  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • Ben1983B Ben1983
    @haus-automatisierung Habe ich versucht... keine Änderung.
    mit der 0.0.12
    auch hat er tzotz der Einstellung 0 und 1 Dezimalstelle 3 dargestellt.
    (Dezimalstellen können auch in den negativen Bereich konfiguriert werden.
    2023-06-08 12:34:26.951 - info: host.buanet-iobroker "system.adapter.awtrix-light.0" enabled
    2023-06-08 12:34:27.104 - info: host.buanet-iobroker instance system.adapter.awtrix-light.0 started with pid 23842
    2023-06-08 12:34:27.635 - debug: awtrix-light.0 (23842) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2023-06-08 12:34:27.677 - debug: awtrix-light.0 (23842) Objects client ready ... initialize now
    2023-06-08 12:34:27.678 - debug: awtrix-light.0 (23842) Objects create System PubSub Client
    2023-06-08 12:34:27.679 - debug: awtrix-light.0 (23842) Objects create User PubSub Client
    2023-06-08 12:34:27.720 - debug: awtrix-light.0 (23842) Objects client initialize lua scripts
    2023-06-08 12:34:27.724 - debug: awtrix-light.0 (23842) Objects connected to redis: 127.0.0.1:9001
    2023-06-08 12:34:27.746 - debug: awtrix-light.0 (23842) Redis States: Use Redis connection: 127.0.0.1:9000
    2023-06-08 12:34:27.757 - debug: awtrix-light.0 (23842) States create System PubSub Client
    2023-06-08 12:34:27.758 - debug: awtrix-light.0 (23842) States create User PubSub Client
    2023-06-08 12:34:27.818 - debug: awtrix-light.0 (23842) States connected to redis: 127.0.0.1:9000
    2023-06-08 12:34:28.710 - info: awtrix-light.0 (23842) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
    2023-06-08 12:34:28.729 - debug: awtrix-light.0 (23842) API is offline
    2023-06-08 12:34:28.730 - debug: awtrix-light.0 (23842) refreshing device state
    2023-06-08 12:34:28.730 - debug: awtrix-light.0 (23842) re-creating refresh state timeout
    2023-06-08 12:34:28.730 - debug: awtrix-light.0 (23842) sending "GET" request to "/api/stats" without data
    2023-06-08 12:34:28.852 - debug: awtrix-light.0 (23842) received 200 response from "/api/stats" with content: {"bat":68,"bat_raw":606,"lux":"8","ldr_raw":558,"ram":141244,"bri":120,"temp":"26","hum":"27","uptime":"1645","wifi_signal":-60,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":true,"indicator3":true}
    2023-06-08 12:34:28.853 - warn: awtrix-light.0 (23842) You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
    2023-06-08 12:34:28.916 - debug: awtrix-light.0 (23842) sending "GET" request to "/api/settings" without data
    2023-06-08 12:34:29.057 - debug: awtrix-light.0 (23842) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":65535,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":7327,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
    2023-06-08 12:34:29.113 - debug: awtrix-light.0 (23842) [initCustomApps] Found custom app "gridpower" with objId alias.0.Allgemein.Leistung.WirkleistungGesamt - subscribed to changes
    2023-06-08 12:34:29.118 - debug: awtrix-light.0 (23842) [initCustomApps] Found custom app "externaltemperature" with objId alias.0.Talstrasse1A.Temperatur.Aussentemperatur - subscribed to changes
    2023-06-08 12:34:29.122 - debug: awtrix-light.0 (23842) [initCustomApps] Found custom app "pvpower" with objId alias.0.PV-Anlage.Leistung.WirkleistungPv - subscribed to changes
    2023-06-08 12:34:29.128 - debug: awtrix-light.0 (23842) [initCustomApps] Found custom app "storagesoc" with objId alias.0.Speicher.Batterie.SOC - subscribed to changes
    2023-06-08 12:34:29.132 - debug: awtrix-light.0 (23842) [initCustomApps] Found custom app "storagepower" with objId alias.0.Speicher.Leistung.WirkleistungSpeicher - subscribed to changes
    2023-06-08 12:34:29.133 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "gridpower" with icon "49243" and text "%s %u"
    2023-06-08 12:34:29.133 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.Allgemein.Leistung.WirkleistungGesamt" from 26.03667449951172 to 26,037 (3 decimals)
    2023-06-08 12:34:29.134 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=gridpower" with data: {"text":"26,037 W","icon":"49243","duration":5}
    2023-06-08 12:34:29.257 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=gridpower" with content: "OK"
    2023-06-08 12:34:29.257 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "externaltemperature" with icon "38231" and text "%s %u"
    2023-06-08 12:34:29.258 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" from 24.923294067382812 to 24,9 (1 decimals)
    2023-06-08 12:34:29.258 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=externaltemperature" with data: {"text":"24,9 °C","icon":"38231","duration":5}
    2023-06-08 12:34:29.286 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=externaltemperature" with content: "OK"
    2023-06-08 12:34:29.287 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "pvpower" with icon "15124" and text "%s %u"
    2023-06-08 12:34:29.287 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.PV-Anlage.Leistung.WirkleistungPv" from 1075.0546875 to 1.075,055 (3 decimals)
    2023-06-08 12:34:29.287 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=pvpower" with data: {"text":"1.075,055 W","icon":"15124","duration":5}
    2023-06-08 12:34:29.317 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=pvpower" with content: "OK"
    2023-06-08 12:34:29.317 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "storagesoc" with icon "49520" and text "%s %u"
    2023-06-08 12:34:29.318 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=storagesoc" with data: {"text":"17 %","icon":"49520","duration":5}
    2023-06-08 12:34:29.349 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=storagesoc" with content: "OK"
    2023-06-08 12:34:29.349 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "storagepower" with icon "49520" and text "%s %u"
    2023-06-08 12:34:29.350 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.Speicher.Leistung.WirkleistungSpeicher" from 992.4154052734375 to 992,415 (3 decimals)
    2023-06-08 12:34:29.350 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=storagepower" with data: {"text":"992,415 W","icon":"49520","duration":5}
    2023-06-08 12:34:29.381 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=storagepower" with content: "OK"
    2023-06-08 12:34:29.382 - debug: awtrix-light.0 (23842) [initHistoryApps] getting history data for app "netz" of "alias.0.Allgemein.Leistung.WirkleistungGesamt" from influxdb.0
    2023-06-08 12:34:30.054 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 41.51405334472656 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:30.064 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1073.4298095703125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:30.076 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 980.4588623046875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:32.063 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 25.6341552734375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:32.079 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1074.4156494140625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:32.087 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 982.1852416992188 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:34.074 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 29.07257843017578 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:34.083 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1073.947265625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:34.094 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 989.5995483398438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:36.076 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 17.389389038085938 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:36.083 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1067.658935546875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:36.093 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 994.9559936523438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:38.055 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 42.191253662109375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:38.063 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1073.6866455078125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:38.071 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 966.4230346679688 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:40.068 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 34.37359619140625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:40.078 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1073.1005859375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:40.086 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 977.9344482421875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:42.057 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 28.61560821533203 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:42.067 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1072.6226806640625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:42.077 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 980.1719360351562 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:44.049 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 24.090599060058594 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:44.061 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1072.5955810546875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:44.071 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 984.1316528320312 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:44.074 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.02789306640625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:46.047 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 32.416526794433594 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:46.052 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1072.4130859375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:46.146 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 974.3511962890625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:46.148 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.02789306640625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:48.050 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 29.598251342773438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:48.057 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1067.0916748046875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:48.064 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 990.41357421875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:48.069 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.062789916992188 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:48.555 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Batterie.SOC" to 16 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:50.037 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 17.227439880371094 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:50.041 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1071.722900390625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:50.045 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 994.4326171875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:50.051 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.062789916992188 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:52.070 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 26.324874877929688 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:52.081 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1071.307373046875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:52.093 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 990.74072265625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:52.100 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 24.993026733398438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:54.048 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 18.498321533203125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:54.058 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1068.7779541015625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:54.069 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 992.2620239257812 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:54.074 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 24.993026733398438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:56.070 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 25.875946044921875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:56.078 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1070.4967041015625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:56.091 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 990.0593872070312 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:56.095 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 24.993026733398438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:58.046 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 16.48052215576172 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:58.052 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1070.841064453125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:58.058 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 996.2488403320312 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:58.062 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 24.993026733398438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:34:59.393 - debug: awtrix-light.0 (23842) [initHistoryApps] History data for app "netz" of "alias.0.Allgemein.Leistung.WirkleistungGesamt: {"result":[],"error":{"name":"RequestTimedOutError","message":"Request timed out"}} - filtered: []
    2023-06-08 12:34:59.393 - debug: awtrix-light.0 (23842) [initHistoryApps] No history data. Going to remove history app "netz"
    2023-06-08 12:34:59.394 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=netz" without data
    2023-06-08 12:34:59.454 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=netz" with content: "OK"
    2023-06-08 12:34:59.454 - debug: awtrix-light.0 (23842) re-creating history apps timeout (60 seconds)
    2023-06-08 12:34:59.455 - debug: awtrix-light.0 (23842) sending "GET" request to "/api/apps" without data
    2023-06-08 12:34:59.457 - debug: awtrix-light.0 (23842) Updating indicator with index 1
    2023-06-08 12:34:59.478 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/indicator1" without data
    2023-06-08 12:34:59.492 - debug: awtrix-light.0 (23842) received 200 response from "/api/apps" with content: [{"name":"time"},{"name":"date"},{"name":"storagepower","icon":"49520.jpg"},{"name":"gridpower","icon":"49243.gif"},{"name":"pvpower","icon":"15124.gif"},{"name":"externaltemperature","icon":"38231.jpg"},{"name":"storagesoc","icon":"49520.jpg"}]
    2023-06-08 12:34:59.492 - debug: awtrix-light.0 (23842) [createAppObjects] existing apps on awtrix light: ["time","date","storagepower","gridpower","pvpower","externaltemperature","storagesoc"]
    2023-06-08 12:34:59.508 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.time
    2023-06-08 12:34:59.511 - debug: awtrix-light.0 (23842) received 200 response from "/api/indicator1" with content: "OK"
    2023-06-08 12:34:59.511 - debug: awtrix-light.0 (23842) Updating indicator with index 2
    2023-06-08 12:34:59.566 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/indicator2" with data: {"color":"#FF0000"}
    2023-06-08 12:34:59.570 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.eyes
    2023-06-08 12:34:59.578 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.date
    2023-06-08 12:34:59.585 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.temp
    2023-06-08 12:34:59.592 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.hum
    2023-06-08 12:34:59.599 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.bat
    2023-06-08 12:34:59.608 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.gridpower
    2023-06-08 12:34:59.622 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.externaltemperature
    2023-06-08 12:34:59.629 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.pvpower
    2023-06-08 12:34:59.637 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.storagesoc
    2023-06-08 12:34:59.644 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.storagepower
    2023-06-08 12:34:59.647 - debug: awtrix-light.0 (23842) received 200 response from "/api/indicator2" with content: "OK"
    2023-06-08 12:34:59.649 - debug: awtrix-light.0 (23842) Updating indicator with index 3
    2023-06-08 12:34:59.706 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/indicator3" with data: {"color":"#FF0000"}
    2023-06-08 12:34:59.715 - debug: awtrix-light.0 (23842) [createAppObjects] found (keep): apps.netz
    2023-06-08 12:34:59.759 - debug: awtrix-light.0 (23842) received 200 response from "/api/indicator3" with content: "OK"
    2023-06-08 12:34:59.760 - debug: awtrix-light.0 (23842) Updating moodlight
    2023-06-08 12:34:59.783 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/moodlight" without data
    2023-06-08 12:34:59.804 - debug: awtrix-light.0 (23842) received 200 response from "/api/moodlight" with content: "OK"
    2023-06-08 12:35:00.042 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "gridpower" with icon "49243" and text "%s %u"
    2023-06-08 12:35:00.042 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.Allgemein.Leistung.WirkleistungGesamt" from 32.68567657470703 to 32,686 (3 decimals)
    2023-06-08 12:35:00.042 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=gridpower" with data: {"text":"32,686 W","icon":"49243","duration":5}
    2023-06-08 12:35:00.051 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "pvpower" with icon "15124" and text "%s %u"
    2023-06-08 12:35:00.052 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.PV-Anlage.Leistung.WirkleistungPv" from 1066.747802734375 to 1.066,748 (3 decimals)
    2023-06-08 12:35:00.052 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=pvpower" with data: {"text":"1.066,748 W","icon":"15124","duration":5}
    2023-06-08 12:35:00.059 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "storagepower" with icon "49520" and text "%s %u"
    2023-06-08 12:35:00.059 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.Speicher.Leistung.WirkleistungSpeicher" from 991.3538818359375 to 991,354 (3 decimals)
    2023-06-08 12:35:00.059 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=storagepower" with data: {"text":"991,354 W","icon":"49520","duration":5}
    2023-06-08 12:35:00.066 - debug: awtrix-light.0 (23842) [refreshCustomApp] Refreshing custom app "externaltemperature" with icon "38231" and text "%s %u"
    2023-06-08 12:35:00.068 - debug: awtrix-light.0 (23842) [refreshCustomApp] formatted value of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" from 24.888399124145508 to 24,9 (1 decimals)
    2023-06-08 12:35:00.068 - debug: awtrix-light.0 (23842) sending "POST" request to "/api/custom?name=externaltemperature" with data: {"text":"24,9 °C","icon":"38231","duration":5}
    2023-06-08 12:35:00.187 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=gridpower" with content: "OK"
    2023-06-08 12:35:00.204 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=pvpower" with content: "OK"
    2023-06-08 12:35:00.215 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=storagepower" with content: "OK"
    2023-06-08 12:35:00.246 - debug: awtrix-light.0 (23842) received 200 response from "/api/custom?name=externaltemperature" with content: "OK"
    2023-06-08 12:35:02.046 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to -4.751686096191406 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:02.053 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1071.3848876953125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:02.061 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1013.8812255859375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:04.112 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 58.20667266845703 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:04.124 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1072.02685546875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:04.135 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 952.8958740234375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:06.091 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 8.598648071289062 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:06.101 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1068.78857421875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:06.111 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1008.16650390625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:08.082 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to -15.956344604492188 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:08.093 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1074.3370361328125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:08.107 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1017.3811645507812 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:10.056 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 6.235755920410156 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:10.064 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1074.08447265625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:10.072 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1003.8346557617188 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:12.053 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 34.189491271972656 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:12.061 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1071.2518310546875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:12.071 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 980.1087036132812 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:14.044 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 18.320518493652344 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:14.052 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1075.56640625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:14.068 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 996.189697265625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:16.070 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 5.822418212890625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:16.083 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1076.7867431640625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:16.095 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 997.6926879882812 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:18.035 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to -33.871803283691406 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:18.042 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1073.54833984375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:18.050 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1035.56689453125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:18.056 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 24.9581298828125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:20.039 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to -28.208633422851562 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:20.047 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1080.5753173828125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:20.056 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1022.98876953125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:20.059 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 24.9581298828125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:22.032 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to -7.009925842285156 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:22.038 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1083.38330078125 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:22.043 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1000.3990478515625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:22.047 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.02789306640625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:24.037 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 48.65162658691406 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:24.043 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1083.2974853515625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:24.046 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 999.0458374023438 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:24.049 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.09765625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:26.032 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 41.94557189941406 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:26.036 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1086.7281494140625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:26.041 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 997.2949829101562 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:26.044 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.09765625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:28.039 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 42.36408996582031 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:28.046 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1089.8355712890625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:28.048 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1004.7303466796875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:28.051 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.09765625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:28.731 - debug: awtrix-light.0 (23842) refreshing device state
    2023-06-08 12:35:28.731 - debug: awtrix-light.0 (23842) re-creating refresh state timeout
    2023-06-08 12:35:28.732 - debug: awtrix-light.0 (23842) sending "GET" request to "/api/stats" without data
    2023-06-08 12:35:28.814 - debug: awtrix-light.0 (23842) received 200 response from "/api/stats" with content: {"bat":69,"bat_raw":607,"lux":"9","ldr_raw":560,"ram":138092,"bri":120,"temp":"26","hum":"27","uptime":"1705","wifi_signal":-58,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":true,"indicator3":true}
    2023-06-08 12:35:29.036 - debug: awtrix-light.0 (23842) sending "GET" request to "/api/settings" without data
    2023-06-08 12:35:29.119 - debug: awtrix-light.0 (23842) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":65535,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":7327,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
    2023-06-08 12:35:30.034 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Allgemein.Leistung.WirkleistungGesamt" to 53.57196044921875 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:30.039 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.PV-Anlage.Leistung.WirkleistungPv" to 1087.718994140625 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:30.045 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Speicher.Leistung.WirkleistungSpeicher" to 1007.8636474609375 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:30.050 - debug: awtrix-light.0 (23842) [onStateChange] ignoring customApps state change of "alias.0.Talstrasse1A.Temperatur.Aussentemperatur" to 25.062789916992188 - refreshes too fast (within 30 seconds)
    2023-06-08 12:35:31.959 - info: awtrix-light.0 (23842) Adapter is disabled => stop
    2023-06-08 12:35:31.960 - debug: awtrix-light.0 (23842) API is offline
    2023-06-08 12:35:31.961 - debug: awtrix-light.0 (23842) clearing refresh state timeout
    2023-06-08 12:35:31.961 - debug: awtrix-light.0 (23842) clearing history apps timeout
    2023-06-08 12:35:31.961 - info: host.buanet-iobroker "system.adapter.awtrix-light.0" disabled
    2023-06-08 12:35:31.962 - info: host.buanet-iobroker stopInstance system.adapter.awtrix-light.0 (force=false, process=true)
    2023-06-08 12:35:32.019 - info: awtrix-light.0 (23842) Got terminate signal TERMINATE_YOURSELF
    2023-06-08 12:35:32.031 - info: awtrix-light.0 (23842) terminating
    2023-06-08 12:35:32.032 - info: awtrix-light.0 (23842) Terminated (NO_ERROR): Without reason
    2023-06-08 12:35:32.104 - info: host.buanet-iobroker stopInstance system.adapter.awtrix-light.0 send kill signal
    2023-06-08 12:35:32.579 - info: host.buanet-iobroker instance system.adapter.awtrix-light.0 terminated with code 0 (NO_ERROR)
    haus-automatisierungH Offline
    #401
    @ben1983 Die Datenbank hat einen Timeout für die Abfrage geliefert. Eventuell hängt das mit den „nicht so performanten“ Abfragen des InfluxDB Adapters zusammen. Dafür gibt es schon einen Issue und Pull Request.
    📚 Meine Dokumentation
    Ben1983B 2 Antworten Letzte Antwort
      Ben1983B Offline
      Ben1983B Offline
      Ben1983
      schrieb am zuletzt editiert von Ben1983
      #402
      @haus-automatisierung OK. Kann ich jetzt nichts dran machen, oder?
      Ps. Der Bug mit der Anzahl der dezimalstellen ist nachvollziehbar?
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        #403
        @haus-automatisierung Kann es sein, dass der Teil vom Code bei den konfigurierten 0 dezimalstellen so nicht funktioniert, weil er dann 3 zurück gibt?
        const decimals = customApp.decimals || 3;
        • Ben1983B Ben1983
          #404
          @ben1983 Stimmt, da sollte eigentlich ?? hin 👍
            marlan99
            schrieb am zuletzt editiert von marlan99
            #405
            Der DP "visible" wurde bei der 0.0.12 nun ja mangels FW Support entfernt.
            Macht der DP "activate" hier noch Sinn ? Bei mir haben diese DP auch keine Werte enthalten
            • M marlan99
              #406
              @marlan99 Bitte manuell löschen. Ich baue in dem Stadium des Adapters keine Upgrade Scripts auf neue Versionen die aufräumen. Im Zweifel einmal den kompletten Objektbaum löschen und Instanz neustarten
                marlan99
                #407
                habe den ganzen Baum "apps" gelöscht. Der DP "activate" wird jedoch wieder erstellt.
                haus-automatisierungH Ben1983B 2 Antworten Letzte Antwort
                • M marlan99
                  #408
                  @marlan99 Der bleibt und funktioniert ja auch?! Geht um visible
                  • M marlan99
                    Ben1983B Offline
                    Ben1983B Offline
                    Ben1983
                    #409
                    @marlan99 Mit dem DP kannst Du zu der App wechseln.
                    Ist also nicht ganz unnötig, finde ich.
                    • Ben1983B Ben1983
                      marlan99
                      #410
                      @ben1983 ok, macht Sinn. Da ich alle internen apps deaktiviert hatte, ist mir diese Funktion beim testen nicht aufgefallen
                      • DJMarc75D DJMarc75
                        @infinity über das + eine Instanz erstellen !
                        I Offline
                        I Offline
                        infinity
                        #411
                        @djmarc75 said in Test Adapter Awtrix-Light:
                        Ok geschnallt.
                        Danke.
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #412
                          @haus-automatisierung funktioniert bei dir der update button?
                          bei mir sag der zwar dass der startet mit update aber ich komme von de 0.67 nicht auf die 0.68
                          davon mal abgesehen dass es hiermit auc nicht geht
                          • arteckA arteck
                            #413
                            @arteck sagte in Test Adapter Awtrix-Light:
                            Kann auch nur ein Fehler in der Anzeige sein. Soll wohl mit 0.69 gefixt werden.
                            Hast du es auch direkt über die Uhr probiert?
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #414
                              @thomas-braun wer lesen kann ist klar im Vorteil
                              • arteckA arteck
                                #415
                                @arteck Ja, das meinte ich.
                                Seltsamerweise bin ich nicht davon betroffen, hier wird überall die 0.68 angezeigt.
                                I 1 Antwort Letzte Antwort
                                  I Offline
                                  I Offline
                                  infinity
                                  #416
                                  So ich habe da mal ein bischen rumgespielt.
                                  Ist das normal das sich die Einstellungen, die ich in der Instanz ändere, wieder auf Standard setzen nach aus/einschalten der Ulanzi?
                                  Beispielsweise setze ich bei der Akku App visible auf false und das kommt dann wieder nach dem Aus/Einschalten der Ulanzi, obwohl es in der Instanz noch auf false steht.
                                  • I infinity
                                    M Online
                                    M Online
                                    MCU
                                    #417
                                    @infinity Ja, deswegen wurde von @haus-automatisierung visible wieder aus den Objekten entfernt. (v0.0.12)
                                    https://github.com/klein0r/ioBroker.awtrix-light/issues/17
                                    ? 1 Antwort Letzte Antwort
                                      marlan99
                                      #418
                                      hat nichts mit dem Adapter zu tun, bitte verzeiht meine Fragestellung hier:
                                      Ich habe zwei Displays (V0.67) und beide verhalten sich so, dass ohne Netzanschluss das Gerät abstellt sobald der interne Akku noch ca 50% anzeigt. Kann dies jemand bei sich ebenfalls nachvollziehen?
                                      maximal1981M B FabioF 3 Antworten Letzte Antwort
                                      • M marlan99
                                        maximal1981M Offline
                                        maximal1981
                                        schrieb am zuletzt editiert von maximal1981
                                        #419
                                        @marlan99 bin nur ghostreader hier, da meine vermutlich heute eintreffen.
                                        Bilde mir aber ein, das schon weit weit oben gelesen zu haben.
                                        • J Offline
                                          Jui
                                          #420
                                          Hallo Zusammen, ich habe eine Frage zur Installation und Einrichtung des Adapter im IoBroker:
                                          Ulanzi Läuft mit awtrix-light, dann habe ich den Adapter per github installiert (mehrfach probiert), lief alles ohne Fehlermeldung.
                                          Der Ordner awtrix-light wird angelegt, jedoch ohne Datenpunkte und es gibt KEINE Instanz dazu?
                                          Wo stelle ich die Verbindung zur Ulanzi ein?
                                          Konnte hier keine Hinweise finden :-(
                                          Danke für Eure Hilfe
