  4. BLE funktioniert nicht
ble adapter
35 Beiträge 4 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • T Tenor 0
    Danke Trotzdem!
    Ich denke dann muss ich es mit einem anderen Adapter probieren.
    Hast du eine Idee welcher gut funktioniert?
    @tenor-0
    Schau mal in das Log, wenn der ble-Adapter neugestartet wird.
    Bei mir spuckt das Ding sowas aus:
    2023-10-23 21:51:57.006  - error: ble.0 (55088) Cannot find module '../build/Release/bluetooth_hci_socket.node'
    Require stack:
    - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js
    - /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/index.js
    - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
    - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
    - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
    - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
    - /opt/iobroker/node_modules/@abandonware/noble/index.js
    - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
    Edit: Neuinstallation des ble-Adapters und das Ding lüppt wieder.
      @tenor-0
      Require stack:
      Tenor 0
      2023-10-23 20:24:31.603  - info: admin.0 (1277) ==> Connected system.user.admin from ::ffff:192.168.178.70
      2023-10-23 20:24:41.810  - info: host.server "system.adapter.ble.0" disabled
      2023-10-23 20:24:41.811  - info: host.server stopInstance system.adapter.ble.0 (force=false, process=true)
      2023-10-23 20:24:41.814  - info: ble.0 (421939) Got terminate signal TERMINATE_YOURSELF
      2023-10-23 20:24:41.856  - info: host.server stopInstance system.adapter.ble.0 send kill signal
      2023-10-23 20:24:41.860  - info: ble.0 (421939) terminating
      2023-10-23 20:24:41.862  - info: ble.0 (421939) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-23 20:24:42.364  - info: ble.0 (421939) terminating
      2023-10-23 20:24:42.431  - info: host.server instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-23 20:24:45.231  - info: host.server "system.adapter.ble.0" enabled
      2023-10-23 20:24:45.268  - info: host.server instance system.adapter.ble.0 started with pid 2462829
      2023-10-23 20:24:45.735  - info: ble.0 (2462829) starting. Version 0.13.4 in /opt/iobroker/node_modules/iobroker.ble, node: v18.18.2, js-controller: 5.0.12
      2023-10-23 20:24:45.792  - info: ble.0 (2462829) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      2023-10-23 20:24:45.793  - info: ble.0 (2462829) enabled plugins: Xiaomi, _default
      2023-10-23 20:24:45.793  - info: ble.0 (2462829) monitoring all services
      2023-10-23 20:24:45.842  - info: ble.0 (2462829) starting scanner process...
      2023-10-23 20:24:46.081  - info: ble.0 (2462829) starting scan for services []
      Für mich sieht alles gut aus...
      Ich habe mir einfach mal einen neuen Stick bestellt und werde testen.
      Thomas BraunT haselchenH 2 Antworten Letzte Antwort
      • T Tenor 0
        @tenor-0
        Ist überhaupt irgendwas in der Nähe, was gescannt werden könnte?
        Für mich schaut das nämlich eigentlich gut aus.
        • T Tenor 0
          haselchenH Offline
          haselchenH Offline
          haselchen
          @tenor-0
          Kann mich da @Thomas-Braun nur anschliessen.
          Bisher ist alles okay lt. Log.
          Kommt auf die Reichweite Deines Gerätes an und die Adapter Einstellungen.
          Die haste glaube ich noch nicht gezeigt.
          Hol das mal bitte nach.
          • haselchenH haselchen
            @tenor-0
            Tenor 0
            @haselchen
            Der steht 2 meter neben dem Raspi 4.
            Habe eben mein Handy auf Bluetooth Empfang gestellt, aber es kommt nichts.
            Der Raspi hat Seitenweise Einträge..
            Es stehen in 1m Entfernung auch ein Xiaomi Temp Sensor der permanent Daten liefert.
            Der ist ja nicht gepaired mit dem alten Raspi.
            • T Tenor 0
              @haselchen
              haselchenH Offline
              haselchenH Offline
              haselchen
              @tenor-0
              Spasseshalber den Haken bei "Neue Geräte ....." setzen?!
                @tenor-0
                Tenor 0
                @haselchen
                Habe ich natürlich schon gemacht ;)
                Deswegen hatte ich auch den Screenshot in meinem ersten Post gewählt, da sieht man das der auf True steht.
                Habe gerade noch einen Fabrikneuen Xiaomi Sensor aus der Verpackung geholt und direkt neben den Server gestellt.
                Es passiert einfach nichts...
                • T Tenor 0
                  @haselchen
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @tenor-0
                  Ja, BLE ist schon speziell.
                  Gibt noch den Radar2 Adapter.
                  Den würde ich an erster Stelle ausprobieren.
                  Und dann kannste auch noch per ESPHome BLE Geräte auslesen.
                  Das hatte ich mal gemacht, weil Raspi Bluetooth und ESPHome sich in die Quere kamen.
                  Da hatte ich dann nur ESPHome benutzt.
                  https://esphome.io/components/esp32_ble_tracker.html
                  Jetzt bin ich auf Radar2 weil das stabiler läuft und 100% bei mir funktioniert.
                  Reichweite zum Gerät knapp 10m (Gigaset Beacon).
                    @tenor-0
                    Tenor 0
                    @haselchen
                    habe den eben gerade installiert, aber der hängt sofort im Restart loop
                    radar initialization finished with error TypeError: Cannot read properties of null (reading 'push')at main (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:782:21)at async IobAdapter.onReady (/opt/iobroker/node_modules/iobroker.radar2/fjadapter-core.js:212:3), will stop adapter!
                    Aber da mache ich erst morgen Abend weiter!
                    Danke dir!
                    • T Tenor 0
                      hm,
                      Wi-Fi-6E-Modul von Mediatek laut Notebookcheck
                      HomoranH Offline
                      HomoranH Offline
                      @tenor-0 sagte in BLE funktioniert nicht:
                      hm,
                      und das kann BLE?
                      hast du alle notwendigen Hilfsprogramme installiert?
                        Tenor 0
                        @homoran said in BLE funktioniert nicht:
                        Wi-Fi-6
                        Nachdem alles grün ist, vermutlich nicht.
                        Da es aber ein neuerer Chip zu seien scheint, habe ich es wohl nur angenommen.
                        Morgen kommt ein neuer Adapter, mal sehen.
                        Bis dahin probiere ich noch ein bißchen mit dem Radar2 Adapter.
                        • T Tenor 0
                          Wi-Fi-6
                          Tenor 0
                          Der neue Adapter lief direkt nachdem ich den alten deaktiviert habe.
                          Somit hat der alte onboard vermutlich ein Macke.
                          Ich habe mit mit hciconfig hci0 down deaktiviert.
                          Das Problem ist aber das der nicht reboot sicher unten bleibt.
                          Wie kann ich den dauerhaft deaktivieren?
                          • T Tenor 0
                            Mit rfkill sollte das gehen.
                              Tenor 0
                              Danke das hat funktioniert!
                              matthias@server:~$ rfkill list
                              0: hci0: Bluetooth
                                      Soft blocked: yes
                                      Hard blocked: no
                              1: hci1: Bluetooth
                                      Soft blocked: no
                                      Hard blocked: no
                              2: phy0: Wireless LAN
                                      Soft blocked: no
                                      Hard blocked: no
                              matthias@server:~$ hciconfig -a
                              hci1:   Type: Primary  Bus: USB
                                      BD Address: 8C:88:4B:05:62:63  ACL MTU: 1021:6  SCO MTU: 255:12
                                      UP RUNNING
                                      RX bytes:2370 acl:0 sco:0 events:221 errors:0
                                      TX bytes:33606 acl:0 sco:0 commands:223 errors:0
                                      Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
                                      Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
                                      Link policy: RSWITCH HOLD SNIFF PARK
                                      Link mode: PERIPHERAL ACCEPT
                                      Class: 0x000000
                                      Service Classes: Unspecified
                                      Device Class: Miscellaneous,
                                      HCI Version: 5.1 (0xa)  Revision: 0xdfc6
                                      LMP Version: 5.1 (0xa)  Subversion: 0xd922
                                      Manufacturer: Realtek Semiconductor Corporation (93)
                              hci0:   Type: Primary  Bus: USB
                                      BD Address: 38:D5:7A:22:B7:20  ACL MTU: 1021:6  SCO MTU: 240:8
                                      DOWN
                                      RX bytes:771 acl:0 sco:0 events:51 errors:0
                                      TX bytes:580 acl:0 sco:0 commands:51 errors:0
                                      Features: 0xbf 0x3e 0x8d 0xfe 0xdb 0xff 0x7b 0x87
                                      Link policy: RSWITCH SNIFF
                              Leider funktioniert der Adapter nur wenn ich hci1 separat down und wieder ab nehme..
                              Wie bekomme ich das automatisiert hin?
                              • T Tenor 0
                                0: hci0: Bluetooth
                                        Soft blocked: yes
                                        Hard blocked: no
                                1: hci1: Bluetooth
                                        Soft blocked: no
                                        Hard blocked: no
                                        Soft blocked: no
                                        Hard blocked: no
                                        UP RUNNING
                                        Class: 0x000000
                                        DOWN
                                Tenor 0
                                Ich habe ne gute Anleitung gefunden um hci0 komplett zu deaktivieren. link text
                                Leider hilft das bei dem Adapter auch nicht weiter. Nach dem Reboot muss ich den stick down und wieder up nehmen... Ist schon nervig
