  4. (gelöst) Sonoff Adapter hat keine Datenpunkte
    5.3k
42 Beiträge 6 Kommentatoren 4.5k Aufrufe 4 Beobachtet
  • W WilliKlein
    @dp20eic
    sonoff.0
    2023-07-12 20:49:55.442	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1689187795435,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1689120066039}
    sonoff.0
    2023-07-12 20:49:55.423	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:49:55.352	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:49:54.999	debug	Plugin sentry Initialize Plugin (enabled=true)
    sonoff.0
    2023-07-12 20:49:50.429	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:49:50.428	debug	Plugin sentry destroyed
    sonoff.0
    2023-07-12 20:49:50.427	info	terminating
    sonoff.0
    2023-07-12 20:49:50.425	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:48:29.906	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:48:18.540	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1689187698533,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1689120066039}
    sonoff.0
    2023-07-12 20:48:18.504	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:48:18.424	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:48:18.075	debug	Plugin sentry Initialize Plugin (enabled=true)
    sonoff.0
    2023-07-12 20:48:13.482	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:48:13.481	debug	Plugin sentry destroyed
    sonoff.0
    2023-07-12 20:48:13.480	info	terminating
    sonoff.0
    2023-07-12 20:48:13.476	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:46:25.113	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:46:13.162	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1689187573156,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1689120066039}
    sonoff.0
    2023-07-12 20:46:13.144	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:46:13.071	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:46:12.740	debug	Plugin sentry Initialize Plugin (enabled=true)
    sonoff.0
    2023-07-12 20:46:08.206	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:46:08.203	info	terminating
    sonoff.0
    2023-07-12 20:46:08.199	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:44:33.356	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:44:33.283	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:44:27.918	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:44:27.915	info	terminating
    sonoff.0
    2023-07-12 20:44:27.910	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:44:20.240	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:42:15.417	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:40:10.605	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:38:05.744	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:36:00.936	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:33:56.103	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:31:51.200	warn	Client [DVES_E0F23B] has invalid password or username
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @williklein
    Original:
    @crunchip sagte in Sonoff Adapter hat keine Datenpunkte:
    sudo netstat -tulpen
    Und dann Deine Eingabe:
    @williklein sagte in Sonoff Adapter hat keine Datenpunkte:
    sudo netstad -tulben
    Finde den Fehler :)
    Und Dein System ist auch nicht grad auf neuem Stand !
    Lehrling seit 1975 !!!
      @williklein du darfst den Port nicht einfach so ändern, könnte anderweitug schon belegt sein
      Bzw zeig mal die Ausgabe von
      W Offline
      W Offline
      WilliKlein
      @crunchip
      machmal ist man einfach zu blöd. Jetzt aber richtig
      pi@raspberrypi:~ $ sudo netstat -tulben
      netstat: invalid option -- 'b'
      usage: netstat [-vWeenNcCF] [<Af>] -r         netstat {-V|--version|-h|--help}
             netstat [-vWnNcaeol] [<Socket> ...]
             netstat { [-vWeenNac] -i | [-cnNe] -M | -s [-6tuw] }
              -r, --route              display routing table
              -i, --interfaces         display interface table
              -g, --groups             display multicast group memberships
              -s, --statistics         display networking statistics (like SNMP)
              -M, --masquerade         display masqueraded connections
              -v, --verbose            be verbose
              -W, --wide               don't truncate IP addresses
              -n, --numeric            don't resolve names
              --numeric-hosts          don't resolve host names
              --numeric-ports          don't resolve port names
              --numeric-users          don't resolve user names
              -N, --symbolic           resolve hardware names
              -e, --extend             display other/more information
              -p, --programs           display PID/Program name for sockets
              -o, --timers             display timers
              -c, --continuous         continuous listing
              -l, --listening          display listening server sockets
              -a, --all                display all sockets (default: connected)
              -F, --fib                display Forwarding Information Base (default)
              -C, --cache              display routing cache instead of FIB
              -Z, --context            display SELinux security context for sockets
        <Socket>={-t|--tcp} {-u|--udp} {-U|--udplite} {-S|--sctp} {-w|--raw}
                 {-x|--unix} --ax25 --ipx --netrom
        <AF>=Use '-6|-4' or '-A <af>' or '--<af>'; default: inet
        List of possible address families (which support routing):
          inet (DARPA Internet) inet6 (IPv6) ax25 (AMPR AX.25)
          netrom (AMPR NET/ROM) ipx (Novell IPX) ddp (Appletalk DDP)
          x25 (CCITT X.25)
      pi@raspberrypi:~ $
      DJMarc75D crunchipC 2 Antworten Letzte Antwort
      • W WilliKlein
        @crunchip
            x25 (CCITT X.25)
        pi@raspberrypi:~ $
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        finde nochmal den Fehler
        • W WilliKlein
          @crunchip
              x25 (CCITT X.25)
          pi@raspberrypi:~ $
          crunchipC Offline
          crunchipC Offline
          Jetzt aber richtig
          nicht ganz, kürz es ab
          sudo netstat -ltp
          W 1 Antwort Letzte Antwort
            Jetzt aber richtig
            sudo netstat -ltp
            W Offline
            W Offline
            WilliKlein
            @crunchip
             sudo netstat -ltp
            Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
            tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      585/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      564/vncserver-x11-c
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      3211437/io.shelly.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      3217593/io.sonoff.0
            tcp        0      0 localhost:ipp           0.0.0.0:*               LISTEN      3201754/cupsd
            tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      548/iobroker.js-con
            tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      548/iobroker.js-con
            tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      585/sshd: /usr/sbin
            tcp6       0      0 [::]:5900               [::]:*                  LISTEN      564/vncserver-x11-c
            tcp6       0      0 [::]:8082               [::]:*                  LISTEN      2913709/io.web.0
            tcp6       0      0 [::]:tproxy             [::]:*                  LISTEN      120900/io.admin.0
            tcp6       0      0 localhost:ipp           [::]:*                  LISTEN      3201754/cupsd
            pi@raspberrypi:~ $
            • W WilliKlein
              @dp20eic
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              sonoff.0
              crunchipC Offline
              crunchipC Offline
              da hast du wohl dich irgendwo vertippt
              passt, ist nicht anderweitig belegt
              W 2 Antworten Letzte Antwort
                W Offline
                W Offline
                WilliKlein
                Das kann nicht sein, ich habe "Willi1" all Benutzernamen und bei dem Passwort kann ich mich nicht vertippt haben, denn das Passwort nutze ich auch beim IOBroker.
                  W Offline
                  W Offline
                  WilliKlein
                  schrieb am zuletzt editiert von WilliKlein
                  @crunchip
                  wer ist denn damit gemeint, ist das die Tasmota App
                  Für wen wird das Passwort gebraucht ? oder mit welchem Passwort wird das verglichen ?
                  • W WilliKlein
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    na dein tasmota Gerät
                    Das kann nicht sein
                    ist aber so, vllt beim Passwort groß/klein Schreibung oder ein Leerzeichen was du übersehen hast
                    die Daten müssen im jeweiligen Gerät mit dem Adapter übereinstimmen
                      Das kann nicht sein
                      W Offline
                      W Offline
                      WilliKlein
                      Wenn es nur dafür genutzt wird dann gebe ich da mal einen anderen Namen und Passwort ein (bei beiden natürlich das gleiche)
                      • W WilliKlein
                        crunchipC Offline
                        crunchipC Offline
                        ja
                          ja
                          W Offline
                          W Offline
                          WilliKlein
                          @crunchip
                          Also, das kann es nicht sein, anderer Name und Passwort nur Zahlen, Ergebnis ist genauso
                          Es ist doch auch nur eine Warnmeldung.
                          Habt ihr keine Idee, was es noch sein könnte ? oder ist das sicher.
                          Kann es nicht sein das es mit der Konsolenmeldung von Tasmota zu tun hat?
                          21:56:06.563 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.178.92:1883, rc -4. Wiederversuch in 60 s
                          • W WilliKlein
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            seh nix
                            wenn es die gleiche Meldung sein sollte, ist es sicher, das du etwas falsch eingegeben hast
                            diese Meldung sagt aus das keine Verbindung zu stande kommt und die kann nur zustande kommen, wenn die Zugangsdaten übereinstimmen
                            noch mal die unbeantwortete Frage
                            @dp20eic sagte in Sonoff Adapter hat keine Datenpunkte:
                            192.168.178.92 ist der ioBroker?
                              seh nix
                              W Offline
                              W Offline
                              WilliKlein
                              ja das ist der ioBroker
                                seh nix
                                W Offline
                                W Offline
                                WilliKlein
                                seh nix
                                sonoff.0
                                2023-07-12 22:57:07.895	warn	Client [DVES_E0F23B] has invalid password or username
                                sonoff.0
                                2023-07-12 22:56:02.982	warn	Client [DVES_E0F23B] has invalid password or username
                                • W WilliKlein
                                  seh nix
                                  sonoff.0
                                  sonoff.0
                                  crunchipC Offline
                                  crunchipC Offline
                                  @williklein kann doch net sein, sind da irgendwelche Sonderzeichen? sonst fällt mir nix ein
                                  bzw starte mal den pi neu durch
                                    TT-Tom
                                    @crunchip
                                    Vielleicht mal ohne Passwort und User probieren, damit sollte es doch funktionieren.
                                    Gruß Tom
                                    Public Transport
                                    NSPanel Adapter Wiki
                                    crunchipC W 2 Antworten Letzte Antwort
                                    • T TT-Tom
                                      @crunchip
                                      crunchipC Offline
                                      crunchipC Offline
                                      @tt-tom auch ne Möglichkeit
                                      eine Idee hätt ich noch, und zwar kann es zu Störungen/Fehlverhalten der mqtt übertragung kommen, wenn z.b die IP Adresse des Gerätes doppelt vergeben ist
                                      mal im Router kontrollieren, oder dem Gerät mal eine andere freie IP geben
                                      • T TT-Tom
                                        @crunchip
                                        W Offline
                                        W Offline
                                        WilliKlein
                                        @tt-tom
                                        hallo Tom, die Idee hatte ich vor 5 Minuten selbst und siehe da, die ist richtig
                                        ich habe Name und Passwort rausgenommen und habe sofort gesehen, das die Fehlermeldung in der Console von Tasmota nicht mehr kommt und habe dann sofort in den Instanzen geschaut, da was der sonoff Adapter grün, was er vorher nur war.
                                        2 Tage damit rumgeärgert und schon ärger mit der Frau.
                                        Alle Datenpunkte sind schon da
                                        Der Gaszähler zählt auch. Der ist schon bei 3000, was mir viel vorkommt.
                                        Das checke ich dann später.
                                          W Offline
                                          W Offline
                                          WilliKlein
                                          @crunchip
                                          siehe meine Antwort an Tom.
                                          Die Frage, die ich euch jetzt stellen muss, kann ich das so lassen, ohne Benutzer und ohne Passwort ?
