  4. Umzug von Raspi auf Proxmox
124 Beiträge 14 Kommentatoren 25.8k Aufrufe 10 Beobachtet
    @guitardoc sagte in Umzug von Raspi auf Proxmox:
    Hab ich noch was vergessen oder woran kann das liegen?
    Moin,
    nicht nacherzählen, zeigen, was Du siehst, Logs bitte als Text in Code Tags </>
    VG
    Bernd
    guitardoc
    schrieb am zuletzt editiert von guitardoc
    #41
    @dp20eic So siehts im Moment aus:
    root@deconz:~# ls -l /dev/ttyACM0
    crw-rw-rw- 1 root root 166, 0 Oct 22 11:17 /dev/ttyACM0
    root@deconz:~# lsusb
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 002: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
    Bus 001 Device 003: ID 8087:0026 Intel Corp. AX201 Bluetooth
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    total 0
    crwx------ 1 root tty  136, 0 Oct 22 11:24 console
    lrwxrwxrwx 1 root root     11 Oct 22 11:24 core -> /proc/kcore
    lrwxrwxrwx 1 root root     13 Oct 22 11:24 fd -> /proc/self/fd
    crw-rw-rw- 1 root root   1, 7 Oct 22 11:24 full
    drwxr-xr-x 2 root root      0 Oct 22 11:24 hugepages
    lrwxrwxrwx 1 root root     12 Oct 22 11:24 initctl -> /run/initctl
    lrwxrwxrwx 1 root root     28 Oct 22 11:24 log -> /run/systemd/journal/dev-log
    drwxrwxrwt 2 root root     40 Oct 22 11:24 mqueue
    crw-rw-rw- 1 root root   1, 3 Oct 22 11:24 null
    crw-rw-rw- 1 root root   5, 2 Oct 22  2023 ptmx
    drwxr-xr-x 2 root root      0 Oct 22 11:24 pts
    crw-rw-rw- 1 root root   1, 8 Oct 22 11:24 random
    drwxr-xr-x 3 root root     60 Oct 22 11:24 serial
    drwxrwxrwt 2 root root     40 Oct 22 11:24 shm
    lrwxrwxrwx 1 root root     15 Oct 22 11:24 stderr -> /proc/self/fd/2
    lrwxrwxrwx 1 root root     15 Oct 22 11:24 stdin -> /proc/self/fd/0
    lrwxrwxrwx 1 root root     15 Oct 22 11:24 stdout -> /proc/self/fd/1
    crw-rw-rw- 1 root root   5, 0 Oct 22 11:24 tty
    crw------- 1 root tty  136, 1 Oct 22  2023 tty1
    crw--w---- 1 root tty  136, 2 Oct 22 11:24 tty2
    crw-rw-rw- 1 root root 166, 0 Oct 22 11:17 ttyACM0
    ---------- 1 root root      0 Oct 22 11:24 ttyACM1
    ---------- 1 root root      0 Oct 22 11:24 ttyUSB0
    ---------- 1 root root      0 Oct 22 11:24 ttyUSB1
    crw-rw-rw- 1 root root   1, 9 Oct 22 11:24 urandom
    crw-rw-rw- 1 root root   1, 5 Oct 22 11:24 zero
    root@deconz:~#
    Der Conbee II hatte auch immer die Berechtigung verloren, von daher hab ich ihn nach Anleitung mit mknod dauerhaft angebunden.
    Edith sagt:
    Der Zwischenstecker wird aber nicht gefunden - er ist zurückgesetzt und blinkt:
    Edith nochmal - der Stick scheint auch nicht verbunden zu sein - normalerweise zeigt er auch das Bild eines USB-Sticks und nicht dieses seltsame Bild:
    ? 1 Antwort Letzte Antwort
    • G guitardoc
      total 0
      root@deconz:~#
      Edith sagt:
      #42
      Moin,
      alles was ich bis jetzt über Deconz gelesen habe, oder hier im Forum, geschrieben wurde, muss der User und die Gruppe anders lauten als bei Dir
      Du
      Laut Doku
      crw-rw-rw- 1 root dialout 166, 0 Oct 22 11:17 /dev/ttyACM0
      Ich muss mal suchen, wo ich das gesehen habe.
      VG
      Bernd
      P.S.: Der User, der das später nutzt, muss in der Gruppe -> Dialout sein!
      P.P.S.: @guitardoc sagte in Umzug von Raspi auf Proxmox:
      Nach welcher?
      G 1 Antwort Letzte Antwort
        Moin,
        Du
        Laut Doku
        VG
        Bernd
        Nach welcher?
        guitardoc
        #43
        @dp20eic Nach dieser hier:
        https://www.iobroker.net/#de/documentation/install/proxmox.md
        Aber da steht tatsächlich auch als Gruppe dialout. Hmm, warum steht da bei mir root? Möglicherweise, weil ich als root angemeldet war und nicht als Benutzer? Wie kann ich das jetzt wieder gerade biegen?
        Thomas BraunT ? T 4 Antworten Letzte Antwort
        • G guitardoc
          #44
          Jein. Aber das herumgehampel als root macht es nicht leichter...
          Das einzige was da leichter geht ist es, sein System zu verfummeln. Das geht nämlich als root superleicht.
          • G guitardoc
            #45
            Nach dieser hier:
            Moin,
            es ist ja schon mal sehr gut, dass Du diese Installationsanleitung hergenommen hast und jetzt aber, das aber, das ist die Installationsanleitung für den ioBroker Du möchtest aber ein LX Container mit Deconz installieren, da sollte man sich an die Eigenheiten des Grundsystems richten.
            Ich schaue aber noch, ob ich die Anleitung wiederfinde.
            VG
            Bernd
            • G guitardoc
              T Nicht stören
              T Nicht stören
              ticaki
              #46
              sudo chown root:dialout /dev/ttyACM0
              wenn mich nicht alles täuscht
              Spenden
              ? Thomas BraunT 2 Antworten Letzte Antwort
              • T ticaki
                #47
                @ticaki sagte in Umzug von Raspi auf Proxmox:
                Moin,
                ja, dann muss er das aber immer machen, sobald er den LX Container rebootet, wenn er das auf PVE Ebene macht, ist das auch nicht von Dauer.
                VG
                Bernd
                • T ticaki
                  #48
                  @ticaki
                  Die Dateien in /dev werden vom System verwaltet, ggfls. über udev-Regeln.
                  Da macht man als user nix direkt.
                  Ob/wie das bei Proxmox funktioniert weiß ich aber nicht. Müsste ich auch nachlesen. Aber das macht ja @dp20eic schon...
                    @ticaki
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    #49
                    @dp20eic
                    Danke für die Korrektur/Info
                    Spenden
                    • T ticaki
                      @dp20eic
                      guitardoc
                      #50
                      Ich habe den Container jetzt fix noch mal erstellt. Hab ja nun schon Übung darin... :-)
                      In der Deconz-Anleitung (https://tteck.github.io/Proxmox/) steht:
                      If the LXC is created Privileged, the script will automatically set up USB passthrough.
                      Weiter hab ich jetzt erst mal nichts installiert oder angepasst, auch aus der ioBroker Anleitung nicht. Es werden trotzdem keine Geräte gefunden.
                      Edith sagt dass er auch irgendwas anpasst:
                        GNU nano 7.2                                     103.conf
                      ## deCONZ LXC
                      #  ### https%3A//tteck.github.io/Proxmox/
                      #  <a href='https%3A//ko-fi.com/D1D7EP4GF'><img src='https%3A//img.shields.io/badge/%E2%98%95-Buy me a c>
                      arch: amd64
                      cores: 2
                      features: nesting=1
                      hostname: deconz
                      memory: 1024
                      net0: name=eth0,bridge=vmbr0,gw=192.168.188.1,hwaddr=56:3E:A8:E2:ED:F3,ip=192.168.188.122/24,type=veth
                      onboot: 1
                      ostype: debian
                      rootfs: local-lvm:vm-103-disk-0,size=4G
                      swap: 512
                      tags: proxmox-helper-scripts
                      lxc.cgroup2.devices.allow: a
                      lxc.cap.drop:
                      lxc.cgroup2.devices.allow: c 188:* rwm
                      lxc.cgroup2.devices.allow: c 189:* rwm
                      lxc.mount.entry: /dev/serial/by-id  dev/serial/by-id  none bind,optional,create=dir
                      lxc.mount.entry: /dev/ttyUSB0       dev/ttyUSB0       none bind,optional,create=file
                      lxc.mount.entry: /dev/ttyUSB1       dev/ttyUSB1       none bind,optional,create=file
                      lxc.mount.entry: /dev/ttyACM0       dev/ttyACM0       none bind,optional,create=file
                      lxc.mount.entry: /dev/ttyACM1       dev/ttyACM1       none bind,optional,create=file
                      • G guitardoc
                        #51
                        Moin,
                        dass Du den LX Container mit diesem Helfer Skript installiert hast, wäre auch gut zu wissen, bevor ich wieder mal angefangen habe eine Anleitung zu schreiben :(
                        VG
                        Bernd
                        P.S.: ich spiele das mal nach, um zu schauen was das Skript da so macht.
                          Moin,
                          VG
                          Bernd
                          guitardoc
                          #52
                          @dp20eic Das hatte ich doch aber geschrieben: https://forum.iobroker.net/post/1062710
                          Ich denke, dass die Rechte durch das Helperscript nicht richtig gesetzt sind:
                          mn@deconz:~$ lsusb
                          Bus 001 Device 005: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
                          mn@deconz:~$ ls -l /dev
                          total 0
                          crwx------ 1 root tty  136, 0 Oct 22 13:09 console
                          lrwxrwxrwx 1 root root     11 Oct 22 13:09 core -> /proc/kcore
                          lrwxrwxrwx 1 root root     13 Oct 22 13:09 fd -> /proc/self/fd
                          crw-rw-rw- 1 root root   1, 7 Oct 22 13:09 full
                          drwxr-xr-x 2 root root      0 Oct 22 13:09 hugepages
                          lrwxrwxrwx 1 root root     12 Oct 22 13:09 initctl -> /run/initctl
                          lrwxrwxrwx 1 root root     28 Oct 22 13:09 log -> /run/systemd/journal/dev-log
                          drwxrwxrwt 2 root root     40 Oct 22 13:09 mqueue
                          crw-rw-rw- 1 root root   1, 3 Oct 22 13:09 null
                          crw-rw-rw- 1 root root   5, 2 Oct 22 13:28 ptmx
                          drwxr-xr-x 2 root root      0 Oct 22 13:09 pts
                          crw-rw-rw- 1 root root   1, 8 Oct 22 13:09 random
                          drwxr-xr-x 3 root root     60 Oct 22 13:09 serial
                          drwxrwxrwt 2 root root     40 Oct 22 13:09 shm
                          lrwxrwxrwx 1 root root     15 Oct 22 13:09 stderr -> /proc/self/fd/2
                          lrwxrwxrwx 1 root root     15 Oct 22 13:09 stdin -> /proc/self/fd/0
                          lrwxrwxrwx 1 root root     15 Oct 22 13:09 stdout -> /proc/self/fd/1
                          crw-rw-rw- 1 root root   5, 0 Oct 22 13:09 tty
                          crw------- 1 root tty  136, 1 Oct 22 13:09 tty1
                          crw--w---- 1 root tty  136, 2 Oct 22 13:09 tty2
                          c--------- 0 root root 166, 0 Oct 22 13:09 ttyACM0
                          ---------- 1 root root      0 Oct 22 13:09 ttyACM1
                          ---------- 1 root root      0 Oct 22 13:09 ttyUSB0
                          ---------- 1 root root      0 Oct 22 13:09 ttyUSB1
                          crw-rw-rw- 1 root root   1, 9 Oct 22 13:09 urandom
                          crw-rw-rw- 1 root root   1, 5 Oct 22 13:09 zero
                          mn@deconz:~$ ls -l /dev/ttyACM0
                          c--------- 0 root root 166, 0 Oct 22 13:09 /dev/ttyACM0
                          mn@deconz:~$
                          • G guitardoc
                            mn@deconz:~$ lsusb
                            total 0
                            mn@deconz:~$
                            #53
                            Moin,
                            man, das war ja vor Tagen, das merke ich mir doch nicht :)
                            Abwarten, ich lasse das gerade mal laufen.
                            VG
                            Bernd
                            G ? 2 Antworten Letzte Antwort
                              Moin,
                              VG
                              Bernd
                              guitardoc
                              #54
                              @dp20eic OK, danke für deine Hilfe und Bemühung!
                              Ich habe gleich noch eine Frage - ich würde zwischenzeitlich gern die ioBroker-Sicherungen in das neue ioBroker-Verzeichnis kopieren um sie von dort über den Backitup-Adapter wieder einzulesen. Ich bin aber einfach zu dämlich von meinem Mac die Dateien in das Backup-Verzeichnis des LXC-Containers zu kopieren. Vermutlich ist das wieder eine Frage der Berechtigungen...
                                Moin,
                                VG
                                Bernd
                                #55
                                @dp20eic sagte in Umzug von Raspi auf Proxmox:
                                Moin,
                                zitiere mich mal selbst.
                                So wenn ich das mittels Advance Mode installiere und mit unpreviliged durchlaufen lasse, dann
                                root@deconz:~# ls -la /dev/ttyACM*
                                crw-rw-rw- 1 root dialout 166, 0 Oct 22 13:38 /dev/ttyACM0
                                crw-rw-rw- 1 root dialout 166, 1 Oct  7 12:55 /dev/ttyACM1
                                Auf die Oberfläche komme ich auch, da ich die Hardware nicht habe, kann ich da nichts weiter testen.
                                So und so sieht es aus, wenn ich mittel Priviliged installiere
                                crw-rw-rw- 1 root dialout 166, 0 Oct 22 13:53 /dev/ttyACM0
                                Bei mir wird es soweit identisch installiert, ob das dann auch funktioniert, kann ich mangels Hardware nicht testen.
                                Dann nochmals von vorn, wie sieht es auf dem Host (PVE) aus?
                                Schritt 1: das Device auf dem Host (PVE) identifizieren
                                root@pve:~# lsusb
                                Hier ist Bus u. Device relevant!
                                root@pve:~# ls -la /dev/bus/usb/<bus>/<device>
                                root@pve:~# ls -la /dev/serial/by-id/
                                root@pve:~# ls -la /dev/ttyACM*
                                VG
                                Bernd
                                  Moin,
                                  root@pve:~# lsusb
                                  VG
                                  Bernd
                                  guitardoc
                                  #56
                                  So sieht das bei mir auf dem Host aus:
                                  root@proxmox:~# lsusb
                                  Bus 001 Device 007: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
                                  root@proxmox:~# ls -la /dev/bus/usb/001/007
                                  crw-rw-r-- 1 root root 189, 6 Oct 22 14:12 /dev/bus/usb/001/007
                                  root@proxmox:~# ls -la /dev/serial/by-id/
                                  total 0
                                  drwxr-xr-x 2 root root 60 Oct 22 14:12 .
                                  drwxr-xr-x 4 root root 80 Oct 22 14:12 ..
                                  lrwxrwxrwx 1 root root 13 Oct 22 14:12 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 -> ../../ttyACM0
                                  root@proxmox:~# ls -la /dev/ttyACM*
                                  crw-rw---- 1 root dialout 166, 0 Oct 22 14:12 /dev/ttyACM0
                                  root@proxmox:~#
                                  • G guitardoc
                                    #57
                                    Moin,
                                    Du hast Dich mit Deinem User mn per sftp angemeldet?
                                    Ist der User auch in der Gruppe -> iobroker?
                                    # id mn
                                    Wie sehen die rechte des Verzeichnisses aus?
                                    # ls -la /opt/iobroker
                                    VG
                                    Bernd
                                      Moin,
                                      # id mn
                                      VG
                                      Bernd
                                      guitardoc
                                      #58
                                      Vermutlich passt das nicht:
                                      mn@iobroker:~$ id mn
                                      uid=1001(mn) gid=1001(mn) groups=1001(mn),27(sudo),100(users)
                                      mn@iobroker:~$ ls -la /opt/iobroker
                                      total 296
                                      drwxrwxr-x+   6 iobroker iobroker   4096 Oct 19 11:24 .
                                      drwxr-xr-x    3 root     root       4096 Oct 19 11:22 ..
                                      -rw-rwxr--+   1 iobroker iobroker    155 Oct 19 11:22 .npmrc
                                      -rwxrwxrwx+   1 iobroker iobroker    133 Oct 19 11:24 INSTALLER_INFO.txt
                                      drwxrwxr-x+   2 iobroker iobroker   4096 Oct 22 02:40 backups
                                      lrwxrwxrwx    1 iobroker iobroker     22 Oct 19 11:24 iob -> /opt/iobroker/iobroker
                                      -rwxrwxr-x+   1 iobroker iobroker    701 Oct 19 11:24 iobroker
                                      drwxrwxr-x+   7 iobroker iobroker   4096 Oct 22 13:09 iobroker-data
                                      drwxrwxr-x+   2 iobroker iobroker   4096 Oct 22 13:09 log
                                      drwxrwxr-x+ 469 iobroker iobroker  20480 Oct 20 14:06 node_modules
                                      -rw-rwxr--+   1 iobroker iobroker 245343 Oct 20 14:06 package-lock.json
                                      -rw-rwxr--+   1 iobroker iobroker    400 Oct 20 14:06 package.json
                                      mn@iobroker:~$
                                      Thomas BraunT ? 2 Antworten Letzte Antwort
                                      • G guitardoc
                                        total 296
                                        mn@iobroker:~$
                                        #59
                                        @guitardoc
                                        sudo usermod -a -G iobroker,dialout mn
                                        • G guitardoc
                                          total 0
                                          root@proxmox:~#
                                          #60
                                          Moin,
                                          ich bin mir nicht mehr sicher, ist schon ~ 2 Jahre her, aber die Rechte stimmen nicht und die kommen standardmäßig von der udev rule -> /usr/lib/udev/rules.d/50-udev-default.rules, an der kann/darf man nichts verändern, denn die würde bei einem Update wieder überschrieben, Du musst Dir eine eigene udev rule schreiben, ich habe mir das damals recht einfach gemacht, indem ich unter /etc/udev/rules.d/ meine eigene angelegt habe, die mit einer höheren Nummer als unter /usr/lib/udev/rules.d anfängt, mit dem Inhalt, auf dem Host(PVE) erstellen
                                          # nano /etc/udev/rules.d/65-add-myusb.rules
                                          KERNEL=="ttyUSB[0-9]*",MODE="0666"
                                          KERNEL=="ttyACM[0-9]*",MODE="0666"
                                          Damit werden die Rechte auf crw-rw-rw- geändert.
                                          Anschließend, muss udev neu eingelesen werden, das kannst Du mit einem kompletten Proxmox reboot machen, oder
                                          # udevadm control --reload-rules && udevadm trigger
                                          VG
                                          Bernd
