  3. Off Topic
  4. (erledigt) Zigbee Adapter startet nicht
    1.0k
    6.1k
18 Beiträge 4 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • H hm_krause
    2023-10-12 19:04:11.759  - info: host.raspberrypi2 "system.adapter.zigbee.0" enabled
    2023-10-12 19:04:12.349  - info: host.raspberrypi2 instance system.adapter.zigbee.0 started with pid 968
    2023-10-12 19:04:29.686  - error: zigbee.0 (968) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-10-12 19:04:29.693  - error: zigbee.0 (968) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    2023-10-12 19:04:29.710  - error: zigbee.0 (968) TypeError: Cannot read properties of undefined (reading 'getDevice')
        at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49)
        at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26)
        at Zigbee.emit (node:events:529:35)
        at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37)
        at process.processImmediate (node:internal/timers:476:21)
    2023-10-12 19:04:29.714  - error: zigbee.0 (968) Cannot read properties of undefined (reading 'getDevice')
    2023-10-12 19:04:33.394  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2023-10-12 19:04:33.397  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
    ^C
    ...hoffe das reicht.🙄
    @hm_krause
    Ein richtiger Start schaut so aus:
    2023-10-12 19:22:32.152  - info: zigbee.0 (68120) Got terminate signal TERMINATE_YOURSELF
    2023-10-12 19:22:32.154  - info: zigbee.0 (68120) cleaned everything up...
    2023-10-12 19:22:32.157  - info: zigbee.0 (68120) Zigbee: disabling joining new devices.
    2023-10-12 19:22:32.655  - info: zigbee.0 (68120) terminating
    2023-10-12 19:22:32.664  - info: zigbee.0 (68120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-12 19:23:07.364  - info: zigbee.0 (68952) starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.8.0, js-controller: 5.0.13
    2023-10-12 19:23:07.532  - info: zigbee.0 (68952) delete old Backup files. keep only last 10
    2023-10-12 19:23:07.535  - info: zigbee.0 (68952) Starting Zigbee  npm ...
    2023-10-12 19:23:07.969  - info: zigbee.0 (68952) Installed Version: iobroker.zigbee@1.8.24
    2023-10-12 19:23:19.816  - info: zigbee.0 (68952) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
    2023-10-12 19:23:19.828  - info: zigbee.0 (68952) Unable to disable LED, unsupported function.
    2023-10-12 19:23:19.847  - info: zigbee.0 (68952)   --> transmitPower : normal
    Die Instanz ausschalten und nach einiger Zeit frisch starten.
    H 1 Antwort Letzte Antwort
      @hm_krause
      H Online
      H Online
      hm_krause
      @thomas-braun sagte in Zigbee Adapter startet nicht:
      Das hilft aber nicht...
      host.raspberrypi2
      	2023-10-12 19:32:24.742	info	"system.adapter.zigbee.0" disabled
      host.raspberrypi2
      	2023-10-12 19:32:03.015	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi2
      	2023-10-12 19:32:03.012	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee.0
      	2023-10-12 19:32:01.525	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 19:32:01.523	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-12 19:32:01.520	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 19:32:01.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      	2023-10-12 19:32:00.965	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 19:32:00.960	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-12 19:32:00.943	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-12 19:32:00.936	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi2
      	2023-10-12 19:31:43.336	info	instance system.adapter.zigbee.0 started with pid 1109
      host.raspberrypi2
      	2023-10-12 19:31:42.910	info	"system.adapter.zigbee.0" enabled
      • H hm_krause
        host.raspberrypi2
        host.raspberrypi2
        host.raspberrypi2
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        host.raspberrypi2
        host.raspberrypi2
        arteckA Offline
        arteckA Offline
        arteck
        @hm_krause installier mal von GIT
        https://github.com/ioBroker/ioBroker.zigbee
        der sollte jetzt an der stelle ne Fehlermeldung liefern
        • arteckA arteck
          H Online
          H Online
          hm_krause
          @arteck
          Bringt folgendes:
          zigbee.0
          	2023-10-13 13:27:58.858	error	adapter disabled
          host.raspberrypi2
          	2023-10-13 13:27:20.259	info	"system.adapter.zigbee.0" disabled
          host.raspberrypi2
          	2023-10-13 13:27:14.281	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.raspberrypi2
          	2023-10-13 13:27:14.278	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          zigbee.0
          	2023-10-13 13:27:12.854	error	Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-13 13:27:12.851	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
          zigbee.0
          	2023-10-13 13:27:12.849	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-13 13:27:12.846	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          	2023-10-13 13:27:12.836	error	Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-13 13:27:12.833	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
          zigbee.0
          	2023-10-13 13:27:12.816	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
          zigbee.0
          	2023-10-13 13:27:12.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          host.raspberrypi2
          	2023-10-13 13:26:54.200	info	instance system.adapter.zigbee.0 started with pid 3125
          host.raspberrypi2
          	2023-10-13 13:26:23.752	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.raspberrypi2
          	2023-10-13 13:26:23.749	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          zigbee.0
          	2023-10-13 13:26:22.299	error	this.zbController.getGroup is not a function
          zigbee.0
          	2023-10-13 13:26:22.297	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
          zigbee.0
          	2023-10-13 13:26:22.279	error	unhandled promise rejection: this.zbController.getGroup is not a function
          zigbee.0
          	2023-10-13 13:26:22.273	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          host.raspberrypi2
          	2023-10-13 13:26:02.219	info	instance system.adapter.zigbee.0 started with pid 3106
          host.raspberrypi2
          	2023-10-13 13:26:01.709	info	"system.adapter.zigbee.0" enabled
          • H hm_krause
            Ich will auf einem Raspi 2 (als Slave) nur den Zigbee Adapter laufen lassen. Leider startet dieser nicht.
            pi@raspberrypi2:~ $ ls -l /dev/serial/by-id
            total 0
            lrwxrwxrwx 1 root root 13 Oct 12 17:17 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 -> ../../ttyACM0
            Einstellung:
            Log:
            host.raspberrypi2
            	2023-10-12 18:06:52.252	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            zigbee.0
            	2023-10-12 18:06:51.176	error	Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:51.173	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
            zigbee.0
            	2023-10-12 18:06:51.171	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:51.168	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0
            	2023-10-12 18:06:51.157	error	Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:51.153	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
            zigbee.0
            	2023-10-12 18:06:51.137	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:51.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            host.raspberrypi2
            	2023-10-12 18:06:33.582	info	instance system.adapter.zigbee.0 started with pid 811
            host.raspberrypi2
            	2023-10-12 18:06:02.935	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.raspberrypi2
            	2023-10-12 18:06:02.932	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            zigbee.0
            	2023-10-12 18:06:01.934	error	Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:01.932	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
            zigbee.0
            	2023-10-12 18:06:01.928	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:01.925	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0
            	2023-10-12 18:06:01.913	error	Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:01.908	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
            zigbee.0
            	2023-10-12 18:06:01.889	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
            zigbee.0
            	2023-10-12 18:06:01.879	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            Was ist hier falsch, welche Infos werden noch benötigt?
            @hm_krause sagte in Zigbee Adapter startet nicht:
            Moin,
            zeig doch mal den langen Output von
            # iob diag
            Vielleicht ist ja was an der Grundinstallation krum!
            Bernd
              Moin,
              # iob diag
              Bernd
              H Online
              H Online
              hm_krause
              @dp20eic
              Bitte schön
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: raspberrypi2
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v7+
                    Architecture: arm
              Model           : Raspberry Pi 2 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
               17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Fri 2023-10-13 17:45:09 CEST
                         Universal time: Fri 2023-10-13 15:45:09 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            921M        236M        409M        0.0K        276M        628M
              Swap:            99M          0B         99M
              Total:          1.0G        236M        509M
                        921 M total memory
                        236 M used memory
                        174 M active memory
                        276 M inactive memory
                        409 M free memory
                         54 M buffer memory
                        221 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       15G  3.4G   11G  25% /
              devtmpfs       devtmpfs  333M     0  333M   0% /dev
              tmpfs          tmpfs     461M     0  461M   0% /dev/shm
              tmpfs          tmpfs     185M  948K  184M   1% /run
              /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
              tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
              [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              894M    /var/
              574M    /var/log
              417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
              120M    /var/cache
              Archived and active journals take up 416.0M in the file system.
              /opt/iobroker/backups:
              2.4M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              103M    /opt/iobroker/iobroker-data/
              74M     /opt/iobroker/iobroker-data/files
              52M     /opt/iobroker/iobroker-data/files/javascript.admin
              34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              7.8M    /opt/iobroker/iobroker-data/objects.jsonl
              7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
              4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
              USB-Devices by-id:
              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.18.1
              /usr/bin/node           v18.18.1
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              /usr/bin/corepack       0.19.0
              nodejs:
                Installed: 18.18.1-1nodesource1
                Candidate: 18.18.1-1nodesource1
                Version table:
               *** 18.18.1-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u4 500
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              At least one iobroker host is running.
              Objects type: file
              States  type: file
              Core adapters versions
              js-controller:  5.0.12
              admin:          6.10.1
              javascript:     7.1.4
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
                system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
              + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
              + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
              + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
              + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
              + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
              + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
                system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
              + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
              + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
              + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
              + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
              + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.10.1   , installed 6.10.1
              Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
              Adapter    "deconz"       : 1.3.21   , installed 1.3.21
              Adapter    "javascript"   : 7.1.4    , installed 7.1.4
              Controller "js-controller": 5.0.12   , installed 5.0.12
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              Objects and States
              Objects:        22288
              States:         19027
              Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 5
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
              udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
              udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
              2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
              2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
              2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
              2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
              2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
              2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
              2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
              2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
              2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
              2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
              2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
              2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
              2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
              2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
              2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
              2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
              2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
              iob diag has finished.
              • H hm_krause
                @dp20eic
                Bitte schön
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                          921 M total memory
                          236 M used memory
                          174 M active memory
                          409 M free memory
                           54 M buffer memory
                          221 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                894M    /var/
                574M    /var/log
                120M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: file
                States  type: file
                admin:          6.10.1
                javascript:     7.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        22288
                States:         19027
                Pending Updates: 5
                Bitte schön
                Moin,
                ist das eine Master/Slave Installation?
                Auch das wäre dann schon am Anfang von Interesse gewesen!
                Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
                Bernd
                  Bitte schön
                  Moin,
                  Bernd
                  H Online
                  H Online
                  hm_krause
                  @dp20eic sagte in Zigbee Adapter startet nicht:
                  Bitte schön
                  Moin,
                  ...Stand im 1. Beitrag und Deconz ist deinstalliert
                  • H hm_krause
                    Bitte schön
                    Moin,
                    Moin,
                    ok, das kleine geklammerte Slave habe ich überlesen.
                    Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
                    Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
                    Bernd
                      Moin,
                      Bernd
                      H Online
                      H Online
                      hm_krause
                      @dp20eic
                      Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
                      pi@raspberrypi2:~ $ sudo systemctl status deconz
                      Unit deconz.service could not be found.
                      pi@raspberrypi2:~ $
                      • H hm_krause
                        @dp20eic
                        pi@raspberrypi2:~ $
                        Moin,
                        kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                        Da müssen andere helfen, da stocher ich nur im Trüben.
                        Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                        Bernd
                        P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                          Moin,
                          Bernd
                          H Online
                          H Online
                          hm_krause
                          @dp20eic
                          Werde alles nochmal neu machen, Danke
                          • H hm_krause
                            @dp20eic
                            H Online
                            H Online
                            hm_krause
                            @hm_krause
                            Läuft noch nicht.
                            Master als VM auf Proxmox
                            Slave komplett neu auf Raspi 4.
                            Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                            Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                            host.iob-oben
                            	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                            host.iob-oben
                            	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                            host.iob-oben
                            	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            zigbee.0
                            	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                            zigbee.0
                            	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                            zigbee.0
                            	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                            zigbee.0
                            	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            host.iob-oben
                            	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                            host.iob-oben
                            	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                            host.iob-oben
                            	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            zigbee.0
                            	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                            zigbee.0
                            	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                            zigbee.0
                            	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                            zigbee.0
                            	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            host.iob-oben
                            	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                            host.iob-oben
                            	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                            host.iob-oben
                            	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            zigbee.0
                            	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                            zigbee.0
                            	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                            zigbee.0
                            	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                            zigbee.0
                            	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            host.iob-oben
                            	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                            host.iob-oben
                            	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                            Noch jemand vielleicht eine Idee..?
                            • H hm_krause
                              @hm_krause
                              Läuft noch nicht.
                              host.iob-oben
                              host.iob-oben
                              host.iob-oben
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              host.iob-oben
                              host.iob-oben
                              host.iob-oben
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              host.iob-oben
                              host.iob-oben
                              host.iob-oben
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              zigbee.0
                              host.iob-oben
                              host.iob-oben
                              @hm_krause said in Zigbee Adapter startet nicht:
                              Moin,
                              natürlich, vom Slave die lange Ausgabe von
                              # iob diag
                              Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                              Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                              Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                 - Tube's Zigbee Gateways (CC2652P2 variant)
                                 - cyijun OpenZ3Gateway
                                 - XGG 52PZ2MGateway
                                 - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                                 - cod.m ZigBee CC2652P2 TCP Coordinator
                              Bernd
                                Moin,
                                # iob diag
                                   - XGG 52PZ2MGateway
                                Bernd
                                H Online
                                H Online
                                hm_krause
                                @dp20eic
                                Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                                Der Stick funktioniert tadellos.
