  4. FLOT nicht mehr aufrufbar - Warnung im Protokoll
    5.1k
60 Beiträge 3 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • K Keulehd
    @thomas-braun Gestartet. Gleicher Fehler
    iobroker@HomeServer:~$ iob start flot
    The adapter "flot.0" was started.
    iob diag:
    ======== Start marking the full check here =========
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: HomeServer
             Icon name: computer-desktop
               Chassis: desktop
            Machine ID: 1592eab9854d408bb2ffeca18adb4314
               Boot ID: ea3d5faa73ee4ab1b51a8d42bc58c08d
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-26-amd64
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     11:50:58 up 5 min,  2 users,  load average: 1.96, 2.35, 1.20
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-10-02 11:50:58 CEST
               Universal time: Mon 2023-10-02 09:50:58 UTC
                     RTC time: Mon 2023-10-02 09:50:58
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout sudo audio video bluetooth
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        3.1G        3.7G        3.0M        1.0G        4.5G
    Swap:           976M          0B        976M
    Total:          8.8G        3.1G        4.7G
             7862 M total memory
             3123 M used memory
              419 M active memory
             3379 M inactive memory
             3697 M free memory
               69 M buffer memory
              971 M swap cache
              976 M total swap
                0 M used swap
              976 M free swap
    *** FILESYSTEM ***
    Filesystem                              Type      Size  Used Avail Use% Mounted on
    udev                                    devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                                   tmpfs     787M  1.5M  785M   1% /run
    /dev/sda5                               ext4      135G   37G   92G  29% /
    tmpfs                                   tmpfs     3.9G   16K  3.9G   1% /dev/shm
    tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                               vfat       96M   33M   64M  34% /boot/efi
    tmpfs                                   tmpfs     787M   96K  787M   1% /run/user/1001
    192.168.100.143:/mnt/pools/A/A0/Kameras nfs       5.4T  2.5T  3.0T  45% /media/nas
    [Mon Oct  2 11:45:11 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct  2 11:45:16 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
    Show mounted filesystems (real ones only):
    TARGET       SOURCE                                  FSTYPE OPTIONS
    /            /dev/sda5                               ext4   rw,relatime,errors=remount-ro
    |-/boot/efi  /dev/sda1                               vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    `-/media/nas 192.168.100.143:/mnt/pools/A/A0/Kameras nfs    rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,soft,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.100.143,mountvers=3,mountport=895,mountproto=udp,local_lock=all,addr=192.168.100.143
    /var:
    28G     /var/
    26G     /var/lib/motioneye/Camera1
    26G     /var/lib
    7.2G    /var/lib/motioneye/Camera1/2023-06-10
    Archived and active journals take up 432.1M in the file system.
    /opt/iobroker/backups:
    94M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    494M    /opt/iobroker/iobroker-data/
    329M    /opt/iobroker/iobroker-data/files
    118M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/files/iot.admin/static
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.b86463fc.js.map
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
            500 http://deb.debian.org/debian bullseye-proposed-updates/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : HomeServer                               -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : HomeServer                               - disabled
    + system.adapter.alexa2.0                 : alexa2                : HomeServer                               -  enabled
    + system.adapter.backitup.0               : backitup              : HomeServer                               -  enabled
    + system.adapter.bring.0                  : bring                 : HomeServer                               -  enabled
    + system.adapter.cloud.0                  : cloud                 : HomeServer                               -  enabled
      system.adapter.daswetter.0              : daswetter             : HomeServer                               -  enabled
    + system.adapter.discovery.0              : discovery             : HomeServer                               -  enabled
      system.adapter.dwd.0                    : dwd                   : HomeServer                               -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : HomeServer                               -  enabled
      system.adapter.feiertage.0              : feiertage             : HomeServer                               -  enabled
      system.adapter.flot.0                   : flot                  : HomeServer                               -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : HomeServer                               -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : HomeServer                               -  enabled
    + system.adapter.govee.0                  : govee                 : HomeServer                               -  enabled
    + system.adapter.heizoel.0                : heizoel               : HomeServer                               -  enabled
    + system.adapter.history.0                : history               : HomeServer                               -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : HomeServer                               -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : HomeServer                               -  enabled
    + system.adapter.hue.0                    : hue                   : HomeServer                               -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : HomeServer                               -  enabled
      system.adapter.ical.1                   : ical                  : HomeServer                               -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : HomeServer                               -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeServer                               - disabled
    + system.adapter.info.0                   : info                  : HomeServer                               -  enabled
    + system.adapter.iot.0                    : iot                   : HomeServer                               -  enabled
    + system.adapter.javascript.0             : javascript            : HomeServer                               -  enabled
    + system.adapter.linux-control.0          : linux-control         : HomeServer                               -  enabled
    + system.adapter.mediola-gateway.0        : mediola-gateway       : HomeServer                               -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : HomeServer                               -  enabled
      system.adapter.mobile.0                 : mobile                : HomeServer                               - disabled
    + system.adapter.netatmo.0                : netatmo               : HomeServer                               -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : HomeServer                               -  enabled
    + system.adapter.nuki.0                   : nuki                  : HomeServer                               -  enabled
    + system.adapter.nut.0                    : nut                   : HomeServer                               -  enabled
    + system.adapter.parcel.0                 : parcel                : HomeServer                               -  enabled
    + system.adapter.ping.0                   : ping                  : HomeServer                               -  enabled
      system.adapter.scenes.0                 : scenes                : HomeServer                               - disabled
      system.adapter.scheduler.0              : scheduler             : HomeServer                               - disabled
    + system.adapter.shelly.0                 : shelly                : HomeServer                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : HomeServer                               -  enabled
    + system.adapter.simple-api.0             : simple-api            : HomeServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeServer                               -  enabled
    + system.adapter.telegram.0               : telegram              : HomeServer                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : HomeServer                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : HomeServer                               -  enabled
    + system.adapter.tr-064.0                 : tr-064                : HomeServer                               -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : HomeServer                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : HomeServer                               -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : HomeServer                               -  enabled
      system.adapter.velux.0                  : velux                 : HomeServer                               - disabled
      system.adapter.viessmannapi.0           : viessmannapi          : HomeServer                               - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeServer                               - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeServer                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeServer                               - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : HomeServer                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeServer                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeServer                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : HomeServer                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomeServer                               - disabled
      system.adapter.vis-weather.0            : vis-weather           : HomeServer                               - disabled
      system.adapter.vis.0                    : vis                   : HomeServer                               -  enabled
    + system.adapter.web.0                    : web                   : HomeServer                               -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : HomeServer                               -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeServer                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : HomeServer                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b6218f1c57c9eb118db68d4f1d69213e-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    live          : http://iobroker.live/repo/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.10.0   , installed 3.10.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 2.0.3
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "parcel"       : 0.0.27   , installed 0.0.30
    Adapter    "scenes"       : 2.3.9    , installed 2.3.9
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
    Adapter    "velux"        : 0.0.7    , installed 0.0.7
    Adapter    "viessmannapi" : 2.0.9    , installed 2.1.1
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        16242
    States:         13943
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12279      1/init
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16022      834/motion
    tcp        0      0 192.168.100.146:42129   0.0.0.0:*               LISTEN      1001       21113      1384/rygel
    tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16023      834/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14934      544/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15272      512/cupsd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       24838      2114/io.shelly.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        17746      514/monocle-gateway
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16980      463/python2
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16024      834/motion
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16996      865/upsd
    tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          16995      865/upsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20671      513/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18814      513/iobroker.js-con
    tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17156      962/monocle-proxy
    tcp        0      0 127.0.0.1:36939         0.0.0.0:*               LISTEN      1001       20404      1384/rygel
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        17745      514/monocle-gateway
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12283      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          15641      545/apache2
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       28210      3484/io.web.0
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       23684      1195/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14936      544/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30799      3346/io.simple-api.
    tcp6       0      0 ::1:45495               :::*                    LISTEN      1001       20407      1384/rygel
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15271      512/cupsd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       32583      4162/io.terminal.0
    tcp6       0      0 :::20002                :::*                    LISTEN      1001       33199      4201/io.web.1
    tcp6       0      0 fe80::921b:eff:fe:43939 :::*                    LISTEN      1001       19167      1384/rygel
    tcp6       0      0 :::36235                :::*                    LISTEN      1001       21093      1499/apache2
    tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20286      1382/gnome-remote-d
    udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       20300      1384/rygel
    udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       20299      1384/rygel
    udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       20295      1384/rygel
    udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       20294      1384/rygel
    udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       31987      3645/io.mediola-gat
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       23912      2189/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       23913      2189/io.tuya.0
    udp        0      0 127.0.0.1:52497         0.0.0.0:*                           1001       20297      1384/rygel
    udp        0      0 192.168.100.146:36627   0.0.0.0:*                           1001       20302      1384/rygel
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12280      1/init
    udp        0      0 0.0.0.0:57463           0.0.0.0:*                           110        13882      449/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15290      622/cups-browsed
    udp        0      0 0.0.0.0:33641           0.0.0.0:*                           1001       31988      3645/io.mediola-gat
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        13880      449/avahi-daemon: r
    udp6       0      0 ::1:1900                :::*                                1001       20305      1384/rygel
    udp6       0      0 ff05::c:1900            :::*                                1001       20306      1384/rygel
    udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       20311      1384/rygel
    udp6       0      0 ff02::c:1900            :::*                                1001       20312      1384/rygel
    udp6       0      0 fe80::921b:eff:fe:44267 :::*                                1001       20314      1384/rygel
    udp6       0      0 ::1:45064               :::*                                1001       20308      1384/rygel
    udp6       0      0 :::111                  :::*                                0          12286      1/init
    udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15778      460/NetworkManager
    udp6       0      0 :::37900                :::*                                110        13883      449/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                110        13881      449/avahi-daemon: r
    2023-10-02 11:50:07.121  - info: tvspielfilm.0 (4181) objects written
    2023-10-02 11:50:07.639  - info: web.1 (4201) socket.io server listening on port 20002
    2023-10-02 11:50:07.641  - info: web.1 (4201) http server listening on port 20002
    2023-10-02 11:50:08.453  - info: daswetter.0 (4113) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-10-02 11:50:08.965  - info: daswetter.0 (4113) cleaned everything up...
    2023-10-02 11:50:09.005  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-02 11:50:17.628  - info: tvspielfilm.0 (4181) Terminated (NO_ERROR): Without reason
    2023-10-02 11:50:18.147  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2023-10-02 11:50:22.093  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Schlafzimmer value: 2%
    2023-10-02 11:50:32.126  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Gästezimmer value: 2%
    2023-10-02 11:50:42.146  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Treppenhaus value: 2%
    2023-10-02 11:50:45.744  - info: host.HomeServer stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
    2023-10-02 11:50:45.747  - info: nuki-extended.0 (2068) Got terminate signal TERMINATE_YOURSELF
    2023-10-02 11:50:45.748  - info: nuki-extended.0 (2068) Adapter stopped und unloaded.
    2023-10-02 11:50:45.749  - info: nuki-extended.0 (2068) terminating
    2023-10-02 11:50:45.750  - info: nuki-extended.0 (2068) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-02 11:50:45.788  - info: host.HomeServer stopInstance system.adapter.nuki-extended.0 send kill signal
    2023-10-02 11:50:46.252  - info: nuki-extended.0 (2068) terminating
    2023-10-02 11:50:46.325  - info: host.HomeServer instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-02 11:50:48.879  - info: host.HomeServer instance system.adapter.nuki-extended.0 started with pid 4260
    2023-10-02 11:50:49.804  - info: nuki-extended.0 (4260) starting. Version 2.6.5 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v18.18.0, js-controller: 5.0.12
    2023-10-02 11:50:49.892  - info: nuki-extended.0 (4260) Polling Nuki Web API with a frequency of 60s.
    2023-10-02 11:51:12.174  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Wohnzimmer rechts value: 2%
    2023-10-02 11:51:22.187  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Küche links value: 2%
    2023-10-02 11:51:31.084  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
    #41
    @keulehd
    Meld dich mit einem andern User an. Es gibt noch einen mit der uid=1000auf dem System. Nimm den.
    • K Keulehd
      iob diag:
      Skript v.2023-06-20
      *** BASE SYSTEM ***
                 Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      iobroker
      /home/iobroker
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           976M          0B        976M
               7862 M total memory
               3123 M used memory
                419 M active memory
               3697 M free memory
                 69 M buffer memory
                971 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FILESYSTEM ***
      /var:
      28G     /var/
      26G     /var/lib
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16242
      States:         13943
      Pending Updates: 0
      #42
      @keulehd
      Und schalt den Desktop aus.
      sudo systemctl set-default multi-user.target
      sudo systemctl iosolate multi-user.target
      K 1 Antwort Letzte Antwort
        @keulehd
        Keulehd
        #43
        Mit den anderen beiden Usern kann ich mich nicht anmelden obwohl die Passwörter korrekt sein müssen. Sagt immer falsches Kennwort
        Abschaltung Desktop hat der erste Befehl funktioniert. Bei dem zweiten kommt:
        iobroker@HomeServer:~$ sudo systemctl iosolate multi-user.target
        Unknown command verb iosolate.
        • K Keulehd
          #44
          @keulehd
          sudo systemctl isolate multi-user.target
          Und das mit den Usern würde mir zu denken geben...
          Setz ein neues Passwort.
          sudo passwd Username
            @keulehd
            Keulehd
            #45
            @thomas-braun Danke. Isolate hat funktioniert
            Mir sind nur 2 User bekannt. Den PC hab ich ja selbst aufgesetzt. Passwort ändern aber nicht möglich
            iobroker@HomeServer:~$ sudo passwd Daniel
            passwd: Benutzer »Daniel« ist nicht vorhanden.
            iobroker@HomeServer:~$ sudo passwd Remote
            passwd: Benutzer »Remote« ist nicht vorhanden.
            • Thomas BraunT Online
              #46
              @keulehd
              In
              cat /etc/passwd | sort
              stehen die User drin
                @keulehd
                In
                Keulehd
                #47
                iobroker@HomeServer:~$ cat /etc/passwd | sort
                _apt❌100:65534::/nonexistent:/usr/sbin/nologin
                avahi❌110:116:Avahi mDNS daemon,,,:/run/avahi-daemon:/usr/sbin/nologin
                backup❌34:34:backup:/var/backups:/usr/sbin/nologin
                bin❌2:2:bin:/bin:/usr/sbin/nologin
                colord❌114:122:colord colour management daemon,,,:/var/lib/colord:/usr/sbin/nologin
                daemon❌1:1:daemon:/usr/sbin:/usr/sbin/nologin
                daniel❌1000:1000:Daniel Hoffmann,,,:/home/daniel:/bin/bash
                Debian-gdm❌116:124:Gnome Display Manager:/var/lib/gdm3:/bin/false
                dnsmasq❌109:65534:dnsmasq,,,:/var/lib/misc:/usr/sbin/nologin
                games❌5:60:games:/usr/games:/usr/sbin/nologin
                geoclue❌115:123::/var/lib/geoclue:/usr/sbin/nologin
                gnats❌41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
                iobroker❌1001:1001:iobroker,,,:/home/iobroker:/bin/bash
                irc❌39:39:ircd:/run/ircd:/usr/sbin/nologin
                lightdm❌119:125:Light Display Manager:/var/lib/lightdm:/bin/false
                list❌38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
                lp❌7:7:lp:/var/spool/lpd:/usr/sbin/nologin
                mail❌8:8:mail:/var/mail:/usr/sbin/nologin
                man❌6:12:man:/var/cache/man:/usr/sbin/nologin
                messagebus❌104:110::/nonexistent:/usr/sbin/nologin
                monocle❌998:998::/home/monocle:/bin/sh
                motion❌120:126::/var/lib/motion:/usr/sbin/nologin
                news❌9:9:news:/var/spool/news:/usr/sbin/nologin
                nobody❌65534:65534:nobody:/nonexistent:/usr/sbin/nologin
                nut❌121:127::/var/lib/nut:/usr/sbin/nologin
                proxy❌13:13:proxy:/bin:/usr/sbin/nologin
                pulse❌112:118:PulseAudio daemon,,,:/run/pulse:/usr/sbin/nologin
                remote❌1002:1002:Remote,,,:/home/remote:/bin/bash
                root❌0:0:root:/root:/bin/bash
                _rpc❌117:65534::/run/rpcbind:/usr/sbin/nologin
                rtkit❌107:115:RealtimeKit,,,:/proc:/usr/sbin/nologin
                saned❌113:121::/var/lib/saned:/usr/sbin/nologin
                speech-dispatcher❌111:29:Speech Dispatcher,,,:/run/speech-dispatcher:/bin/false
                sshd❌108:65534::/run/sshd:/usr/sbin/nologin
                statd❌118:65534::/var/lib/nfs:/usr/sbin/nologin
                sync❌4:65534:sync:/bin:/bin/sync
                systemd-coredump❌999:999:systemd Core Dumper:/:/usr/sbin/nologin
                systemd-network❌101:102:systemd Network Management,,,:/run/systemd:/usr/sbin/nologin
                systemd-resolve❌102:103:systemd Resolver,,,:/run/systemd:/usr/sbin/nologin
                systemd-timesync❌105:111:systemd Time Synchronization,,,:/run/systemd:/usr/sbin/nologin
                sys❌3:3:sys:/dev:/usr/sbin/nologin
                tss❌103:109:TPM software stack,,,:/var/lib/tpm:/bin/false
                usbmux❌106:46:usbmux daemon,,,:/var/lib/usbmux:/usr/sbin/nologin
                uucp❌10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
                www-data❌33:33:www-data:/var/www:/usr/sbin/nologin
                Ja genau. Daniel und Remote. Aber es lassen sich keine Passwörter ändern bzw. setzen. Alles sehr suspekt
                • K Keulehd
                  #48
                  @keulehd sagte in FLOT nicht mehr aufrufbar - Warnung im Protokoll:
                  Richtig, der heißt ja auch 'daniel'
                    Keulehd
                    #49
                    @thomas-braun Wer lesen kann ist klar im Vorteil. Sorry :-(
                    iobroker@HomeServer:~$ sudo passwd daniel
                    Geben Sie ein neues Passwort ein:
                    Geben Sie das neue Passwort erneut ein:
                    passwd: Passwort erfolgreich geändert
                    iob diag mit User "daniel":
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                               Chassis: desktop
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     12:20:21 up 35 min,  2 users,  load average: 1.70, 1.33, 1.42
                    CPU threads: 4
                                   Local time: Mon 2023-10-02 12:20:21 CEST
                               Universal time: Mon 2023-10-02 10:20:21 UTC
                                     RTC time: Mon 2023-10-02 10:20:21
                                  NTP service: active
                              RTC in local TZ: no
                    daniel
                    /home/daniel
                    daniel cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            7.9G        3.3G        2.9G        1.0M        1.7G        4.3G
                    Swap:           976M          0B        976M
                    Total:          8.8G        3.3G        3.9G
                             7862 M total memory
                             3259 M used memory
                              625 M active memory
                             3517 M inactive memory
                             2890 M free memory
                              196 M buffer memory
                             1516 M swap cache
                              976 M total swap
                                0 M used swap
                              976 M free swap
                    *** FILESYSTEM ***
                    tmpfs                                   tmpfs     787M  1.3M  785M   1% /run
                    tmpfs                                   tmpfs     787M   76K  787M   1% /run/user/1000
                    /var:
                    28G     /var/
                    26G     /var/lib
                    Archived and active journals take up 48.0M in the file system.
                    503M    /opt/iobroker/iobroker-data/
                    30M     /opt/iobroker/iobroker-data/states.jsonl
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.1
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        16242
                    States:         13909
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                    Pending Updates: 0
                    2023-10-02 12:15:13.459  - info: tvspielfilm.0 (8249) Terminated (NO_ERROR): Without reason
                    2023-10-02 12:15:13.973  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                    2023-10-02 12:15:16.553  - info: daswetter.0 (8685) still wrong data structure from server received! repaired...
                    2023-10-02 12:15:18.249  - info: daswetter.0 (8685) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                    2023-10-02 12:15:18.763  - info: daswetter.0 (8685) cleaned everything up...
                    2023-10-02 12:15:18.784  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-02 12:16:05.624  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                    2023-10-02 12:16:35.704  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                    2023-10-02 12:17:05.780  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                    2023-10-02 12:17:24.481  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
                    2023-10-02 12:17:35.865  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                    2023-10-02 12:17:36.155  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Velux Dachfenster value: 0%
                    2023-10-02 12:18:05.952  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                    2023-10-02 12:18:36.057  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
                    2023-10-02 12:20:00.044  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 8895
                    2023-10-02 12:20:00.880  - info: dwd.0 (8895) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
                    2023-10-02 12:20:01.817  - info: dwd.0 (8895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-10-02 12:20:02.347  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-10-02 12:20:04.074  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 8914
                    2023-10-02 12:20:04.886  - info: tvspielfilm.0 (8914) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
                    2023-10-02 12:20:06.931  - info: tvspielfilm.0 (8914) objects written
                    2023-10-02 12:20:08.593  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
                    2023-10-02 12:20:10.921  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
                    2023-10-02 12:20:17.440  - info: tvspielfilm.0 (8914) Terminated (NO_ERROR): Without reason
                    2023-10-02 12:20:17.955  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                    • K Keulehd
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                                 Chassis: desktop
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 4
                                    NTP service: active
                                RTC in local TZ: no
                      daniel
                      /home/daniel
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:           976M          0B        976M
                               7862 M total memory
                               3259 M used memory
                                625 M active memory
                               2890 M free memory
                                196 M buffer memory
                               1516 M swap cache
                                976 M total swap
                                  0 M used swap
                                976 M free swap
                      *** FILESYSTEM ***
                      /var:
                      28G     /var/
                      26G     /var/lib
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.10.1
                      javascript:     7.1.4
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        16242
                      States:         13909
                      Pending Updates: 0
                      #50
                      @keulehd
                      Jetzt haust du den Daniel noch in die Gruppe 'adm' rein
                      sudo usermod -a -G adm daniel
                      Daniel danach ausloggen und wieder einloggen.
                        @keulehd
                        Keulehd
                        #51
                        @thomas-braun Erledigt
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                                   Chassis: desktop
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                         12:25:29 up 40 min,  2 users,  load average: 1.26, 1.26, 1.36
                        CPU threads: 4
                                       Local time: Mon 2023-10-02 12:25:29 CEST
                                   Universal time: Mon 2023-10-02 10:25:29 UTC
                                         RTC time: Mon 2023-10-02 10:25:29
                                      NTP service: active
                                  RTC in local TZ: no
                        daniel
                        /home/daniel
                        daniel adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.9G        3.2G        2.9G        1.0M        1.7G        4.3G
                        Swap:           976M          0B        976M
                        Total:          8.8G        3.2G        3.9G
                                 7862 M total memory
                                 3233 M used memory
                                  632 M active memory
                                 3487 M inactive memory
                                 2912 M free memory
                                  197 M buffer memory
                                 1519 M swap cache
                                  976 M total swap
                                    0 M used swap
                                  976 M free swap
                        *** FILESYSTEM ***
                        /var:
                        28G     /var/
                        26G     /var/lib
                        Archived and active journals take up 1008.3M in the file system.
                        504M    /opt/iobroker/iobroker-data/
                        31M     /opt/iobroker/iobroker-data/states.jsonl
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.10.1
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        16242
                        States:         13909
                        Pending Updates: 0
                        2023-10-02 12:21:36.628  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                        2023-10-02 12:22:06.679  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                        2023-10-02 12:22:24.473  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
                        2023-10-02 12:23:06.948  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
                        2023-10-02 12:24:07.108  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                        2023-10-02 12:25:00.066  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 10916
                        2023-10-02 12:25:00.974  - info: tvspielfilm.0 (10916) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
                        2023-10-02 12:25:03.015  - info: tvspielfilm.0 (10916) objects written
                        2023-10-02 12:25:04.095  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 10935
                        2023-10-02 12:25:04.951  - info: dwd.0 (10935) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
                        2023-10-02 12:25:05.514  - info: dwd.0 (10935) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2023-10-02 12:25:06.041  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2023-10-02 12:25:10.922  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
                        2023-10-02 12:25:13.082  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
                        2023-10-02 12:25:13.523  - info: tvspielfilm.0 (10916) Terminated (NO_ERROR): Without reason
                        2023-10-02 12:25:14.054  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                        2023-10-02 12:25:37.376  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                        • K Keulehd
                          Skript v.2023-06-20
                          *** BASE SYSTEM ***
                                     Chassis: desktop
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : amd64
                          CPU threads: 4
                                        NTP service: active
                                    RTC in local TZ: no
                          daniel
                          /home/daniel
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:           976M          0B        976M
                                   7862 M total memory
                                   3259 M used memory
                                    625 M active memory
                                   2890 M free memory
                                    196 M buffer memory
                                   1516 M swap cache
                                    976 M total swap
                                      0 M used swap
                                    976 M free swap
                          *** FILESYSTEM ***
                          /var:
                          28G     /var/
                          26G     /var/lib
                          /usr/bin/npm            9.8.1
                          /usr/bin/npx            9.8.1
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.10.1
                          javascript:     7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        16242
                          States:         13909
                          Pending Updates: 0
                          #52
                          @keulehd
                          Und in die Gruppe 'iobroker' würde ich den auch setzen. Und dann den User 'iobroker' in Ruhe lassen.
                            @keulehd
                            Keulehd
                            #53
                            @thomas-braun Auch erledigt
                            daniel@HomeServer:~$ sudo usermod -a -G iobroker daniel
                            Nur für mich: Hat das mit dem User "iobroker" einen bestimmten Grund ? Nur zum Verständnis. Danke Dir
                            • K Keulehd
                              #54
                              @keulehd
                              Der User iobroker ist eigentlich ein Systemuser (und bekommt in der Standardinstallation erst gar kein Login). Man rödelt mit einem eigenen User durch das System, bei dir halt mit dem 'daniel'.
                                @keulehd
                                Keulehd
                                #55
                                @thomas-braun Ah alles klar. Den iobroker hab ich bei der Installation angelegt aber spielt in dem Fall ja keine Rolle. System ist nun dank Dir stabil und einigermaßen sauber hergestellt. Danke Dir.
                                Nun mal schauen wegen FLOT: Weiß nur überhaupt nicht wo ich da anfangen soll. Dachte mit der zweiten web.1 Instanz geht es weil das Problem anscheinend schon etliche hatten und damit behoben haben aber bei mir geht das nicht.
                                • K Keulehd
                                  #56
                                  Das ist falsch, der wird vom iobroker-Installer angelegt. Und dann tickt der auch anders als jetzt dein 'iobroker'.
                                    Keulehd
                                    #57
                                    @thomas-braun Alles klar
                                      selectID
                                      zeig mal die Eingangsdaten
                                      hat sich da was geändert
                                      und die Optionen.
                                      Nicht dass die Größe auf 0 steht
                                      Keulehd
                                      #58
                                      @homoran Eingangsdaten und Optionen:
                                      • K Keulehd
                                        HomoranH Offline
                                        HomoranH Offline
                                        #59
                                        Eingangsdaten
                                        Aliase?
                                        sind die noch funktionabel?
                                        Optionen
                                        3x3 pixel ist wohl was wenig für den chart
                                        nimm die Werte mal ganz raus
                                          Eingangsdaten
                                          Aliase?
                                          Optionen
                                          Keulehd
                                          #60
                                          @homoran Aliase funktionieren
                                          Danke das war es mit den 3 x 3 Pixeln :-) Klasse :-)
