  4. Error Node-Red
Error Node-Red
23 Beiträge 4 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • AphofisA Aphofis
    So Betriebssystem neu Bullseye in 64 bit iobroker neu installiert wie siehts denn jetzt aus !?
    ======== Start marking the full check here =========
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: GordonX-Home
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     11:44:25 up 18:55,  2 users,  load average: 5.02, 3.60, 3.22
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** Time and Time Zones ***
                   Local time: Sun 2023-12-10 11:44:26 CET
               Universal time: Sun 2023-12-10 10:44:26 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.7G        1.9G        768M        1.0M        1.1G        1.8G
    Swap:            99M          0B         99M
    Total:          3.8G        1.9G        868M
             3744 M total memory
             1874 M used memory
             2012 M active memory
              727 M inactive memory
              768 M free memory
              111 M buffer memory
              990 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       29G   12G   16G  42% /
    devtmpfs       devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     749M  1.1M  748M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs     375M   20K  375M   1% /run/user/1000
    Show mounted filesystems \(real ones only\):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,errors=remount-ro
    /var:
    593M    /var/
    202M    /var/log
    164M    /var/lib
    125M    /var/cache
    115M    /var/cache/apt
    Archived and active journals take up 96.0M in the file system.
    /opt/iobroker/backups:
    11M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    480M    /opt/iobroker/iobroker-data/
    414M    /opt/iobroker/iobroker-data/files
    131M    /opt/iobroker/iobroker-data/files/vis-2
    76M     /opt/iobroker/iobroker-data/files/vis-2/static
    75M     /opt/iobroker/iobroker-data/files/vis-2/static/js
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
    21M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.6c01        4a31.js.map
    18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.3d92bcec.js.map
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
            100 /var/lib/dpkg/status
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : GordonX-Home        -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as        : admin
    + system.adapter.alarm.0                  : alarm                 : GordonX-Home        -  enabled
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : GordonX-Home        -  enabled
    + system.adapter.alexa2.0                 : alexa2                : GordonX-Home        -  enabled
    + system.adapter.backitup.0               : backitup              : GordonX-Home        -  enabled
      system.adapter.daswetter.0              : daswetter             : GordonX-Home        -  enabled
    + system.adapter.discovery.0              : discovery             : GordonX-Home        -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : GordonX-Home        -  enabled
      system.adapter.flot.0                   : flot                  : GordonX-Home        -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : GordonX-Home        -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : GordonX-Home        -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : GordonX-Home        -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : GordonX-Home        - disabled
    + system.adapter.harmony.0                : harmony               : GordonX-Home        -  enabled
      system.adapter.hass.0                   : hass                  : GordonX-Home        - disabled, port: 8123
    + system.adapter.history.0                : history               : GordonX-Home        -  enabled
    + system.adapter.hue.0                    : hue                   : GordonX-Home        -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : GordonX-Home        -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: Gor        donX-Home                             -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : GordonX-Home        -  enabled
      system.adapter.influxdb.0               : influxdb              : GordonX-Home        - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : GordonX-Home        -  enabled
    + system.adapter.javascript.0             : javascript            : GordonX-Home        -  enabled
    + system.adapter.node-red.0               : node-red              : GordonX-Home        -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : GordonX-Home        - disabled
      system.adapter.owfs.0                   : owfs                  : GordonX-Home        - disabled, port: 4304
    + system.adapter.roborock.0               : roborock              : GordonX-Home        -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : GordonX-Home        -  enabled
    + system.adapter.smartthings.0            : smartthings           : GordonX-Home        -  enabled
    + system.adapter.sql.0                    : sql                   : GordonX-Home        -  enabled, port: 3307
    + system.adapter.synology.0               : synology              : GordonX-Home        -  enabled, port: 5001
    + system.adapter.telegram-menu.0          : telegram-menu         : GordonX-Home        -  enabled
    + system.adapter.telegram.0               : telegram              : GordonX-Home        -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : GordonX-Home        -  enabled
    + system.adapter.tr-064.0                 : tr-064                : GordonX-Home        -  enabled
    + system.adapter.tuya.0                   : tuya                  : GordonX-Home        -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : GordonX-Home        -  enabled
      system.adapter.vis-bars.0               : vis-bars              : GordonX-Home        -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : GordonX-Home        -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : GordonX-Home        -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : GordonX-Home        -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : GordonX-Home        -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : GordonX-Home        -  enabled
      system.adapter.vis.0                    : vis                   : GordonX-Home        - disabled
    + system.adapter.web.0                    : web                   : GordonX-Home        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
    + instance is alive
    + system.adapter.admin.0                  : admin                 : GordonX-Home                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.0                    : web                   : GordonX-Home                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alarm"        : 3.4.3    , installed 3.4.3
    Adapter    "alexa-timer-vis": 0.2.0  , installed 0.2.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "daswetter"    : 3.1.11   , installed 3.1.10 [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fritzdect"    : 2.5.9    , installed 2.3.1  [Updatable]
    Adapter    "fullcalendar" : 2.2.6    , installed 2.2.6
    Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "roborock"     : 0.4.4    , installed 0.4.4
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sql"          : 2.2.0    , installed 2.2.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 3.0.0    , installed 3.0.0
    Adapter    "telegram-menu": 0.8.5    , installed 0.8.5
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.98.0   , installed 0.98.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        15236
    States:         11961
    W: GPG error: https://repos.influxdata.com/ubuntu bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    E: The repository 'https://repos.influxdata.com/ubuntu bullseye InRelease' is not signed.
    Pending Updates: 1
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      118        163682     8961/influxd
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       24810      1640/node-red
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16623      559/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18433      559/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15629      592/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          995325     26097/cupsd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          995324     26097/cupsd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       278145     15570/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23200      1123/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      118        161441     8961/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14142      592/sshd: /usr/sbin
    tcp6       0      0 :::4369                 :::*                    LISTEN      0          13802      1/init
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       22479      1894/io.harmony.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       27656      1579/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       27657      1579/io.tuya.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       22480      1894/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          998442     26103/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        115551     6077/avahi-daemon:
    udp        0      0 0.0.0.0:48483           0.0.0.0:*                           108        115553     6077/avahi-daemon:
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15683      483/dhcpcd
    udp6       0      0 :::546                  :::*                                0          14328      483/dhcpcd
    udp6       0      0 :::33783                :::*                                108        115554     6077/avahi-daemon:
    udp6       0      0 :::5353                 :::*                                108        115552     6077/avahi-daemon:
    2023-12-10 11:48:18.453  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpBlue.png": Error: Not exists
    2023-12-10 11:48:18.680  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorz.png": Error: Not exists
    2023-12-10 11:48:18.776  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorzDockClosed.png": Error: Not exists
    2023-12-10 11:48:19.281  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsHorzDockOpen.png": Error: Not exists
    2023-12-10 11:48:19.744  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpPicsVert.png": Error: Not exists
    2023-12-10 11:48:19.977  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpRed.png": Error: Not exists
    2023-12-10 11:48:20.360  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTextHorz.png": Error: Not exists
    2023-12-10 11:48:20.789  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTextVert.png": Error: Not exists
    2023-12-10 11:48:21.010  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/help/helpTransp.png": Error: Not exists
    2023-12-10 11:48:21.537  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-bottom.png": Error: Not exists
    2023-12-10 11:48:21.780  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-left.png": Error: Not exists
    2023-12-10 11:48:21.969  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-right.png": Error: Not exists
    2023-12-10 11:48:21.992  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/img/inject-top.png": Error: Not exists
    2023-12-10 11:48:22.066  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/js/bars.js": Error: Not exists
    2023-12-10 11:48:22.087  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars/js/jquery.sidebar.js": Error: Not exists
    2023-12-10 11:48:22.145  - error: vis-2.0 (12624) Cannot delete file "/widgets/bars.html": Error: Not exists
    2023-12-10 11:48:22.187  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/css/table.css": Error: Not exists
    2023-12-10 11:48:22.201  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/doc.html": Error: Not exists
    2023-12-10 11:48:22.475  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_AckBool.png": Error: Not exists
    2023-12-10 11:48:22.524  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_BasicState.png": Error: Not exists
    2023-12-10 11:48:22.775  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_BulbOnOffCtrl.png": Error: Not exists
    2023-12-10 11:48:23.063  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_ContainerView.png": Error: Not exists
    2023-12-10 11:48:23.385  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_FilterDropdown.png": Error: Not exists
    2023-12-10 11:48:23.834  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_FullScreen.png": Error: Not exists
    2023-12-10 11:48:24.156  - error: vis-2.0 (12624) Cannot delete file "/widgets/basic/img/Prev_HTML.png": Error: Not exists
    oder sollte ich doch ein neues Netzteil kaufen !? Das jetzige ist extra für den Pi4 gekauft und hat 3A aber vllt hat es auch in der Technik gelitten als es im Unterschrank vom Meerwasser Aquarium gesteckt hatte. Es war zwar die Technik abgeschirmt mit einer Acryl Platte aber die Meer Luft ist ja trotzdem im Raum die sogar dazu geführt hatte das ich die Pi Lüfter regelmäßig jedes Jahr tauschen musste da diese durch Slaz Luft verklebt waren.
    @aphofis
    zu hoch für 4 Kerne.
    X-Server:       true
    Graphisches Gedönse ausschalten...
    Ich dachte du hättest die Kiste neuaufgesetzt... Warum dann nicht gleich gescheit?
    • AphofisA Offline
      AphofisA Offline
      Aphofis
      Hab ich doch!
      Nur wenn ein Touchscreen Display dran kommt brauche ich doch grafische unterstützung
      • AphofisA Aphofis
        Hab ich doch!
        @aphofis sagte in Error Node-Red:
        Das stimmt. Der Rest ist aber dann immer noch schief.
        Das influx-Repo ist auch nicht richtig angelegt.
