  4. Fitbit App läuft mit JS Controller 5.0.12 nicht mehr
21 Beiträge 5 Kommentatoren 1.9k Aufrufe 4 Beobachtet
  • W Wahl-HHer
    Ist bei mir auch so. Wenn ich in den Einstellungen bei den Services die Aktivitäten deaktivieren, startet die Instanz ohne Fehler.
    Ben1983B Offline
    Ben1983B Offline
    Ben1983
    @wahl-hher Also ich habe alle Hake gesetzt und beim Start erscheint das hier:
    fitbit-fitness.0
    2023-09-25 09:18:59.395	error	Adapter Connection: Error: Error: Request failed with status code 401
    • W Wahl-HHer
      Ben1983B Offline
      Ben1983B Offline
      Ben1983
      @wahl-hher Jetzt habe ich nochmal update der tokens gemacht:
      fitbit-fitness.0
      2023-09-25 09:21:33.186	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      fitbit-fitness.0
      2023-09-25 09:21:33.176	error	undefined is not a valid state value
      fitbit-fitness.0
      2023-09-25 09:21:33.175	error	Error: undefined is not a valid state value at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17) at FitBit._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5439:49) at FitBit.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5400:21) at FitBit.setActivityStates (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:321:9) at FitBit.getActivityRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:305:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async FitBit.getFitbitRecords (/opt/iobroker/node_modules/iobroker.fitbit-fitness/main.js:87:5)
      fitbit-fitness.0
      2023-09-25 09:21:33.170	error	unhandled promise rejection: undefined is not a valid state value
      fitbit-fitness.0
      2023-09-25 09:21:33.167	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      • W Wahl-HHer
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        schrieb am zuletzt editiert von Ben1983
        @wahl-hher Sorry. Falsch herum verstanden.
        Wenn ich die Aktivitäten raus nehme funktioniert es auch.
        ABER !!! Das sind ja gerade die Daten, die mich interessieren.
        Durchschnittlicher Puls usw.
        W 1 Antwort Letzte Antwort
        • Ben1983B Ben1983
          W Offline
          W Offline
          Wahl-HHer
          @ben1983
          Mein Post war auch nicht als Lösung gedacht, sondern nur als Bestätigung des Fehlers mit der zusätzlichen Information, dass es scheinbar mit den "Aktivitäten" zusammen hängt.
          • W Wahl-HHer
            @ben1983
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            @wahl-hher OK.
            Schade, dass irgendwie keiner zu dem Adapter "gehört" -
            • Ben1983B Ben1983
              @wahl-hher OK.
              mcm1957M Online
              mcm1957M Online
              mcm1957
              @ben1983
              Der Adapter ist unter Kontrolle eines Developers. Ev. kann ich nach meinem Urlaub versuchen ihn zu kontaktieren - ihr könntet das schon jetzt versuchen.
              In jedem Fall bitte ein Issue erstellen wo eure Erkenntnisse wann das Problem auftritt und wie es zu "umgehen" ist drinnen stehen, Das sollte ungemein helfen es einzugrenzen.
              Ev. pingt mich nochmal in 14 Tagen wenn sich nichts getan hat.
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              Ben1983B 2 Antworten Letzte Antwort
              • mcm1957M mcm1957
                @ben1983
                Ben1983B Offline
                Ben1983B Offline
                Ben1983
                @mcm57 Habe in dein Issue geschrieben:
                https://github.com/Chris-656/ioBroker.fitbit-fitness/issues/13
                • mcm1957M mcm1957
                  @ben1983
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  @mcm57 Also bei mir ist nichts im Stable:
                  • Ben1983B Ben1983
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @ben1983
                    Was willst du mir sagen?
                    Das Issue ist nach wie vor offen. Bitte ggF den Maintainer kontaktieren.
                    • mcm1957M mcm1957
                      @ben1983
                      Ben1983B Offline
                      Ben1983B Offline
                      Ben1983
                      @mcm57 Dachte der Text wäre von Dir und die neue Version sollte im Stable sein.
                      https://github.com/Chris-656/ioBroker.fitbit-fitness/issues/13#:~:text=Thanks for release,kane if desired.
                      Also normal von github installieren?
                      • Ben1983B Ben1983
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @ben1983 said in Fitbit App läuft mit JS Controller 5.0.12 nicht mehr:
                        Ja, der Text ist von mir. Nu bitte lesen :-)
                        Thanks for release.
                        Should be available at latrs repo this afternoon.
                        Please create a stable PR if tests are successful and mention js-controller 5 fix to process it at fadt kane if desired.
                        Ich schreibe "should be available at LATRS repo". LATRS sollte natürlich LATEST heißen. Sorry, für Tippfehler.
                        Bisher hat der Maintainer noch keinen PR für stable erstellt. Kann sein, dass er/sie noch Fehler sucht oder auch einem anderen Grund meint, dass die Release noch nicht für Table ready ist. Da die Release aber noch seeeehr jung ist, ist es eher normal, dass sie noch nicht im Stale Repo aufscheint.
                        • mcm1957M mcm1957
                          Thanks for release.
                          Ben1983B Offline
                          Ben1983B Offline
                          Ben1983
                          @mcm57 Ah ok. "should" überlesen.... wahrscheinlich voller Enthusiasmus 🐶
