  4. RING Adapter Verbindet sich nicht mehr
    5.4k
41 Beiträge 5 Kommentatoren 2.2k Aufrufe 4 Beobachtet
    @michihorn
    Auch den reboot der Kiste?
    michihorn
    schrieb am zuletzt editiert von michihorn
    @thomas-braun ja klar . Kompletter Neustart des kleinen PI4
    • M michihorn
      @michihorn
      Dann haste ja jetzt eine stabile Basis.
      iob diag
      sagt?
        @michihorn
        iob diag
        sagt?
        michihorn
        @thomas-braun diag kennt er nicht
        • M michihorn
          @michihorn
          iob stop
          iob fix
          iob start
          iob diag
            @michihorn
            iob stop
            iob fix
            iob start
            iob diag
            michihorn
            @thomas-braun ```
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model : Raspberry Pi 4 Model B Rev 1.5
            Architecture : aarch64
            Docker : false
            Virtualization : none
            Distributor ID: Raspbian
            Description: Raspbian GNU/Linux 11 (bullseye)
            Release: 11
            Codename: bullseye
            PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
            21:16:14 up 9 min, 1 user, load average: 2.66, 3.26, 1.94
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=53.5'C
            volt=0.9260V
            *** Time and Time Zones ***
            Local time: Tue 2023-05-16 21:16:14 CEST
            Universal time: Tue 2023-05-16 19:16:14 UTC
            RTC time: n/a
            NTP service: n/a
            RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server: false
            Desktop:
            Terminal: tty
            Boot Target: multi-user.target
            *** MEMORY ***
            total used free shared buff/cache available
            Mem: 7.9G 711M 6.1G 0.0K 1.0G 7.0G
            Swap: 99M 0B 99M
            Total: 8.0G 711M 6.2G
                 7862 M total memory
                  710 M used memory
                  737 M active memory
                  594 M inactive memory
                 6136 M free memory
                  172 M buffer memory
                  842 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            Filesystem Type Size Used Avail Use% Mounted on
            /dev/root ext4 59G 15G 42G 26% /
            devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
            tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
            tmpfs tmpfs 1.6G 776K 1.6G 1% /run
            tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
            /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot
            tmpfs tmpfs 787M 0 787M 0% /run/user/1000
            [Tue May 16 21:06:56 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:FE:87:59 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=ttyS0,115200 console=tty1 root=PARTUUID=4c91ec57-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
            [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): 1 truncate cleaned up
            [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Tue May 16 21:06:57 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue May 16 21:06:57 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Tue May 16 21:07:00 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET SOURCE FSTYPE OPTIONS
            / /dev/mmcblk0p2 ext4 rw,noatime
            `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            2.4G /var/
            2.1G /var/log
            1.9G /var/log/journal/e2b5e5db604543deab373d50adc66fa2
            96M /var/cache
            Archived and active journals take up 1.8G in the file system.
            /opt/iobroker/backups:
            963M /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            3.0G /opt/iobroker/iobroker-data/
            2.3G /opt/iobroker/iobroker-data/files
            1.6G /opt/iobroker/iobroker-data/files/ring.0
            910M /opt/iobroker/iobroker-data/files/ring.0/doorbell_90474299
            560M /opt/iobroker/iobroker-data/backup-objects
            67M /opt/iobroker/iobroker-data/backups/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
            67M /opt/iobroker/iobroker-data/backup-objects/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
            41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            24M /opt/iobroker/iobroker-data/objects.jsonl
            23M /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs v18.16.0
            /usr/bin/node v18.16.0
            /usr/bin/npm 9.5.1
            /usr/bin/npx 9.5.1
            nodejs:
            Installed: 18.16.0-deb-1nodesource1
            Candidate: 18.16.0-deb-1nodesource1
            Version table:
            *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
            12.22.12~dfsg-1~deb11u4 500
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States type: jsonl
            Core adapters versions
            js-controller: 4.0.24
            admin: 6.4.4
            javascript: 7.0.3
            Adapters from github: 9
            Adapter State
            • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8111, bind: 192.168.178.xxxx, run as: admin
            • system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled
              system.adapter.backitup.0 : backitup : iobroker-pi - enabled
              system.adapter.blebox.0 : blebox : iobroker-pi - enabled
              system.adapter.cloud.0 : cloud : iobroker-pi - enabled
              system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker-pi - disabled
              system.adapter.daswetter.0 : daswetter : iobroker-pi - enabled
              system.adapter.daswetter.1 : daswetter : iobroker-pi - enabled
              system.adapter.device-reminder.0 : device-reminder : iobroker-pi - enabled
              system.adapter.device-watcher.0 : device-watcher : iobroker-pi - disabled
              system.adapter.discovery.0 : discovery : iobroker-pi - disabled
              system.adapter.dwd.0 : dwd : iobroker-pi - enabled
              system.adapter.echarts.0 : echarts : iobroker-pi - enabled
              system.adapter.feiertage.0 : feiertage : iobroker-pi - enabled
              system.adapter.fritzbox.0 : fritzbox : iobroker-pi - enabled
              system.adapter.fully-tablet-control.0 : fully-tablet-control : iobroker-pi - enabled
            • system.adapter.ham.0 : ham : iobroker-pi - enabled
            • system.adapter.history.0 : history : iobroker-pi - enabled
            • system.adapter.hm-rega.0 : hm-rega : iobroker-pi - enabled
            • system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 12001
            • system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 18701
            • system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010
              system.adapter.hue.0 : hue : iobroker-pi - enabled, port: 443
              system.adapter.ical.0 : ical : iobroker-pi - enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-pi - enabled
              system.adapter.icons-icons8.0 : icons-icons8 : iobroker-pi - enabled
              system.adapter.icons-material-png.0 : icons-material-png : iobroker-pi - enabled
              system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker-pi - enabled
              system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker-pi - enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi - enabled
              system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker-pi - enabled
              system.adapter.info.0 : info : iobroker-pi - enabled
              system.adapter.iot.0 : iot : iobroker-pi - enabled
              system.adapter.iot.1 : iot : iobroker-pi - enabled
              system.adapter.iot.2 : iot : iobroker-pi - enabled
            • system.adapter.javascript.0 : javascript : iobroker-pi - enabled
            • system.adapter.javascript.1 : javascript : iobroker-pi - enabled
            • system.adapter.javascript.2 : javascript : iobroker-pi - enabled
            • system.adapter.javascript.3 : javascript : iobroker-pi - enabled
              system.adapter.material.0 : material : iobroker-pi - enabled
            • system.adapter.mqtt-client.0 : mqtt-client : iobroker-pi - enabled, port: 1883
            • system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 0.0.0.0
              system.adapter.parcel.0 : parcel : iobroker-pi - enabled
            • system.adapter.ping.0 : ping : iobroker-pi - enabled
              system.adapter.pollenflug.0 : pollenflug : iobroker-pi - enabled
              system.adapter.psa.0 : psa : iobroker-pi - enabled
              system.adapter.reolink.0 : reolink : iobroker-pi - enabled
              system.adapter.ring.0 : ring : iobroker-pi - enabled
              system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.smartgarden.0 : smartgarden : iobroker-pi - enabled
              system.adapter.sourceanalytix.0 : sourceanalytix : iobroker-pi - enabled
            • system.adapter.tahoma.0 : tahoma : iobroker-pi - enabled
              system.adapter.tankerkoenig.0 : tankerkoenig : iobroker-pi - enabled
            • system.adapter.telegram.0 : telegram : iobroker-pi - enabled, port: 8443, bind: 0.0.0.0
              system.adapter.time-switch.0 : time-switch : iobroker-pi - enabled
            • system.adapter.tr-064.0 : tr-064 : iobroker-pi - enabled
            • system.adapter.tuya.1 : tuya : iobroker-pi - enabled
              system.adapter.vaillant.0 : vaillant : iobroker-pi - enabled
              system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker-pi - enabled
              system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobroker-pi - enabled
              system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker-pi - enabled
              system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker-pi - enabled
              system.adapter.vis-icontwo.0 : vis-icontwo : iobroker-pi - enabled
              system.adapter.vis-inventwo.0 : vis-inventwo : iobroker-pi - enabled
              system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker-pi - enabled
              system.adapter.vis-justgage.0 : vis-justgage : iobroker-pi - enabled
              system.adapter.vis-keyboard.0 : vis-keyboard : iobroker-pi - enabled
              system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker-pi - enabled
              system.adapter.vis-material.0 : vis-material : iobroker-pi - enabled
              system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker-pi - enabled
              system.adapter.vis-metro.0 : vis-metro : iobroker-pi - enabled
              system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker-pi - enabled
              system.adapter.vis-weather.0 : vis-weather : iobroker-pi - enabled
              system.adapter.vis.0 : vis : iobroker-pi - enabled
            • system.adapter.web.0 : web : iobroker-pi - enabled, port: 9082, bind: 192.168.178.xxx, run as: admin
              system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-pi - disabled
              system.adapter.ws.0 : ws : iobroker-pi - enabled, port: 8089, bind: 192.168.178.xxx, run as: admin
            • system.adapter.zigbee.0 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxx:6638
            • system.adapter.zigbee.1 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxx:6638
              system.adapter.zigbee.3 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xx:6638
            • instance is alive
            • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8111, bind: 192.168.178.xxx, run as: admin
            • system.adapter.hue.0 : hue : iobroker-pi - enabled, port: 443
            • system.adapter.zigbee.3 : zigbee : iobroker-pi - enabled, port: tcp://192.168.178.xxxx:6638
            ioBroker-Repositories
            stable : http://download.iobroker.net/sources-dist.json
            beta : http://download.iobroker.net/sources-dist-latest.json
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter "admin" : 6.4.4 , installed 6.4.4
            Adapter "alexa2" : 3.23.2 , installed 3.23.2
            Adapter "backitup" : 2.6.20 , installed 2.6.20
            Adapter "blebox" : 2.0.1 , installed 2.0.1
            Adapter "cloud" : 4.4.1 , installed 4.4.1
            Adapter "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter "daswetter" : 3.1.8 , installed 3.1.8
            Adapter "device-reminder": 1.2.9 , installed 1.2.9
            Adapter "device-watcher": 2.9.1 , installed 2.9.1
            Adapter "discovery" : 3.1.0 , installed 3.1.0
            Adapter "dwd" : 2.8.3 , installed 2.8.3
            Adapter "echarts" : 1.4.15 , installed 1.4.15
            Adapter "elero-usb-transmitter": 0.5.2, installed 0.5.2
            Adapter "feiertage" : 1.1.0 , installed 1.1.0
            Adapter "fritzbox" : 0.5.0 , installed 0.5.0
            Adapter "ham" : 5.3.1 , installed 5.3.1
            Adapter "history" : 2.2.4 , installed 2.2.4
            Adapter "hm-rega" : 3.0.46 , installed 3.0.46
            Adapter "hm-rpc" : 1.15.18 , installed 1.15.18
            Adapter "hue" : 3.7.1 , installed 3.7.1
            Adapter "ical" : 1.13.2 , installed 1.13.2
            Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
            Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
            Adapter "icons-material-png": 0.1.0, installed 0.1.0
            Adapter "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
            Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
            Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
            Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
            Adapter "info" : 1.9.26 , installed 1.9.26
            Adapter "iot" : 1.14.5 , installed 1.14.5
            Adapter "javascript" : 7.0.3 , installed 7.0.3
            Controller "js-controller": 4.0.24 , installed 4.0.24
            Adapter "material" : 1.3.1 , installed 1.3.1
            Adapter "mqtt" : 4.1.1 , installed 4.1.1
            Adapter "mqtt-client" : 1.6.3 , installed 1.6.3
            Adapter "net-tools" : 0.2.0 , installed 0.2.0
            Adapter "ocpp" : 0.12.5 , installed 0.12.5
            Adapter "onvif" : 1.0.5 , installed 1.0.5
            Adapter "openweathermap": 0.3.8 , installed 0.3.8
            Adapter "parcel" : 0.0.28 , installed 0.0.28
            Adapter "ping" : 1.5.3 , installed 1.5.3
            Adapter "pollenflug" : 1.0.6 , installed 1.0.6
            Adapter "psa" : 0.0.11 , installed 0.0.11
            Adapter "ring" : 3.3.0 , installed 3.3.0
            Adapter "simple-api" : 2.7.2 , installed 2.7.2
            Adapter "smartgarden" : 2.0.0 , installed 2.0.0
            Adapter "socketio" : 6.3.5 , installed 6.3.5
            Adapter "sourceanalytix": 0.4.14 , installed 0.4.14
            Adapter "tahoma" : 0.10.2 , installed 0.10.2
            Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
            Adapter "telegram" : 1.15.6 , installed 1.15.6
            Adapter "time-switch" : 2.2.2 , installed 2.2.2
            Adapter "tr-064" : 4.2.18 , installed 4.2.18
            Adapter "tuya" : 3.14.2 , installed 3.14.2
            Adapter "vaillant" : 0.1.2 , installed 0.1.2
            Adapter "vis" : 1.4.16 , installed 1.4.16
            Adapter "vis-2-widgets-energy": 0.1.12, installed 0.1.12
            Adapter "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
            Adapter "vis-2-widgets-jaeger-design": 0.3.2, installed 0.3.2
            Adapter "vis-2-widgets-material": 0.2.13, installed 0.2.13
            Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
            Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
            Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
            Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0
            Adapter "vis-icontwo" : 0.94.0 , installed 0.94.0
            Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3
            Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
            Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
            Adapter "vis-keyboard" : 0.0.2 , installed 0.0.2
            Adapter "vis-material" : 0.1.3 , installed 0.1.3
            Adapter "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter "vis-materialdesign": 0.5.9, installed 0.5.94
            Adapter "vis-metro" : 1.2.0 , installed 1.2.0
            Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
            Adapter "vis-weather" : 2.5.6 , installed 2.5.6
            Adapter "web" : 5.5.3 , installed 5.5.3
            Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3
            Adapter "ws" : 2.3.6 , installed 2.3.6
            Adapter "zigbee" : 1.8.10 , installed 1.8.10
            Objects and States
            Objects: 31979
            States: 27289
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
            W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures were invalid: EXPKEYSIG 23E7166788B63E1E Yarn Packaging yarn@dan.cx
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
            Get:4 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
            Err:4 https://dl.yarnpkg.com/debian stable InRelease
            Fetched 17.1 kB in 2s (11.4 kB/s)
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
            tcp 0 0 192.168.178.xxxx:18701 0.0.0.0:* LISTEN 1001 31354 3453/io.hm-rpc.1
            tcp 0 0 192.168.178.xxx:8111 0.0.0.0:* LISTEN 1001 31915 3149/io.admin.0
            tcp 0 0 192.168.178.xxx:8089 0.0.0.0:* LISTEN 1001 36290 4156/io.ws.0
            tcp 0 0 127.0.0.xxxx:9000 0.0.0.0:* LISTEN 1001 30893 3131/iobroker.js-co
            tcp 0 0 127.0.0.xxxx:9001 0.0.0.0:* LISTEN 1001 28956 3131/iobroker.js-co
            tcp 0 0 192.168.178.xxxx:12010 0.0.0.0:* LISTEN 1001 32420 3460/io.hm-rpc.2
            tcp 0 0 192.168.178.xxxxx:12001 0.0.0.0:* LISTEN 1001 32418 3446/io.hm-rpc.0
            tcp 0 0 192.168.178.xxxx:9082 0.0.0.0:* LISTEN 1001 34940 3725/io.web.0
            tcp 0 0 0.0.0.0:xxx 0.0.0.0:* LISTEN 0 12069 495/sshd: /usr/sbin
            tcp 0 0 0.0.0.0:xxx 0.0.0.0:* LISTEN 1001 31736 3610/io.mqtt.0
            tcp6 0 0 :::8087 :::* LISTEN 1001 36281 4212/io.simple-api.
            tcp6 0 0 :::22 :::* LISTEN 0 12071 495/sshd: /usr/sbin
            udp 0 0 0.0.0.0:6xx6 0.0.0.0:* 1001 35941 3520/io.tuya.1
            udp 0 0 0.0.0.0:6xx7 0.0.0.0:* 1001 35942 3520/io.tuya.1
            udp 0 0 0.0.0.0:xx 0.0.0.0:* 0 12085 690/dhcpcd
            udp 0 0 192.168.178.xxx:123 0.0.0.0:* 109 14860 487/ntpd
            udp 0 0 127.0.0.1:xxx 0.0.0.0:* 0 14669 487/ntpd
            udp 0 0 0.0.0.0:xxx 0.0.0.0:* 0 14665 487/ntpd
            udp 0 0 0.0.0.0:xxx 0.0.0.0:* 108 14567 355/avahi-daemon: r
            udp 0 0 0.0.0.0:xxx 0.0.0.0:* 108 14565 355/avahi-daemon: r
            udp6 0 0 2a02:908:xxx:e560:b:123 :::* 109 14863 487/ntpd
            udp6 0 0 fe80::53bb:xxxx:907:123 :::* 109 14846 487/ntpd
            udp6 0 0 ::1:123 :::* 0 14671 487/ntpd
            udp6 0 0 :::123 :::* 0 14662 487/ntpd
            udp6 0 0 :::546 :::* 0 12096 690/dhcpcd
            udp6 0 0 :::5353 :::* 108 14566 355/avahi-daemon: r
            udp6 0 0 :::50842 :::* 108 14568 355/avahi-daemon: r
            2023-05-16 21:21:18.357 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Manufacturer {"val":"Balboa","ack":true,"ts":1684264705875,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587285530}
            2023-05-16 21:21:18.448 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Model: value = Spa /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
            2023-05-16 21:21:18.453 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
            2023-05-16 21:21:18.698 - debug: reolink.0 (4158) Motion Detection value: 0
            2023-05-16 21:21:18.853 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Model {"val":"Spa","ack":true,"ts":1684264706232,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587285817}
            2023-05-16 21:21:18.912 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Name: value = Temperatur Einstellung /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
            2023-05-16 21:21:19.326 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
            2023-05-16 21:21:19.376 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Name {"val":"Temperatur Einstellung","ack":true,"ts":1684264707007,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286038}
            2023-05-16 21:21:19.404 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Serial-Number: value = 2.2.6 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Serial Number","unit":""}
            2023-05-16 21:21:19.493 - info: tuya.1 (3520) 03200296dc4f2229d2f2: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.108:6668
            2023-05-16 21:21:19.555 - debug: reolink.0 (4158) Motion Detection value: 0
            2023-05-16 21:21:19.806 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Serial-Number {"val":"2.2.6","ack":true,"ts":1684264707422,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286267}
            2023-05-16 21:21:20.170 - info: ham.0 (3617) updateState Temperatur-Einstellung.Accessory-Information.Firmware-Revision: value = 2.2.6 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Firmware Revision","unit":""}
            2023-05-16 21:21:20.204 - info: blebox.0 (3855) State value to set for "blebox.0.Teich.tempSensor.sensors.0.id" has to be type "string" but received type "number"
            2023-05-16 21:21:20.342 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
            2023-05-16 21:21:20.670 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Accessory-Information.Firmware-Revision {"val":"2.2.6","ack":true,"ts":1684264707866,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1667587286484}
            2023-05-16 21:21:20.709 - debug: reolink.0 (4158) Motion Detection value: 0
            2023-05-16 21:21:20.744 - info: ham.0 (3617) updateChannel Temperatur-Einstellung.Thermostat: name =
            2023-05-16 21:21:20.917 - info: ham.0 (3617) updateState Temperatur-Einstellung.Thermostat.Current-Heating-Cooling-State: value = 1 /common= {"type":"number","min":0,"max":2,"read":true,"write":false,"role":"value","name":"Current Heating Cooling State","unit":""}
            2023-05-16 21:21:21.015 - info: tuya.1 (3520) bfed8326787ed29axxxtot: Connect locally to device
            2023-05-16 21:21:21.018 - info: tuya.1 (3520) bfed8326787ed29axxxtot Init with IP=192.168.178.xxx, Key=51d7af4a1464d114, Version=3.4
            2023-05-16 21:21:21.146 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Thermostat.Current-Heating-Cooling-State {"val":1,"ack":true,"ts":1684264881108,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1684261586145}
            2023-05-16 21:21:21.205 - info: ham.0 (3617) updateState Temperatur-Einstellung.Thermostat.Target-Heating-Cooling-State: value = 1 /common= {"type":"number","min":0,"max":2,"read":true,"write":true,"role":"level","name":"Target Heating Cooling State","unit":""}
            2023-05-16 21:21:21.405 - debug: reolink.0 (4158) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
            2023-05-16 21:21:21.533 - info: ham.0 (3617) stateChange ham.0.Temperatur-Einstellung.Thermostat.Target-Heating-Cooling-State {"val":1,"ack":true,"ts":1684264881478,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1681646058199}
            iob diag has finished.
            • M michihorn
              @thomas-braun ```
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker : false
              Release: 11
              Codename: bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=53.5'C
              volt=0.9260V
              RTC time: n/a
              NTP service: n/a
              RTC in local TZ: no
              pi
              /home/pi
              X-Server: false
              Desktop:
              Terminal: tty
              *** MEMORY ***
              Swap: 99M 0B 99M
                   7862 M total memory
                    710 M used memory
                    737 M active memory
                   6136 M free memory
                    172 M buffer memory
                    842 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              2.4G /var/
              2.1G /var/log
              96M /var/cache
              /usr/bin/npm 9.5.1
              /usr/bin/npx 9.5.1
              nodejs:
              Version table:
              ioBroker Status
              Objects type: jsonl
              States type: jsonl
              admin: 6.4.4
              javascript: 7.0.3
              Adapter State
              • instance is alive
              Objects and States
              Objects: 31979
              States: 27289
              Pending Updates: 0
              @michihorn
              Du solltest die Kiste sauber neustarten, nicht austreten!
              Die yarn .list-Datei ist noch vorhanden.
              N M 2 Antworten Letzte Antwort
                @michihorn
                N Offline
                N Offline
                niiccooo1
                schrieb am zuletzt editiert von niiccooo1
                Hallo Zusammen,
                selbes Problem hier.
                ring.0
                2023-05-16 21:27:55.940	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                ring.0
                2023-05-16 21:27:55.938	info	terminating
                ring.0
                2023-05-16 21:27:55.934	error	Cannot read properties of undefined (reading 'battery_percentage')
                ring.0
                2023-05-16 21:27:55.933	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingDevice.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingDevice.js:420:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                ring.0
                2023-05-16 21:27:55.933	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
                ring.0
                2023-05-16 21:27:55.932	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                ring.0
                2023-05-16 21:27:54.544	info	Recieved new Refresh Token. Will use the new one until the token in config gets changed
                Mein ioBroker läuft in einem Docker Container. Habe den "Fixer" schon durchlaufen lassen und den Container neu gestartet.
                Keine Verbesserung.
                • N niiccooo1
                  Hallo Zusammen,
                  ring.0
                  ring.0
                  ring.0
                  ring.0
                  ring.0
                  ring.0
                  ring.0
                  Keine Verbesserung.
                  @niiccooo1
                  https://github.com/iobroker-community-adapters/ioBroker.ring/issues/525
                    @michihorn
                    michihorn
                    @thomas-braun sagte in RING Adapter Verbindet sich nicht mehr:
                    @michihorn
                    😇 Jetzt is die sources.list gelöscht
                      @niiccooo1
                      michihorn
                      @niiccooo1
                      Wir sind nicht allein ;-)
                      • M michihorn
                        @michihorn
                        @michihorn
                        Ich hoffe NICHT die /etc/apt/sources.list gelöscht...
                        ls -lAh /etc/apt
                        Sauberer Neustart wird überigens mit
                        sudo reboot
                        gemacht, nicht durch Stecker ziehen im laufenden Betrieb.
                          @michihorn
                          ls -lAh /etc/apt
                          sudo reboot
                          michihorn
                          @michihorn
                          ls -lAh /etc/apt
                          sudo reboot
                          Doch die ist weg 🤕 Und nun?
                          die sources.list.d ist noch da
                          • M michihorn
                            @michihorn
                            ls -lAh /etc/apt
                            sudo reboot
                            @michihorn
                            Warum hab ich das eigentlich mehrfach geschrieben?
                            • M michihorn
                              @michihorn
                              ls -lAh /etc/apt
                              sudo reboot
                              @michihorn sagte in RING Adapter Verbindet sich nicht mehr:
                              Das ist keine Datei sondern ein Verzeichnis.
                              ls -lAh /etc/apt/sources.list.d/
                              sagt?
                                @michihorn
                                michihorn
                                @thomas-braun habe das .d als schreibfehler angesehen
                                • M michihorn
                                  @michihorn
                                  Ich mache selten Schreibfehler...
                                    sagt?
                                    michihorn
                                    sagt?
                                    root@iobroker-pi:/etc/apt# root@iobroker-pi:/etc/apt# ls -lAh /etc/apt/sources.list.d/
                                    total 12K
                                    -rw-r--r-- 1 root root 208 Oct 26  2022 nodesource.list
                                    -rw-r--r-- 1 root root 191 Feb  3  2022 raspi.list
                                    -rw-r--r-- 1 root root  90 Oct 26  2022 yarn.list
                                    Ich habe noch einen PI4 der fast gleich aufgebaut ist, kann ich die Datei rüber kopieren? Wohl eher nicht?!?
                                    Thomas BraunT DJMarc75D 3 Antworten Letzte Antwort
                                    • M michihorn
                                      sagt?
                                      total 12K
                                      @michihorn yarn.list solltest du löschen, nicht die sources.list
                                      Vielleicht kann dir jemand seine sources.list von seinem pi4/32bit zur Verfügung stellen. Meine kannst du nicht haben, die passt hinten und vorne nicht zu deinem System.
                                      • M michihorn
                                        sagt?
                                        total 12K
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        root@iobroker
                                        Wie oft muss man Dir das eigentlich noch so erklären ?
                                        Gleiches mit "Text in Codetags packen" ;)
                                        Lehrling seit 1975 !!!
                                        • M michihorn
                                          sagt?
                                          total 12K
                                          @michihorn
                                          Und den Scheiß mit dem root kannste dir auch gleich abgewöhnen.
                                          Ich bin dann auch raus hier.
