  3. Off Topic
  4. (erledigt) Zigbee Adapter startet nicht
    1.0k
    6.1k
18 Beiträge 4 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • H hm_krause
    Ich will auf einem Raspi 2 (als Slave) nur den Zigbee Adapter laufen lassen. Leider startet dieser nicht.
    pi@raspberrypi2:~ $ ls -l /dev/serial/by-id
    total 0
    lrwxrwxrwx 1 root root 13 Oct 12 17:17 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 -> ../../ttyACM0
    Einstellung:
    Log:
    host.raspberrypi2
    	2023-10-12 18:06:52.252	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    zigbee.0
    	2023-10-12 18:06:51.176	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.173	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:51.171	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.168	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-10-12 18:06:51.157	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.153	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:51.137	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:51.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi2
    	2023-10-12 18:06:33.582	info	instance system.adapter.zigbee.0 started with pid 811
    host.raspberrypi2
    	2023-10-12 18:06:02.935	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi2
    	2023-10-12 18:06:02.932	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    zigbee.0
    	2023-10-12 18:06:01.934	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.932	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:01.928	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.925	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-10-12 18:06:01.913	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.908	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 18:06:01.889	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 18:06:01.879	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Was ist hier falsch, welche Infos werden noch benötigt?
    @hm_krause sagte in Zigbee Adapter startet nicht:
    Moin,
    zeig doch mal den langen Output von
    # iob diag
    Vielleicht ist ja was an der Grundinstallation krum!
    Bernd
    H 1 Antwort Letzte Antwort
      Moin,
      # iob diag
      Bernd
      H Online
      H Online
      hm_krause
      @dp20eic
      Bitte schön
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi2
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7+
            Architecture: arm
      Model           : Raspberry Pi 2 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2023-10-13 17:45:09 CEST
                 Universal time: Fri 2023-10-13 15:45:09 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            921M        236M        409M        0.0K        276M        628M
      Swap:            99M          0B         99M
      Total:          1.0G        236M        509M
                921 M total memory
                236 M used memory
                174 M active memory
                276 M inactive memory
                409 M free memory
                 54 M buffer memory
                221 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       15G  3.4G   11G  25% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
      tmpfs          tmpfs     185M  948K  184M   1% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      894M    /var/
      574M    /var/log
      417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
      120M    /var/cache
      Archived and active journals take up 416.0M in the file system.
      /opt/iobroker/backups:
      2.4M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      103M    /opt/iobroker/iobroker-data/
      74M     /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      7.8M    /opt/iobroker/iobroker-data/objects.jsonl
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.1
      /usr/bin/node           v18.18.1
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.1-1nodesource1
        Candidate: 18.18.1-1nodesource1
        Version table:
       *** 18.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: file
      States  type: file
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     7.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        22288
      States:         19027
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 5
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
      udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
      udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
      2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
      2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
      2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
      2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
      2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
      2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
      2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
      2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
      2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
      2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
      2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
      2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
      2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
      2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
      2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
      iob diag has finished.
      • H hm_krause
        @dp20eic
        Bitte schön
        Skript v.2023-10-10
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                  921 M total memory
                  236 M used memory
                  174 M active memory
                  409 M free memory
                   54 M buffer memory
                  221 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        894M    /var/
        574M    /var/log
        120M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: file
        States  type: file
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        22288
        States:         19027
        Pending Updates: 5
        Bitte schön
        Moin,
        ist das eine Master/Slave Installation?
        Auch das wäre dann schon am Anfang von Interesse gewesen!
        Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
        Bernd
          Bitte schön
          Moin,
          Bernd
          H Online
          H Online
          hm_krause
          @dp20eic sagte in Zigbee Adapter startet nicht:
          Bitte schön
          Moin,
          ...Stand im 1. Beitrag und Deconz ist deinstalliert
          • H hm_krause
            Bitte schön
            Moin,
            Moin,
            ok, das kleine geklammerte Slave habe ich überlesen.
            Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
            Bernd
              Moin,
              Bernd
              H Online
              H Online
              hm_krause
              @dp20eic
              Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
              pi@raspberrypi2:~ $ sudo systemctl status deconz
              Unit deconz.service could not be found.
              pi@raspberrypi2:~ $
              • H hm_krause
                @dp20eic
                pi@raspberrypi2:~ $
                Moin,
                kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                Da müssen andere helfen, da stocher ich nur im Trüben.
                Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                Bernd
                P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                  Moin,
                  Bernd
                  H Online
                  H Online
                  hm_krause
                  @dp20eic
                  Werde alles nochmal neu machen, Danke
                  • H hm_krause
                    @dp20eic
                    H Online
                    H Online
                    hm_krause
                    @hm_krause
                    Läuft noch nicht.
                    Master als VM auf Proxmox
                    Slave komplett neu auf Raspi 4.
                    Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                    Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                    host.iob-oben
                    	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                    host.iob-oben
                    	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                    host.iob-oben
                    	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    zigbee.0
                    	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                    zigbee.0
                    	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                    zigbee.0
                    	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                    zigbee.0
                    	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    host.iob-oben
                    	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                    host.iob-oben
                    	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                    host.iob-oben
                    	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    zigbee.0
                    	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                    zigbee.0
                    	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                    zigbee.0
                    	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                    zigbee.0
                    	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    host.iob-oben
                    	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                    host.iob-oben
                    	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                    host.iob-oben
                    	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    zigbee.0
                    	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                    zigbee.0
                    	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                    zigbee.0
                    	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                    zigbee.0
                    	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    host.iob-oben
                    	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                    host.iob-oben
                    	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                    Noch jemand vielleicht eine Idee..?
                    • H hm_krause
                      @hm_krause
                      Läuft noch nicht.
                      host.iob-oben
                      host.iob-oben
                      host.iob-oben
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      host.iob-oben
                      host.iob-oben
                      host.iob-oben
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      host.iob-oben
                      host.iob-oben
                      host.iob-oben
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      host.iob-oben
                      host.iob-oben
                      @hm_krause said in Zigbee Adapter startet nicht:
                      Moin,
                      natürlich, vom Slave die lange Ausgabe von
                      # iob diag
                      Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                      Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                      Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                         - Tube's Zigbee Gateways (CC2652P2 variant)
                         - cyijun OpenZ3Gateway
                         - XGG 52PZ2MGateway
                         - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                         - cod.m ZigBee CC2652P2 TCP Coordinator
                      Bernd
                        Moin,
                        # iob diag
                           - XGG 52PZ2MGateway
                        Bernd
                        H Online
                        H Online
                        hm_krause
                        @dp20eic
                        Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                        Der Stick funktioniert tadellos.
