  3. Off Topic
  4. (erledigt) Zigbee Adapter startet nicht
    1.0k
    6.1k
18 Beiträge 4 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • H Online
    H Online
    hm_krause
    schrieb am zuletzt editiert von hm_krause
    Ich will auf einem Raspi 2 (als Slave) nur den Zigbee Adapter laufen lassen. Leider startet dieser nicht.
    pi@raspberrypi2:~ $ ls -l /dev/serial/by-id
    total 0
    lrwxrwxrwx 1 root root 13 Oct 12 17:17 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 -> ../../ttyACM0
    Einstellung:
    Log:
    host.raspberrypi2
    	2023-10-12 18:06:52.252	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    zigbee.0
    	2023-10-12 18:06:51.176	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.173	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:51.171	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.168	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-10-12 18:06:51.157	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.153	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:51.137	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi2
    	2023-10-12 18:06:33.582	info	instance system.adapter.zigbee.0 started with pid 811
    host.raspberrypi2
    	2023-10-12 18:06:02.935	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi2
    	2023-10-12 18:06:02.932	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    zigbee.0
    	2023-10-12 18:06:01.934	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.932	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:01.928	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.925	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-10-12 18:06:01.913	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.908	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:01.889	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.879	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Was ist hier falsch, welche Infos werden noch benötigt?
    Thomas BraunT ? 2 Antworten Letzte Antwort
    • H hm_krause
      total 0
      Einstellung:
      Log:
      host.raspberrypi2
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      host.raspberrypi2
      host.raspberrypi2
      host.raspberrypi2
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @hm_krause sagte in Zigbee Adapter startet nicht:
      Zeig uns mal einen kompletten Start des Adapters. Bevorzugt via
      iob logs --watch | uniq
      H 1 Antwort Letzte Antwort
        H Online
        H Online
        hm_krause
        2023-10-12 19:04:11.759  - info: host.raspberrypi2 "system.adapter.zigbee.0" enabled
        2023-10-12 19:04:12.349  - info: host.raspberrypi2 instance system.adapter.zigbee.0 started with pid 968
        2023-10-12 19:04:29.686  - error: zigbee.0 (968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2023-10-12 19:04:29.693  - error: zigbee.0 (968) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        2023-10-12 19:04:29.710  - error: zigbee.0 (968) TypeError: Cannot read properties of undefined (reading 'getDevice')
        2023-10-12 19:04:29.714  - error: zigbee.0 (968) Cannot read properties of undefined (reading 'getDevice')
        2023-10-12 19:04:33.394  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-10-12 19:04:33.397  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
        ^C
        ...hoffe das reicht.🙄
        • H hm_krause
          ^C
          @hm_krause
          Ein richtiger Start schaut so aus:
          2023-10-12 19:22:32.152  - info: zigbee.0 (68120) Got terminate signal TERMINATE_YOURSELF
          2023-10-12 19:22:32.154  - info: zigbee.0 (68120) cleaned everything up...
          2023-10-12 19:22:32.157  - info: zigbee.0 (68120) Zigbee: disabling joining new devices.
          2023-10-12 19:22:32.655  - info: zigbee.0 (68120) terminating
          2023-10-12 19:22:32.664  - info: zigbee.0 (68120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-12 19:23:07.364  - info: zigbee.0 (68952) starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.8.0, js-controller: 5.0.13
          2023-10-12 19:23:07.532  - info: zigbee.0 (68952) delete old Backup files. keep only last 10
          2023-10-12 19:23:07.535  - info: zigbee.0 (68952) Starting Zigbee  npm ...
          2023-10-12 19:23:07.969  - info: zigbee.0 (68952) Installed Version: iobroker.zigbee@1.8.24
          2023-10-12 19:23:19.816  - info: zigbee.0 (68952) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
          2023-10-12 19:23:19.828  - info: zigbee.0 (68952) Unable to disable LED, unsupported function.
          2023-10-12 19:23:19.847  - info: zigbee.0 (68952)   --> transmitPower : normal
          Die Instanz ausschalten und nach einiger Zeit frisch starten.
            @hm_krause
            H Online
            H Online
            hm_krause
            @thomas-braun sagte in Zigbee Adapter startet nicht:
            Das hilft aber nicht...
            host.raspberrypi2
            	2023-10-12 19:32:24.742	info	"system.adapter.zigbee.0" disabled
            host.raspberrypi2
            	2023-10-12 19:32:03.015	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.raspberrypi2
            	2023-10-12 19:32:03.012	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            zigbee.0
            	2023-10-12 19:32:01.525	error	Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 19:32:01.523	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
            zigbee.0
            	2023-10-12 19:32:01.520	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 19:32:01.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0
            	2023-10-12 19:32:00.965	error	Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 19:32:00.960	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
            zigbee.0
            	2023-10-12 19:32:00.943	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 19:32:00.936	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            host.raspberrypi2
            	2023-10-12 19:31:43.336	info	instance system.adapter.zigbee.0 started with pid 1109
            host.raspberrypi2
            	2023-10-12 19:31:42.910	info	"system.adapter.zigbee.0" enabled
            • H hm_krause
              host.raspberrypi2
              host.raspberrypi2
              host.raspberrypi2
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              host.raspberrypi2
              host.raspberrypi2
              arteckA Offline
              arteckA Offline
              arteck
              @hm_krause installier mal von GIT
              https://github.com/ioBroker/ioBroker.zigbee
              der sollte jetzt an der stelle ne Fehlermeldung liefern
              • arteckA arteck
                H Online
                H Online
                hm_krause
                @arteck
                Bringt folgendes:
                zigbee.0
                	2023-10-13 13:27:58.858	error	adapter disabled
                host.raspberrypi2
                	2023-10-13 13:27:20.259	info	"system.adapter.zigbee.0" disabled
                host.raspberrypi2
                	2023-10-13 13:27:14.281	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.raspberrypi2
                	2023-10-13 13:27:14.278	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                zigbee.0
                	2023-10-13 13:27:12.854	error	Cannot read properties of undefined (reading 'getDevice')
                zigbee.0
                	2023-10-13 13:27:12.851	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                zigbee.0
                	2023-10-13 13:27:12.849	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                zigbee.0
                	2023-10-13 13:27:12.846	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                	2023-10-13 13:27:12.836	error	Cannot read properties of undefined (reading 'getDevice')
                zigbee.0
                	2023-10-13 13:27:12.833	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                zigbee.0
                	2023-10-13 13:27:12.816	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                zigbee.0
                	2023-10-13 13:27:12.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                host.raspberrypi2
                	2023-10-13 13:26:54.200	info	instance system.adapter.zigbee.0 started with pid 3125
                host.raspberrypi2
                	2023-10-13 13:26:23.752	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.raspberrypi2
                	2023-10-13 13:26:23.749	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                zigbee.0
                	2023-10-13 13:26:22.299	error	this.zbController.getGroup is not a function
                zigbee.0
                	2023-10-13 13:26:22.297	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                zigbee.0
                	2023-10-13 13:26:22.279	error	unhandled promise rejection: this.zbController.getGroup is not a function
                zigbee.0
                	2023-10-13 13:26:22.273	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                host.raspberrypi2
                	2023-10-13 13:26:02.219	info	instance system.adapter.zigbee.0 started with pid 3106
                host.raspberrypi2
                	2023-10-13 13:26:01.709	info	"system.adapter.zigbee.0" enabled
                • H hm_krause
                  total 0
                  Einstellung:
                  Log:
                  host.raspberrypi2
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  host.raspberrypi2
                  host.raspberrypi2
                  host.raspberrypi2
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  Moin,
                  zeig doch mal den langen Output von
                  # iob diag
                  Vielleicht ist ja was an der Grundinstallation krum!
                  VG
                  Bernd
                    Moin,
                    # iob diag
                    VG
                    Bernd
                    H Online
                    H Online
                    hm_krause
                    @dp20eic
                    Bitte schön
                    ======== Start marking the full check here =========
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: raspberrypi2
                             Icon name: computer
                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v7+
                          Architecture: arm
                    Model           : Raspberry Pi 2 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : armhf
                    Systemuptime and Load:
                     17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Fri 2023-10-13 17:45:09 CEST
                               Universal time: Fri 2023-10-13 15:45:09 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            921M        236M        409M        0.0K        276M        628M
                    Swap:            99M          0B         99M
                    Total:          1.0G        236M        509M
                              921 M total memory
                              236 M used memory
                              174 M active memory
                              276 M inactive memory
                              409 M free memory
                               54 M buffer memory
                              221 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    lifetime oom required: 0 Mbytes
                    total time in oom handler: 0 ms
                    max time spent in oom handler: 0 ms
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4       15G  3.4G   11G  25% /
                    devtmpfs       devtmpfs  333M     0  333M   0% /dev
                    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                    tmpfs          tmpfs     185M  948K  184M   1% /run
                    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                    [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                    [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                    [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
                    [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    Show mounted filesystems \(real ones only\):
                    TARGET  SOURCE         FSTYPE OPTIONS
                    /       /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    894M    /var/
                    574M    /var/log
                    417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
                    120M    /var/cache
                    Archived and active journals take up 416.0M in the file system.
                    /opt/iobroker/backups:
                    2.4M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    103M    /opt/iobroker/iobroker-data/
                    74M     /opt/iobroker/iobroker-data/files
                    52M     /opt/iobroker/iobroker-data/files/javascript.admin
                    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                    7.8M    /opt/iobroker/iobroker-data/objects.jsonl
                    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                    5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                    USB-Devices by-id:
                    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.18.1
                    /usr/bin/node           v18.18.1
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    nodejs:
                      Installed: 18.18.1-1nodesource1
                      Candidate: 18.18.1-1nodesource1
                      Version table:
                     *** 18.18.1-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                            100 /var/lib/dpkg/status
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: file
                    States  type: file
                    Core adapters versions
                    js-controller:  5.0.12
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
                      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
                    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                    + system.adapter.history.0                : history               : iobroker                                 -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
                    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
                    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                    + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
                    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "admin"        : 6.10.1   , installed 6.10.1
                    Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
                    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                    Controller "js-controller": 5.0.12   , installed 5.0.12
                    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                    Objects and States
                    Objects:        22288
                    States:         19027
                    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 5
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
                    udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
                    udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
                    2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
                    2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
                    2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
                    2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
                    2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
                    2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
                    2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
                    2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                    2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                    2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
                    2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
                    2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
                    2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
                    2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
                    2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
                    2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
                    2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
                    iob diag has finished.
                    ? 1 Antwort Letzte Antwort
                    • H hm_krause
                      @dp20eic
                      Bitte schön
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                                921 M total memory
                                236 M used memory
                                174 M active memory
                                409 M free memory
                                 54 M buffer memory
                                221 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      894M    /var/
                      574M    /var/log
                      120M    /var/cache
                      USB-Devices by-id:
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: file
                      States  type: file
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        22288
                      States:         19027
                      Pending Updates: 5
                      Bitte schön
                      Moin,
                      ist das eine Master/Slave Installation?
                      Auch das wäre dann schon am Anfang von Interesse gewesen!
                      Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
                      VG
                      Bernd
                        Bitte schön
                        Moin,
                        VG
                        Bernd
                        H Online
                        H Online
                        hm_krause
                        @dp20eic sagte in Zigbee Adapter startet nicht:
                        Bitte schön
                        Moin,
                        ...Stand im 1. Beitrag und Deconz ist deinstalliert
                        • H hm_krause
                          Bitte schön
                          Moin,
                          Moin,
                          ok, das kleine geklammerte Slave habe ich überlesen.
                          Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
                          VG
                          Bernd
                            Moin,
                            VG
                            Bernd
                            H Online
                            H Online
                            hm_krause
                            @dp20eic
                            Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
                            pi@raspberrypi2:~ $ sudo systemctl status deconz
                            Unit deconz.service could not be found.
                            pi@raspberrypi2:~ $
                            • H hm_krause
                              @dp20eic
                              pi@raspberrypi2:~ $
                              Moin,
                              kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                              Da müssen andere helfen, da stocher ich nur im Trüben.
                              Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                              VG
                              Bernd
                              P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                                Moin,
                                VG
                                Bernd
                                H Online
                                H Online
                                hm_krause
                                @dp20eic
                                Werde alles nochmal neu machen, Danke
                                • H hm_krause
                                  @dp20eic
                                  H Online
                                  H Online
                                  hm_krause
                                  @hm_krause
                                  Läuft noch nicht.
                                  Master als VM auf Proxmox
                                  Slave komplett neu auf Raspi 4.
                                  Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                                  Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                                  host.iob-oben
                                  	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                  host.iob-oben
                                  	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                                  host.iob-oben
                                  	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  zigbee.0
                                  	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                                  zigbee.0
                                  	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                  zigbee.0
                                  	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                  zigbee.0
                                  	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  host.iob-oben
                                  	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                                  host.iob-oben
                                  	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                                  host.iob-oben
                                  	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  zigbee.0
                                  	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                                  zigbee.0
                                  	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                  zigbee.0
                                  	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                  zigbee.0
                                  	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  host.iob-oben
                                  	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                                  host.iob-oben
                                  	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                                  host.iob-oben
                                  	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  zigbee.0
                                  	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                                  zigbee.0
                                  	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                                  zigbee.0
                                  	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                                  zigbee.0
                                  	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  host.iob-oben
                                  	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                                  host.iob-oben
                                  	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                                  Noch jemand vielleicht eine Idee..?
                                  • H hm_krause
                                    @hm_krause
                                    Läuft noch nicht.
                                    host.iob-oben
                                    host.iob-oben
                                    host.iob-oben
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    host.iob-oben
                                    host.iob-oben
                                    host.iob-oben
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    host.iob-oben
                                    host.iob-oben
                                    host.iob-oben
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    host.iob-oben
                                    host.iob-oben
                                    @hm_krause said in Zigbee Adapter startet nicht:
                                    Moin,
                                    natürlich, vom Slave die lange Ausgabe von
                                    # iob diag
                                    Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                                    Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                                    Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                       - Tube's Zigbee Gateways (CC2652P2 variant)
                                       - cyijun OpenZ3Gateway
                                       - XGG 52PZ2MGateway
                                       - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                                       - cod.m ZigBee CC2652P2 TCP Coordinator
                                    VG
                                    Bernd
                                      Moin,
                                      # iob diag
                                         - XGG 52PZ2MGateway
                                      VG
                                      Bernd
                                      H Online
                                      H Online
                                      hm_krause
                                      @dp20eic
                                      Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                                      Der Stick funktioniert tadellos.
