  4. RING Adapter Verbindet sich nicht mehr
    5.4k
41 Beiträge 5 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • M michihorn
    @thomas-braun diag kennt er nicht
    @michihorn
    iob stop
    iob fix
    iob start
    iob diag
      @michihorn
      iob stop
      iob fix
      iob start
      iob diag
      michihorn
      schrieb am zuletzt editiert von michihorn
      @thomas-braun ```
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model : Raspberry Pi 4 Model B Rev 1.5
      Architecture : aarch64
      Docker : false
      Virtualization : none
      Distributor ID: Raspbian
      Description: Raspbian GNU/Linux 11 (bullseye)
      Release: 11
      Codename: bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
      21:16:14 up 9 min, 1 user, load average: 2.66, 3.26, 1.94
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=53.5'C
      volt=0.9260V
      *** Time and Time Zones ***
      Local time: Tue 2023-05-16 21:16:14 CEST
      Universal time: Tue 2023-05-16 19:16:14 UTC
      RTC time: n/a
      NTP service: n/a
      RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      Boot Target: multi-user.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 7.9G 711M 6.1G 0.0K 1.0G 7.0G
      Swap: 99M 0B 99M
      Total: 8.0G 711M 6.2G
           7862 M total memory
            710 M used memory
            737 M active memory
            594 M inactive memory
           6136 M free memory
            172 M buffer memory
            842 M swap cache
             99 M total swap
              0 M used swap
             99 M free swap
      Raspberry only:
      oom events: 0
      lifetime oom required: 0 Mbytes
      total time in oom handler: 0 ms
      max time spent in oom handler: 0 ms
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/root ext4 59G 15G 42G 26% /
      devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
      tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
      tmpfs tmpfs 1.6G 776K 1.6G 1% /run
      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot
      tmpfs tmpfs 787M 0 787M 0% /run/user/1000
      [Tue May 16 21:06:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:FE:87:59 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=4c91ec57-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): 1 truncate cleaned up
      [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue May 16 21:06:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue May 16 21:07:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime
      `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.4G /var/
      2.1G /var/log
      1.9G /var/log/journal/e2b5e5db604543deab373d50adc66fa2
      96M /var/cache
      Archived and active journals take up 1.8G in the file system.
      /opt/iobroker/backups:
      963M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      3.0G /opt/iobroker/iobroker-data/
      2.3G /opt/iobroker/iobroker-data/files
      1.6G /opt/iobroker/iobroker-data/files/ring.0
      910M /opt/iobroker/iobroker-data/files/ring.0/doorbell_90474299
      560M /opt/iobroker/iobroker-data/backup-objects
      67M /opt/iobroker/iobroker-data/backups/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
      67M /opt/iobroker/iobroker-data/backup-objects/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
      41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      24M /opt/iobroker/iobroker-data/objects.jsonl
      23M /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs v18.16.0
      /usr/bin/node v18.16.0
      /usr/bin/npm 9.5.1
      /usr/bin/npx 9.5.1
      nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
      *** 18.16.0-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
      100 /var/lib/dpkg/status
      12.22.12~dfsg-1~deb11u4 500
      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller: 4.0.24
      admin: 6.4.4
      javascript: 7.0.3
      Adapters from github: 9
      Adapter State
      • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8111, bind: 192.168.178.xxxx, run as: admin
      • system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled
        system.adapter.backitup.0 : backitup : iobroker-pi - enabled
        system.adapter.blebox.0 : blebox : iobroker-pi - enabled
        system.adapter.cloud.0 : cloud : iobroker-pi - enabled
        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker-pi - disabled
        system.adapter.daswetter.0 : daswetter : iobroker-pi - enabled
        system.adapter.daswetter.1 : daswetter : iobroker-pi - enabled
        system.adapter.device-reminder.0 : device-reminder : iobroker-pi - enabled
        system.adapter.device-watcher.0 : device-watcher : iobroker-pi - disabled
        system.adapter.discovery.0 : discovery : iobroker-pi - disabled
        system.adapter.dwd.0 : dwd : iobroker-pi - enabled
        system.adapter.echarts.0 : echarts : iobroker-pi - enabled
        system.adapter.feiertage.0 : feiertage : iobroker-pi - enabled
        system.adapter.fritzbox.0 : fritzbox : iobroker-pi - enabled
        system.adapter.fully-tablet-control.0 : fully-tablet-control : iobroker-pi - enabled
      • system.adapter.ham.0 : ham : iobroker-pi - enabled
      • system.adapter.history.0 : history : iobroker-pi - enabled
      • system.adapter.hm-rega.0 : hm-rega : iobroker-pi - enabled
      • system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 12001
      • system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 18701
      • system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010
        system.adapter.hue.0 : hue : iobroker-pi - enabled, port: 443
        system.adapter.ical.0 : ical : iobroker-pi - enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-pi - enabled
        system.adapter.icons-icons8.0 : icons-icons8 : iobroker-pi - enabled
        system.adapter.icons-material-png.0 : icons-material-png : iobroker-pi - enabled
        system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker-pi - enabled
        system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker-pi - enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi - enabled
        system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker-pi - enabled
        system.adapter.info.0 : info : iobroker-pi - enabled
        system.adapter.iot.0 : iot : iobroker-pi - enabled
        system.adapter.iot.1 : iot : iobroker-pi - enabled
        system.adapter.iot.2 : iot : iobroker-pi - enabled
      • system.adapter.javascript.0 : javascript : iobroker-pi - enabled
      • system.adapter.javascript.1 : javascript : iobroker-pi - enabled
      • system.adapter.javascript.2 : javascript : iobroker-pi - enabled
      • system.adapter.javascript.3 : javascript : iobroker-pi - enabled
        system.adapter.material.0 : material : iobroker-pi - enabled
      • system.adapter.mqtt-client.0 : mqtt-client : iobroker-pi - enabled, port: 1883
      • system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 0.0.0.0
        system.adapter.parcel.0 : parcel : iobroker-pi - enabled
      • system.adapter.ping.0 : ping : iobroker-pi - enabled
        system.adapter.pollenflug.0 : pollenflug : iobroker-pi - enabled
        system.adapter.psa.0 : psa : iobroker-pi - enabled
        system.adapter.reolink.0 : reolink : iobroker-pi - enabled
        system.adapter.ring.0 : ring : iobroker-pi - enabled
        system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartgarden.0 : smartgarden : iobroker-pi - enabled
        system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-pi - enabled
      • system.adapter.tahoma.0 : tahoma : iobroker-pi - enabled
        system.adapter.tankerkoenig.0 : tankerkoenig : iobroker-pi - enabled
      • system.adapter.telegram.0 : telegram : iobroker-pi - enabled, port: 8443, bind: 0.0.0.0
        system.adapter.time-switch.0 : time-switch : iobroker-pi - enabled
      • system.adapter.tr-064.0 : tr-064 : iobroker-pi - enabled
      • system.adapter.tuya.1 : tuya : iobroker-pi - enabled
        system.adapter.vaillant.0 : vaillant : iobroker-pi - enabled
        system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker-pi - enabled
        system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker-pi - enabled
        system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker-pi - enabled
        system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker-pi - enabled
        system.adapter.vis-icontwo.0 : vis-icontwo : iobroker-pi - enabled
        system.adapter.vis-inventwo.0 : vis-inventwo : iobroker-pi - enabled
        system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker-pi - enabled
        system.adapter.vis-justgage.0 : vis-justgage : iobroker-pi - enabled
        system.adapter.vis-keyboard.0 : vis-keyboard : iobroker-pi - enabled
        system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker-pi - enabled
        system.adapter.vis-material.0 : vis-material : iobroker-pi - enabled
        system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker-pi - enabled
        system.adapter.vis-metro.0 : vis-metro : iobroker-pi - enabled
        system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker-pi - enabled
        system.adapter.vis-weather.0 : vis-weather : iobroker-pi - enabled
        system.adapter.vis.0 : vis : iobroker-pi - enabled
      • system.adapter.web.0 : web : iobroker-pi - enabled, port: 9082, bind: 192.168.178.xxx, run as: admin
        system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-pi - disabled
        system.adapter.ws.0 : ws : iobroker-pi - enabled, port: 8089, bind: 192.168.178.xxx, run as: admin
      • system.adapter.zigbee.0 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxx:6638
      • system.adapter.zigbee.1 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxx:6638
        system.adapter.zigbee.3 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xx:6638
      • instance is alive
      • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8111, bind: 192.168.178.xxx, run as: admin
      • system.adapter.hue.0 : hue : iobroker-pi - enabled, port: 443
      • system.adapter.zigbee.3 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxxx:6638
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter "admin" : 6.4.4 , installed 6.4.4
      Adapter "alexa2" : 3.23.2 , installed 3.23.2
      Adapter "backitup" : 2.6.20 , installed 2.6.20
      Adapter "blebox" : 2.0.1 , installed 2.0.1
      Adapter "cloud" : 4.4.1 , installed 4.4.1
      Adapter "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter "daswetter" : 3.1.8 , installed 3.1.8
      Adapter "device-reminder": 1.2.9 , installed 1.2.9
      Adapter "device-watcher": 2.9.1 , installed 2.9.1
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "dwd" : 2.8.3 , installed 2.8.3
      Adapter "echarts" : 1.4.15 , installed 1.4.15
      Adapter "elero-usb-transmitter": 0.5.2, installed 0.5.2
      Adapter "feiertage" : 1.1.0 , installed 1.1.0
      Adapter "fritzbox" : 0.5.0 , installed 0.5.0
      Adapter "ham" : 5.3.1 , installed 5.3.1
      Adapter "history" : 2.2.4 , installed 2.2.4
      Adapter "hm-rega" : 3.0.46 , installed 3.0.46
      Adapter "hm-rpc" : 1.15.18 , installed 1.15.18
      Adapter "hue" : 3.7.1 , installed 3.7.1
      Adapter "ical" : 1.13.2 , installed 1.13.2
      Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
      Adapter "icons-material-png": 0.1.0, installed 0.1.0
      Adapter "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
      Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
      Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter "info" : 1.9.26 , installed 1.9.26
      Adapter "iot" : 1.14.5 , installed 1.14.5
      Adapter "javascript" : 7.0.3 , installed 7.0.3
      Controller "js-controller": 4.0.24 , installed 4.0.24
      Adapter "material" : 1.3.1 , installed 1.3.1
      Adapter "mqtt" : 4.1.1 , installed 4.1.1
      Adapter "mqtt-client" : 1.6.3 , installed 1.6.3
      Adapter "net-tools" : 0.2.0 , installed 0.2.0
      Adapter "ocpp" : 0.12.5 , installed 0.12.5
      Adapter "onvif" : 1.0.5 , installed 1.0.5
      Adapter "openweathermap": 0.3.8 , installed 0.3.8
      Adapter "parcel" : 0.0.28 , installed 0.0.28
      Adapter "ping" : 1.5.3 , installed 1.5.3
      Adapter "pollenflug" : 1.0.6 , installed 1.0.6
      Adapter "psa" : 0.0.11 , installed 0.0.11
      Adapter "ring" : 3.3.0 , installed 3.3.0
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "smartgarden" : 2.0.0 , installed 2.0.0
      Adapter "socketio" : 6.3.5 , installed 6.3.5
      Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
      Adapter "tahoma" : 0.10.2 , installed 0.10.2
      Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
      Adapter "telegram" : 1.15.6 , installed 1.15.6
      Adapter "time-switch" : 2.2.2 , installed 2.2.2
      Adapter "tr-064" : 4.2.18 , installed 4.2.18
      Adapter "tuya" : 3.14.2 , installed 3.14.2
      Adapter "vaillant" : 0.1.2 , installed 0.1.2
      Adapter "vis" : 1.4.16 , installed 1.4.16
      Adapter "vis-2-widgets-energy": 0.1.12, installed 0.1.12
      Adapter "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
      Adapter "vis-2-widgets-jaeger-design": 0.3.2, installed 0.3.2
      Adapter "vis-2-widgets-material": 0.2.13, installed 0.2.13
      Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
      Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
      Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
      Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
      Adapter "vis-icontwo" : 0.94.0 , installed 0.94.0
      Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
      Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
      Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
      Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2
      Adapter "vis-material" : 0.1.3 , installed 0.1.3
      Adapter "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter "vis-metro" : 1.2.0 , installed 1.2.0
      Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
      Adapter "vis-weather" : 2.5.6 , installed 2.5.6
      Adapter "web" : 5.5.3 , installed 5.5.3
      Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
      Adapter "ws" : 2.3.6 , installed 2.3.6
      Adapter "zigbee" : 1.8.10 , installed 1.8.10
      Objects and States
      Objects: 31979
      States: 27289
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
      Err:4 https://dl.yarnpkg.com/debian stable InRelease
      Fetched 17.1 kB in 2s (11.4 kB/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 192.168.178.xxxx:18701 0.0.0.0:* LISTEN 1001 31354 3453/io.hm-rpc.1
      tcp 0 0 192.168.178.xxx:8111 0.0.0.0:* LISTEN 1001 31915 3149/io.admin.0
      tcp 0 0 192.168.178.xxx:8089 0.0.0.0:* LISTEN 1001 36290 4156/io.ws.0
      tcp 0 0 127.0.0.xxxx:9000 0.0.0.0:* LISTEN 1001 30893 3131/iobroker.js-co
      tcp 0 0 127.0.0.xxxx:9001 0.0.0.0:* LISTEN 1001 28956 3131/iobroker.js-co
      tcp 0 0 192.168.178.xxxx:12010 0.0.0.0:* LISTEN 1001 32420 3460/io.hm-rpc.2
      tcp 0 0 192.168.178.xxxxx:12001 0.0.0.0:* LISTEN 1001 32418 3446/io.hm-rpc.0
      tcp 0 0 192.168.178.xxxx:9082 0.0.0.0:* LISTEN 1001 34940 3725/io.web.0
      tcp 0 0 0.0.0.0:xxx 0.0.0.0:* LISTEN 0 12069 495/sshd: /usr/sbin
      tcp 0 0 0.0.0.0:xxx 0.0.0.0:* LISTEN 1001 31736 3610/io.mqtt.0
      tcp6 0 0 :::8087 :::* LISTEN 1001 36281 4212/io.simple-api.
      tcp6 0 0 :::22 :::* LISTEN 0 12071 495/sshd: /usr/sbin
      udp 0 0 0.0.0.0:6xx6 0.0.0.0:* 1001 35941 3520/io.tuya.1
      udp 0 0 0.0.0.0:6xx7 0.0.0.0:* 1001 35942 3520/io.tuya.1
      udp 0 0 0.0.0.0:xx 0.0.0.0:* 0 12085 690/dhcpcd
      udp 0 0 192.168.178.xxx:123 0.0.0.0:* 109 14860 487/ntpd
      udp 0 0 127.0.0.1:xxx 0.0.0.0:* 0 14669 487/ntpd
      udp 0 0 0.0.0.0:xxx 0.0.0.0:* 0 14665 487/ntpd
      udp 0 0 0.0.0.0:xxx 0.0.0.0:* 108 14567 355/avahi-daemon: r
      udp 0 0 0.0.0.0:xxx 0.0.0.0:* 108 14565 355/avahi-daemon: r
      udp6 0 0 2a02:908:xxx:e560:b:123 :::* 109 14863 487/ntpd
      udp6 0 0 fe80::53bb:xxxx:907:123 :::* 109 14846 487/ntpd
      udp6 0 0 ::1:123 :::* 0 14671 487/ntpd
      udp6 0 0 :::123 :::* 0 14662 487/ntpd
      udp6 0 0 :::546 :::* 0 12096 690/dhcpcd
      udp6 0 0 :::5353 :::* 108 14566 355/avahi-daemon: r
      udp6 0 0 :::50842 :::* 108 14568 355/avahi-daemon: r
      2023-05-16 21:21:18.357 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Manufacturer {"val":"Balboa","ack":true,"ts":1684264705875,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587285530}
      2023-05-16 21:21:18.448 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Model: value = Spa /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
      2023-05-16 21:21:18.453 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
      2023-05-16 21:21:18.698 - debug: reolink.0 (4158) Motion Detection value: 0
      2023-05-16 21:21:18.853 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Model {"val":"Spa","ack":true,"ts":1684264706232,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587285817}
      2023-05-16 21:21:18.912 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Name: value = Temperatur Einstellung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
      2023-05-16 21:21:19.326 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
      2023-05-16 21:21:19.376 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Name {"val":"Temperatur Einstellung","ack":true,"ts":1684264707007,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286038}
      2023-05-16 21:21:19.404 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Serial-Number: value = 2.2.6 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
      2023-05-16 21:21:19.493 - info: tuya.1 (3520) 03200296dc4f2229d2f2: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.108:6668
      2023-05-16 21:21:19.555 - debug: reolink.0 (4158) Motion Detection value: 0
      2023-05-16 21:21:19.806 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Serial-Number {"val":"2.2.6","ack":true,"ts":1684264707422,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286267}
      2023-05-16 21:21:20.170 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Firmware-Revision: value = 2.2.6 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
      2023-05-16 21:21:20.204 - info: blebox.0 (3855) State value to set for "blebox.0.Teich.tempSensor.sensors.0.id" has to be type "string" but received type "number"
      2023-05-16 21:21:20.342 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
      2023-05-16 21:21:20.670 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Firmware-Revision {"val":"2.2.6","ack":true,"ts":1684264707866,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286484}
      2023-05-16 21:21:20.709 - debug: reolink.0 (4158) Motion Detection value: 0
      2023-05-16 21:21:20.744 - info: ham.0 (3617) updateChannel Temperatur-Einstellung.Thermostat: name =
      2023-05-16 21:21:20.917 - info: ham.0 (3617) updateState Temperatur-Einstellung.Thermostat.Current-Heating-Cooling-State: value = 1 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value","name":"Current Heating Cooling State","unit":""}
      2023-05-16 21:21:21.015 - info: tuya.1 (3520) bfed8326787ed29axxxtot: Connect locally to device
      2023-05-16 21:21:21.018 - info: tuya.1 (3520) bfed8326787ed29axxxtot Init with IP=192.168.178.xxx, Key=51d7af4a1464d114, Version=3.4
      2023-05-16 21:21:21.146 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Thermostat.Current-Heating-Cooling-State {"val":1,"ack":true,"ts":1684264881108,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1684261586145}
      2023-05-16 21:21:21.205 - info: ham.0 (3617) updateState Temperatur-Einstellung.Thermostat.Target-Heating-Cooling-State: value = 1 /common= {"type":"number","min":0,"max":2,"read":true,"write":true,"role":"level","name":"Target Heating Cooling State","unit":""}
      2023-05-16 21:21:21.405 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
      2023-05-16 21:21:21.533 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Thermostat.Target-Heating-Cooling-State {"val":1,"ack":true,"ts":1684264881478,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1681646058199}
      iob diag has finished.
      • M michihorn
        @thomas-braun ```
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker : false
        Release: 11
        Codename: bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=53.5'C
        volt=0.9260V
        RTC time: n/a
        NTP service: n/a
        RTC in local TZ: no
        pi
        /home/pi
        X-Server: false
        Desktop:
        Terminal: tty
        *** MEMORY ***
        Swap: 99M 0B 99M
             7862 M total memory
              710 M used memory
              737 M active memory
             6136 M free memory
              172 M buffer memory
              842 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        2.4G /var/
        2.1G /var/log
        96M /var/cache
        /usr/bin/npm 9.5.1
        /usr/bin/npx 9.5.1
        nodejs:
        Version table:
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        admin: 6.4.4
        javascript: 7.0.3
        Adapter State
        • instance is alive
        Objects and States
        Objects: 31979
        States: 27289
        Pending Updates: 0
        @michihorn
        Du solltest die Kiste sauber neustarten, nicht austreten!
        Die yarn .list-Datei ist noch vorhanden.
        N M 2 Antworten Letzte Antwort
          @michihorn
          N Offline
          N Offline
          niiccooo1
          schrieb am zuletzt editiert von niiccooo1
          Hallo Zusammen,
          selbes Problem hier.
          ring.0
          2023-05-16 21:27:55.940	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          ring.0
          2023-05-16 21:27:55.938	info	terminating
          ring.0
          2023-05-16 21:27:55.934	error	Cannot read properties of undefined (reading 'battery_percentage')
          ring.0
          2023-05-16 21:27:55.933	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingDevice.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingDevice.js:420:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
          ring.0
          2023-05-16 21:27:55.933	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
          ring.0
          2023-05-16 21:27:55.932	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          ring.0
          2023-05-16 21:27:54.544	info	Recieved new Refresh Token. Will use the new one until the token in config gets changed
          Mein ioBroker läuft in einem Docker Container. Habe den "Fixer" schon durchlaufen lassen und den Container neu gestartet.
          Keine Verbesserung.
          • N niiccooo1
            Hallo Zusammen,
            ring.0
            ring.0
            ring.0
            ring.0
            ring.0
            ring.0
            ring.0
            Keine Verbesserung.
            @niiccooo1
            https://github.com/iobroker-community-adapters/ioBroker.ring/issues/525
              @michihorn
              michihorn
              @thomas-braun sagte in RING Adapter Verbindet sich nicht mehr:
              @michihorn
              😇 Jetzt is die sources.list gelöscht
                @niiccooo1
                michihorn
                @niiccooo1
                Wir sind nicht allein ;-)
                • M michihorn
                  @michihorn
                  @michihorn
                  Ich hoffe NICHT die /etc/apt/sources.list gelöscht...
                  ls -lAh /etc/apt
                  Sauberer Neustart wird überigens mit
                  sudo reboot
                  gemacht, nicht durch Stecker ziehen im laufenden Betrieb.
                    @michihorn
                    ls -lAh /etc/apt
                    sudo reboot
                    michihorn
                    @michihorn
                    ls -lAh /etc/apt
                    sudo reboot
                    Doch die ist weg 🤕 Und nun?
                    die sources.list.d ist noch da
                    • M michihorn
                      @michihorn
                      ls -lAh /etc/apt
                      sudo reboot
                      @michihorn
                      Warum hab ich das eigentlich mehrfach geschrieben?
                      • M michihorn
                        @michihorn
                        ls -lAh /etc/apt
                        sudo reboot
                        @michihorn sagte in RING Adapter Verbindet sich nicht mehr:
                        Das ist keine Datei sondern ein Verzeichnis.
                        ls -lAh /etc/apt/sources.list.d/
                        sagt?
                          @michihorn
                          michihorn
                          @thomas-braun habe das .d als schreibfehler angesehen
                          • M michihorn
                            @michihorn
                            Ich mache selten Schreibfehler...
                              sagt?
                              michihorn
                              sagt?
                              root@iobroker-pi:/etc/apt# root@iobroker-pi:/etc/apt# ls -lAh /etc/apt/sources.list.d/
                              total 12K
                              -rw-r--r-- 1 root root 208 Oct 26  2022 nodesource.list
                              -rw-r--r-- 1 root root 191 Feb  3  2022 raspi.list
                              -rw-r--r-- 1 root root  90 Oct 26  2022 yarn.list
                              Ich habe noch einen PI4 der fast gleich aufgebaut ist, kann ich die Datei rüber kopieren? Wohl eher nicht?!?
                              Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
                              • M michihorn
                                sagt?
                                total 12K
                                @michihorn yarn.list solltest du löschen, nicht die sources.list
                                Vielleicht kann dir jemand seine sources.list von seinem pi4/32bit zur Verfügung stellen. Meine kannst du nicht haben, die passt hinten und vorne nicht zu deinem System.
                                • M michihorn
                                  sagt?
                                  total 12K
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  root@iobroker
                                  Wie oft muss man Dir das eigentlich noch so erklären ?
                                  Gleiches mit "Text in Codetags packen" ;)
                                  Lehrling seit 1975 !!!
                                  • M michihorn
                                    sagt?
                                    total 12K
                                    @michihorn
                                    Und den Scheiß mit dem root kannste dir auch gleich abgewöhnen.
                                    Ich bin dann auch raus hier.
                                      @michihorn
                                      michihorn
                                      @michihorn
                                      YARN.list ist jetzt raus und sources.list wieder da 👍
                                      • M michihorn
                                        @michihorn
                                        @michihorn
                                        iob diag
                                          @michihorn
                                          iob diag
                                          michihorn
                                          ======== Start marking the full check here =========
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=raspbian
                                          ID_LIKE=debian
                                           23:04:25 up 21 min,  1 user,  load average: 1.65, 1.45, 1.65
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=45.2'C
                                          volt=0.9360V
                                                         Local time: Tue 2023-05-16 23:04:25 CEST
                                                     Universal time: Tue 2023-05-16 21:04:25 UTC
                                                           RTC time: n/a
                                                        NTP service: n/a
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            7.9G        2.7G        4.7G        0.0K        527M        5.1G
                                          Swap:            99M          0B         99M
                                          Total:          8.0G        2.7G        4.8G
                                                   7862 M total memory
                                                   2675 M used memory
                                                   2670 M active memory
                                                    365 M inactive memory
                                                   4658 M free memory
                                                     65 M buffer memory
                                                    462 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          tmpfs          tmpfs     1.6G  788K  1.6G   1% /run
                                          [Tue May 16 22:42:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:87:59 vc_mem.        mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty        1 root=PARTUUID=4c91ec57-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Tue May 16 22:42:41 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                          [Tue May 16 22:42:41 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                                          [Tue May 16 22:42:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,flush,errors=remount-ro
                                          /var:
                                          2.3G    /var/
                                          2.0G    /var/log
                                          1.8G    /var/log/journal/e2b5e5db604543deab373d50adc66fa2
                                          96M     /var/cache
                                          Archived and active journals take up 1.7G in the file system.
                                          34M     /opt/iobroker/iobroker-data/objects.jsonl
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.4.4
                                          javascript:     7.0.3
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8111, bind: 192.168.178.144, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                          + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                          + system.adapter.blebox.0                 : blebox                : iobroker-pi                              -  enabled
                                          + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
                                          + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                          + system.adapter.echarts.0                : echarts               : iobroker-pi                              -  enabled
                                          + system.adapter.fritzbox.0               : fritzbox              : iobroker-pi                              -  enabled
                                          + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker-pi                              -  enabled
                                          + system.adapter.ham.0                    : ham                   : iobroker-pi                              -  enabled
                                          + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                          + system.adapter.hue.0                    : hue                   : iobroker-pi                              -  enabled, port: 443
                                          + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
                                          + system.adapter.iot.0                    : iot                   : iobroker-pi                              -  enabled
                                          + system.adapter.iot.1                    : iot                   : iobroker-pi                              -  enabled
                                          + system.adapter.iot.2                    : iot                   : iobroker-pi                              -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                          + system.adapter.javascript.1             : javascript            : iobroker-pi                              -  enabled
                                          + system.adapter.javascript.2             : javascript            : iobroker-pi                              -  enabled
                                          + system.adapter.javascript.3             : javascript            : iobroker-pi                              -  enabled
                                          + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.parcel.0                 : parcel                : iobroker-pi                              -  enabled
                                          + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
                                          + system.adapter.pollenflug.0             : pollenflug            : iobroker-pi                              -  enabled
                                          + system.adapter.psa.0                    : psa                   : iobroker-pi                              -  enabled
                                          + system.adapter.reolink.0                : reolink               : iobroker-pi                              -  enabled
                                          + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.smartgarden.0            : smartgarden           : iobroker-pi                              -  enabled
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pi                              -  enabled
                                          + system.adapter.tahoma.0                 : tahoma                : iobroker-pi                              -  enabled
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
                                          + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.time-switch.0            : time-switch           : iobroker-pi                              -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                          + system.adapter.tuya.1                   : tuya                  : iobroker-pi                              -  enabled
                                          + system.adapter.vaillant.0               : vaillant              : iobroker-pi                              -  enabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-pi                              -  enabled
                                          + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 9082, bind: 192.168.178.xxx, run as: admin
                                          + system.adapter.ws.0                     : ws                    : iobroker-pi                              -  enabled, port: 8089, bind: 192.168.178.xxx, run as: admin
                                          + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
                                          + system.adapter.zigbee.1                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
                                          + system.adapter.zigbee.3                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
                                          + instance is alive
                                          + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8111, bind: 192.168.178.xxx, run as: admin
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.xxx.0
                                          + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.xxx.0, run as: admin
                                          + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, port: 8443, bind: 0.0.xxx.0
                                          Objects and States
                                          Objects:        31972
                                          States:         27169
                                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.xxx:1883            0.0.0.0:*               LISTEN      1001       16572      1038/io.mqtt.0
                                          tcp        0      0 192.168.178.xxx:12001   0.0.0.0:*               LISTEN      1001       18520      868/io.hm-rpc.0
                                          tcp        0      0 192.168.178.xxx:12010   0.0.0.0:*               LISTEN      1001       18527      896/io.hm-rpc.2
                                          tcp        0      0 192.168.178.xxx:8089    0.0.0.0:*               LISTEN      1001       17263      1558/io.ws.0
                                          tcp        0      0 192.168.178.xxx:8111    0.0.0.0:*               LISTEN      1001       13072      698/io.admin.0
                                          tcp        0      0 127.0.0.xxx:9001          0.0.0.0:*               LISTEN      1001       11933      489/iobroker.js-con
                                          tcp        0      0 127.0.0.xxx:9000          0.0.0.0:*               LISTEN      1001       12965      489/iobroker.js-con
                                          tcp        0      0 192.168.178.xxx:18701   0.0.0.0:*               LISTEN      1001       15735      875/io.hm-rpc.1
                                          tcp        0      0 0.0.0.xxx:22              0.0.0.0:*               LISTEN      0          12862      525/sshd: /usr/sbin
                                          tcp        0      0 192.168.178.xxx:9082    0.0.0.0:*               LISTEN      1001       16241      1147/io.web.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12864      525/sshd: /usr/sbin
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19827      1618/io.simple-api.
                                          udp        0      0 0.0.0.xxx:xxx             0.0.0.0:*                           0          11099      696/dhcpcd
                                          udp        0      0 192.168.178.xxx:123     0.0.0.0:*                           109        13011      512/ntpd
                                          udp        0      0 127.0.0.xxx:xxx           0.0.0.0:*                           0          12837      512/ntpd
                                          udp        0      0 0.0.0.0:xxx             0.0.0.0:*                           0          12833      512/ntpd
                                          udp        0      0 0.0.0.0:xxx           0.0.0.0:*                           108        12702      354/avahi-daemon: r
                                          udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           108        12700      354/avahi-daemon: r
                                          udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           1001       19128      991/io.tuya.1
                                          udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           1001       19129      991/io.tuya.1
                                          udp6       0      0 2a02:908:xxx:e560:b:123 :::*                                109        13051      512/ntpd
                                          udp6       0      0 fe80::53bb:xxx:907:123 :::*                                109        12919      512/ntpd
                                          udp6       0      0 ::1:xxx                :::*                                0          12839      512/ntpd
                                          udp6       0      0 :::xxx                  :::*                                0          12830      512/ntpd
                                          udp6       0      0 :::xxx                  :::*                                0          11115      696/dhcpcd
                                          udp6       0      0 :::xxx                 :::*                                108        12701      354/avahi-daemon: r
                                          udp6       0      0 :::5xx6                :::*                                108        12703      354/avahi-daemon: r
                                          2023-05-16 23:05:47.772  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:47.852  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:48.710  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:48.766  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:49.772  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:49.784  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:50.048  - info: blebox.0 (1278) State value to set for "blebox.0.Teich.tempSensor.sensors.0.id" has to be type "string" but received type "number"
                                          2023-05-16 23:05:50.699  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:50.731  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:51.793  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:51.867  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:52.812  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:52.826  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:53.760  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:53.774  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:54.849  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:54.859  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:55.748  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:55.758  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:56.755  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:56.773  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:57.728  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:57.738  - debug: reolink.0 (1584) Motion Detection value: 0
                                          2023-05-16 23:05:58.828  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                          2023-05-16 23:05:58.931  - debug: reolink.0 (1584) Motion Detection value: 0
