  4. FLOT nicht mehr aufrufbar - Warnung im Protokoll
    5.1k
60 Beiträge 3 Kommentatoren 5.4k Aufrufe 3 Beobachtet
    @keulehd
    Jetzt haust du den Daniel noch in die Gruppe 'adm' rein
    sudo usermod -a -G adm daniel
    Daniel danach ausloggen und wieder einloggen.
    Keulehd
    @thomas-braun Erledigt
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: HomeServer
             Icon name: computer-desktop
               Chassis: desktop
            Machine ID: 1592eab9854d408bb2ffeca18adb4314
               Boot ID: ea3d5faa73ee4ab1b51a8d42bc58c08d
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-26-amd64
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:25:29 up 40 min,  2 users,  load average: 1.26, 1.26, 1.36
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Mon 2023-10-02 12:25:29 CEST
               Universal time: Mon 2023-10-02 10:25:29 UTC
                     RTC time: Mon 2023-10-02 10:25:29
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    daniel
    /home/daniel
    daniel adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.9G        3.2G        2.9G        1.0M        1.7G        4.3G
    Swap:           976M          0B        976M
    Total:          8.8G        3.2G        3.9G
             7862 M total memory
             3233 M used memory
              632 M active memory
             3487 M inactive memory
             2912 M free memory
              197 M buffer memory
             1519 M swap cache
              976 M total swap
                0 M used swap
              976 M free swap
    *** FILESYSTEM ***
    Filesystem                              Type      Size  Used Avail Use% Mounted on
    udev                                    devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                                   tmpfs     787M  1.3M  785M   1% /run
    /dev/sda5                               ext4      135G   37G   92G  29% /
    tmpfs                                   tmpfs     3.9G   16K  3.9G   1% /dev/shm
    tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                               vfat       96M   33M   64M  34% /boot/efi
    192.168.100.143:/mnt/pools/A/A0/Kameras nfs       5.4T  2.5T  3.0T  45% /media/nas
    tmpfs                                   tmpfs     787M   76K  787M   1% /run/user/1000
    [Mon Oct  2 11:45:11 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Oct  2 11:45:16 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
    TARGET       SOURCE                                  FSTYPE OPTIONS
    /            /dev/sda5                               ext4   rw,relatime,errors=remount-ro
    |-/boot/efi  /dev/sda1                               vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    `-/media/nas 192.168.100.143:/mnt/pools/A/A0/Kameras nfs    rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,soft,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.100.143,mountvers=3,mountport=895,mountproto=udp,local_lock=all,addr=192.168.100.143
    /var:
    28G     /var/
    26G     /var/lib/motioneye/Camera1
    26G     /var/lib
    7.2G    /var/lib/motioneye/Camera1/2023-06-10
    Archived and active journals take up 1008.3M in the file system.
    /opt/iobroker/backups:
    94M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    504M    /opt/iobroker/iobroker-data/
    329M    /opt/iobroker/iobroker-data/files
    118M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/files/iot.admin/static
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.b86463fc.js.map
    31M     /opt/iobroker/iobroker-data/states.jsonl
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
            500 http://deb.debian.org/debian bullseye-proposed-updates/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : HomeServer                               -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : HomeServer                               - disabled
    + system.adapter.alexa2.0                 : alexa2                : HomeServer                               -  enabled
    + system.adapter.backitup.0               : backitup              : HomeServer                               -  enabled
    + system.adapter.bring.0                  : bring                 : HomeServer                               -  enabled
    + system.adapter.cloud.0                  : cloud                 : HomeServer                               -  enabled
      system.adapter.daswetter.0              : daswetter             : HomeServer                               -  enabled
    + system.adapter.discovery.0              : discovery             : HomeServer                               -  enabled
      system.adapter.dwd.0                    : dwd                   : HomeServer                               -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : HomeServer                               -  enabled
      system.adapter.feiertage.0              : feiertage             : HomeServer                               -  enabled
      system.adapter.flot.0                   : flot                  : HomeServer                               -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : HomeServer                               -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : HomeServer                               -  enabled
    + system.adapter.govee.0                  : govee                 : HomeServer                               -  enabled
    + system.adapter.heizoel.0                : heizoel               : HomeServer                               -  enabled
    + system.adapter.history.0                : history               : HomeServer                               -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : HomeServer                               -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : HomeServer                               -  enabled
    + system.adapter.hue.0                    : hue                   : HomeServer                               -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : HomeServer                               -  enabled
      system.adapter.ical.1                   : ical                  : HomeServer                               -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : HomeServer                               -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeServer                               - disabled
    + system.adapter.info.0                   : info                  : HomeServer                               -  enabled
    + system.adapter.iot.0                    : iot                   : HomeServer                               -  enabled
    + system.adapter.javascript.0             : javascript            : HomeServer                               -  enabled
    + system.adapter.linux-control.0          : linux-control         : HomeServer                               -  enabled
    + system.adapter.mediola-gateway.0        : mediola-gateway       : HomeServer                               -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : HomeServer                               -  enabled
      system.adapter.mobile.0                 : mobile                : HomeServer                               - disabled
    + system.adapter.netatmo.0                : netatmo               : HomeServer                               -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : HomeServer                               -  enabled
    + system.adapter.nuki.0                   : nuki                  : HomeServer                               -  enabled
    + system.adapter.nut.0                    : nut                   : HomeServer                               -  enabled
    + system.adapter.parcel.0                 : parcel                : HomeServer                               -  enabled
    + system.adapter.ping.0                   : ping                  : HomeServer                               -  enabled
      system.adapter.scenes.0                 : scenes                : HomeServer                               - disabled
      system.adapter.scheduler.0              : scheduler             : HomeServer                               - disabled
    + system.adapter.shelly.0                 : shelly                : HomeServer                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : HomeServer                               -  enabled
    + system.adapter.simple-api.0             : simple-api            : HomeServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeServer                               -  enabled
    + system.adapter.telegram.0               : telegram              : HomeServer                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : HomeServer                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : HomeServer                               -  enabled
    + system.adapter.tr-064.0                 : tr-064                : HomeServer                               -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : HomeServer                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : HomeServer                               -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : HomeServer                               -  enabled
      system.adapter.velux.0                  : velux                 : HomeServer                               - disabled
      system.adapter.viessmannapi.0           : viessmannapi          : HomeServer                               - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeServer                               - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeServer                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeServer                               - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : HomeServer                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeServer                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeServer                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : HomeServer                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomeServer                               - disabled
      system.adapter.vis-weather.0            : vis-weather           : HomeServer                               - disabled
      system.adapter.vis.0                    : vis                   : HomeServer                               -  enabled
    + system.adapter.web.0                    : web                   : HomeServer                               -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : HomeServer                               -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeServer                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : HomeServer                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b6218f1c57c9eb118db68d4f1d69213e-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    live          : http://iobroker.live/repo/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.10.0   , installed 3.10.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 2.0.3
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "parcel"       : 0.0.27   , installed 0.0.30
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
    Adapter    "velux"        : 0.0.7    , installed 0.0.7
    Adapter    "viessmannapi" : 2.0.9    , installed 2.1.1
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        16242
    States:         13909
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12279      1/init
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16022      834/motion
    tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16023      834/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14934      544/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15272      512/cupsd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       24838      2114/io.shelly.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        17746      514/monocle-gateway
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16980      463/python2
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16024      834/motion
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16996      865/upsd
    tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          16995      865/upsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20671      513/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18814      513/iobroker.js-con
    tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17156      962/monocle-proxy
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        17745      514/monocle-gateway
    tcp6       0      0 :::111                  :::*                    LISTEN      0          12283      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          15641      545/apache2
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       28210      3484/io.web.0
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       23684      1195/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14936      544/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30799      3346/io.simple-api.
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15271      512/cupsd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       32583      4162/io.terminal.0
    tcp6       0      0 :::20002                :::*                    LISTEN      1001       33199      4201/io.web.1
    udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       31987      3645/io.mediola-gat
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       23912      2189/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       23913      2189/io.tuya.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12280      1/init
    udp        0      0 0.0.0.0:57463           0.0.0.0:*                           110        13882      449/avahi-daemon: r
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15290      622/cups-browsed
    udp        0      0 0.0.0.0:33641           0.0.0.0:*                           1001       31988      3645/io.mediola-gat
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        13880      449/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          12286      1/init
    udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15778      460/NetworkManager
    udp6       0      0 :::37900                :::*                                110        13883      449/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                110        13881      449/avahi-daemon: r
    2023-10-02 12:20:02.347  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-02 12:20:04.074  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 8914
    2023-10-02 12:20:04.886  - info: tvspielfilm.0 (8914) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
    2023-10-02 12:20:06.931  - info: tvspielfilm.0 (8914) objects written
    2023-10-02 12:20:08.593  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
    2023-10-02 12:20:10.921  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
    2023-10-02 12:20:17.440  - info: tvspielfilm.0 (8914) Terminated (NO_ERROR): Without reason
    2023-10-02 12:20:17.955  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2023-10-02 12:21:36.628  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
    2023-10-02 12:22:06.679  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
    2023-10-02 12:22:24.473  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
    2023-10-02 12:23:06.948  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
    2023-10-02 12:24:07.108  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
    2023-10-02 12:25:00.066  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 10916
    2023-10-02 12:25:00.974  - info: tvspielfilm.0 (10916) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
    2023-10-02 12:25:03.015  - info: tvspielfilm.0 (10916) objects written
    2023-10-02 12:25:04.095  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 10935
    2023-10-02 12:25:04.951  - info: dwd.0 (10935) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
    2023-10-02 12:25:05.514  - info: dwd.0 (10935) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-02 12:25:06.041  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-02 12:25:10.922  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
    2023-10-02 12:25:13.082  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
    2023-10-02 12:25:13.523  - info: tvspielfilm.0 (10916) Terminated (NO_ERROR): Without reason
    2023-10-02 12:25:14.054  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2023-10-02 12:25:37.376  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
    • K Keulehd
      @thomas-braun Wer lesen kann ist klar im Vorteil. Sorry :-(
      iobroker@HomeServer:~$ sudo passwd daniel
      Geben Sie ein neues Passwort ein:
      Geben Sie das neue Passwort erneut ein:
      passwd: Passwort erfolgreich geändert
      iob diag mit User "daniel":
      Skript v.2023-06-20
      *** BASE SYSTEM ***
                 Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
       12:20:21 up 35 min,  2 users,  load average: 1.70, 1.33, 1.42
      CPU threads: 4
                     Local time: Mon 2023-10-02 12:20:21 CEST
                 Universal time: Mon 2023-10-02 10:20:21 UTC
                       RTC time: Mon 2023-10-02 10:20:21
                    NTP service: active
                RTC in local TZ: no
      daniel
      /home/daniel
      daniel cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        3.3G        2.9G        1.0M        1.7G        4.3G
      Swap:           976M          0B        976M
      Total:          8.8G        3.3G        3.9G
               7862 M total memory
               3259 M used memory
                625 M active memory
               3517 M inactive memory
               2890 M free memory
                196 M buffer memory
               1516 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      *** FILESYSTEM ***
      /var:
      28G     /var/
      26G     /var/lib
      Archived and active journals take up 48.0M in the file system.
      503M    /opt/iobroker/iobroker-data/
      30M     /opt/iobroker/iobroker-data/states.jsonl
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16242
      States:         13909
      Pending Updates: 0
      2023-10-02 12:15:13.459  - info: tvspielfilm.0 (8249) Terminated (NO_ERROR): Without reason
      2023-10-02 12:15:13.973  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      2023-10-02 12:15:16.553  - info: daswetter.0 (8685) still wrong data structure from server received! repaired...
      2023-10-02 12:15:18.249  - info: daswetter.0 (8685) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-10-02 12:15:18.763  - info: daswetter.0 (8685) cleaned everything up...
      2023-10-02 12:15:18.784  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-02 12:16:05.624  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
      2023-10-02 12:16:35.704  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
      2023-10-02 12:17:05.780  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
      2023-10-02 12:17:24.481  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
      2023-10-02 12:17:35.865  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
      2023-10-02 12:17:36.155  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Velux Dachfenster value: 0%
      2023-10-02 12:18:05.952  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
      2023-10-02 12:18:36.057  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
      2023-10-02 12:20:00.044  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 8895
      2023-10-02 12:20:00.880  - info: dwd.0 (8895) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
      2023-10-02 12:20:01.817  - info: dwd.0 (8895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      @keulehd
      Und in die Gruppe 'iobroker' würde ich den auch setzen. Und dann den User 'iobroker' in Ruhe lassen.
        @keulehd
        Keulehd
        @thomas-braun Auch erledigt
        daniel@HomeServer:~$ sudo usermod -a -G iobroker daniel
        Nur für mich: Hat das mit dem User "iobroker" einen bestimmten Grund ? Nur zum Verständnis. Danke Dir
        • K Keulehd
          @keulehd
          Der User iobroker ist eigentlich ein Systemuser (und bekommt in der Standardinstallation erst gar kein Login). Man rödelt mit einem eigenen User durch das System, bei dir halt mit dem 'daniel'.
            @keulehd
            Keulehd
            @thomas-braun Ah alles klar. Den iobroker hab ich bei der Installation angelegt aber spielt in dem Fall ja keine Rolle. System ist nun dank Dir stabil und einigermaßen sauber hergestellt. Danke Dir.
            Nun mal schauen wegen FLOT: Weiß nur überhaupt nicht wo ich da anfangen soll. Dachte mit der zweiten web.1 Instanz geht es weil das Problem anscheinend schon etliche hatten und damit behoben haben aber bei mir geht das nicht.
            • K Keulehd
              @keulehd sagte in FLOT nicht mehr aufrufbar - Warnung im Protokoll:
              Das ist falsch, der wird vom iobroker-Installer angelegt. Und dann tickt der auch anders als jetzt dein 'iobroker'.
                Keulehd
                @thomas-braun Alles klar
                  selectID
                  zeig mal die Eingangsdaten
                  hat sich da was geändert
                  und die Optionen.
                  Nicht dass die Größe auf 0 steht
                  Keulehd
                  @homoran Eingangsdaten und Optionen:
                  • K Keulehd
                    HomoranH Offline
                    HomoranH Offline
                    Eingangsdaten
                    Aliase?
                    sind die noch funktionabel?
                    Optionen
                    3x3 pixel ist wohl was wenig für den chart
                    nimm die Werte mal ganz raus
                      Eingangsdaten
                      Aliase?
                      Optionen
                      Keulehd
                      @homoran Aliase funktionieren
                      Danke das war es mit den 3 x 3 Pixeln :-) Klasse :-)
