  4. neue Visualisierung "webui" (alternative zu vis & vis-2)
    6.1k
1.2k Beiträge 23 Kommentatoren 457.3k Aufrufe 22 Beobachtet
  • jogibear9988J jogibear9988
    @mguc said in neue Visualisierung "webui" (alternative zu vis):
    First of all - thank you for a very nice project (and please do not attack me for using English in this part of the forum).
    Making any visualization "close to pure HTML" is, for me, a "hit or miss" (for me - more than "great").
    I keep my fingers crossed and try to explore the possibilities of webui.
    And a question from a "webui beginner" - what is the approach to showing/hiding elements depending on the values ​​of variables/points or expressions?
    I am currently try to working on showing the operating status of the home heating system using webui. And depending on the selected configuration, certain elements should appear (or hide) on the screen (e.g. subsequent heating circuits).
    you could create a binding on the css property display, and set it none or your desired value.
    Or you could bind the visibility css property.
    look in: http://129.159.205.3:8082/webui/index.html at page "visibilitysample"
    mguc
    #681
    @jogibear9988 Thank you very much for your quick reply.
    • Smilie108S Smilie108
      @jogibear9988 sagte in neue Visualisierung "webui" (alternative zu vis):
      @blockmove said in neue Visualisierung "webui" (alternative zu vis):
      @smilie108 said in neue Visualisierung "webui" (alternative zu vis):
      @jogibear9988
      Hi habe ein anderes Problem bekommen.
      Seit 1.0.36 funktioniert bei den input feldern teilweise die vorschau nicht mehr.
      Kann ich bestätigen, ist bei mir auch so.
      sollte gefixt sein
      Is das build schon fertig ? latest bring noch 1.0.43
      jogibear9988J Offline
      jogibear9988
      #682
      @jogibear9988
      sollte gefixt sein
      github hat über 1h gebraucht
      Check my ioBroker webui - a vis alternative
      see: https://github.com/iobroker-community-adapters/ioBroker.webui
      Smilie108S 1 Antwort Letzte Antwort
        @jogibear9988
        sollte gefixt sein
        Smilie108S Offline
        Smilie108S Offline
        Smilie108
        #683
        @jogibear9988
        sollte gefixt sein
        Jepp sorry jetzt gerade gegangen ;) und jetzt gehts wieder
        Danke Jochen
          mguc
          #684
          The "rename" option is missing in the menu for folders - as is the case with screens.
          jogibear9988J 1 Antwort Letzte Antwort
          • M mguc
            jogibear9988
            #685
            yeah, not yet implemented.
            will do
            XsevX 1 Antwort Letzte Antwort
            • jogibear9988J Offline
              jogibear9988
              #686
              seems ioBroker at the moment has no api to rename a folder.
              There is first a update on iob side needed
                will do
                XsevX Offline
                XsevX Offline
                Xsev
                #687
                @jogibear9988 Hallo, ich würde mal gerne wissen, ob es schon Erfahrungswerte gibt bei dieser Visualisierung, in Bezug auf "Energiesettings" bei Tablets. Genauer gesagt, wie verhält sich webui beim ausschalten des Monitors. In Vis führt das auf manchen Geräten immer zum nervigen reconnect. Ich würde mir eine Visualisierung wünschen, welche die Seite behält und nur die Daten auf der Seite aktualisiert ohne komplett neu laden zu müssen. Kannst du diesbezüglich etwas sagen?
                jogibear9988J B 2 Antworten Letzte Antwort
                • XsevX Xsev
                  jogibear9988
                  #688
                  @xsev said in neue Visualisierung "webui" (alternative zu vis):
                  Also ich habe keinen reload implementiert. Ich hoffe das sie sich weiter aktualisiert. Ich nutze den socketclient von IOB zur kommunikation, hoffe der hat ein reconnect drinnen. Aber wenn etwas nicht geht, dann schau ich es mir an.
                  Ich könnte mir vorstellen das ich mir vlt. die abonnierten Signale merken muss, aber vlt. gehts ja auch
                    XsevX Offline
                    XsevX Offline
                    Xsev
                    #689
                    @jogibear9988 Danke für deine Info.
                    • XsevX Xsev
                      Blockmove
                      #690
                      Ein Reload mit Countdown wie bei vis ist mir bei webui noch nicht untergekommen.
                      Ich hab einige Seiten mit Daten die sich häufiger aktualisieren und damit ist mir so ein Verhalten wie bei vis nocht nicht aufgefallen. Ob es aber immer funktioniert, will ich nicht mit Sicherheit sagen. Zumindest unter Android und Fullybrowser funktioniert das Aufwecken.
                      The difference beetween Man and Boys:
                      The price of their toys 😀
                      • B Blockmove
                        XsevX Offline
                        XsevX Offline
                        Xsev
                        schrieb am zuletzt editiert von Xsev
                        #691
                        @blockmove
                        Das wäre spitze, dass auch meine Combi. Danke für deine Info!
                        • wendy2702W Online
                          wendy2702W Online
                          wendy2702
                          #692
                          bevor ich anfange WebUi zu probieren eine Frage.
                          Ist ein volles Responsive Design möglich? Auch ohne mega HTML Programmier Kenntnisse?
                          jogibear9988J 2 Antworten Letzte Antwort
                          • wendy2702W wendy2702
                            jogibear9988
                            #693
                            @wendy2702 said in neue Visualisierung "webui" (alternative zu vis):
                            Keine Ahnung wieviel Kenntnisse du dazu brauchst bzw hast.
                            Aber heutzutage kann dir chat-gpt dabei viel helfen.
                            Am besten du nutzt ein css grid, mit named areas und ordnest diese über mediaqueries je nach Auflösung an.
                              jogibear9988
                              #694
                              @wendy2702
                              hab mal das bsp übernommen:
                              https://www.youtube.com/watch?v=68O6eOGAGqA
                              unter "responsive/sample1"
                                wendy2702W Online
                                wendy2702W Online
                                wendy2702
                                #695
                                @jogibear9988 keine Kenntnisse und anhand der Begriffe die du verwendet hast schon entschieden das der Adapter wohl nichts für mich ist.
                                Edit: mein Beitrag hat sich mit deinem überschnitten.
                                Schaue mir das morgen Abend im Hotel mal an.
                                Danke!
                                  jogibear9988
                                  #696
                                  Der Vorteil bei meiner Visualiserung ist, das es einfach HTML & CSS ist, das versteht ChatGpt:
                                    Smilie108S Offline
                                    Smilie108S Offline
                                    Smilie108
                                    #697
                                    @jogibear9988
                                    Kannst du dir wenn du mal zeit hast am test unter smilie108 den sample 2 ansehen und mir sagen was ich machen muss das das javascript richtig ist ?
                                    Danke im voraus ;)
                                      @jogibear9988
                                      Danke im voraus ;)
                                      jogibear9988
                                      #698
                                      @jogibear9988
                                      Danke im voraus ;)
                                      so sollte es gehen:
                                        * @param {BaseScreenViewerAndControl} instance
                                        export function init(instance) {
                                            const toggleMenuButton = instance.shadowRoot.querySelector('.toggle-menu');
                                            const sidebar = instance.shadowRoot.querySelector('.sidebar');
                                            //debugger;
                                            toggleMenuButton.addEventListener('click', function() {
                                              sidebar.classList.toggle('open');
                                      aber auch mit blockly:
                                      (nee okay, damit geht es nicht, da fehlt das toggle... da baue ich was, muss überlegen)
                                      aber mit javascript direkt am event:
                                        @jogibear9988
                                        Danke im voraus ;)
                                        so sollte es gehen:
                                              //debugger;
                                        jogibear9988
                                        #699
                                        @jogibear9988
                                        in den scripten gibt es noch 2 globale variablen IOB und RUNTIME, wenn du z.B. einen screen öffnen willst, signale steuern usw....
                                          @jogibear9988
                                          Smilie108S Offline
                                          Smilie108S Offline
                                          Smilie108
                                          #700
                                          @jogibear9988
                                          mhm bist du dir da sicher ? weil eigentlich sollte er dann das menue einfahren geht aber nicht. can es sein das das sidebar.classlist.toggle('open') nicht greift ?
                                          Sorry aber so manche verknüpfung ist mir noch nicht ganz klar ;
