  3. Off Topic
  4. (erledigt) Zigbee Adapter startet nicht
    1.0k
    6.1k
18 Beiträge 4 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • H hm_krause
    @thomas-braun sagte in Zigbee Adapter startet nicht:
    Die Instanz ausschalten und nach einiger Zeit frisch starten.
    Das hilft aber nicht...
    host.raspberrypi2
    	2023-10-12 19:32:24.742	info	"system.adapter.zigbee.0" disabled
    host.raspberrypi2
    	2023-10-12 19:32:03.015	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi2
    	2023-10-12 19:32:03.012	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    zigbee.0
    	2023-10-12 19:32:01.525	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 19:32:01.523	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 19:32:01.520	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 19:32:01.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    	2023-10-12 19:32:00.965	error	Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 19:32:00.960	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
    zigbee.0
    	2023-10-12 19:32:00.943	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
    zigbee.0
    	2023-10-12 19:32:00.936	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.raspberrypi2
    	2023-10-12 19:31:43.336	info	instance system.adapter.zigbee.0 started with pid 1109
    host.raspberrypi2
    	2023-10-12 19:31:42.910	info	"system.adapter.zigbee.0" enabled
    arteckA Offline
    arteckA Offline
    arteck
    @hm_krause installier mal von GIT
    https://github.com/ioBroker/ioBroker.zigbee
    der sollte jetzt an der stelle ne Fehlermeldung liefern
    H 1 Antwort Letzte Antwort
    • arteckA arteck
      H Online
      H Online
      hm_krause
      @arteck
      Bringt folgendes:
      zigbee.0
      	2023-10-13 13:27:58.858	error	adapter disabled
      host.raspberrypi2
      	2023-10-13 13:27:20.259	info	"system.adapter.zigbee.0" disabled
      host.raspberrypi2
      	2023-10-13 13:27:14.281	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi2
      	2023-10-13 13:27:14.278	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee.0
      	2023-10-13 13:27:12.854	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-13 13:27:12.851	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-13 13:27:12.849	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-13 13:27:12.846	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      	2023-10-13 13:27:12.836	error	Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-13 13:27:12.833	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-13 13:27:12.816	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
      zigbee.0
      	2023-10-13 13:27:12.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi2
      	2023-10-13 13:26:54.200	info	instance system.adapter.zigbee.0 started with pid 3125
      host.raspberrypi2
      	2023-10-13 13:26:23.752	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi2
      	2023-10-13 13:26:23.749	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee.0
      	2023-10-13 13:26:22.299	error	this.zbController.getGroup is not a function
      zigbee.0
      	2023-10-13 13:26:22.297	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
      zigbee.0
      	2023-10-13 13:26:22.279	error	unhandled promise rejection: this.zbController.getGroup is not a function
      zigbee.0
      	2023-10-13 13:26:22.273	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.raspberrypi2
      	2023-10-13 13:26:02.219	info	instance system.adapter.zigbee.0 started with pid 3106
      host.raspberrypi2
      	2023-10-13 13:26:01.709	info	"system.adapter.zigbee.0" enabled
      • H hm_krause
        Ich will auf einem Raspi 2 (als Slave) nur den Zigbee Adapter laufen lassen. Leider startet dieser nicht.
        pi@raspberrypi2:~ $ ls -l /dev/serial/by-id
        total 0
        lrwxrwxrwx 1 root root 13 Oct 12 17:17 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00 -> ../../ttyACM0
        Einstellung:
        Log:
        host.raspberrypi2
        	2023-10-12 18:06:52.252	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0
        	2023-10-12 18:06:51.176	error	Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:51.173	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-12 18:06:51.171	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:51.168	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        	2023-10-12 18:06:51.157	error	Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:51.153	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-12 18:06:51.137	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:51.130	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.raspberrypi2
        	2023-10-12 18:06:33.582	info	instance system.adapter.zigbee.0 started with pid 811
        host.raspberrypi2
        	2023-10-12 18:06:02.935	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi2
        	2023-10-12 18:06:02.932	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0
        	2023-10-12 18:06:01.934	error	Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:01.932	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-12 18:06:01.928	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:01.925	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        	2023-10-12 18:06:01.913	error	Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:01.908	error	TypeError: Cannot read properties of undefined (reading 'getDevice') at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:49) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
        zigbee.0
        	2023-10-12 18:06:01.889	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
        zigbee.0
        	2023-10-12 18:06:01.879	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        Was ist hier falsch, welche Infos werden noch benötigt?
        @hm_krause sagte in Zigbee Adapter startet nicht:
        Moin,
        zeig doch mal den langen Output von
        # iob diag
        Vielleicht ist ja was an der Grundinstallation krum!
        Bernd
          Moin,
          # iob diag
          Bernd
          H Online
          H Online
          hm_krause
          @dp20eic
          Bitte schön
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi2
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v7+
                Architecture: arm
          Model           : Raspberry Pi 2 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           17:45:09 up 23:50,  1 user,  load average: 0.23, 0.07, 0.02
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Fri 2023-10-13 17:45:09 CEST
                     Universal time: Fri 2023-10-13 15:45:09 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            921M        236M        409M        0.0K        276M        628M
          Swap:            99M          0B         99M
          Total:          1.0G        236M        509M
                    921 M total memory
                    236 M used memory
                    174 M active memory
                    276 M inactive memory
                    409 M free memory
                     54 M buffer memory
                    221 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       15G  3.4G   11G  25% /
          devtmpfs       devtmpfs  333M     0  333M   0% /dev
          tmpfs          tmpfs     461M     0  461M   0% /dev/shm
          tmpfs          tmpfs     185M  948K  184M   1% /run
          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
          [Thu Oct 12 17:54:32 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=984cb146-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Thu Oct 12 17:54:36 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): recovery complete
          [Thu Oct 12 17:54:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Thu Oct 12 17:54:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Oct 12 17:54:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          894M    /var/
          574M    /var/log
          417M    /var/log/journal/d396ac506ad544c8953772923028cd1b
          120M    /var/cache
          Archived and active journals take up 416.0M in the file system.
          /opt/iobroker/backups:
          2.4M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          103M    /opt/iobroker/iobroker-data/
          74M     /opt/iobroker/iobroker-data/files
          52M     /opt/iobroker/iobroker-data/files/javascript.admin
          34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          33M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          7.8M    /opt/iobroker/iobroker-data/objects.jsonl
          7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.1
          /usr/bin/node           v18.18.1
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.1-1nodesource1
            Candidate: 18.18.1-1nodesource1
            Version table:
           *** 18.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: file
          States  type: file
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.10.1
          javascript:     7.1.4
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.4, run as: admin
            system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.energiefluss.1           : energiefluss          : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
          + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
          + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 8701
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.javascript.1             : javascript            : raspberrypi2                             -  enabled
          + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
          + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          + system.adapter.resol.0                  : resol                 : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.4
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.zigbee.0                 : zigbee                : raspberrypi2                             - disabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2433967-if00
          + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.10.1
          Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
          Objects and States
          Objects:        22288
          States:         19027
          Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 5
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13985      437/sshd: /usr/sbin
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13987      437/sshd: /usr/sbin
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1712       536/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13885      328/avahi-daemon: r
          udp        0      0 0.0.0.0:46530           0.0.0.0:*                           108        13887      328/avahi-daemon: r
          udp6       0      0 :::53325                :::*                                108        13888      328/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        13886      328/avahi-daemon: r
          2023-10-13 13:48:53.686  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
          2023-10-13 13:48:53.698  - error: zigbee.0 (3202) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-10-13 13:48:53.700  - error: zigbee.0 (3202) unhandled promise rejection: Cannot read properties of undefined (reading 'getDevice')
          2023-10-13 13:48:53.703  - error: zigbee.0 (3202) TypeError: Cannot read properties of undefined (reading 'getDevice')
          2023-10-13 13:48:53.705  - error: zigbee.0 (3202) Cannot read properties of undefined (reading 'getDevice')
          2023-10-13 13:48:55.306  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2023-10-13 13:48:55.308  - info: host.raspberrypi2 Restart adapter system.adapter.zigbee.0 because enabled
          2023-10-13 13:49:01.630  - info: host.raspberrypi2 "system.adapter.zigbee.0" disabled
          2023-10-13 13:49:42.820  - error: zigbee.0 (3218) adapter disabled
          2023-10-13 13:49:43.820  - error: host.raspberrypi2 instance system.adapter.zigbee.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
          2023-10-13 13:49:43.823  - info: host.raspberrypi2 Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
          2023-10-13 16:03:53.346  - error: host.raspberrypi2 Objects database error: read ECONNRESET
          2023-10-13 16:03:53.345  - error: javascript.1 (550) Objects database error: read ECONNRESET
          2023-10-13 16:03:58.380  - error: host.raspberrypi2 Objects database error: connect ECONNREFUSED 192.168.178.4:9001
          2023-10-13 16:03:58.424  - error: javascript.1 (550) Objects database error: connect ECONNREFUSED 192.168.178.4:9001
          2023-10-13 16:04:00.227  - error: host.raspberrypi2 States database error: read ECONNRESET
          2023-10-13 16:04:01.512  - error: javascript.1 (550) States database error: read ECONNRESET
          2023-10-13 16:04:03.397  - info: host.raspberrypi2 Objects database successfully reconnected
          2023-10-13 16:04:05.240  - info: host.raspberrypi2 Objects database successfully reconnected
          iob diag has finished.
          • H hm_krause
            @dp20eic
            Bitte schön
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                      921 M total memory
                      236 M used memory
                      174 M active memory
                      409 M free memory
                       54 M buffer memory
                      221 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            894M    /var/
            574M    /var/log
            120M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: file
            States  type: file
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        22288
            States:         19027
            Pending Updates: 5
            Bitte schön
            Moin,
            ist das eine Master/Slave Installation?
            Auch das wäre dann schon am Anfang von Interesse gewesen!
            Du hast auf dem RasPI-2 noch Deconz installiert, kann das sein, dass sich das mit dem Zigbee - Adapter beißt?
            Bernd
              Bitte schön
              Moin,
              Bernd
              H Online
              H Online
              hm_krause
              @dp20eic sagte in Zigbee Adapter startet nicht:
              Bitte schön
              Moin,
              ...Stand im 1. Beitrag und Deconz ist deinstalliert
              • H hm_krause
                Bitte schön
                Moin,
                Moin,
                ok, das kleine geklammerte Slave habe ich überlesen.
                Aber dekonz wird mir doch in der Liste des RasPI-2 aufgelistet
                Adapter    "deconz"       : 1.3.21   , installed 1.3.21                      <------
                Bernd
                  Moin,
                  Bernd
                  H Online
                  H Online
                  hm_krause
                  @dp20eic
                  Deconz ist aber weder in der Instanz noch im Adapter zu sehen.
                  pi@raspberrypi2:~ $ sudo systemctl status deconz
                  Unit deconz.service could not be found.
                  pi@raspberrypi2:~ $
                  • H hm_krause
                    @dp20eic
                    pi@raspberrypi2:~ $
                    Moin,
                    kenne mich mit Master/Slave nicht wirklich aus, gerade wenn auch mal umgeschaltet wurde und dann Adapter installiert, oder deinstalliert werden.
                    Da müssen andere helfen, da stocher ich nur im Trüben.
                    Wenn das nicht zu viel Arbeit ist, würde ich den ganz neu von vorne aufsetzen.
                    Bernd
                    P.S.: sehe gerade, Du suchst den Service, ich schrieb vom Adapter im ioBroker
                      Moin,
                      Bernd
                      H Online
                      H Online
                      hm_krause
                      @dp20eic
                      Werde alles nochmal neu machen, Danke
                      • H hm_krause
                        @dp20eic
                        H Online
                        H Online
                        hm_krause
                        @hm_krause
                        Läuft noch nicht.
                        Master als VM auf Proxmox
                        Slave komplett neu auf Raspi 4.
                        Wenn ich mit der Maus auf dem roten Kreis bin zeigt eine Verbindung mit Gerät oder Dienst an (grün)
                        Die beiden anderen, Verbunden mit Host und Lebensszeichen, bleiben rot
                        host.iob-oben
                        	2023-10-15 14:51:25.836	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                        host.iob-oben
                        	2023-10-15 14:51:25.836	info	Restart adapter system.adapter.zigbee.0 because enabled
                        host.iob-oben
                        	2023-10-15 14:51:25.835	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        zigbee.0
                        	2023-10-15 14:51:24.417	error	this.zbController.getGroup is not a function
                        zigbee.0
                        	2023-10-15 14:51:24.416	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                        zigbee.0
                        	2023-10-15 14:51:24.413	error	unhandled promise rejection: this.zbController.getGroup is not a function
                        zigbee.0
                        	2023-10-15 14:51:24.411	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        host.iob-oben
                        	2023-10-15 14:51:16.312	info	instance system.adapter.zigbee.0 started with pid 1125
                        host.iob-oben
                        	2023-10-15 14:50:45.849	info	Restart adapter system.adapter.zigbee.0 because enabled
                        host.iob-oben
                        	2023-10-15 14:50:45.848	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        zigbee.0
                        	2023-10-15 14:50:44.412	error	this.zbController.getGroup is not a function
                        zigbee.0
                        	2023-10-15 14:50:44.411	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                        zigbee.0
                        	2023-10-15 14:50:44.408	error	unhandled promise rejection: this.zbController.getGroup is not a function
                        zigbee.0
                        	2023-10-15 14:50:44.406	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        host.iob-oben
                        	2023-10-15 14:50:37.187	info	instance system.adapter.zigbee.0 started with pid 1109
                        host.iob-oben
                        	2023-10-15 14:50:06.660	info	Restart adapter system.adapter.zigbee.0 because enabled
                        host.iob-oben
                        	2023-10-15 14:50:06.659	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        zigbee.0
                        	2023-10-15 14:50:04.658	error	this.zbController.getGroup is not a function
                        zigbee.0
                        	2023-10-15 14:50:04.657	error	TypeError: this.zbController.getGroup is not a function at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:104:94) at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:45:26) at Zigbee.emit (node:events:529:35) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8383:34) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:270:37) at process.processImmediate (node:internal/timers:476:21)
                        zigbee.0
                        	2023-10-15 14:50:04.654	error	unhandled promise rejection: this.zbController.getGroup is not a function
                        zigbee.0
                        	2023-10-15 14:50:04.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        host.iob-oben
                        	2023-10-15 14:49:56.318	info	instance system.adapter.zigbee.0 started with pid 1092
                        host.iob-oben
                        	2023-10-15 14:49:55.849	info	"system.adapter.zigbee.0" enabled
                        Noch jemand vielleicht eine Idee..?
                        • H hm_krause
                          @hm_krause
                          Läuft noch nicht.
                          host.iob-oben
                          host.iob-oben
                          host.iob-oben
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          host.iob-oben
                          host.iob-oben
                          host.iob-oben
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          host.iob-oben
                          host.iob-oben
                          host.iob-oben
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          host.iob-oben
                          host.iob-oben
                          @hm_krause said in Zigbee Adapter startet nicht:
                          Moin,
                          natürlich, vom Slave die lange Ausgabe von
                          # iob diag
                          Welche Version vom Zigbe Adapter, vielleicht mal die Github Version getestet?
                          Schon mal darüber nachgedacht, mittels LAN/WLAN Zigbee Stick zu arbeiten, den kann man besser im Haus positionieren als die, die über USB angeschlossen sind, dann noch gescheite Repeater und man bekommt auch ein stabiles Zigbee Mesh hin.
                          Network -> https://www.zigbee2mqtt.io/guide/adapters/#recommended
                             - Tube's Zigbee Gateways (CC2652P2 variant)
                             - cyijun OpenZ3Gateway
                             - XGG 52PZ2MGateway
                             - SMLIGHT Zigbee LAN Adapter CC2652P Model SLZB-05
                             - cod.m ZigBee CC2652P2 TCP Coordinator
                          Bernd
                            Moin,
                            # iob diag
                               - XGG 52PZ2MGateway
                            Bernd
                            H Online
                            H Online
                            hm_krause
                            @dp20eic
                            Ich habe jetzt aufgegeben und einen seperaten Iobroker auf den Raspi gebracht.
                            Der Stick funktioniert tadellos.
