  4. (gelöst) Sonoff Adapter hat keine Datenpunkte
    5.3k
42 Beiträge 6 Kommentatoren 4.5k Aufrufe 4 Beobachtet
  • W WilliKlein
    @dp20eic
    sonoff.0
    2023-07-12 20:49:55.442	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1689187795435,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1689120066039}
    sonoff.0
    2023-07-12 20:49:55.423	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:49:55.352	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:49:54.999	debug	Plugin sentry Initialize Plugin (enabled=true)
    sonoff.0
    2023-07-12 20:49:50.429	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:49:50.428	debug	Plugin sentry destroyed
    sonoff.0
    2023-07-12 20:49:50.427	info	terminating
    sonoff.0
    2023-07-12 20:49:50.425	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:48:29.906	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:48:18.540	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1689187698533,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1689120066039}
    sonoff.0
    2023-07-12 20:48:18.504	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:48:18.424	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:48:18.075	debug	Plugin sentry Initialize Plugin (enabled=true)
    sonoff.0
    2023-07-12 20:48:13.482	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:48:13.481	debug	Plugin sentry destroyed
    sonoff.0
    2023-07-12 20:48:13.480	info	terminating
    sonoff.0
    2023-07-12 20:48:13.476	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:46:25.113	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:46:13.162	debug	stateChange sonoff.0.info.connection: {"val":"","ack":true,"ts":1689187573156,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1689120066039}
    sonoff.0
    2023-07-12 20:46:13.144	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:46:13.071	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:46:12.740	debug	Plugin sentry Initialize Plugin (enabled=true)
    sonoff.0
    2023-07-12 20:46:08.206	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:46:08.203	info	terminating
    sonoff.0
    2023-07-12 20:46:08.199	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:44:33.356	info	Starting MQTT authenticated server on port 1883
    sonoff.0
    2023-07-12 20:44:33.283	info	starting. Version 2.5.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.18.0, js-controller: 4.0.23
    sonoff.0
    2023-07-12 20:44:27.918	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-07-12 20:44:27.915	info	terminating
    sonoff.0
    2023-07-12 20:44:27.910	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-07-12 20:44:20.240	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:42:15.417	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:40:10.605	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:38:05.744	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:36:00.936	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:33:56.103	warn	Client [DVES_E0F23B] has invalid password or username
    sonoff.0
    2023-07-12 20:31:51.200	warn	Client [DVES_E0F23B] has invalid password or username
    crunchipC Offline
    crunchipC Offline
    @williklein sagte in Sonoff Adapter hat keine Datenpunkte:
    da hast du wohl dich irgendwo vertippt
    0 0.0.0.0:1883 0.0.0.0:* LISTEN 3217593/io.sonoff.0
    passt, ist nicht anderweitig belegt
    W 2 Antworten Letzte Antwort
      W Offline
      W Offline
      WilliKlein
      @crunchip sagte in Sonoff Adapter hat keine Datenpunkte:
      Das kann nicht sein, ich habe "Willi1" all Benutzernamen und bei dem Passwort kann ich mich nicht vertippt haben, denn das Passwort nutze ich auch beim IOBroker.
        W Offline
        W Offline
        WilliKlein
        schrieb am zuletzt editiert von WilliKlein
        @crunchip
        wer ist denn damit gemeint, ist das die Tasmota App
        Für wen wird das Passwort gebraucht ? oder mit welchem Passwort wird das verglichen ?
        • W WilliKlein
          @crunchip
          crunchipC Offline
          crunchipC Offline
          na dein tasmota Gerät
          Das kann nicht sein
          ist aber so, vllt beim Passwort groß/klein Schreibung oder ein Leerzeichen was du übersehen hast
          die Daten müssen im jeweiligen Gerät mit dem Adapter übereinstimmen
          W 1 Antwort Letzte Antwort
            Das kann nicht sein
            W Offline
            W Offline
            WilliKlein
            Wenn es nur dafür genutzt wird dann gebe ich da mal einen anderen Namen und Passwort ein (bei beiden natürlich das gleiche)
            • W WilliKlein
              crunchipC Offline
              crunchipC Offline
              ja
                ja
                W Offline
                W Offline
                WilliKlein
                @crunchip
                Also, das kann es nicht sein, anderer Name und Passwort nur Zahlen, Ergebnis ist genauso
                Es ist doch auch nur eine Warnmeldung.
                Habt ihr keine Idee, was es noch sein könnte ? oder ist das sicher.
                Kann es nicht sein das es mit der Konsolenmeldung von Tasmota zu tun hat?
                21:56:06.563 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.178.92:1883, rc -4. Wiederversuch in 60 s
                • W WilliKlein
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  seh nix
                  wenn es die gleiche Meldung sein sollte, ist es sicher, das du etwas falsch eingegeben hast
                  diese Meldung sagt aus das keine Verbindung zu stande kommt und die kann nur zustande kommen, wenn die Zugangsdaten übereinstimmen
                  noch mal die unbeantwortete Frage
                  @dp20eic sagte in Sonoff Adapter hat keine Datenpunkte:
                  192.168.178.92 ist der ioBroker?
                    seh nix
                    W Offline
                    W Offline
                    WilliKlein
                    ja das ist der ioBroker
                      seh nix
                      W Offline
                      W Offline
                      WilliKlein
                      seh nix
                      sonoff.0
                      2023-07-12 22:57:07.895	warn	Client [DVES_E0F23B] has invalid password or username
                      sonoff.0
                      2023-07-12 22:56:02.982	warn	Client [DVES_E0F23B] has invalid password or username
                      • W WilliKlein
                        seh nix
                        sonoff.0
                        sonoff.0
                        crunchipC Offline
                        crunchipC Offline
                        @williklein kann doch net sein, sind da irgendwelche Sonderzeichen? sonst fällt mir nix ein
                        bzw starte mal den pi neu durch
                          TT-Tom
                          @crunchip
                          Vielleicht mal ohne Passwort und User probieren, damit sollte es doch funktionieren.
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          crunchipC W 2 Antworten Letzte Antwort
                          • T TT-Tom
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            @tt-tom auch ne Möglichkeit
                            eine Idee hätt ich noch, und zwar kann es zu Störungen/Fehlverhalten der mqtt übertragung kommen, wenn z.b die IP Adresse des Gerätes doppelt vergeben ist
                            mal im Router kontrollieren, oder dem Gerät mal eine andere freie IP geben
                            • T TT-Tom
                              @crunchip
                              W Offline
                              W Offline
                              WilliKlein
                              @tt-tom
                              hallo Tom, die Idee hatte ich vor 5 Minuten selbst und siehe da, die ist richtig
                              ich habe Name und Passwort rausgenommen und habe sofort gesehen, das die Fehlermeldung in der Console von Tasmota nicht mehr kommt und habe dann sofort in den Instanzen geschaut, da was der sonoff Adapter grün, was er vorher nur war.
                              2 Tage damit rumgeärgert und schon ärger mit der Frau.
                              Alle Datenpunkte sind schon da
                              Der Gaszähler zählt auch. Der ist schon bei 3000, was mir viel vorkommt.
                              Das checke ich dann später.
                                W Offline
                                W Offline
                                WilliKlein
                                @crunchip
                                siehe meine Antwort an Tom.
                                Die Frage, die ich euch jetzt stellen muss, kann ich das so lassen, ohne Benutzer und ohne Passwort ?
                                • W WilliKlein
                                  @crunchip
                                  TT-Tom
                                  @williklein
                                  Ich habe auch nicht alle Geräte geschützt. Muss jeder selber wissen.
                                  Gruß Tom
                                  Public Transport
                                  • W WilliKlein
                                    @tt-tom
                                    TT-Tom
                                    @williklein
                                    Beim gaszähler musst du prüfen wie viele Impulse ein Kubikmeter sind. Vermutlich musst du ein Faktor noch im Script eintragen.
                                    Mache dazu aber ein neuen Thread auf. Diesen kannst du auf gelöst setzen.
                                    Gruß Tom
                                    Public Transport
