  4. Performance Probleme durch Shelly Adapter?
    3.2k
256 Beiträge 14 Kommentatoren 62.2k Aufrufe 9 Beobachtet
  • S Schtallone
    @Homoran
    Copy text starting here:
                         v.2023-06-20
    model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            7.8G        5.3G        854M        238M        1.6G        1.6G
    Swap:            23G        1.7G         21G
    Total:           31G        7.0G         22G
    Active iob-Instances:   23
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                10441
    States:                 8960
    Size of iob-Database:
    32M     /opt/iobroker/iobroker-data/objects.jsonl
    16M     /opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    Schtallone
    ======== Start marking the full check here =========
    Skript v.2023-06-20
    *** BASE SYSTEM ***
    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
    Hardware Vendor :
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v8.1.0
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:41:54 up 22:06,  0 users,  load average: 8.64, 8.88, 8.33
    CPU threads: 2
    *** Time and Time Zones ***
    Sat Sep 16 10:41:54 UTC 2023
    Sat Sep 16 12:41:54 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            7.8G        5.2G        1.1G        238M        1.5G        1.9G
    Swap:            23G        1.7G         21G
    Total:           31G        6.8G         22G
             7792 M total memory
             5170 M used memory
             2476 M active memory
             2644 M inactive memory
             1076 M free memory
              512 M buffer memory
             1032 M swap cache
            23447 M total swap
             1659 M used swap
            21787 M free swap
    *** FILESYSTEM ***
    Filesystem            Type     Size  Used Avail Use% Mounted on
    overlay               overlay  2.6T  1.6T  1.1T  61% /
    tmpfs                 tmpfs     64M     0   64M   0% /dev
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/fs/cgroup
    shm                   tmpfs     64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev1 ext4     2.6T  1.6T  1.1T  61% /opt/iobroker
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/asound
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/acpi
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /proc/scsi
    tmpfs                 tmpfs    3.9G     0  3.9G   0% /sys/firmware
    dmesg: read kernel buffer failed: Operation not permitted
    Show mounted filesystems (real ones only):
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/mapper/cachedev1[/Docker/iobroker]        ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/resolv.conf /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/resolv.conf] ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/hostname    /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hostname]    ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /etc/hosts       /dev/mapper/cachedev1[/Container/container-station-data/lib/docker/containers/fc3f3c4c81fc4d371ff10ae519deeb41066e2e757561c9f538dca358839bd4af/hosts]       ext4   rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
    /var:
    33M     /var/
    31M     /var/lib
    18M     /var/lib/apt/lists
    18M     /var/lib/apt
    13M     /var/lib/dpkg
    /opt/iobroker/backups:
    987M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    639M    /opt/iobroker/iobroker-data/
    415M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/files/javascript.admin
    129M    /opt/iobroker/iobroker-data/files/devices.admin/static
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.f95354b8.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    *** NodeJS-Installation ***
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 127.0.0.1
    States:                     jsonl on 127.0.0.1
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   1
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.meross.0                 : meross                : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 192.168.1.10
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.1.10
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
      system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 192.168.1.10, run as: admin
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "device-watcher": 2.9.3   , installed 2.9.3
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "meross"       : 1.15.1   , installed 1.15.1
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "pushover"     : 3.0.4    , installed 3.0.4
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
    Adapter    "snmp"         : 2.4.11   , installed 2.4.11
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "vw-connect"   : 0.1.2    , installed 0.1.2
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Objects and States
    Objects:        10441
    States:         8960
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       5569456    -
    tcp        0      0 192.168.1.10:1880       0.0.0.0:*               LISTEN      1000       9092066    -
    tcp        0      0 192.168.1.10:1882       0.0.0.0:*               LISTEN      1000       9247890    -
    tcp        0      0 127.0.0.11:44959        0.0.0.0:*               LISTEN      0          5407964    -
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       5422351    -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       5422233    -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5425094    -
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5536059    -
    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       5535121    -
    udp        0      0 0.0.0.0:38695           0.0.0.0:*                           1000       5552420    -
    udp        0      0 127.0.0.11:60125        0.0.0.0:*                           0          5407963    -
    udp        0      0 0.0.0.0:46182           0.0.0.0:*                           1000       5552419    -
    2023-09-15 00:37:02.337  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032ab94e10 / shellyplus1pm#a8032ab94e10#1) (false)
    2023-09-15 00:37:03.121  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a876248"
    2023-09-15 00:37:04.440  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e5f74" connected!
    2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8b94fc"
    2023-09-15 00:37:05.005  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d970"
    2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8bf730"
    2023-09-15 00:37:05.006  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
    2023-09-15 00:37:05.295  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a863524 / shellyplus2pm#b8d61a863524#1) (false)
    2023-09-15 00:37:05.587  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-3c610579bd34 / shellyplus1pm#3c610579bd34#1) (false)
    2023-09-15 00:37:06.868  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a863524"
    2023-09-15 00:37:07.457  - error: shelly.0 (506) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-3c610579bd34"
    2023-09-15 00:37:07.722  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-4022d8da969c / shellyplus2pm#4022d8da969c#1) (false)
    2023-09-15 00:37:07.785  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-7c87ce65d794 / shellyplus1pm#7c87ce65d794#1) (false)
    2023-09-15 00:37:11.460  - info: modbus.0 (411) Connected to slave 192.168.1.47
    2023-09-15 00:37:12.224  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23ecce4" connected!
    2023-09-15 00:37:14.432  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23e5f74 / shellyplus2pm#5443b23e5f74#1) (false)
    2023-09-15 00:37:22.217  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23ecce4 / shellyplus2pm#5443b23ecce4#1) (false)
    2023-09-15 00:37:25.564  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23fd3dc" connected!
    2023-09-15 00:37:27.320  - info: modbus.0 (411) Disconnected from slave 192.168.1.47
    2023-09-15 00:37:29.078  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1pm-a8032abc230c" connected!
    2023-09-15 00:37:30.096  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-5443b23e1a90" connected!
    2023-09-15 00:37:35.564  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23fd3dc / shellyplus2pm#5443b23fd3dc#1) (false)
    2023-09-15 00:37:36.407  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus2pm-4022d8dbe474" connected!
    2023-09-15 00:37:38.493  - info: shelly.0 (506) [MQTT] Device with client id "shellyplus1-441793a820f4" connected!
    2023-09-15 00:37:38.853  - info: shelly.0 (506) [MQTT] Client Close:  (shellyplus1pm / shellyplus1pm-a8032abc230c / shellyplus1pm#a8032abc230c#1) (false)
    iob diag has finished.
    • S Schtallone
      Skript v.2023-06-20
      *** BASE SYSTEM ***
      Hardware Vendor :
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v8.1.0
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 2
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:            23G        1.7G         21G
      Total:           31G        6.8G         22G
               7792 M total memory
               5170 M used memory
               1076 M free memory
                512 M buffer memory
               1032 M swap cache
              23447 M total swap
               1659 M used swap
              21787 M free swap
      *** FILESYSTEM ***
      /var:
      33M     /var/
      31M     /var/lib
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.10.1
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        10441
      States:         8960
      Pending Updates: 0
      @schtallone
      CPU threads: 2
      Dürfte was wenig sein. Und dann scheint da abgesehen vom iobroker noch anderes rechenintensives Zeug auf der Kiste zu laufen.
      • S Schtallone
        @Homoran
                             v.2023-06-20
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v8.1.0
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
        Swap:            23G        1.7G         21G
        Total:           31G        7.0G         22G
                                admin                   6.10.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                10441
        States:                 8960
        HomoranH Offline
        HomoranH Offline
        @schtallone sagte in Performance Probleme durch Shelly Adapter?:
        wenn das ein Rechner wäre, auf dem nur ioBroker liefe, wäre diese CPUBdurchaus zu gebrauchen
        Ein NAS hat natürlich noch weitere Aufgaben.
        Was sagt denn in dessen GUI die CPU-Auslastung?
        Was läuft da sonst noch?
          dass ich hier eine miese Installation habe.
          das hab ich ja bereits im anderen Thread befürchtet.
          Habe aber auch dort keinerlei Informationen zu deinem System gefunden, ausser x86_amd64.
          was ist das denn für ein NAS?
          was sagt denn iob diag
          HomoranH Offline
          HomoranH Offline
          @homoran sagte in Performance Probleme durch Shelly Adapter?:
          wenn schon der Docker
          Mem: 7.8G
          zur Verfügung hat müsste das NAS ja deutlich mehr haben.
          Davon gibt es nicht viele.
          Schon gar nicht mit Celeron J4005.
            @schtallone
            CPU threads: 2
            Schtallone
            ist nen QNAP TS251D mit 8gb RAM.
            Hier aktuelle Performance-Monitor Daten:
            HomoranH ? 3 Antworten Letzte Antwort
            • S Schtallone
              HomoranH Offline
              HomoranH Offline
              vom NAS selbst?
                vom NAS selbst?
                Schtallone
                ja vom NAS. hier nochmals in größer
                • S Schtallone
                  @schtallone
                  Da wanken auch drei Zombies durch das System.
                  Starte das mal alles sauber durch.
                  • S Schtallone
                    HomoranH Offline
                    HomoranH Offline
                    was ist daran größer?
                    die Schrift jedenfalls nicht
                      @schtallone
                      Schtallone
                      hier nochhmals ohne diesen balken....
                      • S Schtallone
                        HomoranH Offline
                        HomoranH Offline
                        @schtallone was ist passiert?
                        nur noch 22%CPU statt vorher 66?
                        der js controller auf vernünftigen 3.18, statt 20
                          Schtallone
                          nichts, es schwankt hin und her. Ich habe durchschittlich ca. 70% CPU Auslastung gehabt. Ich starte das NAS einmal komplett neu. Bis gleich
                          • S Schtallone
                            @ticaki
                            Ich habe vor 20 min mal den device watcher ausgeschaltet.
                            top - 12:22:05 up 21:46,  0 users,  load average: 7,08, 7,24, 7,59
                            Tasks:  37 total,   2 running,  35 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 36,9 us, 21,1 sy,  0,0 ni, 12,1 id, 29,2 wa,  0,0 hi,  0,7 si,  0,0 st
                            MiB Mem :   7792,2 total,   1012,2 free,   5113,5 used,   1666,5 buff/cache
                            MiB Swap:  23447,2 total,  21722,4 free,   1724,8 used.   1911,4 avail Mem
                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                              453 iobroker  20   0   11,2g 298988  10992 S   5,3   3,7 396:15.25 iobroker.js-con
                            32461 iobroker  20   0 1062764 204584  11836 S   2,0   2,6   8:16.99 io.shelly.0
                            31327 iobroker  20   0   21,0g 167288  12832 S   1,7   2,1   3:54.99 node-red
                             1167 iobroker  20   0  851380 126644   9148 S   0,7   1,6  18:48.56 io.javascript.0
                             1390 iobroker  20   0  960232  46568  10124 R   0,7   0,6   0:37.93 io.netatmo.0
                             1854 iobroker  20   0  694088  67636   9896 S   0,7   0,8  11:39.10 io.jarvis.0
                              486 iobroker  20   0 1063652 151672   9988 S   0,3   1,9   3:27.47 io.admin.0
                             1423 iobroker  20   0  694844  42024   9476 S   0,3   0,5   0:27.42 io.shuttercontr
                             1655 iobroker  20   0  705512  61012   9400 S   0,3   0,8   1:29.35 io.sourceanalyt
                             1831 iobroker  20   0  952040  32844  10696 S   0,3   0,4   0:23.47 io.pushover.0
                             3859 root      20   0   10308   2204   1724 S   0,3   0,0   0:03.83 top
                             3878 root      20   0   10308   2144   1676 R   0,3   0,0   0:03.79 top
                                1 root      20   0    7372    204    204 S   0,0   0,0   0:00.07 bash
                              499 iobroker  20   0  866856  76112   8560 S   0,0   1,0   1:46.15 io.admin.1
                              516 iobroker  20   0   10,9g  48316   9540 S   0,0   0,6   0:25.88 io.backitup.0
                             1056 iobroker  20   0  689424  40376   8428 S   0,0   0,5   0:51.22 io.energiefluss
                             1082 iobroker  20   0  961136  47388   9816 S   0,0   0,6   1:04.70 io.cloud.0
                             1119 iobroker  20   0  950440  51728  12392 S   0,0   0,6   0:08.78 io.pvforecast.0
                             1174 iobroker  20   0  697508  42024   8908 S   0,0   0,5   0:46.79 io.modbus.0
                             1189 iobroker  20   0  779844  60304   8884 S   0,0   0,8   5:30.04 io.mqtt.0
                             1196 iobroker  20   0  700524  29568   8512 S   0,0   0,4   0:25.82 io.mqtt.1
                             1644 iobroker  20   0  691912  39412   8984 S   0,0   0,5   0:53.31 io.snmp.0
                             1666 iobroker  20   0  758052  22932   8364 S   0,0   0,3   0:22.84 io.terminal.0
                            ist seit dem auch im Log ruhiger
                            Ich mache den device watcher nochmals an und teile die ergebnisse
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            Warum hast du 2 x Admin
                            und was ich mich auch schon im anderen Thread gefragt habe
                            warum bist du BETA Tester ... hat das ein Grund !?
                            EDIT :
                            Wegen admin.1 , das war noch von gestern eine Test wegen dem Port , den kannst du deinstallieren
                            https://forum.iobroker.net/post/1044331
                            • S Schtallone
                              Moin,
                              kenne QNAP nicht, aber wenn Dein Docker und die darin enthaltenen Container schon ein Großteil des Memory auffressen, dann bleibt für das Basisbetriebssystem nicht mehr viel, man sieht auch, dass das Betriebssystem schon mal gut 1.7 GB in den Swap verschoben hat.
                              Der Tipp kam ja schon, einmal sauber neu starten, dann mal alles auf der QNAP anhalten, was Du definitiv nicht brauchst.
                              Bei mir auf der Synology sieht das mit 17 Containern und 8 GB so aus,
                              VG
                              Bernd
                              • S Schtallone
                                seit einigen Tagen bemerke ich Performance-Probeme im ioBroker. Oft können z.b. die Instancen nicht angeigt werden. Ich habe den Shelly Adapter in Verdacht, da dieser häufig folgende Fehlermeldung ausgibt:
                                2023-09-16 10:08:19.966  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8b94fc"
                                2023-09-16 10:08:19.967  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-5443b23fd3dc"
                                2023-09-16 10:08:19.968  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-5443b23d6114"
                                2023-09-16 10:08:19.968  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a820f4"
                                2023-09-16 10:08:20.526  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96370"
                                2023-09-16 10:08:21.305  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23d6114 / shellyplus2pm#5443b23d6114#1) (false)
                                2023-09-16 10:08:21.309  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-5443b23e5f74 / shellyplus2pm#5443b23e5f74#1) (false)
                                2023-09-16 10:08:21.790  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-4022d8da969c"
                                2023-09-16 10:08:21.794  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8abb7c"
                                2023-09-16 10:08:21.795  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96980"
                                2023-09-16 10:08:21.795  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-485519a2a5d4"
                                2023-09-16 10:08:21.935  - info: shelly.0 (31449) [MQTT] Device with client id "shellyplus2pm-4022d8dbe474" connected!
                                2023-09-16 10:08:22.320  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a876248"
                                2023-09-16 10:08:24.058  - info: shelly.0 (31449) [MQTT] Device with client id "shellyplus1pm-a8032ab96980" connected!
                                2023-09-16 10:08:24.359  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d794"
                                2023-09-16 10:08:24.359  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-7c87ce65d970"
                                2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
                                2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a8bf730"
                                2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-5443b23e5f74"
                                2023-09-16 10:08:24.360  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-3c610579bd34"
                                2023-09-16 10:08:24.361  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab94e10"
                                2023-09-16 10:08:24.361  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-441793acae2c"
                                2023-09-16 10:08:24.361  - error: shelly.0 (31449) [MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96370"
                                2023-09-16 10:08:24.479  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a863524 / shellyplus2pm#b8d61a863524#1) (false)
                                2023-09-16 10:08:24.525  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a8abb7c / shellyplus2pm#b8d61a8abb7c#1) (false)
                                2023-09-16 10:08:24.606  - info: shelly.0 (31449) [MQTT] Client Close:  (shellyplus2pm / shellyplus2pm-b8d61a8b94fc / shellyplus2pm#b8d61a8b94fc#1) (false
                                Hat jemand eine Idee oder ähnliche Probleme?
                                Was benötigt Ihr noch von mir als Infos?
                                Vielen Dank und Gruß
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                @schtallone
                                Da du im anderen Thread auch ein Binding beim Admin falsch hattest ,
                                zeige mal
                                iob list instances | grep port
                                • GlasfaserG Glasfaser
                                  EDIT :
                                  Schtallone
                                  @glasfaser
                                  Admin.1 ist bereits deinstalliert.
                                  Ich bin kein BETA tester, eher BETA User ;-)
                                  GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                  • S Schtallone
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Glasfaser
                                    @schtallone
                                    Kommt die Ausgabe vom Befehl noch ...
                                    oder war es das gewesen , damit kann ich/wir nichts anfangen!?
                                    ich bin kein BETA tester, eher BETA User 😉
                                    • S Schtallone
                                      Skript v.2023-06-20
                                      *** BASE SYSTEM ***
                                      Hardware Vendor :
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Docker          : v8.1.0
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      CPU threads: 2
                                      CEST +0200
                                      Etc/UTC
                                      root
                                      /root
                                      root
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Swap:            23G        1.7G         21G
                                      Total:           31G        6.8G         22G
                                               7792 M total memory
                                               5170 M used memory
                                               1076 M free memory
                                                512 M buffer memory
                                               1032 M swap cache
                                              23447 M total swap
                                               1659 M used swap
                                              21787 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      33M     /var/
                                      31M     /var/lib
                                      18M     /var/lib/apt
                                      13M     /var/lib/dpkg
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.10.1
                                      javascript:     7.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        10441
                                      States:         8960
                                      Pending Updates: 0
                                      HomoranH Offline
                                      HomoranH Offline
                                      • system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0
                                      und das ganze nochmal mit mqtt.1
                                      warum?
                                        @schtallone
                                        Schtallone
                                        schrieb am zuletzt editiert von Schtallone
                                        @glasfaser
                                        root@iobroker:/opt/iobroker# iob list instances | grep port
                                        Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
                                            at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
                                            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                        • S Schtallone
                                          @glasfaser
                                          Das ist in sich ein Widerspruch.
