  3. Einsteigerfragen
  4. Installation
  5. Docker Installation lädt admin Adapter nicht
30 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • F Offline
    ferrog
    schrieb am zuletzt editiert von ferrog
    Anbei dann noch die Diag von v8:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : v8.0.1
    Virtualization  : Unknown (buanet/Synology?)
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     18:08:27 up  3:20,  0 users,  load average: 0.73, 0.84, 0.80
    CPU threads: 4
    *** Time and Time Zones ***
    Sat May 13 16:08:27 UTC 2023
    Sat May 13 18:08:27 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            3.9G        1.3G        246M        1.1G        2.3G        950M
    Swap:           4.4G        181M        4.2G
    Total:          8.3G        1.5G        4.4G
             3890 M total memory
             1304 M used memory
              902 M active memory
             1076 M inactive memory
              246 M free memory
               11 M buffer memory
             2327 M swap cache
             4383 M total swap
              181 M used swap
             4202 M free swap
    *** FILESYSTEM ***
    Filesystem             Type   Size  Used Avail Use% Mounted on
    /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /
    tmpfs                  tmpfs   64M     0   64M   0% /dev
    tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/fs/cgroup
    shm                    tmpfs   64M     0   64M   0% /dev/shm
    /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /opt/iobroker
    /dev/mapper/cachedev_1 btrfs  8.8T  3.7T  5.1T  42% /etc/hosts
    tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/acpi
    tmpfs                  tmpfs  1.9G     0  1.9G   0% /proc/scsi
    tmpfs                  tmpfs  1.9G     0  1.9G   0% /sys/firmware
    [Sat May 13 14:49:02 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Sat May 13 14:49:02 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Sat May 13 14:49:03 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Sat May 13 14:49:03 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Sat May 13 14:49:03 2023] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
    [Sat May 13 14:49:03 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    [Sat May 13 14:49:08 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
    [Sat May 13 14:49:08 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
    [Sat May 13 14:49:08 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
    [Sat May 13 14:49:31 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  /dev/mapper/cachedev_1[/@syno/@docker/btrfs/subvolumes/e6ecc9255012492ebd334775a6260c88c76a08edb3c0b775424d72fe73930282]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=440,subvol=/@syno/@docker/btrfs/subvolumes/e6ecc9255012492ebd334775a6260c88c76a08edb3c0b775424d72fe73930282
    |-/opt/iobroker    /dev/mapper/cachedev_1[/@syno/docker/iobv81]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=257,subvol=/@syno/docker/iobv81
    |-/etc/resolv.conf /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/resolv.conf
    |-/etc/hostname    /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hostname
    `-/etc/hosts       /dev/mapper/cachedev_1[/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_cache_tree,syno_allocator,subvolid=256,subvol=/@syno/@docker/containers/29bbab4cb9922da718b03610b10e2a45b31c8c66902d5ccdbe4a31f4a00068ff/hosts
    /var:
    33M	/var/
    30M	/var/lib
    18M	/var/lib/apt/lists
    18M	/var/lib/apt
    13M	/var/lib/dpkg
    /opt/iobroker/backups:
    0	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18M	/opt/iobroker/iobroker-data/
    14M	/opt/iobroker/iobroker-data/files
    13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.3M	/opt/iobroker/iobroker-data/objects.jsonl
    2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.16.0
    /usr/bin/node 		v18.16.0
    /usr/bin/npm 		9.5.1
    /usr/bin/npx 		9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	"javascript" not found
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : buanet-iobroker4                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : buanet-iobroker4                         -  enabled
    + system.adapter.discovery.0              : discovery             : buanet-iobroker4                         -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.6.19   , installed 2.6.19
    Objects and States
    Objects: 	143
    States: 	104
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1575259    -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1575252    -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1576185    -
    2023-05-13 17:47:43.755  - info: host.buanet-iobroker4 iobroker.js-controller version 4.0.24 js-controller starting
    2023-05-13 17:47:43.758  - info: host.buanet-iobroker4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-05-13 17:47:43.759  - info: host.buanet-iobroker4 hostname: buanet-iobroker4, node: v18.16.0
    2023-05-13 17:47:43.759  - info: host.buanet-iobroker4 ip addresses: 172.17.0.6
    2023-05-13 17:47:44.092  - info: host.buanet-iobroker4 connected to Objects and States
    2023-05-13 17:47:44.102  - info: host.buanet-iobroker4 Node.js version has changed from unknown to 18.16.0
    2023-05-13 17:47:44.123  - info: host.buanet-iobroker4 added notifications configuration of host
    2023-05-13 17:47:44.258  - info: host.buanet-iobroker4 3 instances found
    2023-05-13 17:47:44.270  - info: host.buanet-iobroker4 starting 3 instances
    2023-05-13 17:47:44.296  - info: host.buanet-iobroker4 instance system.adapter.admin.0 started with pid 1828
    2023-05-13 17:47:44.522  - info: host.buanet-iobroker4 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-05-13 17:47:45.624  - info: admin.0 (1828) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
    2023-05-13 17:47:45.641  - info: admin.0 (1828) requesting all states
    2023-05-13 17:47:45.641  - info: admin.0 (1828) requesting all objects
    2023-05-13 17:47:45.792  - info: admin.0 (1828) received all objects
    2023-05-13 17:47:45.918  - info: admin.0 (1828) http server listening on port 8081
    2023-05-13 17:47:45.919  - info: admin.0 (1828) Use link "http://localhost:8081" to configure.
    2023-05-13 17:47:45.922  - info: admin.0 (1828) socket.io server listening on port 8081
    2023-05-13 17:47:48.281  - info: host.buanet-iobroker4 instance system.adapter.discovery.0 started with pid 1856
    2023-05-13 17:47:48.835  - info: discovery.0 (1856) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
    2023-05-13 17:47:52.281  - info: host.buanet-iobroker4 instance system.adapter.backitup.0 started with pid 1871
    2023-05-13 17:47:52.895  - info: backitup.0 (1871) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-05-13 17:47:52.996  - info: backitup.0 (1871) [iobroker] backup will be activated at 02:40 every 1 day(s)
    		     v.2023-04-16
    Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
    Kernel: 		4.4.180+
    Installation: 		Docker
    Timezone: 		Etc/UTC
    User-ID: 		0
    X-Server: 		false
    Pending OS-Updates: 	0
    Pending iob updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v18.16.0
    			/usr/bin/npm 		9.5.1
    			/usr/bin/npx 		9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.9G        1.3G        285M        1.1G        2.3G        917M
    Swap:           4.4G        184M        4.2G
    Total:          8.3G        1.5G        4.5G
    Active iob-Instances: 	4
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		143
    States: 		104
    Size of iob-Database:
    228K	/opt/iobroker/iobroker-data/states.jsonl
    Habe extra Firefox runtergeladen, funktioniert aber leider auch nicht :(
    Keba P30, 50kWp SMA, 15kWh Victron MP2, Daikin LLWP, Docker@SynologyDS923+
    • F ferrog
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : v8.0.1
      Release:	11
      Codename:	bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CEST +0200
      Etc/UTC
      root
      /root
      root
      X-Server: 	false
      Desktop:
      Terminal:
      *** MEMORY ***
               3890 M total memory
               1304 M used memory
                902 M active memory
                246 M free memory
                 11 M buffer memory
               2327 M swap cache
               4383 M total swap
                181 M used swap
               4202 M free swap
      *** FILESYSTEM ***
      /var:
      33M	/var/
      30M	/var/lib
      18M	/var/lib/apt
      13M	/var/lib/dpkg
      /usr/bin/npm 		9.5.1
      /usr/bin/npx 		9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.3.5
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	143
      States: 	104
      Pending Updates: 0
      		     v.2023-04-16
      Kernel: 		4.4.180+
      Timezone: 		Etc/UTC
      User-ID: 		0
      X-Server: 		false
      			/usr/bin/npm 		9.5.1
      			/usr/bin/npx 		9.5.1
      MEMORY:
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		143
      States: 		104
      GlasfaserG Offline
      GlasfaserG Offline
      @ferrog sagte in Docker Installation lädt admin Adapter nicht:
      ... auch ein Loop mit dem ioBroker Zeichen !?
      Hast du eine Host oder Bridge Netzwerk !
      • F Offline
        ferrog
        Ja, auch in loop.
        Ich habe noch den alten "raspi" iobroker im Netz, aber nicht aktiv host bzw. slave konfiguriert. Sind die sich dann auch ohne Konfiguration im Wege?
        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
        • F ferrog
          Ja, auch in loop.
          @ferrog
          tcp6       0      0 :::8081
          Da läuft der Admin wohl nur auf ipv6.
          Edith: Vergiss es, ist bei mir auch so.
          • F ferrog
            Ja, auch in loop.
            GlasfaserG Offline
            GlasfaserG Offline
            Nein .. passt so .
            Was ist mit :
            @glasfaser sagte in Docker Installation lädt admin Adapter nicht:
            Bitte immer alle Fragen beantworten !
            Wenn Bridge ... dann versuche zum Test Host .
            • F ferrog
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : v8.0.1
              Release:	11
              Codename:	bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 4
              CEST +0200
              Etc/UTC
              root
              /root
              root
              X-Server: 	false
              Desktop:
              Terminal:
              *** MEMORY ***
                       3890 M total memory
                       1304 M used memory
                        902 M active memory
                        246 M free memory
                         11 M buffer memory
                       2327 M swap cache
                       4383 M total swap
                        181 M used swap
                       4202 M free swap
              *** FILESYSTEM ***
              /var:
              33M	/var/
              30M	/var/lib
              18M	/var/lib/apt
              13M	/var/lib/dpkg
              /usr/bin/npm 		9.5.1
              /usr/bin/npx 		9.5.1
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.3.5
              Adapter State
              + instance is alive
              Objects and States
              Objects: 	143
              States: 	104
              Pending Updates: 0
              		     v.2023-04-16
              Kernel: 		4.4.180+
              Timezone: 		Etc/UTC
              User-ID: 		0
              X-Server: 		false
              			/usr/bin/npm 		9.5.1
              			/usr/bin/npx 		9.5.1
              MEMORY:
              			admin 			6.3.5
              Objects type: jsonl
              States  type: jsonl
              Objects: 		143
              States: 		104
              GlasfaserG Offline
              GlasfaserG Offline
              Sehe gerade ...
              Also Bridge
              • F Offline
                ferrog
                Ah, gemeint war docker. Ja das war Bridge, habe gerade auch Host versucht, leider genau so. Liegt das vielleicht an der Bereitstellung des Ports durch DSM „Webstation“?
                Oder kann der Port 8081 auch einfach gemappt werden? (Habe leider noch nicht zum Laufen bekommen…)
                • F ferrog
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Welcher Port hat er denn ,
                  dann würdest du aber nicht ioBroker mit 8081 erreichen !
                  Der Loop ist ein anderer ( Fehler ) . kann Ihn aber nicht erkennen .
                  Zeige mal die Ausgabe von
                  iob logs --watch
                  wenn du im Loop bist
                  • F Offline
                    ferrog
                    Logs —watch von latest-v8:
                    2023-05-13 18:49:56.226  - info: host.buanet-iobroker3 iobroker.js-controller version 4.0.24 js-controller starting
                    2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 hostname: buanet-iobroker3, node: v18.16.0
                    2023-05-13 18:49:56.229  - info: host.buanet-iobroker3 ip addresses: 192.168.178.3 fd9b:f2b9:802:4f06:9209:d0ff:fe32:33f3 2003:cd:f47:c000:9209:d0ff:fe32:33f3 fe80::9209:d0ff:fe32:33f3 172.17.0.1 fe80::42:caff:fe53:7492 fe80::5ca4:c5ff:fec1:c9b fe80::6054:cbff:fe48:42d2 fe80::8c55:c1ff:fee3:f31b fe80::f4c1:fbff:fe20:3a8f fe80::c866:afff:fe37:903a
                    2023-05-13 18:49:56.474  - info: host.buanet-iobroker3 connected to Objects and States
                    2023-05-13 18:49:56.481  - info: host.buanet-iobroker3 Node.js version has changed from unknown to 18.16.0
                    2023-05-13 18:49:56.501  - info: host.buanet-iobroker3 added notifications configuration of host
                    2023-05-13 18:49:56.658  - info: host.buanet-iobroker3 3 instances found
                    2023-05-13 18:49:56.661  - info: host.buanet-iobroker3 starting 3 instances
                    2023-05-13 18:49:56.680  - info: host.buanet-iobroker3 instance system.adapter.admin.0 started with pid 1761
                    2023-05-13 18:49:57.314  - info: host.buanet-iobroker3 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                    2023-05-13 18:49:58.050  - info: admin.0 (1761) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.16.0, js-controller: 4.0.24
                    2023-05-13 18:49:58.067  - info: admin.0 (1761) requesting all states
                    2023-05-13 18:49:58.068  - info: admin.0 (1761) requesting all objects
                    2023-05-13 18:49:58.127  - info: admin.0 (1761) received all objects
                    2023-05-13 18:49:58.151  - info: admin.0 (1761) Request actual repository...
                    2023-05-13 18:49:58.160  - info: host.buanet-iobroker3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2023-05-13 18:49:58.300  - warn: admin.0 (1761) Repository cannot be read: Active repo - stable
                    2023-05-13 18:49:58.301  - warn: admin.0 (1761) Active repository "stable" cannot be read
                    2023-05-13 18:49:58.763  - error: admin.0 (1761) port 8081 already in use
                    2023-05-13 18:49:58.764  - info: admin.0 (1761) Terminated (ADAPTER_REQUESTED_TERMINATION): port 8081 already in use
                    2023-05-13 18:49:59.277  - info: admin.0 (1761) terminating http server on port 8081
                    2023-05-13 18:49:59.289  - error: host.buanet-iobroker3 instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                    2023-05-13 18:49:59.290  - info: host.buanet-iobroker3 Do not restart adapter system.adapter.admin.0 because desired by instance
                    2023-05-13 18:50:00.676  - info: host.buanet-iobroker3 instance system.adapter.discovery.0 started with pid 1785
                    2023-05-13 18:50:01.342  - info: discovery.0 (1785) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.16.0, js-controller: 4.0.24
                    2023-05-13 18:50:04.690  - info: host.buanet-iobroker3 instance system.adapter.backitup.0 started with pid 1804
                    2023-05-13 18:50:05.314  - info: backitup.0 (1804) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
                    2023-05-13 18:50:05.446  - info: backitup.0 (1804) [iobroker] backup will be activated at 02:40 every 1 day(s)
                    • F ferrog
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Logs
                      Bitte aktuell zeigen !!
                      • F Offline
                        ferrog
                        Ahh, sorry falsche Datei, ist korrigiert. Da gibts auch errors…
                        • F ferrog
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Da läuft was doppelt , deshalb startet jetzt in diesem Log der ioBroker nicht
                          • GlasfaserG Glasfaser
                            iob logs --watch
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @ferrog
                            Kann du nicht meine Fragen beantworten !?
                              @ferrog
                              @ferrog
                              bitte lesen und befolgen!
                              • F Offline
                                ferrog
                                Ich habe das nicht als Frage verstanden.
                                Natürlich reicht die Webstation den Port 8081 an den Docker Container weiter.
                                • F ferrog
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Lösche alle diese Einträge !
                                  Hier wird nur der Port vorgegeben :
                                  siehe Beispiel Containereinstellung
                                  und das ausschalten / haken bei dir raus
                                  • F Offline
                                    ferrog
                                    WOW, vielen Dank! Daran hats gelegen.
                                    Und großen Respekt an die Schnelligkeit eurer Unterstützung!
                                    Zum Hintergrund: Belegt Webstation dann in dem Container den besagten Port?
                                    • F ferrog
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      ... aber mühselig erfragt ;)
                                      Jipp , deshalb meine Frage :
                                      @ferrog
                                      • F ferrog
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Dann setze den Thread auf [gelöst]
