  4. Test Adapter Plex v1.1.x
adapterplextautulli
250 Beiträge 7 Kommentatoren 53.2k Aufrufe 9 Beobachtet
  • liv-in-skyL liv-in-sky
    @ticaki
    schau mal - ist wieder da - ic schalt mal das log der instanz auf "error" :-)
       catch() 122: {"message":"connect ECONNREFUSED 192.168.178.202:32500","name":"Error","stack":"Error: connect ECONNREFUSED 192.168.178.202:32500\n at AxiosError.from (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:837:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:3016:25)\n at RedirectableRequest.emit (node:events:526:35)\n at eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)\n at ClientRequest.emit (node:events:514:28)\n at Socket.socketErrorListener (node:_http_client:501:9)\n at Socket.emit (node:events:514:28)\n at emitErrorNT (node:internal/streams/destroy:151:8)\n at emitErrorCloseNT (node:internal/streams/destroy:116:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":700,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Plex-Token":"MB-e_x5Gu1AnqxTxHrGQ","X-Plex-Target-Client-Identifier":"f7c8166be109b676-com-plexapp-android","X-Plex-Client-Identifier":"5cc42810-6dc0-44b1-8c70-747152d4f7f9","X-Plex-Device-Name":"AFTR","User-Agent":"axios/1.5.1","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.202:32500/player/timeline/poll?wait=0&commandID=128"},"code":"ECONNREFUSED","status":null}
    T Nicht stören
    T Nicht stören
    ticaki
    #241
    @liv-in-sky
    a) gib mir mal die Daten dieses Gerätes damit mal sehen kann ob ich infos finde 192.168.178.202
    b) ich hab ne Version auf Github hochgeladen, wo die Meldung ins debug geschrieben wird.
    Spenden
    • T ticaki
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      liv-in-sky
      #242
      @ticaki sagte in Test Adapter Plex v1.1.x:
      was meinst du für daten - irgendwo aus den dp ?
        T Nicht stören
        T Nicht stören
        ticaki
        #243
        @liv-in-sky
        Ne hersteller model baujahr submodel sowas halt :)
        Spenden
        • T ticaki
          @liv-in-sky
          liv-in-skyL Offline
          liv-in-skyL Offline
          liv-in-sky
          #244
          @ticaki reicht das ?
            T Nicht stören
            T Nicht stören
            ticaki
            #245
            @liv-in-sky
            Danke, ja passt. Kann ich nur mit unterdrücken der Fehlermeldung lösen, sonst lässt sich der Fernseher von Sigi nicht steuern.
            Spenden
            • T ticaki
              @liv-in-sky
              liv-in-skyL Offline
              liv-in-skyL Offline
              liv-in-sky
              #246
              @ticaki solange die warnung weg ist und nur unter debug einstellung erscheint, ist das für mich absolut ok - was ich brauche funktioniert ja
              • T Nicht stören
                T Nicht stören
                ticaki
                #247
                Neue Version ist zum Testen auf dem Weg:
                • Mindestvorraussetzung NodeJS >= 18
                • Abhängigkeiten aktualisiert
                • _playing.*.Metadata.viewOffset / +Seconds wird jetzt erzeugt und aktualisiert, kann die aber auch raus werfen wenn keiner die braucht.
                EDIT:
                Ich denke ich werfe die raus, ist mir gerade aufgefallen das die für das Mitzählen der Sekunden gedacht waren, aber dazu gibts ja jetzt seekTo. Bitte Meinung ob das jemand braucht?
                Spenden
                • mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #248
                  @ticaki
                  Wenn Dependecies angehoben werden sollte mindestens eine neue MINOR erstellt werden.
                  Bitte auch Version u d Datum im ERSTEN Post aktualisieren.
                  DANKE
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • T ticaki
                    EDIT:
                    sigi234S Online
                    sigi234S Online
                    sigi234
                    #249
                    EDIT:
                    Nein, wichtig ist mir Playtime in Prozent (0-100)
                    Immer Daten sichern!
                    • mcm1957M mcm1957
                      @ticaki
                      DANKE
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      #250
                      @mcm1957
                      Ok, werde ich in Zukunft beachten
                      Spenden
