  4. FLOT nicht mehr aufrufbar - Warnung im Protokoll
    5.1k
60 Beiträge 3 Kommentatoren 5.4k Aufrufe 3 Beobachtet
    @keulehd
    Ich vermute da liegen Dienste auf den gleichen Ports.
    Hast ja einen ganzen Zoo laufen.
    iob diag
    sagt nun? Langfassung.
    Keulehd
    schrieb am zuletzt editiert von Keulehd
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: HomeServer
             Icon name: computer-desktop
               Chassis: desktop
            Machine ID: 1592eab9854d408bb2ffeca18adb4314
               Boot ID: d4b9b898a4b24f82aed54e27b09ea7cd
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-25-amd64
          Architecture: x86-64
    model name      : Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     11:40:04 up 17 days, 13 min,  2 users,  load average: 0.90, 1.16, 1.25
    CPU threads: 4
    The systems needs to be REBOOTED!
    *** Time and Time Zones ***
                   Local time: Mon 2023-10-02 11:40:04 CEST
               Universal time: Mon 2023-10-02 09:40:04 UTC
                     RTC time: Mon 2023-10-02 09:40:05
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout sudo audio video bluetooth
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        4.3G        952M        2.0M        2.6G        3.3G
    Swap:           976M        192M        784M
    Total:          8.8G        4.5G        1.7G
             7862 M total memory
             4284 M used memory
             1101 M active memory
             4737 M inactive memory
              952 M free memory
              152 M buffer memory
             2472 M swap cache
              976 M total swap
              192 M used swap
              784 M free swap
    *** FILESYSTEM ***
    Filesystem                              Type      Size  Used Avail Use% Mounted on
    udev                                    devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                                   tmpfs     787M  1.5M  785M   1% /run
    /dev/sda5                               ext4      135G   37G   92G  29% /
    tmpfs                                   tmpfs     3.9G   16K  3.9G   1% /dev/shm
    tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                               vfat       96M   33M   64M  34% /boot/efi
    tmpfs                                   tmpfs     787M  100K  787M   1% /run/user/1001
    192.168.100.143:/mnt/pools/A/A0/Kameras nfs       5.4T  2.5T  3.0T  45% /media/nas
    [Fri Sep 15 11:26:09 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Sep 15 11:26:14 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
    TARGET       SOURCE                                  FSTYPE OPTIONS
    /            /dev/sda5                               ext4   rw,relatime,errors=remount-ro
    |-/boot/efi  /dev/sda1                               vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    `-/media/nas 192.168.100.143:/mnt/pools/A/A0/Kameras nfs    rw,relatime,vers=3,rsize=65536,wsize=65536,namlen=255,soft,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.100.143,mountvers=3,mountport=895,mountproto=udp,local_lock=all,addr=192.168.100.143
    /var:
    28G     /var/
    26G     /var/lib/motioneye/Camera1
    26G     /var/lib
    7.2G    /var/lib/motioneye/Camera1/2023-06-10
    Archived and active journals take up 432.1M in the file system.
    /opt/iobroker/backups:
    94M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    488M    /opt/iobroker/iobroker-data/
    329M    /opt/iobroker/iobroker-data/files
    118M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/files/iot.admin/static
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.b86463fc.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.df70fdfc.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
            500 http://deb.debian.org/debian bullseye-proposed-updates/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   3
    Adapter State
    + system.adapter.admin.0                  : admin                 : HomeServer                               -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : HomeServer                               - disabled
    + system.adapter.alexa2.0                 : alexa2                : HomeServer                               -  enabled
    + system.adapter.backitup.0               : backitup              : HomeServer                               -  enabled
    + system.adapter.bring.0                  : bring                 : HomeServer                               -  enabled
    + system.adapter.cloud.0                  : cloud                 : HomeServer                               -  enabled
      system.adapter.daswetter.0              : daswetter             : HomeServer                               -  enabled
    + system.adapter.discovery.0              : discovery             : HomeServer                               -  enabled
      system.adapter.dwd.0                    : dwd                   : HomeServer                               -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : HomeServer                               -  enabled
      system.adapter.feiertage.0              : feiertage             : HomeServer                               -  enabled
      system.adapter.flot.0                   : flot                  : HomeServer                               - disabled
    + system.adapter.fritzdect.0              : fritzdect             : HomeServer                               -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : HomeServer                               -  enabled
    + system.adapter.govee.0                  : govee                 : HomeServer                               -  enabled
    + system.adapter.heizoel.0                : heizoel               : HomeServer                               -  enabled
    + system.adapter.history.0                : history               : HomeServer                               -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : HomeServer                               -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : HomeServer                               -  enabled
    + system.adapter.hue.0                    : hue                   : HomeServer                               -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : HomeServer                               -  enabled
      system.adapter.ical.1                   : ical                  : HomeServer                               -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : HomeServer                               -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeServer                               - disabled
    + system.adapter.info.0                   : info                  : HomeServer                               -  enabled
    + system.adapter.iot.0                    : iot                   : HomeServer                               -  enabled
    + system.adapter.javascript.0             : javascript            : HomeServer                               -  enabled
    + system.adapter.linux-control.0          : linux-control         : HomeServer                               -  enabled
    + system.adapter.mediola-gateway.0        : mediola-gateway       : HomeServer                               -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : HomeServer                               -  enabled
      system.adapter.mobile.0                 : mobile                : HomeServer                               - disabled
    + system.adapter.netatmo.0                : netatmo               : HomeServer                               -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : HomeServer                               -  enabled
    + system.adapter.nuki.0                   : nuki                  : HomeServer                               -  enabled
    + system.adapter.nut.0                    : nut                   : HomeServer                               -  enabled
    + system.adapter.parcel.0                 : parcel                : HomeServer                               -  enabled
    + system.adapter.ping.0                   : ping                  : HomeServer                               -  enabled
      system.adapter.scenes.0                 : scenes                : HomeServer                               - disabled
      system.adapter.scheduler.0              : scheduler             : HomeServer                               - disabled
    + system.adapter.shelly.0                 : shelly                : HomeServer                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : HomeServer                               -  enabled
    + system.adapter.simple-api.0             : simple-api            : HomeServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeServer                               -  enabled
    + system.adapter.telegram.0               : telegram              : HomeServer                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : HomeServer                               -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : HomeServer                               -  enabled
    + system.adapter.tr-064.0                 : tr-064                : HomeServer                               -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : HomeServer                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : HomeServer                               -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : HomeServer                               -  enabled
      system.adapter.velux.0                  : velux                 : HomeServer                               - disabled
      system.adapter.viessmannapi.0           : viessmannapi          : HomeServer                               - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeServer                               - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeServer                               -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeServer                               - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : HomeServer                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeServer                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeServer                               - disabled
      system.adapter.vis-metro.0              : vis-metro             : HomeServer                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : HomeServer                               - disabled
      system.adapter.vis-weather.0            : vis-weather           : HomeServer                               - disabled
      system.adapter.vis.0                    : vis                   : HomeServer                               -  enabled
    + system.adapter.web.0                    : web                   : HomeServer                               -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : HomeServer                               -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeServer                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : HomeServer                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b6218f1c57c9eb118db68d4f1d69213e-if00-port0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    live          : http://iobroker.live/repo/sources-dist-latest.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.10.0   , installed 3.10.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 1.14.5   , installed 2.0.3
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "mediola-gateway": 1.0.1  , installed 1.0.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "parcel"       : 0.0.27   , installed 0.0.30
    Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.5
    Adapter    "velux"        : 0.0.7    , installed 0.0.7
    Adapter    "viessmannapi" : 2.0.9    , installed 2.1.1
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        16242
    States:         13911
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29647184   3146008/iobroker.js
    tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17860      937/monocle-proxy
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        16298      514/monocle-gateway
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13159      1/init
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16677      831/motion
    tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16678      831/motion
    tcp        0      0 192.168.100.146:40499   0.0.0.0:*               LISTEN      1001       19849      1382/rygel
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          29632009   3141906/sshd: /usr/
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          29632077   3142007/cupsd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       29650167   3146281/io.shelly.0
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        16299      514/monocle-gateway
    tcp        0      0 127.0.0.1:44829         0.0.0.0:*               LISTEN      1001       21534      1382/rygel
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16224      471/python2
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16679      831/motion
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          15121      838/upsd
    tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          15120      838/upsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29647187   3146008/iobroker.js
    tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20538      1380/gnome-remote-d
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13163      1/init
    tcp6       0      0 :::80                   :::*                    LISTEN      0          14883      573/apache2
    tcp6       0      0 fe80::921b:eff:fe:42737 :::*                    LISTEN      1001       21536      1382/rygel
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       29653835   3147618/io.web.0
    tcp6       0      0 :::8085                 :::*                    LISTEN      1001       29647269   3146030/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          29632011   3141906/sshd: /usr/
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       29651771   3147490/io.simple-a
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          29632076   3142007/cupsd
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       29658405   3148237/io.terminal
    tcp6       0      0 ::1:37885               :::*                    LISTEN      1001       19850      1382/rygel
    tcp6       0      0 :::20002                :::*                    LISTEN      1001       29658461   3148261/io.web.1
    tcp6       0      0 :::41767                :::*                    LISTEN      1001       20543      1416/apache2
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13160      1/init
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          29638097   3142009/cups-browse
    udp        0      0 0.0.0.0:33524           0.0.0.0:*                           1001       29656139   3147767/io.mediola-
    udp        0      0 127.0.0.1:54408         0.0.0.0:*                           1001       19814      1382/rygel
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        12258      465/avahi-daemon: r
    udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19817      1382/rygel
    udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       19816      1382/rygel
    udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       19812      1382/rygel
    udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       19811      1382/rygel
    udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       29656138   3147767/io.mediola-
    udp        0      0 192.168.100.146:39339   0.0.0.0:*                           1001       19819      1382/rygel
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       29650303   3146333/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       29650304   3146333/io.tuya.0
    udp        0      0 0.0.0.0:35912           0.0.0.0:*                           110        12260      465/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          13166      1/init
    udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15918      468/NetworkManager
    udp6       0      0 :::5353                 :::*                                110        12259      465/avahi-daemon: r
    udp6       0      0 ::1:59194               :::*                                1001       19825      1382/rygel
    udp6       0      0 ::1:1900                :::*                                1001       19822      1382/rygel
    udp6       0      0 ff05::c:1900            :::*                                1001       19823      1382/rygel
    udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       19828      1382/rygel
    udp6       0      0 ff02::c:1900            :::*                                1001       19829      1382/rygel
    udp6       0      0 fe80::921b:eff:fe:47046 :::*                                1001       19831      1382/rygel
    udp6       0      0 :::35528                :::*                                110        12261      465/avahi-daemon: r
    2023-10-02 11:36:36.503  - info: linux-control.0 (3147786) getting data from Debian_11 (192.168.100.146:22)
    2023-10-02 11:36:38.687  - info: linux-control.0 (3147786) successful received data from Debian_11 (192.168.100.146:22)
    2023-10-02 11:37:13.002  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
    2023-10-02 11:37:13.348  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
    2023-10-02 11:37:17.795  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
    2023-10-02 11:37:25.199  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flot
    2023-10-02 11:37:25.653  - info: web.1 (3148261) ==> Connected system.user.admin from ::ffff:192.168.100.163
    2023-10-02 11:37:32.041  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flot
    2023-10-02 11:37:32.072  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEdit
    2023-10-02 11:37:32.075  - info: web.1 (3148261) <== Disconnect system.user.admin from ::ffff:192.168.100.163 flotEditDialog
    2023-10-02 11:38:30.064  - info: hue-extended.0 (3147639) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
    2023-10-02 11:38:45.674  - info: javascript.0 (3146102) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
    2023-10-02 11:40:00.051  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 3156593
    2023-10-02 11:40:00.875  - info: dwd.0 (3156593) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
    2023-10-02 11:40:01.755  - info: dwd.0 (3156593) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-02 11:40:02.304  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-02 11:40:04.081  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 3156622
    2023-10-02 11:40:04.934  - info: tvspielfilm.0 (3156622) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
    2023-10-02 11:40:06.970  - info: tvspielfilm.0 (3156622) objects written
    2023-10-02 11:40:08.219  - info: whatsapp-cmb.0 (3146144) Send Die Post war da to +491712121533
    2023-10-02 11:40:17.474  - info: tvspielfilm.0 (3156622) Terminated (NO_ERROR): Without reason
    2023-10-02 11:40:17.989  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    Boote eben mal den Rechner neu
    • K Keulehd
      Skript v.2023-06-20
      *** BASE SYSTEM ***
                 Chassis: desktop
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      iobroker
      /home/iobroker
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               7862 M total memory
               4284 M used memory
                952 M free memory
                152 M buffer memory
               2472 M swap cache
                976 M total swap
                192 M used swap
                784 M free swap
      *** FILESYSTEM ***
      /var:
      28G     /var/
      26G     /var/lib
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        16242
      States:         13911
      Pending Updates: 0
      @keulehd
      danach nochmal...
      • K Keulehd
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                   Chassis: desktop
        Docker          : false
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        iobroker
        /home/iobroker
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 7862 M total memory
                 4284 M used memory
                  952 M free memory
                  152 M buffer memory
                 2472 M swap cache
                  976 M total swap
                  192 M used swap
                  784 M free swap
        *** FILESYSTEM ***
        /var:
        28G     /var/
        26G     /var/lib
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.10.1
        javascript:     7.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects:        16242
        States:         13911
        Pending Updates: 0
        @keulehd
        iob start flot
          @keulehd
          iob start flot
          Keulehd
          @thomas-braun Gestartet. Gleicher Fehler
          iobroker@HomeServer:~$ iob start flot
          The adapter "flot.0" was started.
          iob diag:
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                     Chassis: desktop
                     Boot ID: ea3d5faa73ee4ab1b51a8d42bc58c08d
                      Kernel: Linux 5.10.0-26-amd64
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
           11:50:58 up 5 min,  2 users,  load average: 1.96, 2.35, 1.20
          CPU threads: 4
                         Local time: Mon 2023-10-02 11:50:58 CEST
                     Universal time: Mon 2023-10-02 09:50:58 UTC
                           RTC time: Mon 2023-10-02 09:50:58
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          /home/iobroker
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.9G        3.1G        3.7G        3.0M        1.0G        4.5G
          Swap:           976M          0B        976M
          Total:          8.8G        3.1G        4.7G
                   7862 M total memory
                   3123 M used memory
                    419 M active memory
                   3379 M inactive memory
                   3697 M free memory
                     69 M buffer memory
                    971 M swap cache
                    976 M total swap
                      0 M used swap
                    976 M free swap
          *** FILESYSTEM ***
          tmpfs                                   tmpfs     787M   96K  787M   1% /run/user/1001
          [Mon Oct  2 11:45:11 2023] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
          [Mon Oct  2 11:45:16 2023] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
          /var:
          28G     /var/
          26G     /var/lib
          494M    /opt/iobroker/iobroker-data/
          26M     /opt/iobroker/iobroker-data/objects.jsonl
          21M     /opt/iobroker/iobroker-data/states.jsonl
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.10.1
          javascript:     7.1.4
          Adapter State
            system.adapter.flot.0                   : flot                  : HomeServer                               -  enabled
          + instance is alive
          Objects and States
          Objects:        16242
          States:         13943
          Pending Updates: 0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12279      1/init
          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          16022      834/motion
          tcp        0      0 192.168.100.146:42129   0.0.0.0:*               LISTEN      1001       21113      1384/rygel
          tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          16023      834/motion
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14934      544/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15272      512/cupsd
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       24838      2114/io.shelly.0
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      998        17746      514/monocle-gateway
          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16980      463/python2
          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16024      834/motion
          tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16996      865/upsd
          tcp        0      0 192.168.100.146:3493    0.0.0.0:*               LISTEN      0          16995      865/upsd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20671      513/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18814      513/iobroker.js-con
          tcp        0      0 0.0.0.0:8554            0.0.0.0:*               LISTEN      998        17156      962/monocle-proxy
          tcp        0      0 127.0.0.1:36939         0.0.0.0:*               LISTEN      1001       20404      1384/rygel
          tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      998        17745      514/monocle-gateway
          tcp6       0      0 :::111                  :::*                    LISTEN      0          12283      1/init
          tcp6       0      0 :::80                   :::*                    LISTEN      0          15641      545/apache2
          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       28210      3484/io.web.0
          tcp6       0      0 :::8085                 :::*                    LISTEN      1001       23684      1195/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14936      544/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30799      3346/io.simple-api.
          tcp6       0      0 ::1:45495               :::*                    LISTEN      1001       20407      1384/rygel
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15271      512/cupsd
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       32583      4162/io.terminal.0
          tcp6       0      0 :::20002                :::*                    LISTEN      1001       33199      4201/io.web.1
          tcp6       0      0 fe80::921b:eff:fe:43939 :::*                    LISTEN      1001       19167      1384/rygel
          tcp6       0      0 :::36235                :::*                    LISTEN      1001       21093      1499/apache2
          tcp6       0      0 :::5900                 :::*                    LISTEN      1001       20286      1382/gnome-remote-d
          udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       20300      1384/rygel
          udp        0      0 192.168.100.146:1900    0.0.0.0:*                           1001       20299      1384/rygel
          udp        0      0 239.255.255.250:1900    0.0.0.0:*                           1001       20295      1384/rygel
          udp        0      0 127.0.0.1:1900          0.0.0.0:*                           1001       20294      1384/rygel
          udp        0      0 0.0.0.0:1902            0.0.0.0:*                           1001       31987      3645/io.mediola-gat
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       23912      2189/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       23913      2189/io.tuya.0
          udp        0      0 127.0.0.1:52497         0.0.0.0:*                           1001       20297      1384/rygel
          udp        0      0 192.168.100.146:36627   0.0.0.0:*                           1001       20302      1384/rygel
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12280      1/init
          udp        0      0 0.0.0.0:57463           0.0.0.0:*                           110        13882      449/avahi-daemon: r
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15290      622/cups-browsed
          udp        0      0 0.0.0.0:33641           0.0.0.0:*                           1001       31988      3645/io.mediola-gat
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        13880      449/avahi-daemon: r
          udp6       0      0 ::1:1900                :::*                                1001       20305      1384/rygel
          udp6       0      0 ff05::c:1900            :::*                                1001       20306      1384/rygel
          udp6       0      0 fe80::921b:eff:fe4:1900 :::*                                1001       20311      1384/rygel
          udp6       0      0 ff02::c:1900            :::*                                1001       20312      1384/rygel
          udp6       0      0 fe80::921b:eff:fe:44267 :::*                                1001       20314      1384/rygel
          udp6       0      0 ::1:45064               :::*                                1001       20308      1384/rygel
          udp6       0      0 :::111                  :::*                                0          12286      1/init
          udp6       0      0 fe80::921b:eff:fe45:546 :::*                                0          15778      460/NetworkManager
          udp6       0      0 :::37900                :::*                                110        13883      449/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                110        13881      449/avahi-daemon: r
          2023-10-02 11:50:07.121  - info: tvspielfilm.0 (4181) objects written
          2023-10-02 11:50:07.639  - info: web.1 (4201) socket.io server listening on port 20002
          2023-10-02 11:50:07.641  - info: web.1 (4201) http server listening on port 20002
          2023-10-02 11:50:08.453  - info: daswetter.0 (4113) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2023-10-02 11:50:08.965  - info: daswetter.0 (4113) cleaned everything up...
          2023-10-02 11:50:09.005  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-02 11:50:17.628  - info: tvspielfilm.0 (4181) Terminated (NO_ERROR): Without reason
          2023-10-02 11:50:18.147  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
          2023-10-02 11:50:22.093  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Schlafzimmer value: 2%
          2023-10-02 11:50:32.126  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Gästezimmer value: 2%
          2023-10-02 11:50:42.146  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Treppenhaus value: 2%
          2023-10-02 11:50:45.744  - info: host.HomeServer stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
          2023-10-02 11:50:45.747  - info: nuki-extended.0 (2068) Got terminate signal TERMINATE_YOURSELF
          2023-10-02 11:50:45.748  - info: nuki-extended.0 (2068) Adapter stopped und unloaded.
          2023-10-02 11:50:45.749  - info: nuki-extended.0 (2068) terminating
          2023-10-02 11:50:45.750  - info: nuki-extended.0 (2068) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-02 11:50:45.788  - info: host.HomeServer stopInstance system.adapter.nuki-extended.0 send kill signal
          2023-10-02 11:50:46.252  - info: nuki-extended.0 (2068) terminating
          2023-10-02 11:50:46.325  - info: host.HomeServer instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-02 11:50:48.879  - info: host.HomeServer instance system.adapter.nuki-extended.0 started with pid 4260
          2023-10-02 11:50:49.804  - info: nuki-extended.0 (4260) starting. Version 2.6.5 in /opt/iobroker/node_modules/iobroker.nuki-extended, node: v18.18.0, js-controller: 5.0.12
          2023-10-02 11:50:49.892  - info: nuki-extended.0 (4260) Polling Nuki Web API with a frequency of 60s.
          2023-10-02 11:51:12.174  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Wohnzimmer rechts value: 2%
          2023-10-02 11:51:22.187  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Küche links value: 2%
          2023-10-02 11:51:31.084  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
          • K Keulehd
            iob diag:
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                       Chassis: desktop
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            /home/iobroker
            X-Server:       true
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           976M          0B        976M
                     7862 M total memory
                     3123 M used memory
                      419 M active memory
                     3697 M free memory
                       69 M buffer memory
                      971 M swap cache
                      976 M total swap
                        0 M used swap
                      976 M free swap
            *** FILESYSTEM ***
            /var:
            28G     /var/
            26G     /var/lib
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.10.1
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        16242
            States:         13943
            Pending Updates: 0
            @keulehd
            Meld dich mit einem andern User an. Es gibt noch einen mit der uid=1000auf dem System. Nimm den.
            • K Keulehd
              iob diag:
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                         Chassis: desktop
              Docker          : false
              Kernel          : x86_64
              Userland        : amd64
              CPU threads: 4
                            NTP service: active
                        RTC in local TZ: no
              iobroker
              /home/iobroker
              X-Server:       true
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           976M          0B        976M
                       7862 M total memory
                       3123 M used memory
                        419 M active memory
                       3697 M free memory
                         69 M buffer memory
                        971 M swap cache
                        976 M total swap
                          0 M used swap
                        976 M free swap
              *** FILESYSTEM ***
              /var:
              28G     /var/
              26G     /var/lib
              /usr/bin/npm            9.8.1
              /usr/bin/npx            9.8.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.10.1
              javascript:     7.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        16242
              States:         13943
              Pending Updates: 0
              @keulehd
              Und schalt den Desktop aus.
              sudo systemctl set-default multi-user.target
              sudo systemctl iosolate multi-user.target
                @keulehd
                Keulehd
                Mit den anderen beiden Usern kann ich mich nicht anmelden obwohl die Passwörter korrekt sein müssen. Sagt immer falsches Kennwort
                Abschaltung Desktop hat der erste Befehl funktioniert. Bei dem zweiten kommt:
                iobroker@HomeServer:~$ sudo systemctl iosolate multi-user.target
                Unknown command verb iosolate.
                • K Keulehd
                  @keulehd
                  sudo systemctl isolate multi-user.target
                  Und das mit den Usern würde mir zu denken geben...
                  Setz ein neues Passwort.
                  sudo passwd Username
                    @keulehd
                    Keulehd
                    @thomas-braun Danke. Isolate hat funktioniert
                    Mir sind nur 2 User bekannt. Den PC hab ich ja selbst aufgesetzt. Passwort ändern aber nicht möglich
                    iobroker@HomeServer:~$ sudo passwd Daniel
                    passwd: Benutzer »Daniel« ist nicht vorhanden.
                    iobroker@HomeServer:~$ sudo passwd Remote
                    passwd: Benutzer »Remote« ist nicht vorhanden.
                    • Thomas BraunT Online
                      @keulehd
                      In
                      cat /etc/passwd | sort
                      stehen die User drin
                        @keulehd
                        In
                        Keulehd
                        iobroker@HomeServer:~$ cat /etc/passwd | sort
                        _apt❌100:65534::/nonexistent:/usr/sbin/nologin
                        avahi❌110:116:Avahi mDNS daemon,,,:/run/avahi-daemon:/usr/sbin/nologin
                        backup❌34:34:backup:/var/backups:/usr/sbin/nologin
                        bin❌2:2:bin:/bin:/usr/sbin/nologin
                        colord❌114:122:colord colour management daemon,,,:/var/lib/colord:/usr/sbin/nologin
                        daemon❌1:1:daemon:/usr/sbin:/usr/sbin/nologin
                        daniel❌1000:1000:Daniel Hoffmann,,,:/home/daniel:/bin/bash
                        Debian-gdm❌116:124:Gnome Display Manager:/var/lib/gdm3:/bin/false
                        dnsmasq❌109:65534:dnsmasq,,,:/var/lib/misc:/usr/sbin/nologin
                        games❌5:60:games:/usr/games:/usr/sbin/nologin
                        geoclue❌115:123::/var/lib/geoclue:/usr/sbin/nologin
                        gnats❌41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
                        iobroker❌1001:1001:iobroker,,,:/home/iobroker:/bin/bash
                        irc❌39:39:ircd:/run/ircd:/usr/sbin/nologin
                        lightdm❌119:125:Light Display Manager:/var/lib/lightdm:/bin/false
                        list❌38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
                        lp❌7:7:lp:/var/spool/lpd:/usr/sbin/nologin
                        mail❌8:8:mail:/var/mail:/usr/sbin/nologin
                        man❌6:12:man:/var/cache/man:/usr/sbin/nologin
                        messagebus❌104:110::/nonexistent:/usr/sbin/nologin
                        monocle❌998:998::/home/monocle:/bin/sh
                        motion❌120:126::/var/lib/motion:/usr/sbin/nologin
                        news❌9:9:news:/var/spool/news:/usr/sbin/nologin
                        nobody❌65534:65534:nobody:/nonexistent:/usr/sbin/nologin
                        nut❌121:127::/var/lib/nut:/usr/sbin/nologin
                        proxy❌13:13:proxy:/bin:/usr/sbin/nologin
                        pulse❌112:118:PulseAudio daemon,,,:/run/pulse:/usr/sbin/nologin
                        remote❌1002:1002:Remote,,,:/home/remote:/bin/bash
                        root❌0:0:root:/root:/bin/bash
                        _rpc❌117:65534::/run/rpcbind:/usr/sbin/nologin
                        rtkit❌107:115:RealtimeKit,,,:/proc:/usr/sbin/nologin
                        saned❌113:121::/var/lib/saned:/usr/sbin/nologin
                        speech-dispatcher❌111:29:Speech Dispatcher,,,:/run/speech-dispatcher:/bin/false
                        sshd❌108:65534::/run/sshd:/usr/sbin/nologin
                        statd❌118:65534::/var/lib/nfs:/usr/sbin/nologin
                        sync❌4:65534:sync:/bin:/bin/sync
                        systemd-coredump❌999:999:systemd Core Dumper:/:/usr/sbin/nologin
                        systemd-network❌101:102:systemd Network Management,,,:/run/systemd:/usr/sbin/nologin
                        systemd-resolve❌102:103:systemd Resolver,,,:/run/systemd:/usr/sbin/nologin
                        systemd-timesync❌105:111:systemd Time Synchronization,,,:/run/systemd:/usr/sbin/nologin
                        sys❌3:3:sys:/dev:/usr/sbin/nologin
                        tss❌103:109:TPM software stack,,,:/var/lib/tpm:/bin/false
                        usbmux❌106:46:usbmux daemon,,,:/var/lib/usbmux:/usr/sbin/nologin
                        uucp❌10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
                        www-data❌33:33:www-data:/var/www:/usr/sbin/nologin
                        Ja genau. Daniel und Remote. Aber es lassen sich keine Passwörter ändern bzw. setzen. Alles sehr suspekt
                        • K Keulehd
                          @keulehd sagte in FLOT nicht mehr aufrufbar - Warnung im Protokoll:
                          Richtig, der heißt ja auch 'daniel'
                            Keulehd
                            @thomas-braun Wer lesen kann ist klar im Vorteil. Sorry :-(
                            iobroker@HomeServer:~$ sudo passwd daniel
                            Geben Sie ein neues Passwort ein:
                            Geben Sie das neue Passwort erneut ein:
                            passwd: Passwort erfolgreich geändert
                            iob diag mit User "daniel":
                            Skript v.2023-06-20
                            *** BASE SYSTEM ***
                                       Chassis: desktop
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : amd64
                             12:20:21 up 35 min,  2 users,  load average: 1.70, 1.33, 1.42
                            CPU threads: 4
                                           Local time: Mon 2023-10-02 12:20:21 CEST
                                       Universal time: Mon 2023-10-02 10:20:21 UTC
                                             RTC time: Mon 2023-10-02 10:20:21
                                          NTP service: active
                                      RTC in local TZ: no
                            daniel
                            /home/daniel
                            daniel cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            7.9G        3.3G        2.9G        1.0M        1.7G        4.3G
                            Swap:           976M          0B        976M
                            Total:          8.8G        3.3G        3.9G
                                     7862 M total memory
                                     3259 M used memory
                                      625 M active memory
                                     3517 M inactive memory
                                     2890 M free memory
                                      196 M buffer memory
                                     1516 M swap cache
                                      976 M total swap
                                        0 M used swap
                                      976 M free swap
                            *** FILESYSTEM ***
                            tmpfs                                   tmpfs     787M  1.3M  785M   1% /run
                            tmpfs                                   tmpfs     787M   76K  787M   1% /run/user/1000
                            /var:
                            28G     /var/
                            26G     /var/lib
                            Archived and active journals take up 48.0M in the file system.
                            503M    /opt/iobroker/iobroker-data/
                            30M     /opt/iobroker/iobroker-data/states.jsonl
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.10.1
                            javascript:     7.1.4
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        16242
                            States:         13909
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                            Pending Updates: 0
                            2023-10-02 12:15:13.459  - info: tvspielfilm.0 (8249) Terminated (NO_ERROR): Without reason
                            2023-10-02 12:15:13.973  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                            2023-10-02 12:15:16.553  - info: daswetter.0 (8685) still wrong data structure from server received! repaired...
                            2023-10-02 12:15:18.249  - info: daswetter.0 (8685) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                            2023-10-02 12:15:18.763  - info: daswetter.0 (8685) cleaned everything up...
                            2023-10-02 12:15:18.784  - info: host.HomeServer instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2023-10-02 12:16:05.624  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                            2023-10-02 12:16:35.704  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                            2023-10-02 12:17:05.780  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                            2023-10-02 12:17:24.481  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
                            2023-10-02 12:17:35.865  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                            2023-10-02 12:17:36.155  - info: shuttercontrol.0 (3596) Sunprotect #418 Set ID: Velux Dachfenster value: 0%
                            2023-10-02 12:18:05.952  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                            2023-10-02 12:18:36.057  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
                            2023-10-02 12:20:00.044  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 8895
                            2023-10-02 12:20:00.880  - info: dwd.0 (8895) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
                            2023-10-02 12:20:01.817  - info: dwd.0 (8895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2023-10-02 12:20:02.347  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2023-10-02 12:20:04.074  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 8914
                            2023-10-02 12:20:04.886  - info: tvspielfilm.0 (8914) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
                            2023-10-02 12:20:06.931  - info: tvspielfilm.0 (8914) objects written
                            2023-10-02 12:20:08.593  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
                            2023-10-02 12:20:10.921  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
                            2023-10-02 12:20:17.440  - info: tvspielfilm.0 (8914) Terminated (NO_ERROR): Without reason
                            2023-10-02 12:20:17.955  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                            • K Keulehd
                              Skript v.2023-06-20
                              *** BASE SYSTEM ***
                                         Chassis: desktop
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : amd64
                              CPU threads: 4
                                            NTP service: active
                                        RTC in local TZ: no
                              daniel
                              /home/daniel
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           976M          0B        976M
                                       7862 M total memory
                                       3259 M used memory
                                        625 M active memory
                                       2890 M free memory
                                        196 M buffer memory
                                       1516 M swap cache
                                        976 M total swap
                                          0 M used swap
                                        976 M free swap
                              *** FILESYSTEM ***
                              /var:
                              28G     /var/
                              26G     /var/lib
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.10.1
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        16242
                              States:         13909
                              Pending Updates: 0
                              @keulehd
                              Jetzt haust du den Daniel noch in die Gruppe 'adm' rein
                              sudo usermod -a -G adm daniel
                              Daniel danach ausloggen und wieder einloggen.
                                @keulehd
                                Keulehd
                                @thomas-braun Erledigt
                                Skript v.2023-06-20
                                *** BASE SYSTEM ***
                                           Chassis: desktop
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : amd64
                                 12:25:29 up 40 min,  2 users,  load average: 1.26, 1.26, 1.36
                                CPU threads: 4
                                               Local time: Mon 2023-10-02 12:25:29 CEST
                                           Universal time: Mon 2023-10-02 10:25:29 UTC
                                                 RTC time: Mon 2023-10-02 10:25:29
                                              NTP service: active
                                          RTC in local TZ: no
                                daniel
                                /home/daniel
                                daniel adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.9G        3.2G        2.9G        1.0M        1.7G        4.3G
                                Swap:           976M          0B        976M
                                Total:          8.8G        3.2G        3.9G
                                         7862 M total memory
                                         3233 M used memory
                                          632 M active memory
                                         3487 M inactive memory
                                         2912 M free memory
                                          197 M buffer memory
                                         1519 M swap cache
                                          976 M total swap
                                            0 M used swap
                                          976 M free swap
                                *** FILESYSTEM ***
                                /var:
                                28G     /var/
                                26G     /var/lib
                                Archived and active journals take up 1008.3M in the file system.
                                504M    /opt/iobroker/iobroker-data/
                                31M     /opt/iobroker/iobroker-data/states.jsonl
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.10.1
                                javascript:     7.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        16242
                                States:         13909
                                Pending Updates: 0
                                2023-10-02 12:21:36.628  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                2023-10-02 12:22:06.679  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                2023-10-02 12:22:24.473  - info: javascript.0 (1392) script.js.Sprachsteuerung_Alexa.Offene_Fenster:
                                2023-10-02 12:23:06.948  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.031-hue_outdoor_light_sensor_1.state.lightlevel" has to be type "string" but received type "number"
                                2023-10-02 12:24:07.108  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                2023-10-02 12:25:00.066  - info: host.HomeServer instance system.adapter.tvspielfilm.0 started with pid 10916
                                2023-10-02 12:25:00.974  - info: tvspielfilm.0 (10916) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.12
                                2023-10-02 12:25:03.015  - info: tvspielfilm.0 (10916) objects written
                                2023-10-02 12:25:04.095  - info: host.HomeServer instance system.adapter.dwd.0 started with pid 10935
                                2023-10-02 12:25:04.951  - info: dwd.0 (10935) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.0, js-controller: 5.0.12
                                2023-10-02 12:25:05.514  - info: dwd.0 (10935) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2023-10-02 12:25:06.041  - info: host.HomeServer instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2023-10-02 12:25:10.922  - info: linux-control.0 (3694) getting data from Debian_11 (192.168.100.146:22)
                                2023-10-02 12:25:13.082  - info: linux-control.0 (3694) successful received data from Debian_11 (192.168.100.146:22)
                                2023-10-02 12:25:13.523  - info: tvspielfilm.0 (10916) Terminated (NO_ERROR): Without reason
                                2023-10-02 12:25:14.054  - info: host.HomeServer instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                                2023-10-02 12:25:37.376  - info: hue-extended.0 (3505) State value to set for "hue-extended.0.sensors.030-hue_outdoor_motion_sensor_1.state.presence" has to be type "string" but received type "boolean"
                                • K Keulehd
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                             Chassis: desktop
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  CPU threads: 4
                                                NTP service: active
                                            RTC in local TZ: no
                                  daniel
                                  /home/daniel
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           976M          0B        976M
                                           7862 M total memory
                                           3259 M used memory
                                            625 M active memory
                                           2890 M free memory
                                            196 M buffer memory
                                           1516 M swap cache
                                            976 M total swap
                                              0 M used swap
                                            976 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  28G     /var/
                                  26G     /var/lib
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.10.1
                                  javascript:     7.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        16242
                                  States:         13909
                                  Pending Updates: 0
                                  @keulehd
                                  Und in die Gruppe 'iobroker' würde ich den auch setzen. Und dann den User 'iobroker' in Ruhe lassen.
                                    @keulehd
                                    Keulehd
                                    @thomas-braun Auch erledigt
                                    daniel@HomeServer:~$ sudo usermod -a -G iobroker daniel
                                    Nur für mich: Hat das mit dem User "iobroker" einen bestimmten Grund ? Nur zum Verständnis. Danke Dir
                                    • K Keulehd
                                      @keulehd
                                      Der User iobroker ist eigentlich ein Systemuser (und bekommt in der Standardinstallation erst gar kein Login). Man rödelt mit einem eigenen User durch das System, bei dir halt mit dem 'daniel'.
                                        @keulehd
                                        Keulehd
                                        @thomas-braun Ah alles klar. Den iobroker hab ich bei der Installation angelegt aber spielt in dem Fall ja keine Rolle. System ist nun dank Dir stabil und einigermaßen sauber hergestellt. Danke Dir.
                                        Nun mal schauen wegen FLOT: Weiß nur überhaupt nicht wo ich da anfangen soll. Dachte mit der zweiten web.1 Instanz geht es weil das Problem anscheinend schon etliche hatten und damit behoben haben aber bei mir geht das nicht.
                                        • K Keulehd
                                          Das ist falsch, der wird vom iobroker-Installer angelegt. Und dann tickt der auch anders als jetzt dein 'iobroker'.
