  4. Test Adapter Plex v1.1.x
adapterplextautulli
250 Beiträge 7 Kommentatoren 53.2k Aufrufe 9 Beobachtet
  • T ticaki
    @liv-in-sky
    Erstmal der Fehler ist egal, wird abgefangen und behandelt nervt nur im log. Aber durch das löschen der States ist entweder die ip oder der port verschwunden(weiß net mehr was es genau war) und damit weiß der Adapter das der Player das nicht unterstützt und versuchts erst garnicht.
    liv-in-skyL Offline
    liv-in-skyL Offline
    #240
    @ticaki
    schau mal - ist wieder da - ic schalt mal das log der instanz auf "error" :-)
       catch() 122: {"message":"connect ECONNREFUSED 192.168.178.202:32500","name":"Error","stack":"Error: connect ECONNREFUSED 192.168.178.202:32500\n at AxiosError.from (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:837:14)\n at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.plex/node_modules/axios/dist/node/axios.cjs:3016:25)\n at RedirectableRequest.emit (node:events:526:35)\n at eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24)\n at ClientRequest.emit (node:events:514:28)\n at Socket.socketErrorListener (node:_http_client:501:9)\n at Socket.emit (node:events:514:28)\n at emitErrorNT (node:internal/streams/destroy:151:8)\n at emitErrorCloseNT (node:internal/streams/destroy:116:3)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":700,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","X-Plex-Token":"MB-e_x5Gu1AnqxTxHrGQ","X-Plex-Target-Client-Identifier":"f7c8166be109b676-com-plexapp-android","X-Plex-Client-Identifier":"5cc42810-6dc0-44b1-8c70-747152d4f7f9","X-Plex-Device-Name":"AFTR","User-Agent":"axios/1.5.1","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.202:32500/player/timeline/poll?wait=0&commandID=128"},"code":"ECONNREFUSED","status":null}
    • liv-in-skyL liv-in-sky
      @ticaki
      T Nicht stören
      T Nicht stören
      ticaki
      #241
      @liv-in-sky
      a) gib mir mal die Daten dieses Gerätes damit mal sehen kann ob ich infos finde 192.168.178.202
      b) ich hab ne Version auf Github hochgeladen, wo die Meldung ins debug geschrieben wird.
      Spenden
      • T ticaki
        @liv-in-sky
        liv-in-skyL Offline
        liv-in-skyL Offline
        #242
        @ticaki sagte in Test Adapter Plex v1.1.x:
        was meinst du für daten - irgendwo aus den dp ?
          T Nicht stören
          T Nicht stören
          ticaki
          #243
          @liv-in-sky
          Ne hersteller model baujahr submodel sowas halt :)
          Spenden
          • T ticaki
            @liv-in-sky
            liv-in-skyL Offline
            liv-in-skyL Offline
            #244
            @ticaki reicht das ?
              T Nicht stören
              T Nicht stören
              ticaki
              #245
              @liv-in-sky
              Danke, ja passt. Kann ich nur mit unterdrücken der Fehlermeldung lösen, sonst lässt sich der Fernseher von Sigi nicht steuern.
              Spenden
              • T ticaki
                @liv-in-sky
                liv-in-skyL Offline
                liv-in-skyL Offline
                #246
                @ticaki solange die warnung weg ist und nur unter debug einstellung erscheint, ist das für mich absolut ok - was ich brauche funktioniert ja
                • T Nicht stören
                  T Nicht stören
                  ticaki
                  #247
                  Neue Version ist zum Testen auf dem Weg:
                  • Mindestvorraussetzung NodeJS >= 18
                  • Abhängigkeiten aktualisiert
                  • _playing.*.Metadata.viewOffset / +Seconds wird jetzt erzeugt und aktualisiert, kann die aber auch raus werfen wenn keiner die braucht.
                  EDIT:
                  Ich denke ich werfe die raus, ist mir gerade aufgefallen das die für das Mitzählen der Sekunden gedacht waren, aber dazu gibts ja jetzt seekTo. Bitte Meinung ob das jemand braucht?
                  Spenden
                  • mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #248
                    @ticaki
                    Wenn Dependecies angehoben werden sollte mindestens eine neue MINOR erstellt werden.
                    Bitte auch Version u d Datum im ERSTEN Post aktualisieren.
                    DANKE
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • T ticaki
                      EDIT:
                      sigi234S Online
                      sigi234S Online
                      #249
                      EDIT:
                      Nein, wichtig ist mir Playtime in Prozent (0-100)
                      • mcm1957M mcm1957
                        @ticaki
                        DANKE
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        #250
                        @mcm1957
                        Ok, werde ich in Zukunft beachten
                        Spenden
