  4. Anleitung Zigbee2MQTT Einrichtung im ioBroker
    5.1k
28 Beiträge 5 Kommentatoren 16.6k Aufrufe 3 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    tue uns beiden den gefallen und mach nur das was wir dir sagen egal obs plausiebel für dich ist oder nicht (von debug war nie die Rede)
    wenn @dp20eic langen Output will dann zeigmal ALLES was das iob diag liefert
    ich will die Adapter Einstellungen als screensot sehen..ja alles
    hast den umgestellt ??
    ? 1 Antwort Letzte Antwort
    • arteckA arteck
      @arteck du meinst so?
      iob diag
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the  characters at start and end.
      It helps us to help you!
      Press any key to continue
      ======== Start marking the full check here =========
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: app-server1.weinbrecht.lan
               Icon name: computer
              Machine ID: f699c63377c1419dbac4c0c664f4b780
                 Boot ID: 2dad0456cb654f80b695eb65355ad96e
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.54-v8+
            Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       08:53:22 up 14:16,  1 user,  load average: 0.36, 0.46, 0.50
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=32.6'C
      volt=0.9360V
      *** Time and Time Zones ***
                     Local time: Wed 2023-10-04 08:53:22 CEST
                 Universal time: Wed 2023-10-04 06:53:22 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            3.8G        2.0G        534M        114M        1.3G        1.7G
      Swap:             0B          0B          0B
      Total:          3.8G        2.0G        534M
               3843 M total memory
               2010 M used memory
               2643 M active memory
                476 M inactive memory
                534 M free memory
                 74 M buffer memory
               1223 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      lifetime oom required: 0 Mbytes
      total time in oom handler: 0 ms
      max time spent in oom handler: 0 ms
      *** FILESYSTEM ***
      /dev/root      ext4      220G  6.6G  204G   4% /
      devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     769M  9.0M  760M   2% /run
      none           tmpfs     1.9G  2.2M  1.9G   1% /tmp
      tmpfs          tmpfs     1.9G  104M  1.8G   6% /var/cache
      tmpfs          tmpfs     1.9G  200K  1.9G   1% /var/log
      tmpfs          tmpfs     1.9G     0  1.9G   0% /var/tmp
      /dev/sda1      vfat      255M   53M  203M  21% /boot
      tmpfs          tmpfs     385M     0  385M   0% /run/user/0
      [Tue Oct  3 18:37:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:37:E1:5F vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=66aa2880-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Oct  3 18:37:15 2023] EXT4-fs (sda2): mounted filesystem with writeback data mode. Quota mode: none.
      [Tue Oct  3 18:37:15 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Tue Oct  3 18:37:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime,nodiratime,discard,nobarrier,stripe=8191
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      421M	/var/
      316M	/var/lib
      158M	/var/lib/influxdb/engine
      154M	/var/lib/influxdb/engine/data/a9866606e533e3f8/autogen
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      29M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      439M	/opt/iobroker/iobroker-data/
      316M	/opt/iobroker/iobroker-data/files
      147M	/opt/iobroker/iobroker-data/files/vis-2
      75M	/opt/iobroker/iobroker-data/files/vis-2/static
      74M	/opt/iobroker/iobroker-data/files/vis-2/static/js
      46M	/opt/iobroker/iobroker-data/objects.jsonl
      33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
      19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.d3c12542.js.map
      17M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.b6e16d06.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.18.0
      /usr/bin/node 		v18.18.0
      /usr/bin/npm 		10.1.0
      /usr/bin/npx 		10.1.0
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    jsonl on 127.0.0.1
      States:                     jsonl on 127.0.0.1
      Core adapters versions
      js-controller: 	5.0.12
      admin: 		6.10.4
      javascript: 	7.1.4
      Adapters from github: 	1
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.admin.0                  : admin                 : app-server1.weinbrecht.lan               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.apsystems-ecu.0          : apsystems-ecu         : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.backitup.0               : backitup              : app-server1.weinbrecht.lan               -  enabled
        system.adapter.cloud.0                  : cloud                 : app-server1.weinbrecht.lan               - disabled
        system.adapter.feiertage.0              : feiertage             : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.influxdb.0               : influxdb              : app-server1.weinbrecht.lan               -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : app-server1.weinbrecht.lan               -  enabled
        system.adapter.iot.0                    : iot                   : app-server1.weinbrecht.lan               - disabled
      + system.adapter.javascript.0             : javascript            : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : app-server1.weinbrecht.lan               -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.sonoff.0                 : sonoff                : app-server1.weinbrecht.lan               -  enabled, port: 1883, bind: 192.168.174.12
      + system.adapter.telegram.0               : telegram              : app-server1.weinbrecht.lan               -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.tuya.0                   : tuya                  : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.vaillant.0               : vaillant              : app-server1.weinbrecht.lan               -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : app-server1.weinbrecht.lan               - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : app-server1.weinbrecht.lan               - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: app-server1.weinbrecht.lan               - disabled
      + system.adapter.vis-2.0                  : vis-2                 : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.web.0                    : web                   : app-server1.weinbrecht.lan               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wifilight.0              : wifilight             : app-server1.weinbrecht.lan               -  enabled
      + system.adapter.zigbee.0                 : zigbee                : app-server1.weinbrecht.lan               -  enabled, port: tcp://192.168.174.73:8888
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
      Adapter    "admin"        : 6.10.4   , installed 6.10.4
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.2    , installed 2.8.2
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 2.0.0    , installed 2.0.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "socketio"     : 6.5.6    , installed 6.5.6
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vaillant"     : 0.2.0    , installed 0.2.0
      Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
      Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
      Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
      Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
      Adapter    "web"          : 6.1.3    , installed 6.1.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.6    , installed 2.5.6
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects: 	6543
      States: 	6142
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.174.12:1883     0.0.0.0:*               LISTEN      1001       87078      8050/io.sonoff.0
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        944        320/systemd-resolve
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        950        320/systemd-resolve
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       62525      4511/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61674      4511/iobroker.js-co
      tcp        0      0 192.168.178.12:22       0.0.0.0:*               LISTEN      0          998        394/sshd: /usr/sbin
      tcp        0      0 192.168.178.12:80       0.0.0.0:*               LISTEN      0          13414      493/nginx: master p
      tcp        0      0 192.168.174.12:22       0.0.0.0:*               LISTEN      0          996        394/sshd: /usr/sbin
      tcp        0      0 192.168.178.12:443      0.0.0.0:*               LISTEN      0          13412      493/nginx: master p
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        13546      525/grafana
      tcp6       0      0 :::5355                 :::*                    LISTEN      102        947        320/systemd-resolve
      tcp6       0      0 fd00::da3a:ddff:fe3:443 :::*                    LISTEN      0          13413      493/nginx: master p
      tcp6       0      0 fd00::da3a:ddff:fe37:80 :::*                    LISTEN      0          13415      493/nginx: master p
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62602      4550/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       88461      8156/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      110        13436      466/influxd
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        949        320/systemd-resolve
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       78573      8014/io.mihome-vacu
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       88475      8084/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       88476      8084/io.tuya.0
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        943        320/systemd-resolve
      udp6       0      0 fe80::da3a:ddff:fe3:546 :::*                                101        481293     179/systemd-network
      udp6       0      0 :::5355                 :::*                                102        946        320/systemd-resolve
      2023-10-04 08:47:37.093  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
      2023-10-04 08:49:07.681  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
      2023-10-04 08:49:07.682  - error: zigbee.0 (49242) Failed to start Zigbee
      2023-10-04 08:49:07.683  - error: zigbee.0 (49242) Error herdsman start
      2023-10-04 08:49:17.685  - info: zigbee.0 (49242) Try to reconnect.
      2023-10-04 08:49:17.686  - info: zigbee.0 (49242) Starting Zigbee  npm ...
      2023-10-04 08:49:17.693  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
      2023-10-04 08:51:42.121  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
      2023-10-04 08:51:42.123  - error: zigbee.0 (49242) Failed to start Zigbee
      2023-10-04 08:51:42.124  - error: zigbee.0 (49242) Error herdsman start
      2023-10-04 08:51:52.129  - info: zigbee.0 (49242) Try to reconnect.
      2023-10-04 08:51:52.131  - info: zigbee.0 (49242) Starting Zigbee  npm ...
      2023-10-04 08:51:52.138  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
      2023-10-04 08:53:13.428  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
      2023-10-04 08:53:13.429  - error: zigbee.0 (49242) Failed to start Zigbee
      2023-10-04 08:53:13.430  - error: zigbee.0 (49242) Error herdsman start
      2023-10-04 08:53:23.432  - info: zigbee.0 (49242) Try to reconnect.
      2023-10-04 08:53:23.433  - info: zigbee.0 (49242) Starting Zigbee  npm ...
      2023-10-04 08:53:23.442  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
      2023-10-04 08:53:48.737  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
      2023-10-04 08:53:48.755  - error: zigbee.0 (49242) Failed to start Zigbee
      2023-10-04 08:53:48.756  - error: zigbee.0 (49242) Error herdsman start
      2023-10-04 08:53:58.759  - info: zigbee.0 (49242) Try to reconnect.
      2023-10-04 08:53:58.760  - info: zigbee.0 (49242) Starting Zigbee  npm ...
      2023-10-04 08:53:58.777  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      		     v.2023-06-20
               Icon name: computer
            Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		0
      X-Server: 		false
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
      			/usr/bin/npm 		10.1.0
      			/usr/bin/npx 		10.1.0
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            3.8G        2.1G        456M        114M        1.3G        1.6G
      Swap:             0B          0B          0B
      Total:          3.8G        2.1G        456M
      Active iob-Instances: 	21
      ioBroker Core: 		js-controller 		5.0.12
      			admin 			6.10.4
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		6543
      States: 		6142
      Size of iob-Database:
      9.6M	/opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      arteckA ? 2 Antworten Letzte Antwort
        iob diag
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=32.6'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        root
        /root
        root
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                 3843 M total memory
                 2010 M used memory
                  534 M free memory
                   74 M buffer memory
                 1223 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        421M	/var/
        316M	/var/lib
        /usr/bin/npm 		10.1.0
        /usr/bin/npx 		10.1.0
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.10.4
        javascript: 	7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	6543
        States: 	6142
        Pending Updates: 0
        		     v.2023-06-20
                 Icon name: computer
              Architecture: arm64
        Kernel: 		aarch64
        Userland: 		arm64
        User-ID: 		0
        X-Server: 		false
        			/usr/bin/npm 		10.1.0
        			/usr/bin/npx 		10.1.0
        MEMORY:
        Swap:             0B          0B          0B
        			admin 			6.10.4
        Objects type: jsonl
        States  type: jsonl
        Objects: 		6543
        States: 		6142
        arteckA Offline
        arteckA Offline
        arteck
        @papa_aus_rastatt
        • arteckA arteck
          @papa_aus_rastatt
          @arteck Ich habe scheinbar die Anleitung nicht richtig verstanden. In was müsste das geändert werden?
          https://zigbee.blakadder.com/Sonoff_ZBBridge-P.html
            iob diag
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : arm64
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=32.6'C
            volt=0.9360V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            root
            /root
            root
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     3843 M total memory
                     2010 M used memory
                      534 M free memory
                       74 M buffer memory
                     1223 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            421M	/var/
            316M	/var/lib
            /usr/bin/npm 		10.1.0
            /usr/bin/npx 		10.1.0
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		6.10.4
            javascript: 	7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	6543
            States: 	6142
            Pending Updates: 0
            		     v.2023-06-20
                     Icon name: computer
                  Architecture: arm64
            Kernel: 		aarch64
            Userland: 		arm64
            User-ID: 		0
            X-Server: 		false
            			/usr/bin/npm 		10.1.0
            			/usr/bin/npx 		10.1.0
            MEMORY:
            Swap:             0B          0B          0B
            			admin 			6.10.4
            Objects type: jsonl
            States  type: jsonl
            Objects: 		6543
            States: 		6142
            @papa_aus_rastatt sagte in Anleitung Zigbee2MQTT Einrichtung im ioBroker:
            Moin,
            da ist einiges, was man verbessern könnte/muss.
            Es fehlt ein User, der nicht root ist, denn wenn Du mit root arbeitest, dann kann man ganz schnell mal ungewollt etwas zerschießen, also leg Dir einen persönlichen User an, installier sudo und gib Deinem persönlichen User, zusätzlich die Gruppen sudo und iobroker.
            root
            /root
            root
            Memory ist aktuell noch kein Problem, könnte aber zu einem werden, wenn Du Dein System ausbaust.
            *** MEMORY ***
            Ansonsten sehe ich da erst einmal nichts, was auf Probleme hinsichtlich zigbee hindeuten würde.
            VG
            Bernd
              Moin,
              wollte ich gestern schon, anmerken, hab es im Trubel aber verpennt.
              VG
              Bernd
              Edit
              hatte heute Morgen wohl zittrige Hände, oder den Schlaf noch nicht aus den Augen gerieben, falsches Bild, ersetzt, siehe auch Beitrag https://forum.iobroker.net/topic/68795/anleitung-zigbee2mqtt-einrichtung-im-iobroker/21?_=1696399590830 von @arteck
              • arteckA Offline
                arteckA Offline
                arteck
                änder das mal nach ezsp und im adapter auch..aus meinem ersten screenshot..
                der Sender muss zum adaptereinstellung passen.. da der Coordinator mehrere simulieren kann. musst du schauen..
                am besten .. was wir im Adapter haben. und dann im coordinator einstellen
                zigate würde auch gehen... dann bei uns auch zigate einstellen
                • arteckA arteck
                  @arteck
                  ezsp dürfte auch nicht gehen, ich habe hier ja die PRO-Ausführung, nicht die normale.
                  https://zigbee.blakadder.com/Sonoff_ZBBridge.html
