  4. RING Adapter Verbindet sich nicht mehr
    5.4k
41 Beiträge 5 Kommentatoren 2.2k Aufrufe 4 Beobachtet
    @michihorn
    iob stop
    iob fix
    iob start
    iob diag
    michihorn
    schrieb am zuletzt editiert von michihorn
    @thomas-braun ```
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model : Raspberry Pi 4 Model B Rev 1.5
    Architecture : aarch64
    Docker : false
    Virtualization : none
    Distributor ID: Raspbian
    Description: Raspbian GNU/Linux 11 (bullseye)
    Release: 11
    Codename: bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
    21:16:14 up 9 min, 1 user, load average: 2.66, 3.26, 1.94
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=53.5'C
    volt=0.9260V
    *** Time and Time Zones ***
    Local time: Tue 2023-05-16 21:16:14 CEST
    Universal time: Tue 2023-05-16 19:16:14 UTC
    RTC time: n/a
    NTP service: n/a
    RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    Boot Target: multi-user.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 7.9G 711M 6.1G 0.0K 1.0G 7.0G
    Swap: 99M 0B 99M
    Total: 8.0G 711M 6.2G
         7862 M total memory
          710 M used memory
          737 M active memory
          594 M inactive memory
         6136 M free memory
          172 M buffer memory
          842 M swap cache
           99 M total swap
            0 M used swap
           99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 59G 15G 42G 26% /
    devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
    tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
    tmpfs tmpfs 1.6G 776K 1.6G 1% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot
    tmpfs tmpfs 787M 0 787M 0% /run/user/1000
    [Tue May 16 21:06:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:FE:87:59 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=4c91ec57-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): 1 truncate cleaned up
    [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue May 16 21:06:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue May 16 21:07:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mmcblk0p2 ext4 rw,noatime
    `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.4G /var/
    2.1G /var/log
    1.9G /var/log/journal/e2b5e5db604543deab373d50adc66fa2
    96M /var/cache
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    963M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.0G /opt/iobroker/iobroker-data/
    2.3G /opt/iobroker/iobroker-data/files
    1.6G /opt/iobroker/iobroker-data/files/ring.0
    910M /opt/iobroker/iobroker-data/files/ring.0/doorbell_90474299
    560M /opt/iobroker/iobroker-data/backup-objects
    67M /opt/iobroker/iobroker-data/backups/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
    67M /opt/iobroker/iobroker-data/backup-objects/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
    41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    24M /opt/iobroker/iobroker-data/objects.jsonl
    23M /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs v18.16.0
    /usr/bin/node v18.16.0
    /usr/bin/npm 9.5.1
    /usr/bin/npx 9.5.1
    nodejs:
    Installed: 18.16.0-deb-1nodesource1
    Candidate: 18.16.0-deb-1nodesource1
    Version table:
    *** 18.16.0-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
    12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Core adapters versions
    js-controller: 4.0.24
    admin: 6.4.4
    javascript: 7.0.3
    Adapters from github: 9
    Adapter State
    • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8111, bind: 192.168.178.xxxx, run as: admin
    • system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled
      system.adapter.backitup.0 : backitup : iobroker-pi - enabled
      system.adapter.blebox.0 : blebox : iobroker-pi - enabled
      system.adapter.cloud.0 : cloud : iobroker-pi - enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker-pi - disabled
      system.adapter.daswetter.0 : daswetter : iobroker-pi - enabled
      system.adapter.daswetter.1 : daswetter : iobroker-pi - enabled
      system.adapter.device-reminder.0 : device-reminder : iobroker-pi - enabled
      system.adapter.device-watcher.0 : device-watcher : iobroker-pi - disabled
      system.adapter.discovery.0 : discovery : iobroker-pi - disabled
      system.adapter.dwd.0 : dwd : iobroker-pi - enabled
      system.adapter.echarts.0 : echarts : iobroker-pi - enabled
      system.adapter.feiertage.0 : feiertage : iobroker-pi - enabled
      system.adapter.fritzbox.0 : fritzbox : iobroker-pi - enabled
      system.adapter.fully-tablet-control.0 : fully-tablet-control : iobroker-pi - enabled
    • system.adapter.ham.0 : ham : iobroker-pi - enabled
    • system.adapter.history.0 : history : iobroker-pi - enabled
    • system.adapter.hm-rega.0 : hm-rega : iobroker-pi - enabled
    • system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 12001
    • system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 18701
    • system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010
      system.adapter.hue.0 : hue : iobroker-pi - enabled, port: 443
      system.adapter.ical.0 : ical : iobroker-pi - enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-pi - enabled
      system.adapter.icons-icons8.0 : icons-icons8 : iobroker-pi - enabled
      system.adapter.icons-material-png.0 : icons-material-png : iobroker-pi - enabled
      system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker-pi - enabled
      system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker-pi - enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi - enabled
      system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker-pi - enabled
      system.adapter.info.0 : info : iobroker-pi - enabled
      system.adapter.iot.0 : iot : iobroker-pi - enabled
      system.adapter.iot.1 : iot : iobroker-pi - enabled
      system.adapter.iot.2 : iot : iobroker-pi - enabled
    • system.adapter.javascript.0 : javascript : iobroker-pi - enabled
    • system.adapter.javascript.1 : javascript : iobroker-pi - enabled
    • system.adapter.javascript.2 : javascript : iobroker-pi - enabled
    • system.adapter.javascript.3 : javascript : iobroker-pi - enabled
      system.adapter.material.0 : material : iobroker-pi - enabled
    • system.adapter.mqtt-client.0 : mqtt-client : iobroker-pi - enabled, port: 1883
    • system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 0.0.0.0
      system.adapter.parcel.0 : parcel : iobroker-pi - enabled
    • system.adapter.ping.0 : ping : iobroker-pi - enabled
      system.adapter.pollenflug.0 : pollenflug : iobroker-pi - enabled
      system.adapter.psa.0 : psa : iobroker-pi - enabled
      system.adapter.reolink.0 : reolink : iobroker-pi - enabled
      system.adapter.ring.0 : ring : iobroker-pi - enabled
      system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartgarden.0 : smartgarden : iobroker-pi - enabled
      system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-pi - enabled
    • system.adapter.tahoma.0 : tahoma : iobroker-pi - enabled
      system.adapter.tankerkoenig.0 : tankerkoenig : iobroker-pi - enabled
    • system.adapter.telegram.0 : telegram : iobroker-pi - enabled, port: 8443, bind: 0.0.0.0
      system.adapter.time-switch.0 : time-switch : iobroker-pi - enabled
    • system.adapter.tr-064.0 : tr-064 : iobroker-pi - enabled
    • system.adapter.tuya.1 : tuya : iobroker-pi - enabled
      system.adapter.vaillant.0 : vaillant : iobroker-pi - enabled
      system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker-pi - enabled
      system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker-pi - enabled
      system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker-pi - enabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker-pi - enabled
      system.adapter.vis-icontwo.0 : vis-icontwo : iobroker-pi - enabled
      system.adapter.vis-inventwo.0 : vis-inventwo : iobroker-pi - enabled
      system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker-pi - enabled
      system.adapter.vis-justgage.0 : vis-justgage : iobroker-pi - enabled
      system.adapter.vis-keyboard.0 : vis-keyboard : iobroker-pi - enabled
      system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker-pi - enabled
      system.adapter.vis-material.0 : vis-material : iobroker-pi - enabled
      system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker-pi - enabled
      system.adapter.vis-metro.0 : vis-metro : iobroker-pi - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker-pi - enabled
      system.adapter.vis-weather.0 : vis-weather : iobroker-pi - enabled
      system.adapter.vis.0 : vis : iobroker-pi - enabled
    • system.adapter.web.0 : web : iobroker-pi - enabled, port: 9082, bind: 192.168.178.xxx, run as: admin
      system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-pi - disabled
      system.adapter.ws.0 : ws : iobroker-pi - enabled, port: 8089, bind: 192.168.178.xxx, run as: admin
    • system.adapter.zigbee.0 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxx:6638
    • system.adapter.zigbee.1 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxx:6638
      system.adapter.zigbee.3 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xx:6638
    • instance is alive
    • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8111, bind: 192.168.178.xxx, run as: admin
    • system.adapter.hue.0 : hue : iobroker-pi - enabled, port: 443
    • system.adapter.zigbee.3 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxxx:6638
    ioBroker-Repositories
    stable : http://download.iobroker.net/sources-dist.json
    beta : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter "admin" : 6.4.4 , installed 6.4.4
    Adapter "alexa2" : 3.23.2 , installed 3.23.2
    Adapter "backitup" : 2.6.20 , installed 2.6.20
    Adapter "blebox" : 2.0.1 , installed 2.0.1
    Adapter "cloud" : 4.4.1 , installed 4.4.1
    Adapter "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter "daswetter" : 3.1.8 , installed 3.1.8
    Adapter "device-reminder": 1.2.9 , installed 1.2.9
    Adapter "device-watcher": 2.9.1 , installed 2.9.1
    Adapter "discovery" : 3.1.0 , installed 3.1.0
    Adapter "dwd" : 2.8.3 , installed 2.8.3
    Adapter "echarts" : 1.4.15 , installed 1.4.15
    Adapter "elero-usb-transmitter": 0.5.2, installed 0.5.2
    Adapter "feiertage" : 1.1.0 , installed 1.1.0
    Adapter "fritzbox" : 0.5.0 , installed 0.5.0
    Adapter "ham" : 5.3.1 , installed 5.3.1
    Adapter "history" : 2.2.4 , installed 2.2.4
    Adapter "hm-rega" : 3.0.46 , installed 3.0.46
    Adapter "hm-rpc" : 1.15.18 , installed 1.15.18
    Adapter "hue" : 3.7.1 , installed 3.7.1
    Adapter "ical" : 1.13.2 , installed 1.13.2
    Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
    Adapter "icons-material-png": 0.1.0, installed 0.1.0
    Adapter "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
    Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
    Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter "info" : 1.9.26 , installed 1.9.26
    Adapter "iot" : 1.14.5 , installed 1.14.5
    Adapter "javascript" : 7.0.3 , installed 7.0.3
    Controller "js-controller": 4.0.24 , installed 4.0.24
    Adapter "material" : 1.3.1 , installed 1.3.1
    Adapter "mqtt" : 4.1.1 , installed 4.1.1
    Adapter "mqtt-client" : 1.6.3 , installed 1.6.3
    Adapter "net-tools" : 0.2.0 , installed 0.2.0
    Adapter "ocpp" : 0.12.5 , installed 0.12.5
    Adapter "onvif" : 1.0.5 , installed 1.0.5
    Adapter "openweathermap": 0.3.8 , installed 0.3.8
    Adapter "parcel" : 0.0.28 , installed 0.0.28
    Adapter "ping" : 1.5.3 , installed 1.5.3
    Adapter "pollenflug" : 1.0.6 , installed 1.0.6
    Adapter "psa" : 0.0.11 , installed 0.0.11
    Adapter "ring" : 3.3.0 , installed 3.3.0
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "smartgarden" : 2.0.0 , installed 2.0.0
    Adapter "socketio" : 6.3.5 , installed 6.3.5
    Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
    Adapter "tahoma" : 0.10.2 , installed 0.10.2
    Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
    Adapter "telegram" : 1.15.6 , installed 1.15.6
    Adapter "time-switch" : 2.2.2 , installed 2.2.2
    Adapter "tr-064" : 4.2.18 , installed 4.2.18
    Adapter "tuya" : 3.14.2 , installed 3.14.2
    Adapter "vaillant" : 0.1.2 , installed 0.1.2
    Adapter "vis" : 1.4.16 , installed 1.4.16
    Adapter "vis-2-widgets-energy": 0.1.12, installed 0.1.12
    Adapter "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
    Adapter "vis-2-widgets-jaeger-design": 0.3.2, installed 0.3.2
    Adapter "vis-2-widgets-material": 0.2.13, installed 0.2.13
    Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
    Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
    Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
    Adapter "vis-icontwo" : 0.94.0 , installed 0.94.0
    Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
    Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
    Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
    Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2
    Adapter "vis-material" : 0.1.3 , installed 0.1.3
    Adapter "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter "vis-metro" : 1.2.0 , installed 1.2.0
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "vis-weather" : 2.5.6 , installed 2.5.6
    Adapter "web" : 5.5.3 , installed 5.5.3
    Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
    Adapter "ws" : 2.3.6 , installed 2.3.6
    Adapter "zigbee" : 1.8.10 , installed 1.8.10
    Objects and States
    Objects: 31979
    States: 27289
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
    W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
    Err:4 https://dl.yarnpkg.com/debian stable InRelease
    Fetched 17.1 kB in 2s (11.4 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 192.168.178.xxxx:18701 0.0.0.0:* LISTEN 1001 31354 3453/io.hm-rpc.1
    tcp 0 0 192.168.178.xxx:8111 0.0.0.0:* LISTEN 1001 31915 3149/io.admin.0
    tcp 0 0 192.168.178.xxx:8089 0.0.0.0:* LISTEN 1001 36290 4156/io.ws.0
    tcp 0 0 127.0.0.xxxx:9000 0.0.0.0:* LISTEN 1001 30893 3131/iobroker.js-co
    tcp 0 0 127.0.0.xxxx:9001 0.0.0.0:* LISTEN 1001 28956 3131/iobroker.js-co
    tcp 0 0 192.168.178.xxxx:12010 0.0.0.0:* LISTEN 1001 32420 3460/io.hm-rpc.2
    tcp 0 0 192.168.178.xxxxx:12001 0.0.0.0:* LISTEN 1001 32418 3446/io.hm-rpc.0
    tcp 0 0 192.168.178.xxxx:9082 0.0.0.0:* LISTEN 1001 34940 3725/io.web.0
    tcp 0 0 0.0.0.0:xxx 0.0.0.0:* LISTEN 0 12069 495/sshd: /usr/sbin
    tcp 0 0 0.0.0.0:xxx 0.0.0.0:* LISTEN 1001 31736 3610/io.mqtt.0
    tcp6 0 0 :::8087 :::* LISTEN 1001 36281 4212/io.simple-api.
    tcp6 0 0 :::22 :::* LISTEN 0 12071 495/sshd: /usr/sbin
    udp 0 0 0.0.0.0:6xx6 0.0.0.0:* 1001 35941 3520/io.tuya.1
    udp 0 0 0.0.0.0:6xx7 0.0.0.0:* 1001 35942 3520/io.tuya.1
    udp 0 0 0.0.0.0:xx 0.0.0.0:* 0 12085 690/dhcpcd
    udp 0 0 192.168.178.xxx:123 0.0.0.0:* 109 14860 487/ntpd
    udp 0 0 127.0.0.1:xxx 0.0.0.0:* 0 14669 487/ntpd
    udp 0 0 0.0.0.0:xxx 0.0.0.0:* 0 14665 487/ntpd
    udp 0 0 0.0.0.0:xxx 0.0.0.0:* 108 14567 355/avahi-daemon: r
    udp 0 0 0.0.0.0:xxx 0.0.0.0:* 108 14565 355/avahi-daemon: r
    udp6 0 0 2a02:908:xxx:e560:b:123 :::* 109 14863 487/ntpd
    udp6 0 0 fe80::53bb:xxxx:907:123 :::* 109 14846 487/ntpd
    udp6 0 0 ::1:123 :::* 0 14671 487/ntpd
    udp6 0 0 :::123 :::* 0 14662 487/ntpd
    udp6 0 0 :::546 :::* 0 12096 690/dhcpcd
    udp6 0 0 :::5353 :::* 108 14566 355/avahi-daemon: r
    udp6 0 0 :::50842 :::* 108 14568 355/avahi-daemon: r
    2023-05-16 21:21:18.357 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Manufacturer {"val":"Balboa","ack":true,"ts":1684264705875,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587285530}
    2023-05-16 21:21:18.448 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Model: value = Spa /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
    2023-05-16 21:21:18.453 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 21:21:18.698 - debug: reolink.0 (4158) Motion Detection value: 0
    2023-05-16 21:21:18.853 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Model {"val":"Spa","ack":true,"ts":1684264706232,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587285817}
    2023-05-16 21:21:18.912 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Name: value = Temperatur Einstellung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
    2023-05-16 21:21:19.326 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 21:21:19.376 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Name {"val":"Temperatur Einstellung","ack":true,"ts":1684264707007,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286038}
    2023-05-16 21:21:19.404 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Serial-Number: value = 2.2.6 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
    2023-05-16 21:21:19.493 - info: tuya.1 (3520) 03200296dc4f2229d2f2: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.108:6668
    2023-05-16 21:21:19.555 - debug: reolink.0 (4158) Motion Detection value: 0
    2023-05-16 21:21:19.806 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Serial-Number {"val":"2.2.6","ack":true,"ts":1684264707422,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286267}
    2023-05-16 21:21:20.170 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Firmware-Revision: value = 2.2.6 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
    2023-05-16 21:21:20.204 - info: blebox.0 (3855) State value to set for "blebox.0.Teich.tempSensor.sensors.0.id" has to be type "string" but received type "number"
    2023-05-16 21:21:20.342 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 21:21:20.670 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Firmware-Revision {"val":"2.2.6","ack":true,"ts":1684264707866,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286484}
    2023-05-16 21:21:20.709 - debug: reolink.0 (4158) Motion Detection value: 0
    2023-05-16 21:21:20.744 - info: ham.0 (3617) updateChannel Temperatur-Einstellung.Thermostat: name =
    2023-05-16 21:21:20.917 - info: ham.0 (3617) updateState Temperatur-Einstellung.Thermostat.Current-Heating-Cooling-State: value = 1 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value","name":"Current Heating Cooling State","unit":""}
    2023-05-16 21:21:21.015 - info: tuya.1 (3520) bfed8326787ed29axxxtot: Connect locally to device
    2023-05-16 21:21:21.018 - info: tuya.1 (3520) bfed8326787ed29axxxtot Init with IP=192.168.178.xxx, Key=51d7af4a1464d114, Version=3.4
    2023-05-16 21:21:21.146 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Thermostat.Current-Heating-Cooling-State {"val":1,"ack":true,"ts":1684264881108,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1684261586145}
    2023-05-16 21:21:21.205 - info: ham.0 (3617) updateState Temperatur-Einstellung.Thermostat.Target-Heating-Cooling-State: value = 1 /common= {"type":"number","min":0,"max":2,"read":true,"write":true,"role":"level","name":"Target Heating Cooling State","unit":""}
    2023-05-16 21:21:21.405 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 21:21:21.533 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Thermostat.Target-Heating-Cooling-State {"val":1,"ack":true,"ts":1684264881478,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1681646058199}
    iob diag has finished.
    • M michihorn
      @thomas-braun ```
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker : false
      Release: 11
      Codename: bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=53.5'C
      volt=0.9260V
      RTC time: n/a
      NTP service: n/a
      RTC in local TZ: no
      pi
      /home/pi
      X-Server: false
      Desktop:
      Terminal: tty
      *** MEMORY ***
      Swap: 99M 0B 99M
           7862 M total memory
            710 M used memory
            737 M active memory
           6136 M free memory
            172 M buffer memory
            842 M swap cache
             99 M total swap
              0 M used swap
             99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      2.4G /var/
      2.1G /var/log
      96M /var/cache
      /usr/bin/npm 9.5.1
      /usr/bin/npx 9.5.1
      nodejs:
      Version table:
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      admin: 6.4.4
      javascript: 7.0.3
      Adapter State
      • instance is alive
      Objects and States
      Objects: 31979
      States: 27289
      Pending Updates: 0
      @michihorn
      Du solltest die Kiste sauber neustarten, nicht austreten!
      Die yarn .list-Datei ist noch vorhanden.
      N M 2 Antworten Letzte Antwort
        @michihorn
        N Offline
        N Offline
        niiccooo1
        schrieb am zuletzt editiert von niiccooo1
        Hallo Zusammen,
        selbes Problem hier.
        ring.0
        2023-05-16 21:27:55.940	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        ring.0
        2023-05-16 21:27:55.938	info	terminating
        ring.0
        2023-05-16 21:27:55.934	error	Cannot read properties of undefined (reading 'battery_percentage')
        ring.0
        2023-05-16 21:27:55.933	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingDevice.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingDevice.js:420:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        ring.0
        2023-05-16 21:27:55.933	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
        ring.0
        2023-05-16 21:27:55.932	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        ring.0
        2023-05-16 21:27:54.544	info	Recieved new Refresh Token. Will use the new one until the token in config gets changed
        Mein ioBroker läuft in einem Docker Container. Habe den "Fixer" schon durchlaufen lassen und den Container neu gestartet.
        Keine Verbesserung.
        • N niiccooo1
          Hallo Zusammen,
          ring.0
          ring.0
          ring.0
          ring.0
          ring.0
          ring.0
          ring.0
          Keine Verbesserung.
          @niiccooo1
          https://github.com/iobroker-community-adapters/ioBroker.ring/issues/525
            @michihorn
            michihorn
            @thomas-braun sagte in RING Adapter Verbindet sich nicht mehr:
            @michihorn
            😇 Jetzt is die sources.list gelöscht
              @niiccooo1
              michihorn
              @niiccooo1
              Wir sind nicht allein ;-)
              • M michihorn
                @michihorn
                @michihorn
                Ich hoffe NICHT die /etc/apt/sources.list gelöscht...
                ls -lAh /etc/apt
                Sauberer Neustart wird überigens mit
                sudo reboot
                gemacht, nicht durch Stecker ziehen im laufenden Betrieb.
                  @michihorn
                  ls -lAh /etc/apt
                  sudo reboot
                  michihorn
                  @michihorn
                  ls -lAh /etc/apt
                  sudo reboot
                  Doch die ist weg 🤕 Und nun?
                  die sources.list.d ist noch da
                  • M michihorn
                    @michihorn
                    ls -lAh /etc/apt
                    sudo reboot
                    @michihorn
                    Warum hab ich das eigentlich mehrfach geschrieben?
                    • M michihorn
                      @michihorn
                      ls -lAh /etc/apt
                      sudo reboot
                      @michihorn sagte in RING Adapter Verbindet sich nicht mehr:
                      Das ist keine Datei sondern ein Verzeichnis.
                      ls -lAh /etc/apt/sources.list.d/
                      sagt?
                        @michihorn
                        michihorn
                        @thomas-braun habe das .d als schreibfehler angesehen
                        • M michihorn
                          @michihorn
                          Ich mache selten Schreibfehler...
                            sagt?
                            michihorn
                            sagt?
                            root@iobroker-pi:/etc/apt# root@iobroker-pi:/etc/apt# ls -lAh /etc/apt/sources.list.d/
                            total 12K
                            -rw-r--r-- 1 root root 208 Oct 26  2022 nodesource.list
                            -rw-r--r-- 1 root root 191 Feb  3  2022 raspi.list
                            -rw-r--r-- 1 root root  90 Oct 26  2022 yarn.list
                            Ich habe noch einen PI4 der fast gleich aufgebaut ist, kann ich die Datei rüber kopieren? Wohl eher nicht?!?
                            Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
                            • M michihorn
                              sagt?
                              total 12K
                              @michihorn yarn.list solltest du löschen, nicht die sources.list
                              Vielleicht kann dir jemand seine sources.list von seinem pi4/32bit zur Verfügung stellen. Meine kannst du nicht haben, die passt hinten und vorne nicht zu deinem System.
                              • M michihorn
                                sagt?
                                total 12K
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                root@iobroker
                                Wie oft muss man Dir das eigentlich noch so erklären ?
                                Gleiches mit "Text in Codetags packen" ;)
                                Lehrling seit 1975 !!!
                                • M michihorn
                                  sagt?
                                  total 12K
                                  @michihorn
                                  Und den Scheiß mit dem root kannste dir auch gleich abgewöhnen.
                                  Ich bin dann auch raus hier.
                                    @michihorn
                                    michihorn
                                    @michihorn
                                    YARN.list ist jetzt raus und sources.list wieder da 👍
                                    • M michihorn
                                      @michihorn
                                      @michihorn
                                      iob diag
                                        @michihorn
                                        iob diag
                                        michihorn
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=raspbian
                                        ID_LIKE=debian
                                         23:04:25 up 21 min,  1 user,  load average: 1.65, 1.45, 1.65
                                        CPU threads: 4
                                        Raspberry only:
                                        throttled=0x0
                                        temp=45.2'C
                                        volt=0.9360V
                                                       Local time: Tue 2023-05-16 23:04:25 CEST
                                                   Universal time: Tue 2023-05-16 21:04:25 UTC
                                                         RTC time: n/a
                                                      NTP service: n/a
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            7.9G        2.7G        4.7G        0.0K        527M        5.1G
                                        Swap:            99M          0B         99M
                                        Total:          8.0G        2.7G        4.8G
                                                 7862 M total memory
                                                 2675 M used memory
                                                 2670 M active memory
                                                  365 M inactive memory
                                                 4658 M free memory
                                                   65 M buffer memory
                                                  462 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        tmpfs          tmpfs     1.6G  788K  1.6G   1% /run
                                        [Tue May 16 22:42:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:87:59 vc_mem.        mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty        1 root=PARTUUID=4c91ec57-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Tue May 16 22:42:41 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                        [Tue May 16 22:42:41 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
                                        [Tue May 16 22:42:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,flush,errors=remount-ro
                                        /var:
                                        2.3G    /var/
                                        2.0G    /var/log
                                        1.8G    /var/log/journal/e2b5e5db604543deab373d50adc66fa2
                                        96M     /var/cache
                                        Archived and active journals take up 1.7G in the file system.
                                        34M     /opt/iobroker/iobroker-data/objects.jsonl
                                        /usr/bin/npm            9.5.1
                                        /usr/bin/npx            9.5.1
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.4.4
                                        javascript:     7.0.3
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8111, bind: 192.168.178.144, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                        + system.adapter.blebox.0                 : blebox                : iobroker-pi                              -  enabled
                                        + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
                                        + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
                                        + system.adapter.echarts.0                : echarts               : iobroker-pi                              -  enabled
                                        + system.adapter.fritzbox.0               : fritzbox              : iobroker-pi                              -  enabled
                                        + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker-pi                              -  enabled
                                        + system.adapter.ham.0                    : ham                   : iobroker-pi                              -  enabled
                                        + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
                                        + system.adapter.hue.0                    : hue                   : iobroker-pi                              -  enabled, port: 443
                                        + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
                                        + system.adapter.iot.0                    : iot                   : iobroker-pi                              -  enabled
                                        + system.adapter.iot.1                    : iot                   : iobroker-pi                              -  enabled
                                        + system.adapter.iot.2                    : iot                   : iobroker-pi                              -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                        + system.adapter.javascript.1             : javascript            : iobroker-pi                              -  enabled
                                        + system.adapter.javascript.2             : javascript            : iobroker-pi                              -  enabled
                                        + system.adapter.javascript.3             : javascript            : iobroker-pi                              -  enabled
                                        + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
                                        + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.parcel.0                 : parcel                : iobroker-pi                              -  enabled
                                        + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
                                        + system.adapter.pollenflug.0             : pollenflug            : iobroker-pi                              -  enabled
                                        + system.adapter.psa.0                    : psa                   : iobroker-pi                              -  enabled
                                        + system.adapter.reolink.0                : reolink               : iobroker-pi                              -  enabled
                                        + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.smartgarden.0            : smartgarden           : iobroker-pi                              -  enabled
                                        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pi                              -  enabled
                                        + system.adapter.tahoma.0                 : tahoma                : iobroker-pi                              -  enabled
                                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
                                        + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.time-switch.0            : time-switch           : iobroker-pi                              -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
                                        + system.adapter.tuya.1                   : tuya                  : iobroker-pi                              -  enabled
                                        + system.adapter.vaillant.0               : vaillant              : iobroker-pi                              -  enabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-pi                              -  enabled
                                        + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 9082, bind: 192.168.178.xxx, run as: admin
                                        + system.adapter.ws.0                     : ws                    : iobroker-pi                              -  enabled, port: 8089, bind: 192.168.178.xxx, run as: admin
                                        + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
                                        + system.adapter.zigbee.1                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
                                        + system.adapter.zigbee.3                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
                                        + instance is alive
                                        + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8111, bind: 192.168.178.xxx, run as: admin
                                        + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.xxx.0
                                        + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.xxx.0, run as: admin
                                        + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, port: 8443, bind: 0.0.xxx.0
                                        Objects and States
                                        Objects:        31972
                                        States:         27169
                                        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Pending Updates: 0
                                        tcp        0      0 0.0.0.xxx:1883            0.0.0.0:*               LISTEN      1001       16572      1038/io.mqtt.0
                                        tcp        0      0 192.168.178.xxx:12001   0.0.0.0:*               LISTEN      1001       18520      868/io.hm-rpc.0
                                        tcp        0      0 192.168.178.xxx:12010   0.0.0.0:*               LISTEN      1001       18527      896/io.hm-rpc.2
                                        tcp        0      0 192.168.178.xxx:8089    0.0.0.0:*               LISTEN      1001       17263      1558/io.ws.0
                                        tcp        0      0 192.168.178.xxx:8111    0.0.0.0:*               LISTEN      1001       13072      698/io.admin.0
                                        tcp        0      0 127.0.0.xxx:9001          0.0.0.0:*               LISTEN      1001       11933      489/iobroker.js-con
                                        tcp        0      0 127.0.0.xxx:9000          0.0.0.0:*               LISTEN      1001       12965      489/iobroker.js-con
                                        tcp        0      0 192.168.178.xxx:18701   0.0.0.0:*               LISTEN      1001       15735      875/io.hm-rpc.1
                                        tcp        0      0 0.0.0.xxx:22              0.0.0.0:*               LISTEN      0          12862      525/sshd: /usr/sbin
                                        tcp        0      0 192.168.178.xxx:9082    0.0.0.0:*               LISTEN      1001       16241      1147/io.web.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          12864      525/sshd: /usr/sbin
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19827      1618/io.simple-api.
                                        udp        0      0 0.0.0.xxx:xxx             0.0.0.0:*                           0          11099      696/dhcpcd
                                        udp        0      0 192.168.178.xxx:123     0.0.0.0:*                           109        13011      512/ntpd
                                        udp        0      0 127.0.0.xxx:xxx           0.0.0.0:*                           0          12837      512/ntpd
                                        udp        0      0 0.0.0.0:xxx             0.0.0.0:*                           0          12833      512/ntpd
                                        udp        0      0 0.0.0.0:xxx           0.0.0.0:*                           108        12702      354/avahi-daemon: r
                                        udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           108        12700      354/avahi-daemon: r
                                        udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           1001       19128      991/io.tuya.1
                                        udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           1001       19129      991/io.tuya.1
                                        udp6       0      0 2a02:908:xxx:e560:b:123 :::*                                109        13051      512/ntpd
                                        udp6       0      0 fe80::53bb:xxx:907:123 :::*                                109        12919      512/ntpd
                                        udp6       0      0 ::1:xxx                :::*                                0          12839      512/ntpd
                                        udp6       0      0 :::xxx                  :::*                                0          12830      512/ntpd
                                        udp6       0      0 :::xxx                  :::*                                0          11115      696/dhcpcd
                                        udp6       0      0 :::xxx                 :::*                                108        12701      354/avahi-daemon: r
                                        udp6       0      0 :::5xx6                :::*                                108        12703      354/avahi-daemon: r
                                        2023-05-16 23:05:47.772  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:47.852  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:48.710  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:48.766  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:49.772  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:49.784  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:50.048  - info: blebox.0 (1278) State value to set for "blebox.0.Teich.tempSensor.sensors.0.id" has to be type "string" but received type "number"
                                        2023-05-16 23:05:50.699  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:50.731  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:51.793  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:51.867  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:52.812  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:52.826  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:53.760  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:53.774  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:54.849  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:54.859  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:55.748  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:55.758  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:56.755  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:56.773  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:57.728  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:57.738  - debug: reolink.0 (1584) Motion Detection value: 0
                                        2023-05-16 23:05:58.828  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
                                        2023-05-16 23:05:58.931  - debug: reolink.0 (1584) Motion Detection value: 0
                                        • M michihorn
                                          Skript v.2023-04-16
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=raspbian
                                          ID_LIKE=debian
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          temp=45.2'C
                                          volt=0.9360V
                                                           RTC time: n/a
                                                        NTP service: n/a
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M          0B         99M
                                                   7862 M total memory
                                                   2675 M used memory
                                                   4658 M free memory
                                                     65 M buffer memory
                                                    462 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          2.3G    /var/
                                          2.0G    /var/log
                                          96M     /var/cache
                                          /usr/bin/npm            9.5.1
                                          /usr/bin/npx            9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.4.4
                                          javascript:     7.0.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        31972
                                          States:         27169
                                          Pending Updates: 0
                                          @michihorn
                                          Künftig regelmäßig Updates fahren und den root in Ruhe lassen.
