  3. Off Topic
  4. (erledigt) Zigbee Adapter startet nicht
    1.0k
    6.1k
18 Beiträge 4 Kommentatoren 1.9k Aufrufe 4 Beobachtet
    @hm_krause sagte in Zigbee Adapter startet nicht:
    ch will auf einem Raspi 2 (als Slave)
    Moin,
    zeig doch mal den langen Output von
    # iob diag
    Vielleicht ist ja was an der Grundinstallation krum!
    Bernd
    hm_krause
    @dp20eic
    Bitte schön
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi2
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v7+
          Architecture: arm
    Model           : Raspberry Pi 2 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Fri 2023-10-13 17:45:09 CEST
               Universal time: Fri 2023-10-13 15:45:09 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            921M        236M        409M        0.0K        276M        628M
    Swap:            99M          0B         99M
    Total:          1.0G        236M        509M
              921 M total memory
              236 M used memory
              174 M active memory
              276 M inactive memory
              409 M free memory
               54 M buffer memory
              221 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       15G  3.4G   11G  25% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  948K  184M   1% /run
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    894M    /var/
    574M    /var/log
    417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
    120M    /var/cache
    Archived and active journals take up 416.0M in the file system.
    /opt/iobroker/backups:
    2.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    103M    /opt/iobroker/iobroker-data/
    74M     /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    7.8M    /opt/iobroker/iobroker-data/objects.jsonl
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.1
    /usr/bin/node           v18.18.1
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.1-1nodesource1
      Candidate: 18.18.1-1nodesource1
      Version table:
     *** 18.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: file
    States  type: file
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
    + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        22288
    States:         19027
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 5
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
    udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
    udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
    2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
    2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
        at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49)
        at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26)
        at Zigbee.emit (node:events:529:35)
        at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37)
        at process.processImmediate (node:internal/timers:476:21)
    2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
    2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
    2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
    2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
    2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
    2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
    2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
    2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
    2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
    2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
    2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
    2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
    2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
    iob diag has finished.
    • H hm_krause
      @dp20eic
      Bitte schön
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
                921 M total memory
                236 M used memory
                174 M active memory
                409 M free memory
                 54 M buffer memory
                221 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      894M    /var/
      574M    /var/log
      120M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: file
      States  type: file
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        22288
      States:         19027
      Pending Updates: 5
      Bitte schön
      Moin,
      ist das eine Master/Slave Installation?
      Auch das wäre dann schon am Anfang von Interesse gewesen!
      Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
      Bernd
      H 1 Antwort Letzte Antwort
        Bitte schön
        Moin,
        Bernd
        hm_krause
        @dp20eic sagte in Zigbee Adapter startet nicht:
        Bitte schön
        Moin,
        ...Stand im 1. Beitrag und Deconz ist deinstalliert
        • H hm_krause
          Bitte schön
          Moin,
          Moin,
          ok, das kleine geklammerte Slave habe ich überlesen.
          Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
          Bernd
            Moin,
            Bernd
            hm_krause
            @dp20eic
            Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
            pi@raspberrypi2:~ $ sudo systemctl status deconz
            Unit deconz.service could not be found.
            pi@raspberrypi2:~ $
            • H hm_krause
              @dp20eic
              pi@raspberrypi2:~ $
              Moin,
              kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
              Da müssen andere helfen, da stocher ich nur im Trüben.
              Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
              Bernd
              P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                Moin,
                Bernd
                hm_krause
                @dp20eic
                Werde alles nochmal neu machen, Danke
                • H hm_krause
                  @dp20eic
                  hm_krause
                  @hm_krause
                  Läuft noch nicht.
                  Master als VM auf Proxmox
                  Slave komplett neu auf Raspi 4.
                  Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                  Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                  host.iob-oben
                  	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                  host.iob-oben
                  	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.iob-oben
                  	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  zigbee.0
                  	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                  zigbee.0
                  	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  host.iob-oben
                  	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                  host.iob-oben
                  	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.iob-oben
                  	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  zigbee.0
                  	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                  zigbee.0
                  	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  host.iob-oben
                  	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                  host.iob-oben
                  	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.iob-oben
                  	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  zigbee.0
                  	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                  zigbee.0
                  	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                  zigbee.0
                  	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  host.iob-oben
                  	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                  host.iob-oben
                  	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                  Noch jemand vielleicht eine Idee..?
                  • H hm_krause
                    @hm_krause
                    Läuft noch nicht.
                    host.iob-oben
                    host.iob-oben
                    host.iob-oben
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    host.iob-oben
                    host.iob-oben
                    host.iob-oben
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    host.iob-oben
                    host.iob-oben
                    host.iob-oben
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    host.iob-oben
                    host.iob-oben
                    @hm_krause said in Zigbee Adapter startet nicht:
                    Moin,
                    natürlich, vom Slave die lange Ausgabe von
                    # iob diag
                    Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                    Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                    Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                       - Tube's Zigbee Gateways (CC2652P2 variant)
                       - cyijun OpenZ3Gateway
                       - XGG 52PZ2MGateway
                       - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                       - cod.m ZigBee CC2652P2 TCP Coordinator
                    Bernd
                      Moin,
                      # iob diag
                         - XGG 52PZ2MGateway
                      Bernd
                      hm_krause
                      @dp20eic
                      Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                      Der Stick funktioniert tadellos.
