  4. Anleitung Zigbee2MQTT Einrichtung im ioBroker
    5.1k
28 Beiträge 5 Kommentatoren 16.6k Aufrufe 3 Beobachtet
  • arteckA arteck
    @papa_aus_rastatt sagte in Anleitung Zigbee2MQTT Einrichtung im ioBroker:
    Starting zigbee-herdsman problem : "Failed to initialize NV memory item (id=3, name=STARTUP_OPTION, len=1, status=0)"
    der kann den Spcicher nicht initialisieren .. warum auch immer
    @arteck Guten morgen,
    ich hab den Debug gerade mal ausgeschnitten:
    2023-10-04 07:08:26.755	info	Try to reconnect.
    2023-10-04 07:08:16.750	error	Error herdsman start
    2023-10-04 07:08:16.749	error	Failed to start Zigbee
    2023-10-04 07:08:16.748	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    2023-10-04 07:08:10.595	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    2023-10-04 07:08:10.594	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    2023-10-04 07:08:04.592	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    2023-10-04 07:08:04.591	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    2023-10-04 07:07:58.588	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
    2023-10-04 07:07:58.586	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
    2023-10-04 07:07:58.584	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
    2023-10-04 07:07:57.579	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
    2023-10-04 07:07:57.578	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
    2023-10-04 07:07:57.576	debug	zigbee-herdsman:adapter:zStack:znp:log Socket ready
    2023-10-04 07:07:57.575	debug	zigbee-herdsman:adapter:zStack:znp:log Socket connected
    2023-10-04 07:07:57.572	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_04-07_07_56.tar.gz success
    2023-10-04 07:07:57.092	info	Installed Version: iobroker.zigbee@1.8.24
    2023-10-04 07:07:57.086	debug	zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.174.73:8888
    2023-10-04 07:07:57.084	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.174.73:8888","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
    2023-10-04 07:07:56.769	debug	Starting zigbee-herdsman...
    2023-10-04 07:07:56.727	info	Starting Zigbee npm ...
    2023-10-04 07:07:56.724	info	delete old Backup files. keep only last 10
    2023-10-04 07:07:56.637	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.174.73:8888","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":true}}
    2023-10-04 07:07:56.580	info	starting. Version 1.8.24 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.0, js-controller: 5.0.12
    2023-10-04 07:07:56.041	debug	Plugin sentry Initialize Plugin (enabled=true)
    bin für Vorschläge dankbar.
    • ? Offline
      Moin,
      kannst Du auch noch den langen Output posten, von
      iob diag
      Bernd
        Moin,
        iob diag
        Bernd
        @dp20eic ja natürlich, kannst etwas spezifieren, was dich genau interressiert?
        • arteckA Offline
          arteckA Offline
          arteck
          tue uns beiden den gefallen und mach nur das was wir dir sagen egal obs plausiebel für dich ist oder nicht (von debug war nie die Rede)
          wenn @dp20eic langen Output will dann zeigmal ALLES was das iob diag liefert
          ich will die Adapter Einstellungen als screensot sehen..ja alles
          hast den umgestellt ??
          • arteckA arteck
            @arteck du meinst so?
            iob diag
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the  characters at start and end.
            It helps us to help you!
            Press any key to continue
            Skript v.2023-06-20
            *** BASE SYSTEM ***
               Static hostname: app-server1.weinbrecht.lan
                     Icon name: computer
                    Machine ID: f699c63377c1419dbac4c0c664f4b780
                       Boot ID: 2dad0456cb654f80b695eb65355ad96e
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.54-v8+
                  Architecture: arm64
            Model		: Raspberry Pi 4 Model B Rev 1.5
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             08:53:22 up 14:16,  1 user,  load average: 0.36, 0.46, 0.50
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=32.6'C
            volt=0.9360V
            *** Time and Time Zones ***
                           Local time: Wed 2023-10-04 08:53:22 CEST
                       Universal time: Wed 2023-10-04 06:53:22 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            Boot Target: 	multi-user.target
            *** MEMORY ***
            Mem:            3.8G        2.0G        534M        114M        1.3G        1.7G
            Swap:             0B          0B          0B
            Total:          3.8G        2.0G        534M
                     3843 M total memory
                     2010 M used memory
                     2643 M active memory
                      476 M inactive memory
                      534 M free memory
                       74 M buffer memory
                     1223 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4      220G  6.6G  204G   4% /
            devtmpfs       devtmpfs  1.9G     0  1.9G   0% /dev
            tmpfs          tmpfs     769M  9.0M  760M   2% /run
            none           tmpfs     1.9G  2.2M  1.9G   1% /tmp
            tmpfs          tmpfs     1.9G  104M  1.8G   6% /var/cache
            tmpfs          tmpfs     1.9G  200K  1.9G   1% /var/log
            tmpfs          tmpfs     1.9G     0  1.9G   0% /var/tmp
            /dev/sda1      vfat      255M   53M  203M  21% /boot
            tmpfs          tmpfs     385M     0  385M   0% /run/user/0
            [Tue Oct  3 18:37:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=D8:3A:DD:37:E1:5F vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=66aa2880-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue Oct  3 18:37:15 2023] EXT4-fs (sda2): mounted filesystem with writeback data mode. Quota mode: none.
            [Tue Oct  3 18:37:15 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Tue Oct  3 18:37:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
            TARGET  SOURCE    FSTYPE OPTIONS
            /       /dev/sda2 ext4   rw,noatime,nodiratime,discard,nobarrier,stripe=8191
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            421M	/var/
            316M	/var/lib
            158M	/var/lib/influxdb/engine
            154M	/var/lib/influxdb/engine/data/a9866606e533e3f8/autogen
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            29M	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            439M	/opt/iobroker/iobroker-data/
            316M	/opt/iobroker/iobroker-data/files
            147M	/opt/iobroker/iobroker-data/files/vis-2
            75M	/opt/iobroker/iobroker-data/files/vis-2/static
            74M	/opt/iobroker/iobroker-data/files/vis-2/static/js
            46M	/opt/iobroker/iobroker-data/objects.jsonl
            33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.9aab3e1f.js.map
            19M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.d3c12542.js.map
            17M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.b6e16d06.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs 	v18.18.0
            /usr/bin/node 		v18.18.0
            /usr/bin/npm 		10.1.0
            /usr/bin/npx 		10.1.0
            nodejs:
              Installed: 18.18.0-1nodesource1
              Candidate: 18.18.0-1nodesource1
              Version table:
             *** 18.18.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            No configuration change needed.
            Multihost discovery server: disabled
            Discovery authentication:   enabled
            Persistent activation:      disabled
            Objects:                    jsonl on 127.0.0.1
            States:                     jsonl on 127.0.0.1
            Core adapters versions
            admin: 		6.10.4
            javascript: 	7.1.4
            Adapters from github: 	1
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.admin.0                  : admin                 : app-server1.weinbrecht.lan               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.apsystems-ecu.0          : apsystems-ecu         : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.backitup.0               : backitup              : app-server1.weinbrecht.lan               -  enabled
              system.adapter.cloud.0                  : cloud                 : app-server1.weinbrecht.lan               - disabled
              system.adapter.feiertage.0              : feiertage             : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.influxdb.0               : influxdb              : app-server1.weinbrecht.lan               -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : app-server1.weinbrecht.lan               -  enabled
              system.adapter.iot.0                    : iot                   : app-server1.weinbrecht.lan               - disabled
            + system.adapter.javascript.0             : javascript            : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : app-server1.weinbrecht.lan               -  enabled, port: 54321
            + system.adapter.modbus.0                 : modbus                : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.sonoff.0                 : sonoff                : app-server1.weinbrecht.lan               -  enabled, port: 1883, bind: 192.168.174.12
            + system.adapter.telegram.0               : telegram              : app-server1.weinbrecht.lan               -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.tuya.0                   : tuya                  : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.vaillant.0               : vaillant              : app-server1.weinbrecht.lan               -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : app-server1.weinbrecht.lan               - disabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : app-server1.weinbrecht.lan               - disabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: app-server1.weinbrecht.lan               - disabled
            + system.adapter.vis-2.0                  : vis-2                 : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.web.0                    : web                   : app-server1.weinbrecht.lan               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wifilight.0              : wifilight             : app-server1.weinbrecht.lan               -  enabled
            + system.adapter.zigbee.0                 : zigbee                : app-server1.weinbrecht.lan               -  enabled, port: tcp://192.168.174.73:8888
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
            Adapter    "admin"        : 6.10.4   , installed 6.10.4
            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
            Adapter    "backitup"     : 2.8.2    , installed 2.8.2
            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
            Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
            Adapter    "info"         : 2.0.0    , installed 2.0.0
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
            Controller "js-controller": 5.0.12   , installed 5.0.12
            Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
            Adapter    "modbus"       : 5.0.11   , installed 5.0.11
            Adapter    "socketio"     : 6.5.6    , installed 6.5.6
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
            Adapter    "tuya"         : 3.14.2   , installed 3.14.2
            Adapter    "vaillant"     : 0.2.0    , installed 0.2.0
            Adapter    "vis-2"        : 2.3.0    , installed 2.3.0
            Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
            Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
            Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
            Adapter    "web"          : 6.1.3    , installed 6.1.3
            Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
            Adapter    "ws"           : 2.5.6    , installed 2.5.6
            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
            Objects and States
            Objects: 	6543
            States: 	6142
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 192.168.174.12:1883     0.0.0.0:*               LISTEN      1001       87078      8050/io.sonoff.0
            tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        944        320/systemd-resolve
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        950        320/systemd-resolve
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       62525      4511/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61674      4511/iobroker.js-co
            tcp        0      0 192.168.178.12:22       0.0.0.0:*               LISTEN      0          998        394/sshd: /usr/sbin
            tcp        0      0 192.168.178.12:80       0.0.0.0:*               LISTEN      0          13414      493/nginx: master p
            tcp        0      0 192.168.174.12:22       0.0.0.0:*               LISTEN      0          996        394/sshd: /usr/sbin
            tcp        0      0 192.168.178.12:443      0.0.0.0:*               LISTEN      0          13412      493/nginx: master p
            tcp6       0      0 :::3000                 :::*                    LISTEN      111        13546      525/grafana
            tcp6       0      0 :::5355                 :::*                    LISTEN      102        947        320/systemd-resolve
            tcp6       0      0 fd00::da3a:ddff:fe3:443 :::*                    LISTEN      0          13413      493/nginx: master p
            tcp6       0      0 fd00::da3a:ddff:fe37:80 :::*                    LISTEN      0          13415      493/nginx: master p
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62602      4550/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       88461      8156/io.web.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      110        13436      466/influxd
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        949        320/systemd-resolve
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       78573      8014/io.mihome-vacu
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       88475      8084/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       88476      8084/io.tuya.0
            udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        943        320/systemd-resolve
            udp6       0      0 fe80::da3a:ddff:fe3:546 :::*                                101        481293     179/systemd-network
            udp6       0      0 :::5355                 :::*                                102        946        320/systemd-resolve
            2023-10-04 08:47:37.093  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
            2023-10-04 08:49:07.681  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
            2023-10-04 08:49:07.682  - error: zigbee.0 (49242) Failed to start Zigbee
            2023-10-04 08:49:07.683  - error: zigbee.0 (49242) Error herdsman start
            2023-10-04 08:49:17.685  - info: zigbee.0 (49242) Try to reconnect.
            2023-10-04 08:49:17.686  - info: zigbee.0 (49242) Starting Zigbee  npm ...
            2023-10-04 08:49:17.693  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
            2023-10-04 08:51:42.121  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
            2023-10-04 08:51:42.123  - error: zigbee.0 (49242) Failed to start Zigbee
            2023-10-04 08:51:42.124  - error: zigbee.0 (49242) Error herdsman start
            2023-10-04 08:51:52.129  - info: zigbee.0 (49242) Try to reconnect.
            2023-10-04 08:51:52.131  - info: zigbee.0 (49242) Starting Zigbee  npm ...
            2023-10-04 08:51:52.138  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
            2023-10-04 08:53:13.428  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
            2023-10-04 08:53:13.429  - error: zigbee.0 (49242) Failed to start Zigbee
            2023-10-04 08:53:13.430  - error: zigbee.0 (49242) Error herdsman start
            2023-10-04 08:53:23.432  - info: zigbee.0 (49242) Try to reconnect.
            2023-10-04 08:53:23.433  - info: zigbee.0 (49242) Starting Zigbee  npm ...
            2023-10-04 08:53:23.442  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
            2023-10-04 08:53:48.737  - error: zigbee.0 (49242) Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
            2023-10-04 08:53:48.755  - error: zigbee.0 (49242) Failed to start Zigbee
            2023-10-04 08:53:48.756  - error: zigbee.0 (49242) Error herdsman start
            2023-10-04 08:53:58.759  - info: zigbee.0 (49242) Try to reconnect.
            2023-10-04 08:53:58.760  - info: zigbee.0 (49242) Starting Zigbee  npm ...
            2023-10-04 08:53:58.777  - info: zigbee.0 (49242) Installed Version: iobroker.zigbee@1.8.24
            iob diag has finished.
            Press any key for a summary
            Copy text starting here:
            		     v.2023-06-20
                     Icon name: computer
                  Architecture: arm64
            Installation: 		native
            Kernel: 		aarch64
            Userland: 		arm64
            Timezone: 		Europe/Berlin (CEST, +0200)
            User-ID: 		0
            X-Server: 		false
            Pending OS-Updates: 	0
            Pending iob updates: 	0
            Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
            			/usr/bin/npm 		10.1.0
            			/usr/bin/npx 		10.1.0
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:            3.8G        2.1G        456M        114M        1.3G        1.6G
            Swap:             0B          0B          0B
            Total:          3.8G        2.1G        456M
            Active iob-Instances: 	21
            ioBroker Core: 		js-controller 		5.0.12
            			admin 			6.10.4
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            Objects: 		6543
            States: 		6142
            Size of iob-Database:
            9.6M	/opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
            arteckA ? 2 Antworten Letzte Antwort
              iob diag
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=32.6'C
              volt=0.9360V
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              root
              /root
              root
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                       3843 M total memory
                       2010 M used memory
                        534 M free memory
                         74 M buffer memory
                       1223 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              421M	/var/
              316M	/var/lib
              /usr/bin/npm 		10.1.0
              /usr/bin/npx 		10.1.0
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.10.4
              javascript: 	7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	6543
              States: 	6142
              Pending Updates: 0
              		     v.2023-06-20
                       Icon name: computer
                    Architecture: arm64
              Kernel: 		aarch64
              Userland: 		arm64
              User-ID: 		0
              X-Server: 		false
              			/usr/bin/npm 		10.1.0
              			/usr/bin/npx 		10.1.0
              MEMORY:
              Swap:             0B          0B          0B
              			admin 			6.10.4
              Objects type: jsonl
              States  type: jsonl
              Objects: 		6543
              States: 		6142
              arteckA Offline
              arteckA Offline
              arteck
              @papa_aus_rastatt
              • arteckA arteck
                @papa_aus_rastatt
                @arteck Ich habe scheinbar die Anleitung nicht richtig verstanden. In was müsste das geändert werden?
                https://zigbee.blakadder.com/Sonoff_ZBBridge-P.html
                  iob diag
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=32.6'C
                  volt=0.9360V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  root
                  /root
                  root
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:             0B          0B          0B
                           3843 M total memory
                           2010 M used memory
                            534 M free memory
                             74 M buffer memory
                           1223 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  421M	/var/
                  316M	/var/lib
                  /usr/bin/npm 		10.1.0
                  /usr/bin/npx 		10.1.0
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.10.4
                  javascript: 	7.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	6543
                  States: 	6142
                  Pending Updates: 0
                  		     v.2023-06-20
                           Icon name: computer
                        Architecture: arm64
                  Kernel: 		aarch64
                  Userland: 		arm64
                  User-ID: 		0
                  X-Server: 		false
                  			/usr/bin/npm 		10.1.0
                  			/usr/bin/npx 		10.1.0
                  MEMORY:
                  Swap:             0B          0B          0B
                  			admin 			6.10.4
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		6543
                  States: 		6142
                  Moin,
                  da ist einiges, was man verbessern könnte/muss.
                  Es fehlt ein User, der nicht root ist, denn wenn Du mit root arbeitest, dann kann man ganz schnell mal ungewollt etwas zerschießen, also leg Dir einen persönlichen User an, installier sudo und gib Deinem persönlichen User, zusätzlich die Gruppen sudo und iobroker.
                  root
                  /root
                  root
                  Memory ist aktuell noch kein Problem, könnte aber zu einem werden, wenn Du Dein System ausbaust.
                  *** MEMORY ***
                  Ansonsten sehe ich da erst einmal nichts, was auf Probleme hinsichtlich zigbee hindeuten würde.
                  Bernd
                    Moin,
                    wollte ich gestern schon, anmerken, hab es im Trubel aber verpennt.
                    Bernd
                    Edit
                    hatte heute Morgen wohl zittrige Hände, oder den Schlaf noch nicht aus den Augen gerieben, falsches Bild, ersetzt, siehe auch Beitrag https://forum.iobroker.net/topic/68795/anleitung-zigbee2mqtt-einrichtung-im-iobroker/21?_=1696399590830 von @arteck
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      änder das mal nach ezsp und im adapter auch..aus meinem ersten screenshot..
                      der Sender muss zum adaptereinstellung passen.. da der Coordinator mehrere simulieren kann. musst du schauen..
                      am besten .. was wir im Adapter haben. und dann im coordinator einstellen
                      zigate würde auch gehen... dann bei uns auch zigate einstellen
                      • arteckA arteck
                        @arteck
                        ezsp dürfte auch nicht gehen, ich habe hier ja die PRO-Ausführung, nicht die normale.
                        https://zigbee.blakadder.com/Sonoff_ZBBridge.html
