  4. RING Adapter Verbindet sich nicht mehr
    5.4k
41 Beiträge 5 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • M michihorn
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     23:04:25 up 21 min,  1 user,  load average: 1.65, 1.45, 1.65
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=45.2'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Tue 2023-05-16 23:04:25 CEST
               Universal time: Tue 2023-05-16 21:04:25 UTC
                     RTC time: n/a
                  NTP service: n/a
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.9G        2.7G        4.7G        0.0K        527M        5.1G
    Swap:            99M          0B         99M
    Total:          8.0G        2.7G        4.8G
             7862 M total memory
             2675 M used memory
             2670 M active memory
              365 M inactive memory
             4658 M free memory
               65 M buffer memory
              462 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4       59G   15G   42G  26% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  788K  1.6G   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     787M     0  787M   0% /run/user/1000
    [Tue May 16 22:42:40 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:FE:87:59 vc_mem.        mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty        1 root=PARTUUID=4c91ec57-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue May 16 22:42:41 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
    [Tue May 16 22:42:41 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
    [Tue May 16 22:42:44 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.3G    /var/
    2.0G    /var/log
    1.8G    /var/log/journal/e2b5e5db604543deab373d50adc66fa2
    96M     /var/cache
    Archived and active journals take up 1.7G in the file system.
    /opt/iobroker/backups:
    963M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    3.0G    /opt/iobroker/iobroker-data/
    2.3G    /opt/iobroker/iobroker-data/files
    1.6G    /opt/iobroker/iobroker-data/files/ring.0
    910M    /opt/iobroker/iobroker-data/files/ring.0/doorbell_90474299
    560M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/backups/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
    67M     /opt/iobroker/iobroker-data/backup-objects/iobroker_2022_12_20-17_08_17_backupiobroker.tar.gz
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    34M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.4.4
    javascript:     7.0.3
    Adapters from github:   9
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8111, bind: 192.168.178.144, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iobroker-pi                              -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
    + system.adapter.blebox.0                 : blebox                : iobroker-pi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker-pi                              -  enabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker-pi                              - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker-pi                              -  enabled
      system.adapter.daswetter.1              : daswetter             : iobroker-pi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker-pi                              -  enabled
      system.adapter.device-watcher.0         : device-watcher        : iobroker-pi                              - disabled
      system.adapter.discovery.0              : discovery             : iobroker-pi                              - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker-pi                              -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker-pi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker-pi                              -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker-pi                              -  enabled
    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker-pi                              -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker-pi                              -  enabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-pi                              -  enabled, port: 12010
    + system.adapter.hue.0                    : hue                   : iobroker-pi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker-pi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-pi                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker-pi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker-pi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-pi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-pi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-pi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-pi                              -  enabled
    + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker-pi                              -  enabled
    + system.adapter.iot.1                    : iot                   : iobroker-pi                              -  enabled
    + system.adapter.iot.2                    : iot                   : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.javascript.2             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.javascript.3             : javascript            : iobroker-pi                              -  enabled
      system.adapter.material.0               : material              : iobroker-pi                              -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.parcel.0                 : parcel                : iobroker-pi                              -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker-pi                              -  enabled
    + system.adapter.psa.0                    : psa                   : iobroker-pi                              -  enabled
    + system.adapter.reolink.0                : reolink               : iobroker-pi                              -  enabled
      system.adapter.ring.0                   : ring                  : iobroker-pi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartgarden.0            : smartgarden           : iobroker-pi                              -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pi                              -  enabled
    + system.adapter.tahoma.0                 : tahoma                : iobroker-pi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.time-switch.0            : time-switch           : iobroker-pi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              -  enabled
    + system.adapter.tuya.1                   : tuya                  : iobroker-pi                              -  enabled
    + system.adapter.vaillant.0               : vaillant              : iobroker-pi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-pi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-pi                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-pi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-pi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-pi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-pi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-pi                              -  enabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-pi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-pi                              -  enabled
      system.adapter.vis-material.0           : vis-material          : iobroker-pi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-pi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker-pi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker-pi                              -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
    + system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 9082, bind: 192.168.178.xxx, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker-pi                              - disabled
    + system.adapter.ws.0                     : ws                    : iobroker-pi                              -  enabled, port: 8089, bind: 192.168.178.xxx, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
    + system.adapter.zigbee.1                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
    + system.adapter.zigbee.3                 : zigbee                : iobroker-pi                              -  enabled, port: tcp://192.168.178.xxx:6638
    + instance is alive
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8111, bind: 192.168.178.xxx, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.xxx.0
    + system.adapter.simple-api.0             : simple-api            : iobroker-pi                              -  enabled, port: 8087, bind: 0.0.xxx.0, run as: admin
    + system.adapter.telegram.0               : telegram              : iobroker-pi                              -  enabled, port: 8443, bind: 0.0.xxx.0
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.4.4    , installed 6.4.4
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.20   , installed 2.6.20
    Adapter    "blebox"       : 2.0.1    , installed 2.0.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.8    , installed 3.1.8
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "device-watcher": 2.9.1   , installed 2.9.1
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "echarts"      : 1.4.15   , installed 1.4.15
    Adapter    "elero-usb-transmitter": 0.5.2, installed 0.5.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "ical"         : 1.13.2   , installed 1.13.2
    Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-png": 0.1.0, installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "openweathermap": 0.3.8   , installed 0.3.8
    Adapter    "parcel"       : 0.0.28   , installed 0.0.28
    Adapter    "ping"         : 1.5.3    , installed 1.5.3
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "psa"          : 0.0.11   , installed 0.0.11
    Adapter    "ring"         : 3.3.0    , installed 3.3.0
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
    Adapter    "vis"          : 1.4.16   , installed 1.4.16
    Adapter    "vis-2-widgets-energy": 0.1.12, installed 0.1.12
    Adapter    "vis-2-widgets-gauges": 0.1.12, installed 0.1.12
    Adapter    "vis-2-widgets-jaeger-design": 0.3.2, installed 0.3.2
    Adapter    "vis-2-widgets-material": 0.2.13, installed 0.2.13
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "vis-icontwo"  : 0.94.0   , installed 0.94.0
    Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
    Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        31972
    States:         27169
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.xxx:1883            0.0.0.0:*               LISTEN      1001       16572      1038/io.mqtt.0
    tcp        0      0 192.168.178.xxx:12001   0.0.0.0:*               LISTEN      1001       18520      868/io.hm-rpc.0
    tcp        0      0 192.168.178.xxx:12010   0.0.0.0:*               LISTEN      1001       18527      896/io.hm-rpc.2
    tcp        0      0 192.168.178.xxx:8089    0.0.0.0:*               LISTEN      1001       17263      1558/io.ws.0
    tcp        0      0 192.168.178.xxx:8111    0.0.0.0:*               LISTEN      1001       13072      698/io.admin.0
    tcp        0      0 127.0.0.xxx:9001          0.0.0.0:*               LISTEN      1001       11933      489/iobroker.js-con
    tcp        0      0 127.0.0.xxx:9000          0.0.0.0:*               LISTEN      1001       12965      489/iobroker.js-con
    tcp        0      0 192.168.178.xxx:18701   0.0.0.0:*               LISTEN      1001       15735      875/io.hm-rpc.1
    tcp        0      0 0.0.0.xxx:22              0.0.0.0:*               LISTEN      0          12862      525/sshd: /usr/sbin
    tcp        0      0 192.168.178.xxx:9082    0.0.0.0:*               LISTEN      1001       16241      1147/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12864      525/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19827      1618/io.simple-api.
    udp        0      0 0.0.0.xxx:xxx             0.0.0.0:*                           0          11099      696/dhcpcd
    udp        0      0 192.168.178.xxx:123     0.0.0.0:*                           109        13011      512/ntpd
    udp        0      0 127.0.0.xxx:xxx           0.0.0.0:*                           0          12837      512/ntpd
    udp        0      0 0.0.0.0:xxx             0.0.0.0:*                           0          12833      512/ntpd
    udp        0      0 0.0.0.0:xxx           0.0.0.0:*                           108        12702      354/avahi-daemon: r
    udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           108        12700      354/avahi-daemon: r
    udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           1001       19128      991/io.tuya.1
    udp        0      0 0.0.0.0:xxx            0.0.0.0:*                           1001       19129      991/io.tuya.1
    udp6       0      0 2a02:908:xxx:e560:b:123 :::*                                109        13051      512/ntpd
    udp6       0      0 fe80::53bb:xxx:907:123 :::*                                109        12919      512/ntpd
    udp6       0      0 ::1:xxx                :::*                                0          12839      512/ntpd
    udp6       0      0 :::xxx                  :::*                                0          12830      512/ntpd
    udp6       0      0 :::xxx                  :::*                                0          11115      696/dhcpcd
    udp6       0      0 :::xxx                 :::*                                108        12701      354/avahi-daemon: r
    udp6       0      0 :::5xx6                :::*                                108        12703      354/avahi-daemon: r
    2023-05-16 23:05:47.772  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:47.852  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:48.710  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:48.766  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:49.772  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:49.784  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:50.048  - info: blebox.0 (1278) State value to set for "blebox.0.Teich.tempSensor.sensors.0.id" has to be type "string" but received type "number"
    2023-05-16 23:05:50.699  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:50.731  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:51.793  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:51.867  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:52.812  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:52.826  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:53.760  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:53.774  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:54.849  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:54.859  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:55.748  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:55.758  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:56.755  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:56.773  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:57.728  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:57.738  - debug: reolink.0 (1584) Motion Detection value: 0
    2023-05-16 23:05:58.828  - debug: reolink.0 (1584) camMdStateInfo 200: [{"cmd":"GetMdState","code":0,"value":{"state":0}}]
    2023-05-16 23:05:58.931  - debug: reolink.0 (1584) Motion Detection value: 0
    iob diag has finished.
    #41
    @michihorn
    Künftig regelmäßig Updates fahren und den root in Ruhe lassen.
