  4. (Gelöst) OpenHab : Adapter crash bei aenderung einen dimm wertes
3 Beiträge 2 Kommentatoren 4.6k Aufrufe
  • DutchmanD Offline
    DutchmanD Offline
    Dutchman
    In OpenHab habe ich ein item dimmer, dieses laesst sich auch steuern.
    Aenderungen der werten in OpenHab kommen im iobroker an, aenderen das wertes laesst den adapater crashes.
    Nach adapter neustart wird dan wieder der wert aus OpenHab uebernommen:
    Debug log:
    openhab.0	2017-07-03 09:51:12.764	debug	inMem message openhab.0.* openhab.0.items.Dimmer_Test val=0, ack=true, ts=1499068241521, q=64, from=system.adapter.openhab.0, lc=1499068241494
    openhab.0	2017-07-03 09:51:12.573	debug	inMem message openhab.0.* openhab.0.info.connection val=true, ack=true, ts=1499068272566, q=0, from=system.adapter.openhab.0, lc=1499068272566
    openhab.0	2017-07-03 09:51:12.542	info	connected
    openhab.0	2017-07-03 09:51:12.507	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.openhab, node: v4.8.3
    openhab.0	2017-07-03 09:51:12.479	debug	statesDB connected
    openhab.0	2017-07-03 09:51:12.446	debug	objectDB connected
    host.HomeControl	2017-07-03 09:51:11.623	info	instance system.adapter.openhab.0 started with pid 4535
    host.HomeControl	2017-07-03 09:50:41.584	info	Restart adapter system.adapter.openhab.0 because enabled
    host.HomeControl	2017-07-03 09:50:41.584	error	instance system.adapter.openhab.0 terminated with code 0 (OK)
    openhab.0	2017-07-03 09:50:41.558	info	terminating
    openhab.0	2017-07-03 09:50:41.546	debug	inMem message openhab.0.* openhab.0.info.connection val=false, ack=true, ts=1499068241539, q=0, from=system.adapter.openhab.0, lc=1499068241539
    openhab.0	2017-07-03 09:50:41.540	debug	inMem message openhab.0.* openhab.0.items.Dimmer_Test val=10, ack=true, ts=1499068241521, q=64, from=system.adapter.openhab.0, lc=1499068241494
    openhab.0	2017-07-03 09:50:41.537	info	cleaned everything up...
    openhab.0	2017-07-03 09:50:41.536	error	at processImmediate [as _immediateCallback] (timers.js:396:17)
    openhab.0	2017-07-03 09:50:41.536	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.openhab/node_modules/request/request.js:581:7)
    openhab.0	2017-07-03 09:50:41.536	error	at end (/opt/iobroker/node_modules/iobroker.openhab/node_modules/request/request.js:552:18)
    openhab.0	2017-07-03 09:50:41.536	error	at Request.write (/opt/iobroker/node_modules/iobroker.openhab/node_modules/request/request.js:1514:27)
    openhab.0	2017-07-03 09:50:41.536	error	at ClientRequest.OutgoingMessage.write (_http_outgoing.js:459:11)
    openhab.0	2017-07-03 09:50:41.536	error	TypeError: first argument must be a string or Buffer
    openhab.0	2017-07-03 09:50:41.533	error	uncaught exception: first argument must be a string or Buffer
    openhab.0	2017-07-03 09:50:41.518	warn	Cannot write "openhab.0.items.Dimmer_Test": Error: Argument error, options.body.
    openhab.0	2017-07-03 09:50:41.509	debug	http://192.168.1.243:8080/rest/items/Dimmer_Test
    openhab.0	2017-07-03 09:50:41.506	debug	inMem message openhab.0.* openhab.0.items.Dimmer_Test val=10, ack=false, ts=1499068241494, q=0, from=system.adapter.admin.0, lc=1499068241494
    openhab.0	2017-07-03 09:50:02.701	debug	inMem message openhab.0.* openhab.0.info.connection val=true, ack=true, ts=1499068202691, q=0, from=system.adapter.openhab.0, lc=1499068202691
    openhab.0	2017-07-03 09:50:02.690	info	connected
    openhab.0	2017-07-03 09:50:02.419	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.openhab, node: v4.8.3
    openhab.0	2017-07-03 09:50:02.380	debug	statesDB connected
    openhab.0	2017-07-03 09:50:02.300	debug	objectDB connected
    host.HomeControl	2017-07-03 09:50:00.419	info	instance system.adapter.openhab.0 started with pid 4501
    host.HomeControl	2017-07-03 09:49:58.197	info	instance system.adapter.openhab.0 terminated with code 0 (OK)
    • BluefoxB Offline
      BluefoxB Offline
      @Dutchman:
      Debug log:
      Bitte die Version 0.1.4 testen.
      • DutchmanD Offline
        DutchmanD Offline
        Dutchman
        fixed mit version 1.0.4 ! Danke dir !!!
