  3. Einsteigerfragen
  4. Installation
  5. Docker Installation lädt admin Adapter nicht
Geplant Angeheftet Gesperrt Verschoben Installation
30 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • F ferrog
    Logs —watch von latest-v8:
    2023-05-13 18:49:56.226  - info: host.buanet-iobroker3 iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 hostname: buanet-iobroker3, node: v18.16.0
    2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 ip addresses: 192.168.178.3 fd9b:f2b9:802:4f06:9209:d0ff:fe32:33f3 2003:cd:f47:c000:9209:d0ff:fe32:33f3 fe80::9209:d0ff:fe32:33f3 172.17.0.1 fe80::42:caff:fe53:7492 fe80::5ca4:c5ff:fec1:c9b fe80::6054:cbff:fe48:42d2 fe80::8c55:c1ff:fee3:f31b fe80::f4c1:fbff:fe20:3a8f fe80::c866:afff:fe37:903a
    2023-05-13 18:49:56.474  - info: host.buanet-iobroker3 connected to Objects and States
    2023-05-13 18:49:56.481  - info: host.buanet-iobroker3 Node.js version has changed from unknown to 18.16.0
    2023-05-13 18:49:56.501  - info: host.buanet-iobroker3 added notifications configuration of host
    2023-05-13 18:49:56.658  - info: host.buanet-iobroker3 3 instances found
    2023-05-13 18:49:56.661  - info: host.buanet-iobroker3 starting 3 instances
    2023-05-13 18:49:56.680  - info: host.buanet-iobroker3 instance system.adapter.admin.0 started with pid 1761
    2023-05-13 18:49:57.314  - info: host.buanet-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-05-13 18:49:58.050  - info: admin.0 (1761) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-05-13 18:49:58.067  - info: admin.0 (1761) requesting all states
    2023-05-13 18:49:58.068  - info: admin.0 (1761) requesting all objects
    2023-05-13 18:49:58.127  - info: admin.0 (1761) received all objects
    2023-05-13 18:49:58.151  - info: admin.0 (1761) Request actual repository...
    2023-05-13 18:49:58.160  - info: host.buanet-iobroker3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-05-13 18:49:58.300  - warn: admin.0 (1761) Repository cannot be read: Active repo - stable
    2023-05-13 18:49:58.301  - warn: admin.0 (1761) Active repository "stable" cannot be read
    2023-05-13 18:49:58.763  - error: admin.0 (1761) port 8081 already in use
    2023-05-13 18:49:58.764  - info: admin.0 (1761) Terminated (ADAPTER_REQUESTED_TERMINATION): port 8081 already in use
    2023-05-13 18:49:59.277  - info: admin.0 (1761) terminating http server on port 8081
    2023-05-13 18:49:59.289  - error: host.buanet-iobroker3 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2023-05-13 18:49:59.290  - info: host.buanet-iobroker3 Do not restart adapter system.adapter.admin.0 because desired by instance
    2023-05-13 18:50:00.676  - info: host.buanet-iobroker3 instance system.adapter.discovery.0 started with pid 1785
    2023-05-13 18:50:01.342  - info: discovery.0 (1785) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-05-13 18:50:04.690  - info: host.buanet-iobroker3 instance system.adapter.backitup.0 started with pid 1804
    2023-05-13 18:50:05.314  - info: backitup.0 (1804) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-05-13 18:50:05.446  - info: backitup.0 (1804) [iobroker] backup will be activated at 02:40 every 1 day(s)
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @ferrog sagte in Docker Installation lädt admin Adapter nicht:
    Logs
    2023-05-13 17:47:52.996
    Bitte aktuell zeigen !!
    • F Offline
      ferrog
      Ahh, sorry falsche Datei, ist korrigiert. Da gibts auch errors…
      Keba P30, 50kWp SMA, 15kWh Victron MP2, Daikin LLWP, Docker@SynologyDS923+
      • F ferrog
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        Da läuft was doppelt , deshalb startet jetzt in diesem Log der ioBroker nicht
        • GlasfaserG Glasfaser
          Liegt das vielleicht an der Bereitstellung des Ports durch DSM „Webstation“?
          Welcher Port hat er denn ,
          dann würdest du aber nicht ioBroker mit 8081 erreichen !
          Der Loop ist ein anderer ( Fehler ) . kann Ihn aber nicht erkennen .
          Zeige mal die Ausgabe von
          iob logs --watch
          wenn du im Loop bist
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @ferrog
          @glasfaser sagte in Docker Installation lädt admin Adapter nicht:
          Kann du nicht meine Fragen beantworten !?
            @ferrog
            HomoranH Offline
            HomoranH Offline
            @ferrog
            bitte lesen und befolgen!
            • F Offline
              ferrog
              Ich habe das nicht als Frage verstanden.
              Natürlich reicht die Webstation den Port 8081 an den Docker Container weiter.
              • F ferrog
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                Lösche alle diese Einträge !
                Hier wird nur der Port vorgegeben :
                siehe Beispiel Containereinstellung
                und das ausschalten / haken bei dir raus
                • F Offline
                  ferrog
                  WOW, vielen Dank! Daran hats gelegen.
                  Und großen Respekt an die Schnelligkeit eurer Unterstützung!
                  Zum Hintergrund: Belegt Webstation dann in dem Container den besagten Port?
                  GlasfaserG 2 Antworten Letzte Antwort
                  • F ferrog
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    ... aber mühselig erfragt ;)
                    Jipp , deshalb meine Frage :
                    @ferrog
                    • F ferrog
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      Dann setze den Thread auf [gelöst]
