  4. Fitbit App läuft mit JS Controller 5.0.12 nicht mehr
21 Beiträge 5 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • Ben1983B Offline
    Ben1983B Offline
    Ben1983
    Hallo, ich habe gerade auf JS-Controller 5.0.12 geupdatet und dann kam das hier:
    fitbit-fitness.0 2023-09-15 15:07:19.211	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    fitbit-fitness.0 2023-09-15 15:07:19.206	error	undefined is not a valid state value
    fitbit-fitness.0 2023-09-15 15:07:19.205	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9) at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
    fitbit-fitness.0 2023-09-15 15:07:19.199	error	unhandled promise rejection: undefined is not a valid state value
    fitbit-fitness.0 2023-09-15 15:07:19.197	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Jemand eine Idee?
    • Ben1983B Ben1983
      Jemand eine Idee?
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @ben1983
      Bitte bei allen Problemmeldungen IMMER die entsprechenden Versionen angeben:
      Welche Release von fitbit hast du installiert?
      Allerdings schaut es so aus als wäre der Adapter ioBroker.fitbit-fitness NICHT mit js-controller 5 kompatiobel. Siehe issue
      https://github.com/Chris-656/ioBroker.fitbit-fitness/issues/10
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
        myssv
        Also bei mir läuft der FitBit Adapter mit dem JS Controller 5.0.12
        • mcm1957M mcm1957
          @ben1983
          Ben1983B Offline
          Ben1983B Offline
          Ben1983
          @mcm57 fitbir Adapterversion: 0.4.10
          ? 1 Antwort Letzte Antwort
          • Ben1983B Ben1983
            @ben1983
            Das issue trat bei mir ganz am Anfang mit ner Alpha vom 5.x auf, seit v5.0.10 ist hier der Fehler weg.
            Welche Node Version hast du?
              @ben1983
              Ben1983B Offline
              Ben1983B Offline
              Ben1983
              @ilovegym 18.17.2
              • Ben1983B Ben1983
                @ilovegym 18.17.2
                @ben1983
                mal den adapter geloescht und neu installiert?
                Beim ersten start ohne Token wird er meckern, dann den Token holen, Adapter neu starten und er laeuft...
                So ist es jedenfalls bei mir..
                mit dem Adapter und js-controller 5.x schon 2x auf ein anderes System umgezogen, und er laeuft..
                obs an der Node-Version liegt.. k.a...
                  @ben1983
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  @ilovegym Habe die Tokens geupdatet. Jetzt erscheint wieder das hier nach dem Starten des Adapters.
                  host.buanet-iobroker-8_1_0
                  2023-09-17 17:09:57.286	error	instance system.adapter.fitbit-fitness.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  fitbit-fitness.0 2023-09-17 17:09:56.734	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  fitbit-fitness.0 2023-09-17 17:09:56.729	error	undefined is not a valid state value
                  fitbit-fitness.0 2023-09-17 17:09:56.729	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9) at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
                  fitbit-fitness.0 2023-09-17 17:09:56.726	error	unhandled promise rejection: undefined is not a valid state value
                  fitbit-fitness.0 2023-09-17 17:09:56.725	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  • W Offline
                    W Offline
                    Wahl-HHer
                    Ist bei mir auch so. Wenn ich in den Einstellungen bei den Services die Aktivitäten deaktivieren, startet die Instanz ohne Fehler.
                    Ben1983B 3 Antworten Letzte Antwort
                    • W Wahl-HHer
                      Ben1983B Offline
                      Ben1983B Offline
                      Ben1983
                      @wahl-hher Also ich habe alle Hake gesetzt und beim Start erscheint das hier:
                      fitbit-fitness.0
                      2023-09-25 09:18:59.395	error	Adapter Connection: Error: Error: Request failed with status code 401
                      • W Wahl-HHer
                        Ben1983B Offline
                        Ben1983B Offline
                        Ben1983
                        @wahl-hher Jetzt habe ich nochmal update der tokens gemacht:
                        fitbit-fitness.0
                        2023-09-25 09:21:33.186	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                        fitbit-fitness.0
                        2023-09-25 09:21:33.176	error	undefined is not a valid state value
                        fitbit-fitness.0
                        2023-09-25 09:21:33.175	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9) at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
                        fitbit-fitness.0
                        2023-09-25 09:21:33.170	error	unhandled promise rejection: undefined is not a valid state value
                        fitbit-fitness.0
                        2023-09-25 09:21:33.167	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        • W Wahl-HHer
                          Ben1983B Offline
                          Ben1983B Offline
                          Ben1983
                          schrieb am zuletzt editiert von Ben1983
                          @wahl-hher Sorry. Falsch herum verstanden.
                          Wenn ich die Aktivitäten raus nehme funktioniert es auch.
                          ABER !!! Das sind ja gerade die Daten, die mich interessieren.
                          Durchschnittlicher Puls usw.
                          W 1 Antwort Letzte Antwort
                          • Ben1983B Ben1983
                            W Offline
                            W Offline
                            Wahl-HHer
                            @ben1983
                            Mein Post war auch nicht als Lösung gedacht, sondern nur als Bestätigung des Fehlers mit der zusätzlichen Information, dass es scheinbar mit den "Aktivitäten" zusammen hängt.
                            • W Wahl-HHer
                              @ben1983
                              Ben1983B Offline
                              Ben1983B Offline
                              Ben1983
                              @wahl-hher OK.
                              Schade, dass irgendwie keiner zu dem Adapter "gehört" -
                              • Ben1983B Ben1983
                                @wahl-hher OK.
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                @ben1983
                                Der Adapter ist unter Kontrolle eines Developers. Ev. kann ich nach meinem Urlaub versuchen ihn zu kontaktieren - ihr könntet das schon jetzt versuchen.
                                In jedem Fall bitte ein Issue erstellen wo eure Erkenntnisse wann das Problem auftritt und wie es zu "umgehen" ist drinnen stehen, Das sollte ungemein helfen es einzugrenzen.
                                Ev. pingt mich nochmal in 14 Tagen wenn sich nichts getan hat.
                                Ben1983B 2 Antworten Letzte Antwort
                                • mcm1957M mcm1957
                                  @ben1983
                                  Ben1983B Offline
                                  Ben1983B Offline
                                  Ben1983
                                  @mcm57 Habe in dein Issue geschrieben:
                                  https://github.com/Chris-656/ioBroker.fitbit-fitness/issues/13
                                  • mcm1957M mcm1957
                                    @ben1983
                                    Ben1983B Offline
                                    Ben1983B Offline
                                    Ben1983
                                    @mcm57 Also bei mir ist nichts im Stable:
                                    • Ben1983B Ben1983
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      @ben1983
                                      Was willst du mir sagen?
                                      Das Issue ist nach wie vor offen. Bitte ggF den Maintainer kontaktieren.
                                      • mcm1957M mcm1957
                                        @ben1983
                                        Ben1983B Offline
                                        Ben1983B Offline
                                        Ben1983
                                        @mcm57 Dachte der Text wäre von Dir und die neue Version sollte im Stable sein.
                                        https://github.com/Chris-656/ioBroker.fitbit-fitness/issues/13#:~:text=Thanks for release,kane if desired.
                                        Also normal von github installieren?
                                        • Ben1983B Ben1983
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @ben1983 said in Fitbit App läuft mit JS Controller 5.0.12 nicht mehr:
                                          Ja, der Text ist von mir. Nu bitte lesen :-)
                                          Thanks for release.
                                          Should be available at latrs repo this afternoon.
                                          Please create a stable PR if tests are successful and mention js-controller 5 fix to process it at fadt kane if desired.
                                          Ich schreibe "should be available at LATRS repo". LATRS sollte natürlich LATEST heißen. Sorry, für Tippfehler.
                                          Bisher hat der Maintainer noch keinen PR für stable erstellt. Kann sein, dass er/sie noch Fehler sucht oder auch einem anderen Grund meint, dass die Release noch nicht für Table ready ist. Da die Release aber noch seeeehr jung ist, ist es eher normal, dass sie noch nicht im Stale Repo aufscheint.
