_timeout","label":"Vibration timeout","property":"vibration_timeout","access":2,"value_min":0,"description":"Time in seconds after which vibration is cleared after detecting it (default 90 seconds)."},{"type":"numeric","name":"x_calibration","label":"X calibration","property":"x_calibration","access":2,"description":"Calibrates the x value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"y_calibration","label":"Y calibration","property":"y_calibration","access":2,"description":"Calibrates the y value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"z_calibration","label":"Z calibration","property":"z_calibration","access":2,"description":"Calibrates the z value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["sensitivity"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"binary","name":"vibration","label":"Vibration","property":"vibration","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected vibration"},{"type":"enum","name":"action","label":"Action","property":"action","access":1,"values":["vibration","tilt","drop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"strength","label":"Strength","property":"strength","access":1},{"type":"enum","name":"sensitivity","label":"Sensitivity","property":"sensitivity","access":3,"values":["low","medium","high"]},{"type":"numeric","name":"angle_x","label":"Angle x","property":"angle_x","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_y","label":"Angle y","property":"angle_y","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_z","label":"Angle z","property":"angle_z","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"x_axis","label":"X axis","property":"x_axis","access":1,"description":"Accelerometer X value"},{"type":"numeric","name":"y_axis","label":"Y axis","property":"y_axis","access":1,"description":"Accelerometer Y value"},{"type":"numeric","name":"z_axis","label":"Z axis","property":"z_axis","access":1,"description":"Accelerometer Z value"},{"type":"numeric","name":"voltage","label":"Voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"power_outage_count","label":"Power outage count","property":"power_outage_count","access":1,"description":"Number of power outages"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."},"[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00158d0007ec86e0"}
                    zigbee.0
                    	2024-01-02 13:21:52.033	info	0x00158d00041fdb24 (addr 16249): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                    zigbee.0
                    	2024-01-02 13:21:52.031	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_type":"EndDevice","_ieeeAddr":"0x00158d00041fdb24","_networkAddress":16249,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":24321,"inputClusters":[0,3,65535,6],"outputClusters":[0,4,65535],"deviceNetworkAddress":16249,"deviceIeeeAddress":"0x00158d00041fdb24","clusters":{"genBasic":{"attributes":{"65281":{"1":2965,"3":12,"4":17320,"5":243,"6":[0,1],"10":0,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20161128","swBuildId":"3000-0001"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d00041fdb24"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_magnet.aq2","_applicationVersion":3,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20161128","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":-1496948516},"_lastSeen":1704197691025,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.sensor_magnet.aq2"],"model":"MCCGQ11LM","vendor":"Xiaomi","description":"Aqara door & window contact sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"binary","name":"contact","label":"Contact","property":"contact","access":1,"value_on":false,"value_off":true,"description":"Indicates if the contact is closed (= true) or open (= false)"},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"numeric","name":"voltage","label":"Voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"power_outage_count","label":"Power outage count","property":"power_outage_count","access":1,"description":"Number of power outages"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."}]},"name":"0x00158d00041fdb24"}
                    zigbee.0
                    	2024-01-02 13:21:52.029	info	0x3410f4fffee3428b (addr 28201): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
                    zigbee.0
                    	2024-01-02 13:21:52.028	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":7,"_type":"Router","_ieeeAddr":"0x3410f4fffee3428b","_networkAddress":28201,"_manufacturerID":4742,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"deviceNetworkAddress":28201,"deviceIeeeAddress":"0x3410f4fffee3428b","clusters":{"64529":{"attributes":{}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20230905","swBuildId":"1.0.3"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b0003a4c483","zoneState":1}},"msOccupancySensing":{"attributes":{"occupancy":0,"ultrasonicOToUDelay":60,"ultrasonicUToOThreshold":2}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x3410f4fffee3428b"}}],"_manufacturerName":"SONOFF","_powerSource":"DC Source","_modelID":"SNZB-06P","_applicationVersion":1,"_zclVersion":3,"_hardwareVersion":0,"_dateCode":"20230905","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704198012562,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"toZigbee":[{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"type":"list","name":"no_occupancy_since","label":"No occupancy since","property":"no_occupancy_since","access":2,"item_type":{"type":"numeric","name":"time","label":"Time","access":3},"description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds."}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"type":"binary","name":"occupancy","label":"Occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"occupancy_timeout","label":"Occupancy timeout","property":"occupancy_timeout","access":7,"description":"Unoccupied to occupied delay","value_min":15,"value_max":65535},{"type":"enum","name":"occupancy_sensitivity","label":"Occupancy sensitivity","property":"occupancy_sensitivity","access":7,"values":["low","medium","high"],"description":"Sensitivity of human presence detection"},{"type":"enum","name":"illumination","label":"Illumination","property":"illumination","access":5,"values":["dim","bright"],"description":"Only updated when occupancy is detected"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"ota":{},"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"name":"0x3410f4fffee3428b"}
                    zigbee.0
                    	2024-01-02 13:21:52.026	info	0x00124b002214642f (addr 38327): DIYRuZ_Flower - DIYRuZ [Flower sensor](http://modkam.ru/?p=1700) (EndDevice)
                    zigbee.0
                    	2024-01-02 13:21:52.024	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":6,"_type":"EndDevice","_ieeeAddr":"0x00124b002214642f","_networkAddress":38327,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":12,"inputClusters":[0],"outputClusters":[1,1024,1026,1027,1029,1032],"deviceNetworkAddress":38327,"deviceIeeeAddress":"0x00124b002214642f","clusters":{"genBasic":{"attributes":{"modelId":"DIYRuZ_Flower","manufacturerName":"modkam.ru","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":4,"hwVersion":1,"dateCode":"18/01/2021 10:59","swBuildId":"18/01/2021 10:59"}},"genPowerCfg":{"attributes":{"512":6317,"batteryVoltage":28,"batteryPercentageRemaining":54}},"msPressureMeasurement":{"attributes":{"scale":-1,"scaledValue":0,"measuredValue":0}},"msIlluminanceMeasurement":{"attributes":{"measuredValue":556}},"msSoilMoisture":{"attributes":{"512":4970,"513":6317,"measuredValue":406}},"msTemperatureMeasurement":{"attributes":{"measuredValue":0}},"msRelativeHumidity":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1029,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1027,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1024,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1},{"cluster":1032,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1029,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1027,"attrId":16,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1024,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0},{"cluster":1032,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00124b002214642f"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"profileID":260,"deviceID":12,"inputClusters":[],"outputClusters":[1026],"deviceNetworkAddress":38327,"deviceIeeeAddress":"0x00124b002214642f","clusters":{"msTemperatureMeasurement":{"attributes":{"measuredValue":0}}},"_binds":[{"cluster":1026,"type":"endpoint","deviceIeeeAddress":"0x00124b0003a4c483","endpointID":1}],"_configuredReportings":[{"cluster":1026,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":2,"deviceIeeeAddress":"0x00124b002214642f"}}],"_manufacturerName":"modkam.ru","_powerSource":"Battery","_modelID":"DIYRuZ_Flower","_applicationVersion":3,"_stackVersion":4,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"18/01/2021 10:59","_softwareBuildID":"18/01/2021 10:59","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1673866955578,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["DIYRuZ_Flower"],"model":"DIYRuZ_Flower","vendor":"DIYRuZ","description":"[Flower sensor](http://modkam.ru/?p=1700)","fromZigbee":[{"cluster":"msTemperatureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"temperature_precision","label":"Temperature precision","property":"temperature_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device."},{"type":"numeric","name":"temperature_calibration","label":"Temperature calibration","property":"temperature_calibration","access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msRelativeHumidity","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"humidity_precision","label":"Humidity precision","property":"humidity_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device."},{"type":"numeric","name":"humidity_calibration","label":"Humidity calibration","property":"humidity_calibration","access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"illuminance_calibration","label":"Illuminance calibration","property":"illuminance_calibration","access":2,"description":"Calibrates the illuminance value (percentual offset), takes into effect on next report of device."},{"type":"numeric","name":"illuminance_lux_calibration","label":"Illuminance lux calibration","property":"illuminance_lux_calibration","access":2,"description":"Calibrates the illuminance_lux value (percentual offset), takes into effect on next report of device."}]},{"cluster":"msSoilMoisture","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"soil_moisture_precision","label":"Soil moisture precision","property":"soil_moisture_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for soil_moisture, takes into effect on next report of device."},{"type":"numeric","name":"soil_moisture_calibration","label":"Soil moisture calibration","property":"soil_moisture_calibration","access":2,"description":"Calibrates the soil_moisture value (absolute offset), takes into effect on next report of device."}]},{"cluster":"msPressureMeasurement","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"pressure_precision","label":"Pressure precision","property":"pressure_precision","access":2,"value_min":0,"value_max":3,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device."},{"type":"numeric","name":"pressure_calibration","label":"Pressure calibration","property":"pressure_calibration","access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device."}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"meta":{"multiEndpoint":true,"multiEndpointSkip":["humidity"]},"exposes":[{"type":"numeric","name":"soil_moisture","label":"Soil moisture","property":"soil_moisture","access":1,"unit":"%","description":"Measured soil moisture value"},{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"illuminance","label":"Illuminance","property":"illuminance","access":1,"description":"Raw measured illuminance"},{"type":"numeric","name":"humidity","label":"Humidity","property":"humidity","access":1,"unit":"%","description":"Measured relative humidity"},{"type":"numeric","name":"pressure","label":"Pressure","property":"pressure","access":1,"unit":"hPa","description":"The measured atmospheric pressure"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_ds","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"ds"},{"type":"numeric","name":"temperature","label":"Temperature","property":"temperature_bme","access":1,"unit":"°C","description":"Measured temperature value","endpoint":"bme"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":["[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00124b002214642f"}
                    zigbee.0
                    	2024-01-02 13:21:52.020	info	0x00158d000543212d (addr 25713): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                    zigbee.0
                    	2024-01-02 13:21:52.018	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":5,"_type":"EndDevice","_ieeeAddr":"0x00158d000543212d","_networkAddress":25713,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"inputClusters":[],"outputClusters":[],"deviceNetworkAddress":25713,"deviceIeeeAddress":"0x00158d000543212d","clusters":{"genBasic":{"attributes":{"65281":{"1":3015,"3":23,"4":17320,"5":122,"6":[0,6],"8":776,"10":0,"152":25,"153":316,"154":[209,969]},"modelId":"lumi.vibration.aq1","appVersion":8}},"closuresDoorLock":{"attributes":{"85":1,"1283":5,"1285":393216,"1288":[242,4294509540]}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d000543212d"}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.vibration.aq1","_applicationVersion":8,"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1704197984100,"_defaultSendRequestWhen":"immediate","_pendingRequestTimeout":0},"mapped":{"zigbeeModel":["lumi.vibration.aq1"],"model":"DJT11LM","vendor":"Xiaomi","description":"Aqara vibration sensor","meta":{"battery":{"voltageToPercentage":"3V_2850_3000"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"closuresDoorLock","type":["attributeReport","readResponse"],"options":[{"type":"numeric","name":"vibration_timeout","label":"Vibration timeout","property":"vibration_timeout","access":2,"value_min":0,"description":"Time in seconds after which vibration is cleared after detecting it (default 90 seconds)."},{"type":"numeric","name":"x_calibration","label":"X calibration","property":"x_calibration","access":2,"description":"Calibrates the x value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"y_calibration","label":"Y calibration","property":"y_calibration","access":2,"description":"Calibrates the y value (absolute offset), takes into effect on next report of device."},{"type":"numeric","name":"z_calibration","label":"Z calibration","property":"z_calibration","access":2,"description":"Calibrates the z value (absolute offset), takes into effect on next report of device."}]}],"toZigbee":[{"key":["sensitivity"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"exposes":[{"type":"numeric","name":"battery","label":"Battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %, can take up to 24 hours before reported.","value_min":0,"value_max":100},{"type":"numeric","name":"device_temperature","label":"Device temperature","property":"device_temperature","access":1,"unit":"°C","description":"Temperature of the device"},{"type":"binary","name":"vibration","label":"Vibration","property":"vibration","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected vibration"},{"type":"enum","name":"action","label":"Action","property":"action","access":1,"values":["vibration","tilt","drop"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"strength","label":"Strength","property":"strength","access":1},{"type":"enum","name":"sensitivity","label":"Sensitivity","property":"sensitivity","access":3,"values":["low","medium","high"]},{"type":"numeric","name":"angle_x","label":"Angle x","property":"angle_x","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_y","label":"Angle y","property":"angle_y","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"angle_z","label":"Angle z","property":"angle_z","access":1,"value_min":-90,"value_max":90,"unit":"°"},{"type":"numeric","name":"x_axis","label":"X axis","property":"x_axis","access":1,"description":"Accelerometer X value"},{"type":"numeric","name":"y_axis","label":"Y axis","property":"y_axis","access":1,"description":"Accelerometer Y value"},{"type":"numeric","name":"z_axis","label":"Z axis","property":"z_axis","access":1,"description":"Accelerometer Z value"},{"type":"numeric","name":"voltage","label":"Voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"power_outage_count","label":"Power outage count","property":"power_outage_count","access":1,"description":"Number of power outages"},{"type":"numeric","name":"linkquality","label":"Linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"options":[{"type":"numeric","name":"device_temperature_calibration","label":"Device temperature calibration","property":"device_temperature_calibration","access":2,"description":"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device."},"[Circular]","[Circular]","[Circular]","[Circular]"]},"name":"0x00158d000543212d"}
                    zigbee.0
                    	2024-01-02 13:21:52.014	info	0x3410f4fffee9c7fe (addr 4766): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
                    • arteckA arteck
                      super ihr beiden
                      @mrjeschke
                      @fredf
                      aber
                      !!!!!!!!!!!!!!!!!!!!!!!!!!!! ich brauch mal ein LOG
                      adapter stoppen
                      und jetzt
                      starten warten bis zum abbruch und LOG posten
                      tobrog
                      schrieb am zuletzt editiert von tobrog
                      @arteck hier auch nochmal ein log von mir mit der aktuelle Git version.
                      Der zweite Präsenzsensor (0x048727fffeb18c96) ist momentan nicht an.
                      zigbee.0
                      2024-01-02 17:33:04.823	warn	DeviceAvailability:Failed to ping 0x048727fffeb18c96 SNZB-06P
                      zigbee.0
                      2024-01-02 17:33:02.396	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                      zigbee.0
                      2024-01-02 17:32:54.254	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-02 17:32:53.366	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                      zigbee.0
                      2024-01-02 17:32:52.778	info	Configuring 0x048727fffeb18c96 SNZB-06P
                      zigbee.0
                      2024-01-02 17:32:52.246	info	debug devices set to []
                      zigbee.0
                      2024-01-02 17:32:52.107	warn	download icon from https://www.zigbee2mqtt.io/images/devices/SNZB-06P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SNZB-06P.png
                      zigbee.0
                      2024-01-02 17:32:52.098	warn	download icon from https://www.zigbee2mqtt.io/images/devices/SNZB-06P.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/SNZB-06P.png
                      zigbee.0
                      2024-01-02 17:32:52.046	info	Zigbee started
                      zigbee.0
                      2024-01-02 17:32:52.045	info	0x048727fffeb18c96 (addr 42562): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
                      zigbee.0
                      2024-01-02 17:32:52.044	info	0x3410f4fffee99489 (addr 54779): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
                      zigbee.0
                      2024-01-02 17:32:52.044	info	0x847127fffe33d461 (addr 63785): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      zigbee.0
                      2024-01-02 17:32:52.043	info	0x847127fffe4270a6 (addr 1307): LED1537R6/LED1739R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable, white spectrum (Router)
                      zigbee.0
                      2024-01-02 17:32:52.042	info	0x00158d0006b245e7 (addr 29823): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.042	info	0x847127fffec731ec (addr 9835): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.041	info	0x5c0272fffed12f83 (addr 13606): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                      zigbee.0
                      2024-01-02 17:32:52.041	info	0x5c0272fffef5d514 (addr 50002): LED1837R5 - IKEA TRADFRI LED bulb GU10 400 lumen, dimmable (Router)
                      zigbee.0
                      2024-01-02 17:32:52.039	info	0x7cb03eaa0a0beebe (addr 24279): AB3257001NJ - OSRAM Smart+ plug (Router)
                      zigbee.0
                      2024-01-02 17:32:52.024	info	0x7cb03eaa0a0bfbdf (addr 25609): AB3257001NJ - OSRAM Smart+ plug (Router)
                      zigbee.0
                      2024-01-02 17:32:52.021	info	0x7cb03eaa0a0bfb47 (addr 16039): AB3257001NJ - OSRAM Smart+ plug (Router)
                      zigbee.0
                      2024-01-02 17:32:52.019	info	0x7cb03eaa0a0bf6b6 (addr 13030): AB3257001NJ - OSRAM Smart+ plug (Router)
                      zigbee.0
                      2024-01-02 17:32:52.017	info	0x00158d0006c57f78 (addr 21990): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.015	info	0x00158d0006c521ec (addr 23215): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.014	info	0x00158d000700186c (addr 4751): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.014	info	0x00158d000805a976 (addr 58423): DJT11LM - Xiaomi Aqara vibration sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.013	info	0x00158d0007e5fe63 (addr 17147): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:52.005	info	Configuring 0x3410f4fffee99489 SNZB-06P
                      zigbee.0
                      2024-01-02 17:32:52.004	info	0x00158d0007e4c53c (addr 11255): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                      zigbee.0
                      2024-01-02 17:32:51.957	info	Currently 18 devices are joined:
                      zigbee.0
                      2024-01-02 17:32:51.953	info	Unable to set transmit power, unsupported function.
                      zigbee.0
                      2024-01-02 17:32:51.886	info	--> transmitPower : high+
                      zigbee.0
                      2024-01-02 17:32:51.875	info	Unable to disable LED, unsupported function.
                      zigbee.0
                      2024-01-02 17:32:51.850	info	Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
                      zigbee.0
                      2024-01-02 17:32:50.646	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      2024-01-02 17:32:50.218	info	Starting Zigbee npm ...
                      zigbee.0
                      2024-01-02 17:32:50.200	info	delete old Backup files. keep only last 10
                      zigbee.0
                      2024-01-02 17:32:50.015	info	starting. Version 1.9.6 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                      host.iobroker
                      2024-01-02 17:32:44.194	info	instance system.adapter.zigbee.0 started with pid 44215
                      • arteckA arteck
                        super ihr beiden
                        @mrjeschke
                        @fredf
                        aber
                        adapter stoppen
                        und jetzt
                        denjo
                        @arteck moin, habe mit der aktuellen github version auch das gleiche problem mit den sonoff
                        zigbee.0
                        2024-01-02 18:45:53.962	error	Error while processing converters DEVICE_ID: '84ba20fffed21f14'
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          und die Meldung kommt nur bei Start richtig ?
                          FredFF T 2 Antworten Letzte Antwort
                          • arteckA arteck
                            FredFF Online
                            FredFF Online
                            FredF
                            Most Active Forum Testing
                            @arteck Nö, öfters:
                            2024-01-03 09:51:21.508	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:51:19.228	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:51:18.519	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:51:16.491	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:51:16.246	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:51:13.528	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:51:13.263	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:51:10.754	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:51:10.331	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:51:07.763	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:51:07.392	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:44:14.569	info	Device '0xec1bbdfffea30275' announced itself
                            2024-01-03 09:41:06.129	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:41:05.914	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:41:03.152	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:41:02.931	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:41:00.250	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:40:59.938	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:40:57.237	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:40:56.958	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:40:54.209	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:40:54.012	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:35:32.062	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:35:31.643	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:30:52.784	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:30:52.577	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:30:49.788	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:30:49.597	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:30:46.861	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:30:46.620	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:30:43.855	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:30:43.630	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:30:40.842	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:30:40.650	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:29:14.763	info	Device '0xec1bbdfffea30275' announced itself
                            2024-01-03 09:25:22.683	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:25:22.482	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:24:17.353	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:24:17.139	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:20:39.455	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:20:39.249	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:20:36.491	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:20:36.271	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:20:33.538	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:20:33.298	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:20:30.493	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:20:30.305	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:20:27.624	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:20:27.322	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:10:26.112	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:10:25.927	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:10:23.168	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:10:22.952	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:10:20.151	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:10:19.961	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:10:17.264	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:10:16.990	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            2024-01-03 09:10:14.185	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                            2024-01-03 09:10:13.996	info	Configuring 0x3410f4fffee39865 SNZB-06P
                            • arteckA arteck
                              tobrog
                              @arteck Bei mir auch. Wiederholt sich alle paar Minuten:
                              zigbee.0
                              2024-01-03 09:50:51.375	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:50:51.137	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:50:48.600	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:50:48.111	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:50:45.433	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:50:45.113	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:50:42.256	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:50:42.089	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:50:39.235	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:50:39.072	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:48:02.275	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:48:01.723	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:40:31.648	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:40:31.377	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:40:29.204	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:40:28.360	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:40:25.563	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:40:25.345	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:40:22.483	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:40:22.328	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:40:19.521	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:40:19.331	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:37:42.089	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:37:41.892	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:30:12.372	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:30:11.620	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:30:08.826	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:30:08.603	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:30:05.897	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:30:05.588	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:30:03.318	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:30:02.579	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:29:59.768	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:29:59.566	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              zigbee.0
                              2024-01-03 09:27:22.335	error	Error while processing converters DEVICE_ID: '3410f4fffee99489'
                              zigbee.0
                              2024-01-03 09:27:22.113	info	Configuring 0x3410f4fffee99489 SNZB-06P
                              • arteckA Offline
                                arteckA Offline
                                arteck
                                na dann weiter gehts
                                bitte die
                                /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                editieren und diese Zeile suchen (ca. Zeile 559 )
                                this.log.error(`Error while processing converters DEVICE_ID: '${devId}' `);
                                direkt danach das einfügen..(copy paste nutzen nicht abtippen)
                                this.log.error(`arteck: '${cluster}' -> '${type}'`);
                                es sollte dann erst die Fehlermeldung kommen und dann noch eine mit
                                arteck:
                                diese brauch ich
                                • arteckA arteck
                                  bitte die
                                  arteck:
                                  diese brauch ich
                                  FredFF Online
                                  FredFF Online
                                  FredF
                                  @arteck Adapter vorher stoppen?
                                  • FredFF FredF
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @fredf ne musst du nicht.. danach aber nue starten
                                    oder stoppen editieren und starten
                                    • arteckA arteck
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      @arteck
                                      2024-01-03 11:15:18.918	error	arteck: '64529' -> 'readResponse'
                                      2024-01-03 11:15:18.918	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                      2024-01-03 11:15:18.913	error	arteck: '64529' -> 'readResponse'
                                      2024-01-03 11:15:18.913	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                      2024-01-03 11:15:16.712	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                      2024-01-03 11:15:15.279	error	arteck: '64529' -> 'readResponse'
                                      2024-01-03 11:15:15.279	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                      2024-01-03 11:15:15.275	error	arteck: '64529' -> 'readResponse'
                                      2024-01-03 11:15:15.275	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                      2024-01-03 11:15:14.867	info	debug devices set to []
                                      • FredFF FredF
                                        @arteck
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @fredf sagte in Sonoff Presence Sensor SNZB-06P problem:
                                        readResponse
                                        du bist ja schnell ..
                                        paar zeilen dadrüber sollte
                                        meta.state = { state: '' };   // for tuya
                                        da sein ..lösche mal die zeile... und starte adapter neu...
                                        kommt dann die error meldung ?? für den SNZB-06P
                                        • arteckA arteck
                                          readResponse
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          @arteck Immer noch
                                          2024-01-03 11:20:37.439	error	arteck: '64529' -> 'readResponse'
                                          2024-01-03 11:20:37.439	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                          2024-01-03 11:20:37.276	info	Configuring 0x3410f4fffee39865 SNZB-06P
                                          2024-01-03 11:20:35.704	error	arteck: '64529' -> 'readResponse'
                                          2024-01-03 11:20:35.703	error	Error while processing converters DEVICE_ID: '3410f4fffee39865'
                                          2024-01-03 11:20:35.299	info	debug devices set to []
